commit 39f1f78d53b9bcbca91967380c5f0f2305a5c55f upstream.
too many places open-code it
commit 6436a123a147db51a0b06024a8350f4c230e73ff upstream.
Return a negative error value like the rest of the entries in this function.
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
[PM: tweaked subject line]
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit d0709f1e66e8066c4ac6a54620ec116aa41937c0 upstream.
If a request_key() call to allocate and fill out a key attempts to insert the
key structure into a revoked keyring, the key will leak, using memory and part
of the user's key quota until the system reboots. This is from a failure of
construct_alloc_key() to decrement the key's reference count after the attempt
to insert into the requested keyring is rejected.
key_put() needs to be called in the link_prealloc_failed callpath to ensure
the unused key is released.
Signed-off-by: David Jeffery <djeffery@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit b138004ea0382bdc6d02599c39392651b4f63889 upstream.
The /sys/fs/selinux/policy file is not valid on big endian systems like
ppc64 or s390. Let's see why:
static int hashtab_cnt(void *key, void *data, void *ptr)
int *cnt = ptr;
*cnt = *cnt + 1;
return 0;
static int range_write(struct policydb *p, void *fp)
size_t nel;
/* count the number of entries in the hashtab */
nel = 0;
rc = hashtab_map(p->range_tr, hashtab_cnt, &nel);
if (rc)
return rc;
buf[0] = cpu_to_le32(nel);
rc = put_entry(buf, sizeof(u32), 1, fp);
So size_t is 64 bits. But then we pass a pointer to it as we do to
hashtab_cnt. hashtab_cnt thinks it is a 32 bit int and only deals with
the first 4 bytes. On x86_64 which is little endian, those first 4
bytes and the least significant, so this works out fine. On ppc64/s390
those first 4 bytes of memory are the high order bits. So at the end of
the call to hashtab_map nel has a HUGE number. But the least
significant 32 bits are all 0's.
We then pass that 64 bit number to cpu_to_le32() which happily truncates
it to a 32 bit number and does endian swapping. But the low 32 bits are
all 0's. So no matter how many entries are in the hashtab, big endian
systems always say there are 0 entries because I screwed up the
counting.
The fix is easy. Use a 32 bit int, as the hashtab_cnt expects, for nel.
Signed-off-by: Eric Paris <eparis@redhat.com>
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
Acked-by: Miklos Szeredi <mszeredi@suse.cz>
commit a3a8784454692dd72e5d5d34dcdab17b4420e74c upstream.
When a key is being garbage collected, it's key->user would get put before
the ->destroy() callback is called, where the key is removed from it's
respective tracking structures.
This leaves a key hanging in a semi-invalid state which leaves a window open
for a different task to try an access key->user. An example is
find_keyring_by_name() which would dereference key->user for a key that is
in the process of being garbage collected (where key->user was freed but
->destroy() wasn't called yet - so it's still present in the linked list).
This would cause either a panic, or corrupt memory.
Fixes CVE-2014-9529.
commit b26bdde5bb27f3f900e25a95e33a0c476c8c2c48 upstream.
When loading encrypted-keys module, if the last check of
aes_get_sizes() in init_encrypted() fails, the driver just returns an
error without unregistering its key type. This results in the stale
entry in the list. In addition to memory leaks, this leads to a kernel
crash when registering a new key type later.
This patch fixes the problem by swapping the calls of aes_get_sizes()
and register_key_type(), and releasing resources properly at the error
paths.
Bugzilla: https://bugzilla.opensuse.org/show_bug.cgi?id=908163
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 923190d32de4428afbea5e5773be86bea60a9925 upstream.
sb_finish_set_opts() can race with inode_free_security()
when initializing inode security structures for inodes
created prior to initial policy load or by the filesystem
during ->mount(). This appears to have always been
a possible race, but commit 3dc91d4 ("SELinux: Fix possible
NULL pointer dereference in selinux_inode_permission()")
made it more evident by immediately reusing the unioned
list/rcu element of the inode security structure for call_rcu()
upon an inode_free_security(). But the underlying issue
was already present before that commit as a possible use-after-free
of isec.
Shivnandan Kumar reported the list corruption and proposed
a patch to split the list and rcu elements out of the union
as separate fields of the inode_security_struct so that setting
the rcu element would not affect the list element. However,
this would merely hide the issue and not truly fix the code.
This patch instead moves up the deletion of the list entry
prior to dropping the sbsec->isec_lock initially. Then,
if the inode is dropped subsequently, there will be no further
references to the isec.
Reported-by: Shivnandan Kumar <shivnandan.k@samsung.com>
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
commit 3b1deef6b1289a99505858a3b212c5b50adf0c2f upstream.
evm_inode_setxattr() can be called with no value. The function does not
check the length so that following command can be used to produce the
kernel oops: setfattr -n security.evm FOO. This patch fixes it.
Changes in v3:
* there is no reason to return different error codes for EVM_XATTR_HMAC
and non EVM_XATTR_HMAC. Remove unnecessary test then.
Changes in v2:
* testing for validity of xattr type
[ 1106.396921] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1106.398192] IP: [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.399244] PGD 29048067 PUD 290d7067 PMD 0
[ 1106.399953] Oops: 0000 [#1] SMP
[ 1106.400020] Modules linked in: bridge stp llc evdev serio_raw i2c_piix4 button fuse
[ 1106.400020] CPU: 0 PID: 3635 Comm: setxattr Not tainted 3.16.0-kds+ #2936
[ 1106.400020] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 1106.400020] task: ffff8800291a0000 ti: ffff88002917c000 task.ti: ffff88002917c000
[ 1106.400020] RIP: 0010:[<ffffffff812af7b8>] [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.400020] RSP: 0018:ffff88002917fd50 EFLAGS: 00010246
[ 1106.400020] RAX: 0000000000000000 RBX: ffff88002917fdf8 RCX: 0000000000000000
[ 1106.400020] RDX: 0000000000000000 RSI: ffffffff818136d3 RDI: ffff88002917fdf8
[ 1106.400020] RBP: ffff88002917fd68 R08: 0000000000000000 R09: 00000000003ec1df
[ 1106.400020] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8800438a0a00
[ 1106.400020] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 1106.400020] FS: 00007f7dfa7d7740(0000) GS:ffff88005da00000(0000) knlGS:0000000000000000
[ 1106.400020] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1106.400020] CR2: 0000000000000000 CR3: 000000003763e000 CR4: 00000000000006f0
[ 1106.400020] Stack:
[ 1106.400020] ffff8800438a0a00 ffff88002917fdf8 0000000000000000 ffff88002917fd98
[ 1106.400020] ffffffff812a1030 ffff8800438a0a00 ffff88002917fdf8 0000000000000000
[ 1106.400020] 0000000000000000 ffff88002917fde0 ffffffff8116d08a ffff88002917fdc8
[ 1106.400020] Call Trace:
[ 1106.400020] [<ffffffff812a1030>] security_inode_setxattr+0x5d/0x6a
[ 1106.400020] [<ffffffff8116d08a>] vfs_setxattr+0x6b/0x9f
[ 1106.400020] [<ffffffff8116d1e0>] setxattr+0x122/0x16c
[ 1106.400020] [<ffffffff811687e8>] ? mnt_want_write+0x21/0x45
[ 1106.400020] [<ffffffff8114d011>] ? __sb_start_write+0x10f/0x143
[ 1106.400020] [<ffffffff811687c0>] ? __mnt_want_write+0x48/0x4f
[ 1106.400020] [<ffffffff8116d3e6>] SyS_setxattr+0x6e/0xb0
[ 1106.400020] [<ffffffff81529da9>] system_call_fastpath+0x16/0x1b
[ 1106.400020] Code: c3 0f 1f 44 00 00 55 48 89 e5 41 55 49 89 d5 41 54 49 89 fc 53 48 89 f3 48 c7 c6 d3 36 81 81 48 89 df e8 18 22 04 00 85 c0 75 07 <41> 80 7d 00 02 74 0d 48 89 de 4c 89 e7 e8 5a fe ff ff eb 03 83
[ 1106.400020] RIP [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.400020] RSP <ffff88002917fd50>
[ 1106.428061] ---[ end trace ae08331628ba3050 ]---
Reported-by: Jan Kara <jack@suse.cz>
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream.
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
commit 2fb1c9a4f2dbc2f0bd2431c7fa64d0b5483864e4 upstream.
Calculating the 'security.evm' HMAC value requires access to the
EVM encrypted key. Only the kernel should have access to it. This
patch prevents userspace tools(eg. setfattr, cp --preserve=xattr)
from setting/modifying the 'security.evm' HMAC value directly.
commit 0430e49b6e7c6b5e076be8fefdee089958c9adad upstream.
Commit 8aac62706 "move exit_task_namespaces() outside of exit_notify"
introduced the kernel opps since the kernel v3.10, which happens when
Apparmor and IMA-appraisal are enabled at the same time.
[ 106.750167] BUG: unable to handle kernel NULL pointer dereference at
0000000000000018
[ 106.750221] IP: [<ffffffff811ec7da>] our_mnt+0x1a/0x30
[ 106.750241] PGD 0
[ 106.750254] Oops: 0000 [#1] SMP
[ 106.750272] Modules linked in: cuse parport_pc ppdev bnep rfcomm
bluetooth rpcsec_gss_krb5 nfsd auth_rpcgss nfs_acl nfs lockd sunrpc
fscache dm_crypt intel_rapl x86_pkg_temp_thermal intel_powerclamp
kvm_intel snd_hda_codec_hdmi kvm crct10dif_pclmul crc32_pclmul
ghash_clmulni_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul
ablk_helper cryptd snd_hda_codec_realtek dcdbas snd_hda_intel
snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_seq_midi
snd_seq_midi_event snd_rawmidi psmouse snd_seq microcode serio_raw
snd_timer snd_seq_device snd soundcore video lpc_ich coretemp mac_hid lp
parport mei_me mei nbd hid_generic e1000e usbhid ahci ptp hid libahci
pps_core
[ 106.750658] CPU: 6 PID: 1394 Comm: mysqld Not tainted 3.13.0-rc7-kds+ #15
[ 106.750673] Hardware name: Dell Inc. OptiPlex 9010/0M9KCM, BIOS A08
09/19/2012
[ 106.750689] task: ffff8800de804920 ti: ffff880400fca000 task.ti:
ffff880400fca000
[ 106.750704] RIP: 0010:[<ffffffff811ec7da>] [<ffffffff811ec7da>]
our_mnt+0x1a/0x30
[ 106.750725] RSP: 0018:ffff880400fcba60 EFLAGS: 00010286
[ 106.750738] RAX: 0000000000000000 RBX: 0000000000000100 RCX:
ffff8800d51523e7
[ 106.750764] RDX: ffffffffffffffea RSI: ffff880400fcba34 RDI:
ffff880402d20020
[ 106.750791] RBP: ffff880400fcbae0 R08: 0000000000000000 R09:
0000000000000001
[ 106.750817] R10: 0000000000000000 R11: 0000000000000001 R12:
ffff8800d5152300
[ 106.750844] R13: ffff8803eb8df510 R14: ffff880400fcbb28 R15:
ffff8800d51523e7
[ 106.750871] FS: 0000000000000000(0000) GS:ffff88040d200000(0000)
[ 106.750910] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 106.750935] CR2: 0000000000000018 CR3: 0000000001c0e000 CR4:
00000000001407e0
[ 106.750962] Stack:
[ 106.750981] ffffffff813434eb ffff880400fcbb20 ffff880400fcbb18
0000000000000000
[ 106.751037] ffff8800de804920 ffffffff8101b9b9 0001800000000000
0000000000000100
[ 106.751093] 0000010000000000 0000000000000002 000000000000000e
ffff8803eb8df500
[ 106.751149] Call Trace:
[ 106.751172] [<ffffffff813434eb>] ? aa_path_name+0x2ab/0x430
[ 106.751199] [<ffffffff8101b9b9>] ? sched_clock+0x9/0x10
[ 106.751225] [<ffffffff8134a68d>] aa_path_perm+0x7d/0x170
[ 106.751250] [<ffffffff8101b945>] ? native_sched_clock+0x15/0x80
[ 106.751276] [<ffffffff8134aa73>] aa_file_perm+0x33/0x40
[ 106.751301] [<ffffffff81348c5e>] common_file_perm+0x8e/0xb0
[ 106.751327] [<ffffffff81348d78>] apparmor_file_permission+0x18/0x20
[ 106.751355] [<ffffffff8130c853>] security_file_permission+0x23/0xa0
[ 106.751382] [<ffffffff811c77a2>] rw_verify_area+0x52/0xe0
[ 106.751407] [<ffffffff811c789d>] vfs_read+0x6d/0x170
[ 106.751432] [<ffffffff811cda31>] kernel_read+0x41/0x60
[ 106.751457] [<ffffffff8134fd45>] ima_calc_file_hash+0x225/0x280
[ 106.751483] [<ffffffff8134fb52>] ? ima_calc_file_hash+0x32/0x280
[ 106.751509] [<ffffffff8135022d>] ima_collect_measurement+0x9d/0x160
[ 106.751536] [<ffffffff810b552d>] ? trace_hardirqs_on+0xd/0x10
[ 106.751562] [<ffffffff8134f07c>] ? ima_file_free+0x6c/0xd0
[ 106.751587] [<ffffffff81352824>] ima_update_xattr+0x34/0x60
[ 106.751612] [<ffffffff8134f0d0>] ima_file_free+0xc0/0xd0
[ 106.751637] [<ffffffff811c9635>] __fput+0xd5/0x300
[ 106.751662] [<ffffffff811c98ae>] ____fput+0xe/0x10
[ 106.751687] [<ffffffff81086774>] task_work_run+0xc4/0xe0
[ 106.751712] [<ffffffff81066fad>] do_exit+0x2bd/0xa90
[ 106.751738] [<ffffffff8173c958>] ? retint_swapgs+0x13/0x1b
[ 106.751763] [<ffffffff8106780c>] do_group_exit+0x4c/0xc0
[ 106.751788] [<ffffffff81067894>] SyS_exit_group+0x14/0x20
[ 106.751814] [<ffffffff8174522d>] system_call_fastpath+0x1a/0x1f
[ 106.751839] Code: c3 0f 1f 44 00 00 55 48 89 e5 e8 22 fe ff ff 5d c3
0f 1f 44 00 00 55 65 48 8b 04 25 c0 c9 00 00 48 8b 80 28 06 00 00 48 89
e5 5d <48> 8b 40 18 48 39 87 c0 00 00 00 0f 94 c0 c3 0f 1f 80 00 00 00
[ 106.752185] RIP [<ffffffff811ec7da>] our_mnt+0x1a/0x30
[ 106.752214] RSP <ffff880400fcba60>
[ 106.752236] CR2: 0000000000000018
[ 106.752258] ---[ end trace 3c520748b4732721 ]---
The reason for the oops is that IMA-appraisal uses "kernel_read()" when
file is closed. kernel_read() honors LSM security hook which calls
Apparmor handler, which uses current->nsproxy->mnt_ns. The 'guilty'
commit changed the order of cleanup code so that nsproxy->mnt_ns was
not already available for Apparmor.
Discussion about the issue with Al Viro and Eric W. Biederman suggested
that kernel_read() is too high-level for IMA. Another issue, except
security checking, that was identified is mandatory locking. kernel_read
honors it as well and it might prevent IMA from calculating necessary hash.
It was suggested to use simplified version of the function without security
and locking checks.
This patch introduces special version ima_kernel_read(), which skips security
and mandatory locking checking. It prevents the kernel oops to happen.
Suggested-by: Eric W. Biederman <ebiederm@xmission.com>
commit f9b2a735bdddf836214b5dca74f6ca7712e5a08c upstream.
Files are measured or appraised based on the IMA policy. When a
file, in policy, is opened with the O_DIRECT flag, a deadlock
occurs.
The first attempt at resolving this lockdep temporarily removed the
O_DIRECT flag and restored it, after calculating the hash. The
second attempt introduced the O_DIRECT_HAVELOCK flag. Based on this
flag, do_blockdev_direct_IO() would skip taking the i_mutex a second
time. The third attempt, by Dmitry Kasatkin, resolves the i_mutex
locking issue, by re-introducing the IMA mutex, but uncovered
another problem. Reading a file with O_DIRECT flag set, writes
directly to userspace pages. A second patch allocates a user-space
like memory. This works for all IMA hooks, except ima_file_free(),
which is called on __fput() to recalculate the file hash.
Until this last issue is addressed, do not 'collect' the
measurement for measuring, appraising, or auditing files opened
with the O_DIRECT flag set. Based on policy, permit or deny file
access. This patch defines a new IMA policy rule option named
'permit_directio'. Policy rules could be defined, based on LSM
or other criteria, to permit specific applications to open files
Changelog v1:
- permit or deny file access based IMA policy rules
Acked-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
commit d2c2b11cfa134f4fbdcc34088824da26a084d8de upstream.
[PATCH v3 1/2] device_cgroup: check if exception removal is allowed
When the device cgroup hierarchy was introduced in
bd2953ebbb53 - devcg: propagate local changes down the hierarchy
a specific case was overlooked. Consider the hierarchy bellow:
A default policy: ALLOW, exceptions will deny access
B default policy: ALLOW, exceptions will deny access
There's no need to verify when an new exception is added to B because
in this case exceptions will deny access to further devices, which is
always fine. Hierarchy in device cgroup only makes sure B won't have
more access than A.
But when an exception is removed (by writing devices.allow), it isn't
checked if the user is in fact removing an inherited exception from A,
thus giving more access to B.
Example:
# echo 'a' >A/devices.allow
# echo 'c 1:3 rw' >A/devices.deny
# echo $$ >A/B/tasks
# echo >/dev/null
-bash: /dev/null: Operation not permitted
# echo 'c 1:3 w' >A/B/devices.allow
# echo >/dev/null
This shouldn't be allowed and this patch fixes it by making sure to never allow
exceptions in this case to be removed if the exception is partially or fully
present on the parent.
v3: missing '*' in function description
v2: improved log message and formatting fixes
Cc: cgroups@vger.kernel.org
Cc: Li Zefan <lizefan@huawei.com>
Signed-off-by: Aristeu Rozanski <arozansk@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
commit 79d719749d23234e9b725098aa49133f3ef7299d upstream.
Whenever a device file is opened and checked against current device
cgroup rules, it uses the same function (may_access()) as when a new
exception rule is added by writing devices.{allow,deny}. And in both
cases, the algorithm is the same, doesn't matter the behavior.
First problem is having device access to be considered the same as rule
checking. Consider the following structure:
A (default behavior: allow, exceptions disallow access)
B (default behavior: allow, exceptions disallow access)
A new exception is added to B by writing devices.deny:
c 12:34 rw
When checking if that exception is allowed in may_access():
if (dev_cgroup->behavior == DEVCG_DEFAULT_ALLOW) {
if (behavior == DEVCG_DEFAULT_ALLOW) {
/* the exception will deny access to certain devices */
return true;
Which is ok, since B is not getting more privileges than A, it doesn't
matter and the rule is accepted
Now, consider it's a device file open check and the process belongs to
cgroup B. The access will be generated as:
behavior: allow
exception: c 12:34 rw
The very same chunk of code will allow it, even if there's an explicit
exception telling to do otherwise.
A simple test case:
# mkdir new_group
# cd new_group
# echo $$ >tasks
# echo "c 1:3 w" >devices.deny
# echo >/dev/null
# echo $?
0
This is a serious bug and was introduced on
c39a2a3018f8 devcg: prepare may_access() for hierarchy support
To solve this problem, the device file open function was split from the
new exception check.
Second problem is how exceptions are processed by may_access(). The
first part of the said function tries to match fully with an existing
exception:
list_for_each_entry_rcu(ex, &dev_cgroup->exceptions, list) {
if ((refex->type & DEV_BLOCK) && !(ex->type & DEV_BLOCK))
continue;
if ((refex->type & DEV_CHAR) && !(ex->type & DEV_CHAR))
continue;
if (ex->major != ~0 && ex->major != refex->major)
continue;
if (ex->minor != ~0 && ex->minor != refex->minor)
continue;
if (refex->access & (~ex->access))
continue;
match = true;
break;
That means the new exception should be contained into an existing one to
be considered a match:
New exception Existing match? notes
b 12:34 rwm b 12:34 rwm yes
b 12:34 r b *:34 rw yes
b 12:34 rw b 12:34 w no extra "r"
b *:34 rw b 12:34 rw no too broad "*"
b *:34 rw b *:34 rwm yes
Which is fine in some cases. Consider:
A (default behavior: deny, exceptions allow access)
B (default behavior: deny, exceptions allow access)
In this case the full match makes sense, the new exception cannot add
more access than the parent allows
But this doesn't always work, consider:
In this case, a new exception in B shouldn't match any of the exceptions
in A, after all you can't allow something that was forbidden by A. But
consider this scenario:
New exception Existing in A match? outcome
b 12:34 rw b 12:34 r no exception is accepted
Because the new exception has "w" as extra, it doesn't match, so it'll
be added to B's exception list.
The same problem can happen during a file access check. Consider a
cgroup with allow as default behavior:
Access Exception match?
In this case, the access didn't match any of the exceptions in the
cgroup, which is required since exceptions will disallow access.
To solve this problem, two new functions were created to match an
exception either fully or partially. In the example above, a partial
check will be performed and it'll produce a match since at least
"b 12:34 r" from "b 12:34 rw" access matches.
Cc: Tejun Heo <tj@kernel.org>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
commit f64410ec665479d7b4b77b7519e814253ed0f686 upstream.
This patch is based on an earlier patch by Eric Paris, he describes
the problem below:
"If an inode is accessed before policy load it will get placed on a
list of inodes to be initialized after policy load. After policy
load we call inode_doinit() which calls inode_doinit_with_dentry()
on all inodes accessed before policy load. In the case of inodes
in procfs that means we'll end up at the bottom where it does:
/* Default to the fs superblock SID. */
isec->sid = sbsec->sid;
if ((sbsec->flags & SE_SBPROC) && !S_ISLNK(inode->i_mode)) {
if (opt_dentry) {
isec->sclass = inode_mode_to_security_class(...)
rc = selinux_proc_get_sid(opt_dentry,
isec->sclass,
&sid);
if (rc)
goto out_unlock;
isec->sid = sid;
Since opt_dentry is null, we'll never call selinux_proc_get_sid()
and will leave the inode labeled with the label on the superblock.
I believe a fix would be to mimic the behavior of xattrs. Look
for an alias of the inode. If it can't be found, just leave the
inode uninitialized (and pick it up later) if it can be found, we
should be able to call selinux_proc_get_sid() ..."
On a system exhibiting this problem, you will notice a lot of files in
/proc with the generic "proc_t" type (at least the ones that were
accessed early in the boot), for example:
# ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }'
system_u:object_r:proc_t:s0 /proc/sys/kernel/shmmax
However, with this patch in place we see the expected result:
system_u:object_r:sysctl_kernel_t:s0 /proc/sys/kernel/shmmax
Cc: Eric Paris <eparis@redhat.com>
Acked-by: Eric Paris <eparis@redhat.com>
commit a767f680e34bf14a36fefbbb6d85783eef99fd57 upstream.
Currently, the ebitmap_node structure has a fixed size of 32 bytes. On
a 32-bit system, the overhead is 8 bytes, leaving 24 bytes for being
used as bitmaps. The overhead ratio is 1/4.
On a 64-bit system, the overhead is 16 bytes. Therefore, only 16 bytes
are left for bitmap purpose and the overhead ratio is 1/2. With a
3.8.2 kernel, a boot-up operation will cause the ebitmap_get_bit()
function to be called about 9 million times. The average number of
ebitmap_node traversal is about 3.7.
This patch increases the size of the ebitmap_node structure to 64
bytes for 64-bit system to keep the overhead ratio at 1/4. This may
also improve performance a little bit by making node to node traversal
less frequent (< 2) as more bits are available in each node.
Signed-off-by: Waiman Long <Waiman.Long@hp.com>
commit fee7114298cf54bbd221cdb2ab49738be8b94f4c upstream.
While running the high_systime workload of the AIM7 benchmark on
a 2-socket 12-core Westmere x86-64 machine running 3.10-rc4 kernel
(with HT on), it was found that a pretty sizable amount of time was
spent in the SELinux code. Below was the perf trace of the "perf
record -a -s" of a test run at 1500 users:
5.04% ls [kernel.kallsyms] [k] ebitmap_get_bit
1.96% ls [kernel.kallsyms] [k] mls_level_isvalid
1.95% ls [kernel.kallsyms] [k] find_next_bit
The ebitmap_get_bit() was the hottest function in the perf-report
output. Both the ebitmap_get_bit() and find_next_bit() functions
were, in fact, called by mls_level_isvalid(). As a result, the
mls_level_isvalid() call consumed 8.95% of the total CPU time of
all the 24 virtual CPUs which is quite a lot. The majority of the
mls_level_isvalid() function invocations come from the socket creation
system call.
Looking at the mls_level_isvalid() function, it is checking to see
if all the bits set in one of the ebitmap structure are also set in
another one as well as the highest set bit is no bigger than the one
specified by the given policydb data structure. It is doing it in
a bit-by-bit manner. So if the ebitmap structure has many bits set,
the iteration loop will be done many times.
The current code can be rewritten to use a similar algorithm as the
ebitmap_contains() function with an additional check for the
highest set bit. The ebitmap_contains() function was extended to
cover an optional additional check for the highest set bit, and the
mls_level_isvalid() function was modified to call ebitmap_contains().
With that change, the perf trace showed that the used CPU time drop
down to just 0.08% (ebitmap_contains + mls_level_isvalid) of the
total which is about 100X less than before.
0.07% ls [kernel.kallsyms] [k] ebitmap_contains
0.05% ls [kernel.kallsyms] [k] ebitmap_get_bit
0.01% ls [kernel.kallsyms] [k] mls_level_isvalid
0.01% ls [kernel.kallsyms] [k] find_next_bit
The remaining ebitmap_get_bit() and find_next_bit() functions calls
are made by other kernel routines as the new mls_level_isvalid()
function will not call them anymore.
This patch also improves the high_systime AIM7 benchmark result,
though the improvement is not as impressive as is suggested by the
reduction in CPU time spent in the ebitmap functions. The table below
shows the performance change on the 2-socket x86-64 system (with HT
on) mentioned above.
| Workload | mean % change | mean % change | mean % change |
| | 10-100 users | 200-1000 users | 1100-2000 users |
| high_systime | +0.1% | +0.9% | +2.6% |
commit 9085a6422900092886da8c404e1c5340c4ff1cbf upstream.
When writing policy via /sys/fs/selinux/policy I wrote the type and class
of filename trans rules in CPU endian instead of little endian. On
x86_64 this works just fine, but it means that on big endian arch's like
ppc64 and s390 userspace reads the policy and converts it from
le32_to_cpu. So the values are all screwed up. Write the values in le
format like it should have been to start.
commit 2172fa709ab32ca60e86179dc67d0857be8e2c98 upstream.
Setting an empty security context (length=0) on a file will
lead to incorrectly dereferencing the type and other fields
of the security context structure, yielding a kernel BUG.
As a zero-length security context is never valid, just reject
all such security contexts whether coming from userspace
via setxattr or coming from the filesystem upon a getxattr
request by SELinux.
Setting a security context value (empty or otherwise) unknown to
SELinux in the first place is only possible for a root process
(CAP_MAC_ADMIN), and, if running SELinux in enforcing mode, only
if the corresponding SELinux mac_admin permission is also granted
to the domain by policy. In Fedora policies, this is only allowed for
specific domains such as livecd for setting down security contexts
that are not defined in the build host policy.
Reproducer:
su
setenforce 0
touch foo
setfattr -n security.selinux foo
Caveat:
Relabeling or removing foo after doing the above may not be possible
without booting with SELinux disabled. Any subsequent access to foo
after doing the above will also trigger the BUG.
BUG output from Matthew Thode:
[ 473.893141] ------------[ cut here ]------------
[ 473.962110] kernel BUG at security/selinux/ss/services.c:654!
[ 473.995314] invalid opcode: 0000 [#6] SMP
[ 474.027196] Modules linked in:
[ 474.058118] CPU: 0 PID: 8138 Comm: ls Tainted: G D I
3.13.0-grsec #1
[ 474.116637] Hardware name: Supermicro X8ST3/X8ST3, BIOS 2.0
07/29/10
[ 474.149768] task: ffff8805f50cd010 ti: ffff8805f50cd488 task.ti:
ffff8805f50cd488
[ 474.183707] RIP: 0010:[<ffffffff814681c7>] [<ffffffff814681c7>]
context_struct_compute_av+0xce/0x308
[ 474.219954] RSP: 0018:ffff8805c0ac3c38 EFLAGS: 00010246
[ 474.252253] RAX: 0000000000000000 RBX: ffff8805c0ac3d94 RCX:
0000000000000100
[ 474.287018] RDX: ffff8805e8aac000 RSI: 00000000ffffffff RDI:
ffff8805e8aaa000
[ 474.321199] RBP: ffff8805c0ac3cb8 R08: 0000000000000010 R09:
0000000000000006
[ 474.357446] R10: 0000000000000000 R11: ffff8805c567a000 R12:
0000000000000006
[ 474.419191] R13: ffff8805c2b74e88 R14: 00000000000001da R15:
0000000000000000
[ 474.453816] FS: 00007f2e75220800(0000) GS:ffff88061fc00000(0000)
[ 474.489254] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 474.522215] CR2: 00007f2e74716090 CR3: 00000005c085e000 CR4:
00000000000207f0
[ 474.556058] Stack:
[ 474.584325] ffff8805c0ac3c98 ffffffff811b549b ffff8805c0ac3c98
ffff8805f1190a40
[ 474.618913] ffff8805a6202f08 ffff8805c2b74e88 00068800d0464990
ffff8805e8aac860
[ 474.653955] ffff8805c0ac3cb8 000700068113833a ffff880606c75060
ffff8805c0ac3d94
[ 474.690461] Call Trace:
[ 474.723779] [<ffffffff811b549b>] ? lookup_fast+0x1cd/0x22a
[ 474.778049] [<ffffffff81468824>] security_compute_av+0xf4/0x20b
[ 474.811398] [<ffffffff8196f419>] avc_compute_av+0x2a/0x179
[ 474.843813] [<ffffffff8145727b>] avc_has_perm+0x45/0xf4
[ 474.875694] [<ffffffff81457d0e>] inode_has_perm+0x2a/0x31
[ 474.907370] [<ffffffff81457e76>] selinux_inode_getattr+0x3c/0x3e
[ 474.938726] [<ffffffff81455cf6>] security_inode_getattr+0x1b/0x22
[ 474.970036] [<ffffffff811b057d>] vfs_getattr+0x19/0x2d
[ 475.000618] [<ffffffff811b05e5>] vfs_fstatat+0x54/0x91
[ 475.030402] [<ffffffff811b063b>] vfs_lstat+0x19/0x1b
[ 475.061097] [<ffffffff811b077e>] SyS_newlstat+0x15/0x30
[ 475.094595] [<ffffffff8113c5c1>] ? __audit_syscall_entry+0xa1/0xc3
[ 475.148405] [<ffffffff8197791e>] system_call_fastpath+0x16/0x1b
[ 475.179201] Code: 00 48 85 c0 48 89 45 b8 75 02 0f 0b 48 8b 45 a0 48
8b 3d 45 d0 b6 00 8b 40 08 89 c6 ff ce e8 d1 b0 06 00 48 85 c0 49 89 c7
75 02 <0f> 0b 48 8b 45 b8 4c 8b 28 eb 1e 49 8d 7d 08 be 80 01 00 00 e8
[ 475.255884] RIP [<ffffffff814681c7>]
[ 475.296120] RSP <ffff8805c0ac3c38>
[ 475.328734] ---[ end trace f076482e9d754adc ]---
Reported-by: Matthew Thode <mthode@mthode.org>
commit 8ed814602876bec9bad2649ca17f34b499357a1c upstream.
Hello.
I got below leak with linux-3.10.0-54.0.1.el7.x86_64 .
[ 681.903890] kmemleak: 5538 new suspected memory leaks (see /sys/kernel/debug/kmemleak)
Below is a patch, but I don't know whether we need special handing for undoing
ebitmap_set_bit() call.
>>From fe97527a90fe95e2239dfbaa7558f0ed559c0992 Mon Sep 17 00:00:00 2001
From: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Date: Mon, 6 Jan 2014 16:30:21 +0900
Subject: SELinux: Fix memory leak upon loading policy
Commit 2463c26d "SELinux: put name based create rules in a hashtable" did not
check return value from hashtab_insert() in filename_trans_read(). It leaks
memory if hashtab_insert() returns error.
unreferenced object 0xffff88005c9160d0 (size 8):
comm "systemd", pid 1, jiffies 4294688674 (age 235.265s)
hex dump (first 8 bytes):
57 0b 00 00 6b 6b 6b a5 W...kkk.
backtrace:
[<ffffffff816604ae>] kmemleak_alloc+0x4e/0xb0
[<ffffffff811cba5e>] kmem_cache_alloc_trace+0x12e/0x360
[<ffffffff812aec5d>] policydb_read+0xd1d/0xf70
[<ffffffff812b345c>] security_load_policy+0x6c/0x500
[<ffffffff812a623c>] sel_write_load+0xac/0x750
[<ffffffff811eb680>] vfs_write+0xc0/0x1f0
[<ffffffff811ec08c>] SyS_write+0x4c/0xa0
[<ffffffff81690419>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
However, we should not return EEXIST error to the caller, or the systemd will
show below message and the boot sequence freezes.
systemd[1]: Failed to load SELinux policy. Freezing.
commit 3dc91d4338d698ce77832985f9cb183d8eeaf6be upstream.
While running stress tests on adding and deleting ftrace instances I hit
this bug:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: selinux_inode_permission+0x85/0x160
PGD 63681067 PUD 7ddbe067 PMD 0
Oops: 0000 [#1] PREEMPT
CPU: 0 PID: 5634 Comm: ftrace-test-mki Not tainted 3.13.0-rc4-test-00033-gd2a6dde-dirty #20
Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006
task: ffff880078375800 ti: ffff88007ddb0000 task.ti: ffff88007ddb0000
RIP: 0010:[<ffffffff812d8bc5>] [<ffffffff812d8bc5>] selinux_inode_permission+0x85/0x160
RSP: 0018:ffff88007ddb1c48 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000800000 RCX: ffff88006dd43840
RDX: 0000000000000001 RSI: 0000000000000081 RDI: ffff88006ee46000
RBP: ffff88007ddb1c88 R08: 0000000000000000 R09: ffff88007ddb1c54
R10: 6e6576652f6f6f66 R11: 0000000000000003 R12: 0000000000000000
R13: 0000000000000081 R14: ffff88006ee46000 R15: 0000000000000000
FS: 00007f217b5b6700(0000) GS:ffffffff81e21000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033^M
CR2: 0000000000000020 CR3: 000000006a0fe000 CR4: 00000000000007f0
Call Trace:
security_inode_permission+0x1c/0x30
__inode_permission+0x41/0xa0
inode_permission+0x18/0x50
link_path_walk+0x66/0x920
path_openat+0xa6/0x6c0
do_filp_open+0x43/0xa0
do_sys_open+0x146/0x240
SyS_open+0x1e/0x20
Code: 84 a1 00 00 00 81 e3 00 20 00 00 89 d8 83 c8 02 40 f6 c6 04 0f 45 d8 40 f6 c6 08 74 71 80 cf 02 49 8b 46 38 4c 8d 4d cc 45 31 c0 <0f> b7 50 20 8b 70 1c 48 8b 41 70 89 d9 8b 78 04 e8 36 cf ff ff
RIP selinux_inode_permission+0x85/0x160
Investigating, I found that the inode->i_security was NULL, and the
dereference of it caused the oops.
in selinux_inode_permission():
isec = inode->i_security;
rc = avc_has_perm_noaudit(sid, isec->sid, isec->sclass, perms, 0, &avd);
Note, the crash came from stressing the deletion and reading of debugfs
files. I was not able to recreate this via normal files. But I'm not
sure they are safe. It may just be that the race window is much harder
to hit.
What seems to have happened (and what I have traced), is the file is
being opened at the same time the file or directory is being deleted.
As the dentry and inode locks are not held during the path walk, nor is
the inodes ref counts being incremented, there is nothing saving these
structures from being discarded except for an rcu_read_lock().
The rcu_read_lock() protects against freeing of the inode, but it does
not protect freeing of the inode_security_struct. Now if the freeing of
the i_security happens with a call_rcu(), and the i_security field of
the inode is not changed (it gets freed as the inode gets freed) then
there will be no issue here. (Linus Torvalds suggested not setting the
field to NULL such that we do not need to check if it is NULL in the
permission check).
Note, this is a hack, but it fixes the problem at hand. A real fix is
to restructure the destroy_inode() to call all the destructor handlers
from the RCU callback. But that is a major job to do, and requires a
lot of work. For now, we just band-aid this bug with this fix (it
works), and work on a more maintainable solution in the future.
Link: http://lkml.kernel.org/r/20140109101932.0508dec7@gandalf.local.home
Link: http://lkml.kernel.org/r/20140109182756.17abaaa8@gandalf.local.home
selinux_ip_postroute()
commit c0828e50485932b7e019df377a6b0a8d1ebd3080 upstream.
Due to difficulty in arriving at the proper security label for
TCP SYN-ACK packets in selinux_ip_postroute(), we need to check packets
while/before they are undergoing XFRM transforms instead of waiting
until afterwards so that we can determine the correct security label.
Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu>
commit 817eff718dca4e54d5721211ddde0914428fbb7c upstream.
Previously selinux_skb_peerlbl_sid() would only check for labeled
IPsec security labels on inbound packets, this patch enables it to
check both inbound and outbound traffic for labeled IPsec security
labels.
commit c0c1439541f5305b57a83d599af32b74182933fe upstream.
selinux_setprocattr() does ptrace_parent(p) under task_lock(p),
but task_struct->alloc_lock doesn't pin ->parent or ->ptrace,
this looks confusing and triggers the "suspicious RCU usage"
warning because ptrace_parent() does rcu_dereference_check().
And in theory this is wrong, spin_lock()->preempt_disable()
doesn't necessarily imply rcu_read_lock() we need to access
the ->parent.
Reported-by: Evan McNabb <emcnabb@redhat.com>
commit 46d01d63221c3508421dd72ff9c879f61053cffc upstream.
Fix a broken networking check. Return an error if peer recv fails. If
secmark is active and the packet recv succeeds the peer recv error is
ignored.
Signed-off-by: Chad Hanson <chanson@trustedcs.com>
commit 446b802437f285de68ffb8d6fac3c44c3cab5b04 upstream.
In selinux_ip_postroute() we perform access checks based on the
packet's security label. For locally generated traffic we get the
packet's security label from the associated socket; this works in all
cases except for TCP SYN-ACK packets. In the case of SYN-ACK packet's
the correct security label is stored in the connection's request_sock,
not the server's socket. Unfortunately, at the point in time when
selinux_ip_postroute() is called we can't query the request_sock
directly, we need to recreate the label using the same logic that
originally labeled the associated request_sock.
See the inline comments for more explanation.
Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu>
commit 47180068276a04ed31d24fe04c673138208b07a9 upstream.
In selinux_ip_output() we always label packets based on the parent
socket. While this approach works in almost all cases, it doesn't
work in the case of TCP SYN-ACK packets when the correct label is not
the label of the parent socket, but rather the label of the larval
socket represented by the request_sock struct.
Unfortunately, since the request_sock isn't queued on the parent
socket until *after* the SYN-ACK packet is sent, we can't lookup the
request_sock to determine the correct label for the packet; at this
point in time the best we can do is simply pass/NF_ACCEPT the packet.
It must be said that simply passing the packet without any explicit
labeling action, while far from ideal, is not terrible as the SYN-ACK
packet will inherit any IP option based labeling from the initial
connection request so the label *should* be correct and all our
access controls remain in place so we shouldn't have to worry about
information leaks.
commit 42d64e1add3a1ce8a787116036163b8724362145 upstream.
The SELinux/NetLabel glue code has a locking bug that affects systems
with NetLabel enabled, see the kernel error message below. This patch
corrects this problem by converting the bottom half socket lock to a
more conventional, and correct for this call-path, lock_sock() call.
[ INFO: suspicious RCU usage. ]
3.11.0-rc3+ #19 Not tainted
net/ipv4/cipso_ipv4.c:1928 suspicious rcu_dereference_protected() usage!
rcu_scheduler_active = 1, debug_locks = 0
2 locks held by ping/731:
#0: (slock-AF_INET/1){+.-...}, at: [...] selinux_netlbl_socket_connect
#1: (rcu_read_lock){.+.+..}, at: [<...>] netlbl_conn_setattr
stack backtrace:
CPU: 1 PID: 731 Comm: ping Not tainted 3.11.0-rc3+ #19
0000000000000001 ffff88006f659d28 ffffffff81726b6a ffff88003732c500
ffff88006f659d58 ffffffff810e4457 ffff88006b845a00 0000000000000000
000000000000000c ffff880075aa2f50 ffff88006f659d90 ffffffff8169bec7
Call Trace:
[<ffffffff81726b6a>] dump_stack+0x54/0x74
[<ffffffff810e4457>] lockdep_rcu_suspicious+0xe7/0x120
[<ffffffff8169bec7>] cipso_v4_sock_setattr+0x187/0x1a0
[<ffffffff8170f317>] netlbl_conn_setattr+0x187/0x190
[<ffffffff8170f195>] ? netlbl_conn_setattr+0x5/0x190
[<ffffffff8131ac9e>] selinux_netlbl_socket_connect+0xae/0xc0
[<ffffffff81303025>] selinux_socket_connect+0x135/0x170
[<ffffffff8119d127>] ? might_fault+0x57/0xb0
[<ffffffff812fb146>] security_socket_connect+0x16/0x20
[<ffffffff815d3ad3>] SYSC_connect+0x73/0x130
[<ffffffff81739a85>] ? sysret_check+0x22/0x5d
[<ffffffff810e5e2d>] ? trace_hardirqs_on_caller+0xfd/0x1c0
[<ffffffff81373d4e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff815d52be>] SyS_connect+0xe/0x10
[<ffffffff81739a59>] system_call_fastpath+0x16/0x1b
commit 08de59eb144d7c41351a467442f898d720f0f15f upstream.
This reverts commit 4c2c392763a682354fac65b6a569adec4e4b5387.
Everything in the initramfs should be measured and appraised,
but until the initramfs has extended attribute support, at
least measured.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
BugLink: http://bugs.launchpad.net/bugs/1235977
The profile introspection seq file has a locking bug when policy is viewed
from a virtual root (task in a policy namespace), introspection from the
real root is not affected.
The test for root
while (parent) {
is correct for the real root, but incorrect for tasks in a policy namespace.
This allows the task to walk backup the policy tree past its virtual root
causing it to be unlocked before the virtual root should be in the p_stop
fn.
This results in the following lockdep back trace:
[ 78.479744] [ BUG: bad unlock balance detected! ]
[ 78.479792] 3.11.0-11-generic #17 Not tainted
[ 78.479838] -------------------------------------
[ 78.479885] grep/2223 is trying to release lock (&ns->lock) at:
[ 78.479952] [<ffffffff817bf3be>] mutex_unlock+0xe/0x10
[ 78.480002] but there are no more locks to release!
[ 78.480037]
[ 78.480037] other info that might help us debug this:
[ 78.480037] 1 lock held by grep/2223:
[ 78.480037] #0: (&p->lock){+.+.+.}, at: [<ffffffff812111bd>] seq_read+0x3d/0x3d0
[ 78.480037]
[ 78.480037] stack backtrace:
[ 78.480037] CPU: 0 PID: 2223 Comm: grep Not tainted 3.11.0-11-generic #17
[ 78.480037] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 78.480037] ffffffff817bf3be ffff880007763d60 ffffffff817b97ef ffff8800189d2190
[ 78.480037] ffff880007763d88 ffffffff810e1c6e ffff88001f044730 ffff8800189d2190
[ 78.480037] ffffffff817bf3be ffff880007763e00 ffffffff810e5bd6 0000000724fe56b7
[ 78.480037] Call Trace:
[ 78.480037] [<ffffffff817bf3be>] ? mutex_unlock+0xe/0x10
[ 78.480037] [<ffffffff817b97ef>] dump_stack+0x54/0x74
[ 78.480037] [<ffffffff810e1c6e>] print_unlock_imbalance_bug+0xee/0x100
[ 78.480037] [<ffffffff810e5bd6>] lock_release_non_nested+0x226/0x300
[ 78.480037] [<ffffffff817bf2fe>] ? __mutex_unlock_slowpath+0xce/0x180
[ 78.480037] [<ffffffff810e5d5c>] lock_release+0xac/0x310
[ 78.480037] [<ffffffff817bf2b3>] __mutex_unlock_slowpath+0x83/0x180
[ 78.480037] [<ffffffff817bf3be>] mutex_unlock+0xe/0x10
[ 78.480037] [<ffffffff81376c91>] p_stop+0x51/0x90
[ 78.480037] [<ffffffff81211408>] seq_read+0x288/0x3d0
[ 78.480037] [<ffffffff811e9d9e>] vfs_read+0x9e/0x170
[ 78.480037] [<ffffffff811ea8cc>] SyS_read+0x4c/0xa0
[ 78.480037] [<ffffffff817ccc9d>] system_call_fastpath+0x1a/0x1f
Signed-off-by: John Johansen <john.johansen@canonical.com>
BugLink: http://bugs.launchpad.net/bugs/1235523
This fixes the following kmemleak trace:
unreferenced object 0xffff8801e8c35680 (size 32):
comm "apparmor_parser", pid 691, jiffies 4294895667 (age 13230.876s)
hex dump (first 32 bytes):
e0 d3 4e b5 ac 6d f4 ed 3f cb ee 48 1c fd 40 cf ..N..m..?..H..@.
5b cc e9 93 00 00 00 00 00 00 00 00 00 00 00 00 [...............
backtrace:
[<ffffffff817a97ee>] kmemleak_alloc+0x4e/0xb0
[<ffffffff811ca9f3>] __kmalloc+0x103/0x290
[<ffffffff8138acbc>] aa_calc_profile_hash+0x6c/0x150
[<ffffffff8138074d>] aa_unpack+0x39d/0xd50
[<ffffffff8137eced>] aa_replace_profiles+0x3d/0xd80
[<ffffffff81376937>] profile_replace+0x37/0x50
[<ffffffff811e9f2d>] vfs_write+0xbd/0x1e0
[<ffffffff811ea96c>] SyS_write+0x4c/0xa0
[<ffffffff817ccb1d>] system_call_fastpath+0x1a/0x1f
Now avc_audit() has no more users with that parameter. Remove it.
.. so get rid of it. The only indirect users were all the
avc_has_perm() callers which just expanded to have a zero flags
argument.
Every single user passes in '0'. I think we had non-zero users back in
some stone age when selinux_inode_permission() was implemented in terms
of inode_has_perm(), but that complicated case got split up into a
totally separate code-path so that we could optimize the much simpler
special cases.
See commit 2e33405785d3 ("SELinux: delay initialization of audit data in
selinux_inode_permission") for example.
The recent 3.12 pull request for apparmor was missing a couple rcu _protected
access modifiers. Resulting in the follow suspicious RCU usage
[ 29.804534] [ INFO: suspicious RCU usage. ]
[ 29.804539] 3.11.0+ #5 Not tainted
[ 29.804541] -------------------------------
[ 29.804545] security/apparmor/include/policy.h:363 suspicious rcu_dereference_check() usage!
[ 29.804548]
[ 29.804548] other info that might help us debug this:
[ 29.804548]
[ 29.804553]
[ 29.804553] rcu_scheduler_active = 1, debug_locks = 1
[ 29.804558] 2 locks held by apparmor_parser/1268:
[ 29.804560] #0: (sb_writers#9){.+.+.+}, at: [<ffffffff81120a4c>] file_start_write+0x27/0x29
[ 29.804576] #1: (&ns->lock){+.+.+.}, at: [<ffffffff811f5d88>] aa_replace_profiles+0x166/0x57c
[ 29.804589]
[ 29.804589] stack backtrace:
[ 29.804595] CPU: 0 PID: 1268 Comm: apparmor_parser Not tainted 3.11.0+ #5
[ 29.804599] Hardware name: ASUSTeK Computer Inc. UL50VT /UL50VT , BIOS 217 03/01/2010
[ 29.804602] 0000000000000000 ffff8800b95a1d90 ffffffff8144eb9b ffff8800b94db540
[ 29.804611] ffff8800b95a1dc0 ffffffff81087439 ffff880138cc3a18 ffff880138cc3a18
[ 29.804619] ffff8800b9464a90 ffff880138cc3a38 ffff8800b95a1df0 ffffffff811f5084
[ 29.804628] Call Trace:
[ 29.804636] [<ffffffff8144eb9b>] dump_stack+0x4e/0x82
[ 29.804642] [<ffffffff81087439>] lockdep_rcu_suspicious+0xfc/0x105
[ 29.804649] [<ffffffff811f5084>] __aa_update_replacedby+0x53/0x7f
[ 29.804655] [<ffffffff811f5408>] __replace_profile+0x11f/0x1ed
[ 29.804661] [<ffffffff811f6032>] aa_replace_profiles+0x410/0x57c
[ 29.804668] [<ffffffff811f16d4>] profile_replace+0x35/0x4c
[ 29.804674] [<ffffffff81120fa3>] vfs_write+0xad/0x113
[ 29.804680] [<ffffffff81121609>] SyS_write+0x44/0x7a
[ 29.804687] [<ffffffff8145bfd2>] system_call_fastpath+0x16/0x1b
[ 29.804691]
[ 29.804694] ===============================
[ 29.804697] [ INFO: suspicious RCU usage. ]
[ 29.804700] 3.11.0+ #5 Not tainted
[ 29.804703] -------------------------------
[ 29.804706] security/apparmor/policy.c:566 suspicious rcu_dereference_check() usage!
[ 29.804709]
[ 29.804709] other info that might help us debug this:
[ 29.804709]
[ 29.804714]
[ 29.804714] rcu_scheduler_active = 1, debug_locks = 1
[ 29.804718] 2 locks held by apparmor_parser/1268:
[ 29.804721] #0: (sb_writers#9){.+.+.+}, at: [<ffffffff81120a4c>] file_start_write+0x27/0x29
[ 29.804733] #1: (&ns->lock){+.+.+.}, at: [<ffffffff811f5d88>] aa_replace_profiles+0x166/0x57c
[ 29.804744]
[ 29.804744] stack backtrace:
[ 29.804750] CPU: 0 PID: 1268 Comm: apparmor_parser Not tainted 3.11.0+ #5
[ 29.804753] Hardware name: ASUSTeK Computer Inc. UL50VT /UL50VT , BIOS 217 03/01/2010
[ 29.804756] 0000000000000000 ffff8800b95a1d80 ffffffff8144eb9b ffff8800b94db540
[ 29.804764] ffff8800b95a1db0 ffffffff81087439 ffff8800b95b02b0 0000000000000000
[ 29.804772] ffff8800b9efba08 ffff880138cc3a38 ffff8800b95a1dd0 ffffffff811f4f94
[ 29.804779] Call Trace:
[ 29.804786] [<ffffffff8144eb9b>] dump_stack+0x4e/0x82
[ 29.804791] [<ffffffff81087439>] lockdep_rcu_suspicious+0xfc/0x105
[ 29.804798] [<ffffffff811f4f94>] aa_free_replacedby_kref+0x4d/0x62
[ 29.804804] [<ffffffff811f4f47>] ? aa_put_namespace+0x17/0x17
[ 29.804810] [<ffffffff811f4f0b>] kref_put+0x36/0x40
[ 29.804816] [<ffffffff811f5423>] __replace_profile+0x13a/0x1ed
[ 29.804822] [<ffffffff811f6032>] aa_replace_profiles+0x410/0x57c
[ 29.804829] [<ffffffff811f16d4>] profile_replace+0x35/0x4c
[ 29.804835] [<ffffffff81120fa3>] vfs_write+0xad/0x113
[ 29.804840] [<ffffffff81121609>] SyS_write+0x44/0x7a
[ 29.804847] [<ffffffff8145bfd2>] system_call_fastpath+0x16/0x1b
Reported-by: miles.lane@gmail.com
CC: paulmck@linux.vnet.ibm.com
Use the shash interface, rather than the hash interface, when hashing
AppArmor profiles. The shash interface does not use scatterlists and it
is a better fit for what AppArmor needs.
This fixes a kernel paging BUG when aa_calc_profile_hash() is passed a
buffer from vmalloc(). The hash interface requires callers to handle
vmalloc() buffers differently than what AppArmor was doing. Due to
vmalloc() memory not being physically contiguous, each individual page
behind the buffer must be assigned to a scatterlist with sg_set_page()
and then the scatterlist passed to crypto_hash_update().
The shash interface does not have that limitation and allows vmalloc()
and kmalloc() buffers to be handled in the same manner.
BugLink: https://launchpad.net/bugs/1216294/
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=62261
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Acked-by: Seth Arnold <seth.arnold@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace changes from Eric Biederman:
"This is an assorted mishmash of small cleanups, enhancements and bug
fixes.
The major theme is user namespace mount restrictions. nsown_capable
is killed as it encourages not thinking about details that need to be
considered. A very hard to hit pid namespace exiting bug was finally
tracked and fixed. A couple of cleanups to the basic namespace
infrastructure.
Finally there is an enhancement that makes per user namespace
capabilities usable as capabilities, and an enhancement that allows
the per userns root to nice other processes in the user namespace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
userns: Kill nsown_capable it makes the wrong thing easy
capabilities: allow nice if we are privileged
pidns: Don't have unshare(CLONE_NEWPID) imply CLONE_THREAD
userns: Allow PR_CAPBSET_DROP in a user namespace.
namespaces: Simplify copy_namespaces so it is clear what is going on.
pidns: Fix hang in zap_pid_ns_processes by sending a potentially extra wakeup
sysfs: Restrict mounting sysfs
userns: Better restrictions on when proc and sysfs can be mounted
vfs: Don't copy mount bind mounts of /proc/<pid>/ns/mnt between namespaces
kernel/nsproxy.c: Improving a snippet of code.
proc: Restrict mounting the proc filesystem
vfs: Lock in place mounts from more privileged users
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Nothing major for this kernel, just maintenance updates"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits)
apparmor: add the ability to report a sha1 hash of loaded policy
apparmor: export set of capabilities supported by the apparmor module
apparmor: add the profile introspection file to interface
apparmor: add an optional profile attachment string for profiles
apparmor: add interface files for profiles and namespaces
apparmor: allow setting any profile into the unconfined state
apparmor: make free_profile available outside of policy.c
apparmor: rework namespace free path
apparmor: update how unconfined is handled
apparmor: change how profile replacement update is done
apparmor: convert profile lists to RCU based locking
apparmor: provide base for multiple profiles to be replaced at once
apparmor: add a features/policy dir to interface
apparmor: enable users to query whether apparmor is enabled
apparmor: remove minimum size check for vmalloc()
Smack: parse multiple rules per write to load2, up to PAGE_SIZE-1 bytes
Smack: network label match fix
security: smack: add a hash table to quicken smk_find_entry()
security: smack: fix memleak in smk_write_rules_list()
xattr: Constify ->name member of "struct xattr".
Pull networking changes from David Miller:
"Noteworthy changes this time around:
1) Multicast rejoin support for team driver, from Jiri Pirko.
2) Centralize and simplify TCP RTT measurement handling in order to
reduce the impact of bad RTO seeding from SYN/ACKs. Also, when
both timestamps and local RTT measurements are available prefer
the later because there are broken middleware devices which
scramble the timestamp.
From Yuchung Cheng.
3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel
memory consumed to queue up unsend user data. From Eric Dumazet.
4) Add a "physical port ID" abstraction for network devices, from
Jiri Pirko.
5) Add a "suppress" operation to influence fib_rules lookups, from
Stefan Tomanek.
6) Add a networking development FAQ, from Paul Gortmaker.
7) Extend the information provided by tcp_probe and add ipv6 support,
from Daniel Borkmann.
8) Use RCU locking more extensively in openvswitch data paths, from
Pravin B Shelar.
9) Add SCTP support to openvswitch, from Joe Stringer.
10) Add EF10 chip support to SFC driver, from Ben Hutchings.
11) Add new SYNPROXY netfilter target, from Patrick McHardy.
12) Compute a rate approximation for sending in TCP sockets, and use
this to more intelligently coalesce TSO frames. Furthermore, add
a new packet scheduler which takes advantage of this estimate when
available. From Eric Dumazet.
13) Allow AF_PACKET fanouts with random selection, from Daniel
Borkmann.
14) Add ipv6 support to vxlan driver, from Cong Wang"
Resolved conflicts as per discussion.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits)
openvswitch: Fix alignment of struct sw_flow_key.
netfilter: Fix build errors with xt_socket.c
tcp: Add missing braces to do_tcp_setsockopt
caif: Add missing braces to multiline if in cfctrl_linkup_request
bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize
vxlan: Fix kernel panic on device delete.
net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls
net: mvneta: properly disable HW PHY polling and ensure adjust_link() works
icplus: Use netif_running to determine device state
ethernet/arc/arc_emac: Fix huge delays in large file copies
tuntap: orphan frags before trying to set tx timestamp
tuntap: purge socket error queue on detach
qlcnic: use standard NAPI weights
ipv6:introduce function to find route for redirect
bnx2x: VF RSS support - VF side
bnx2x: VF RSS support - PF side
vxlan: Notify drivers for listening UDP port changes
net: usbnet: update addr_assign_type if appropriate
driver/net: enic: update enic maintainers and driver
driver/net: enic: Exposing symbols for Cisco's low latency driver
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Minor fixes mainly, including a potential use-after-free on remove
found by CONFIG_DEBUG_KOBJECT_RELEASE which may be theoretical"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
module: Fix mod->mkobj.kobj potentially freed too early
kernel/params.c: use scnprintf() instead of sprintf()
kernel/module.c: use scnprintf() instead of sprintf()
module/lsm: Have apparmor module parameters work with no args
module: Add NOARG flag for ops with param_set_bool_enable_only() set function
module: Add flag to allow mod params to have no arguments
modules: add support for soft module dependencies
scripts/mod/modpost.c: permit '.cranges' secton for sh64 architecture.
module: fix sprintf format specifier in param_get_byte()
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"A lot of activities on the cgroup front. Most changes aren't visible
to userland at all at this point and are laying foundation for the
planned unified hierarchy.
- The biggest change is decoupling the lifetime management of css
(cgroup_subsys_state) from that of cgroup's. Because controllers
(cpu, memory, block and so on) will need to be dynamically enabled
and disabled, css which is the association point between a cgroup
and a controller may come and go dynamically across the lifetime of
a cgroup. Till now, css's were created when the associated cgroup
was created and stayed till the cgroup got destroyed.
Assumptions around this tight coupling permeated through cgroup
core and controllers. These assumptions are gradually removed,
which consists bulk of patches, and css destruction path is
completely decoupled from cgroup destruction path. Note that
decoupling of creation path is relatively easy on top of these
changes and the patchset is pending for the next window.
- cgroup has its own event mechanism cgroup.event_control, which is
only used by memcg. It is overly complex trying to achieve high
flexibility whose benefits seem dubious at best. Going forward,
new events will simply generate file modified event and the
existing mechanism is being made specific to memcg. This pull
request contains prepatory patches for such change.
- Various fixes and cleanups"
Fixed up conflict in kernel/cgroup.c as per Tejun.
* 'for-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (69 commits)
cgroup: fix cgroup_css() invocation in css_from_id()
cgroup: make cgroup_write_event_control() use css_from_dir() instead of __d_cgrp()
cgroup: make cgroup_event hold onto cgroup_subsys_state instead of cgroup
cgroup: implement CFTYPE_NO_PREFIX
cgroup: make cgroup_css() take cgroup_subsys * instead and allow NULL subsys
cgroup: rename cgroup_css_from_dir() to css_from_dir() and update its syntax
cgroup: fix cgroup_write_event_control()
cgroup: fix subsystem file accesses on the root cgroup
cgroup: change cgroup_from_id() to css_from_id()
cgroup: use css_get() in cgroup_create() to check CSS_ROOT
cpuset: remove an unncessary forward declaration
cgroup: RCU protect each cgroup_subsys_state release
cgroup: move subsys file removal to kill_css()
cgroup: factor out kill_css()
cgroup: decouple cgroup_subsys_state destruction from cgroup destruction
cgroup: replace cgroup->css_kill_cnt with ->nr_css
cgroup: bounce cgroup_subsys_state ref kill confirmation to a work item
cgroup: move cgroup->subsys[] assignment to online_css()
cgroup: reorganize css init / exit paths
cgroup: add __rcu modifier to cgroup->subsys[]
We allow task A to change B's nice level if it has a supserset of
B's privileges, or of it has CAP_SYS_NICE. Also allow it if A has
CAP_SYS_NICE with respect to B - meaning it is root in the same
namespace, or it created B's namespace.
Signed-off-by: Serge Hallyn <serge.hallyn@canonical.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
As the capabilites and capability bounding set are per user namespace
properties it is safe to allow changing them with just CAP_SETPCAP
permission in the user namespace.
Tested-by: Richard Weinberger <richard@nod.at>
into ra-next
The apparmor module parameters for param_ops_aabool and
param_ops_aalockpolicy are both based off of the param_ops_bool,
and can handle a NULL value passed in as val. Have it enable the
new KERNEL_PARAM_FL_NOARGS flag to allow the parameters to be set
without having to state "=y" or "=1".
Cc: John Johansen <john.johansen@canonical.com>
Provide userspace the ability to introspect a sha1 hash value for each
profile currently loaded.
Add the dynamic namespace relative profiles file to the interace, to allow
introspection of loaded profiles and their modes.
Acked-by: Kees Cook <kees@ubuntu.com>
