Calculate what would be the label of newly created file and set that
secid in the passed creds.
Context of the task which is actually creating file is retrieved from
set of creds passed in. (old->security).
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: Paul Moore <paul@paul-moore.com>
During a new file creation we need to make sure new file is created with the
right label. New file is created in upper/ so effectively file should get
label as if task had created file in upper/.
We switched to mounter's creds for actual file creation. Also if there is a
whiteout present, then file will be created in work/ dir first and then
renamed in upper. In none of the cases file will be labeled as we want it to
be.
This patch introduces a new hook dentry_create_files_as(), which determines
the label/context dentry will get if it had been created by task in upper
and modify passed set of creds appropriately. Caller makes use of these new
creds for file creation.
[PM: fix whitespace issues found with checkpatch.pl]
[PM: changes to use stat->mode in ovl_create_or_link()]
Right now selinux_determine_inode_label() works on security pointer of
current task. Soon I need this to work on a security pointer retrieved
from a set of creds. So start passing in a pointer and caller can
decide where to fetch security pointer from.
When a file is copied up in overlay, we have already created file on
upper/ with right label and there is no need to copy up selinux
label/xattr from lower file to upper file. In fact in case of context
mount, we don't want to copy up label as newly created file got its label
from context= option.
Provide a security hook which is called when xattrs of a file are being
copied up. This hook is called once for each xattr and LSM can return
0 if the security module wants the xattr to be copied up, 1 if the
security module wants the xattr to be discarded on the copy, -EOPNOTSUPP
if the security module does not handle/manage the xattr, or a -errno
upon an error.
[PM: whitespace cleanup for checkpatch.pl]
A file is being copied up for overlay file system. Prepare a new set of
creds and set create_sid appropriately so that new file is created with
appropriate label.
Overlay inode has right label for both context and non-context mount
cases. In case of non-context mount, overlay inode will have the label
of lower file and in case of context mount, overlay inode will have
the label from context= mount option.
Provide a security hook to label new file correctly when a file is copied
up from lower layer to upper layer of a overlay/union mount.
This hook can prepare a new set of creds which are suitable for new file
creation during copy up. Caller will use new creds to create file and then
revert back to old creds and release new creds.
[PM: whitespace cleanup to appease checkpatch.pl]
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull usercopy protection from Kees Cook:
"Tbhis implements HARDENED_USERCOPY verification of copy_to_user and
copy_from_user bounds checking for most architectures on SLAB and
SLUB"
* tag 'usercopy-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
mm: SLUB hardened usercopy support
mm: SLAB hardened usercopy support
s390/uaccess: Enable hardened usercopy
sparc/uaccess: Enable hardened usercopy
powerpc/uaccess: Enable hardened usercopy
ia64/uaccess: Enable hardened usercopy
arm64/uaccess: Enable hardened usercopy
ARM: uaccess: Enable hardened usercopy
x86/uaccess: Enable hardened usercopy
mm: Hardened usercopy
mm: Implement stack frame object validation
mm: Add is_migrate_cma_page
ioctlcmd is currently printing hex numbers, but their is no leading
0x. Thus things like ioctlcmd=1234 are misleading, as the base is
not evident.
Correct this by adding 0x as a prefix, so ioctlcmd=1234 becomes
ioctlcmd=0x1234.
Signed-off-by: William Roberts <william.c.roberts@intel.com>
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled
either built-in or as a module, use that macro instead of open coding
the same.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Pull qstr constification updates from Al Viro:
"Fairly self-contained bunch - surprising lot of places passes struct
qstr * as an argument when const struct qstr * would suffice; it
complicates analysis for no good reason.
I'd prefer to feed that separately from the assorted fixes (those are
in #for-linus and with somewhat trickier topology)"
* 'work.const-qstr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
qstr: constify instances in adfs
qstr: constify instances in lustre
qstr: constify instances in f2fs
qstr: constify instances in ext2
qstr: constify instances in vfat
qstr: constify instances in procfs
qstr: constify instances in fuse
qstr constify instances in fs/dcache.c
qstr: constify instances in nfs
qstr: constify instances in ocfs2
qstr: constify instances in autofs4
qstr: constify instances in hfs
qstr: constify instances in hfsplus
qstr: constify instances in logfs
qstr: constify dentry_init_security
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- TPM core and driver updates/fixes
- IPv6 security labeling (CALIPSO)
- Lots of Apparmor fixes
- Seccomp: remove 2-phase API, close hole where ptrace can change
syscall #"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (156 commits)
apparmor: fix SECURITY_APPARMOR_HASH_DEFAULT parameter handling
tpm: Add TPM 2.0 support to the Nuvoton i2c driver (NPCT6xx family)
tpm: Factor out common startup code
tpm: use devm_add_action_or_reset
tpm2_i2c_nuvoton: add irq validity check
tpm: read burstcount from TPM_STS in one 32-bit transaction
tpm: fix byte-order for the value read by tpm2_get_tpm_pt
tpm_tis_core: convert max timeouts from msec to jiffies
apparmor: fix arg_size computation for when setprocattr is null terminated
apparmor: fix oops, validate buffer size in apparmor_setprocattr()
apparmor: do not expose kernel stack
apparmor: fix module parameters can be changed after policy is locked
apparmor: fix oops in profile_unpack() when policy_db is not present
apparmor: don't check for vmalloc_addr if kvzalloc() failed
apparmor: add missing id bounds check on dfa verification
apparmor: allow SYS_CAP_RESOURCE to be sufficient to prlimit another task
apparmor: use list_next_entry instead of list_entry_next
apparmor: fix refcount race when finding a child profile
apparmor: fix ref count leak when profile sha1 hash is read
apparmor: check that xindex is in trans_table bounds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull userns vfs updates from Eric Biederman:
"This tree contains some very long awaited work on generalizing the
user namespace support for mounting filesystems to include filesystems
with a backing store. The real world target is fuse but the goal is
to update the vfs to allow any filesystem to be supported. This
patchset is based on a lot of code review and testing to approach that
goal.
While looking at what is needed to support the fuse filesystem it
became clear that there were things like xattrs for security modules
that needed special treatment. That the resolution of those concerns
would not be fuse specific. That sorting out these general issues
made most sense at the generic level, where the right people could be
drawn into the conversation, and the issues could be solved for
everyone.
At a high level what this patchset does a couple of simple things:
- Add a user namespace owner (s_user_ns) to struct super_block.
- Teach the vfs to handle filesystem uids and gids not mapping into
to kuids and kgids and being reported as INVALID_UID and
INVALID_GID in vfs data structures.
By assigning a user namespace owner filesystems that are mounted with
only user namespace privilege can be detected. This allows security
modules and the like to know which mounts may not be trusted. This
also allows the set of uids and gids that are communicated to the
filesystem to be capped at the set of kuids and kgids that are in the
owning user namespace of the filesystem.
One of the crazier corner casees this handles is the case of inodes
whose i_uid or i_gid are not mapped into the vfs. Most of the code
simply doesn't care but it is easy to confuse the inode writeback path
so no operation that could cause an inode write-back is permitted for
such inodes (aka only reads are allowed).
This set of changes starts out by cleaning up the code paths involved
in user namespace permirted mounts. Then when things are clean enough
adds code that cleanly sets s_user_ns. Then additional restrictions
are added that are possible now that the filesystem superblock
contains owner information.
These changes should not affect anyone in practice, but there are some
parts of these restrictions that are changes in behavior.
- Andy's restriction on suid executables that does not honor the
suid bit when the path is from another mount namespace (think
/proc/[pid]/fd/) or when the filesystem was mounted by a less
privileged user.
- The replacement of the user namespace implicit setting of MNT_NODEV
with implicitly setting SB_I_NODEV on the filesystem superblock
instead.
Using SB_I_NODEV is a stronger form that happens to make this state
user invisible. The user visibility can be managed but it caused
problems when it was introduced from applications reasonably
expecting mount flags to be what they were set to.
There is a little bit of work remaining before it is safe to support
mounting filesystems with backing store in user namespaces, beyond
what is in this set of changes.
- Verifying the mounter has permission to read/write the block device
during mount.
- Teaching the integrity modules IMA and EVM to handle filesystems
mounted with only user namespace root and to reduce trust in their
security xattrs accordingly.
- Capturing the mounters credentials and using that for permission
checks in d_automount and the like. (Given that overlayfs already
does this, and we need the work in d_automount it make sense to
generalize this case).
Furthermore there are a few changes that are on the wishlist:
- Get all filesystems supporting posix acls using the generic posix
acls so that posix_acl_fix_xattr_from_user and
posix_acl_fix_xattr_to_user may be removed. [Maintainability]
- Reducing the permission checks in places such as remount to allow
the superblock owner to perform them.
- Allowing the superblock owner to chown files with unmapped uids and
gids to something that is mapped so the files may be treated
normally.
I am not considering even obvious relaxations of permission checks
until it is clear there are no more corner cases that need to be
locked down and handled generically.
Many thanks to Seth Forshee who kept this code alive, and putting up
with me rewriting substantial portions of what he did to handle more
corner cases, and for his diligent testing and reviewing of my
changes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (30 commits)
fs: Call d_automount with the filesystems creds
fs: Update i_[ug]id_(read|write) to translate relative to s_user_ns
evm: Translate user/group ids relative to s_user_ns when computing HMAC
dquot: For now explicitly don't support filesystems outside of init_user_ns
quota: Handle quota data stored in s_user_ns in quota_setxquota
quota: Ensure qids map to the filesystem
vfs: Don't create inodes with a uid or gid unknown to the vfs
vfs: Don't modify inodes with a uid or gid unknown to the vfs
cred: Reject inodes with invalid ids in set_create_file_as()
fs: Check for invalid i_uid in may_follow_link()
vfs: Verify acls are valid within superblock's s_user_ns.
userns: Handle -1 in k[ug]id_has_mapping when !CONFIG_USER_NS
fs: Refuse uid/gid changes which don't map into s_user_ns
selinux: Add support for unprivileged mounts from user namespaces
Smack: Handle labels consistently in untrusted mounts
Smack: Add support for unprivileged mounts from user namespaces
fs: Treat foreign mounts as nosuid
fs: Limit file caps to the user namespace of the super block
userns: Remove the now unnecessary FS_USERNS_DEV_MOUNT flag
userns: Remove implicit MNT_NODEV fragility.
Pull vfs updates from Al Viro:
"Assorted cleanups and fixes.
Probably the most interesting part long-term is ->d_init() - that will
have a bunch of followups in (at least) ceph and lustre, but we'll
need to sort the barrier-related rules before it can get used for
really non-trivial stuff.
Another fun thing is the merge of ->d_iput() callers (dentry_iput()
and dentry_unlink_inode()) and a bunch of ->d_compare() ones (all
except the one in __d_lookup_lru())"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
fs/dcache.c: avoid soft-lockup in dput()
vfs: new d_init method
vfs: Update lookup_dcache() comment
bdev: get rid of ->bd_inodes
Remove last traces of ->sync_page
new helper: d_same_name()
dentry_cmp(): use lockless_dereference() instead of smp_read_barrier_depends()
vfs: clean up documentation
vfs: document ->d_real()
vfs: merge .d_select_inode() into .d_real()
unify dentry_iput() and dentry_unlink_inode()
binfmt_misc: ->s_root is not going anywhere
drop redundant ->owner initializations
ufs: get rid of redundant checks
orangefs: constify inode_operations
missed comment updates from ->direct_IO() prototype change
file_inode(f)->i_mapping is f->f_mapping
trim fsnotify hooks a bit
9p: new helper - v9fs_parent_fid()
debugfs: ->d_parent is never NULL or negative
This changes the vfs dentry hashing to mix in the parent pointer at the
_beginning_ of the hash, rather than at the end.
That actually improves both the hash and the code generation, because we
can move more of the computation to the "static" part of the dcache
setup, and do less at lookup runtime.
It turns out that a lot of other hash users also really wanted to mix in
a base pointer as a 'salt' for the hash, and so the slightly extended
interface ends up working well for other cases too.
Users that want a string hash that is purely about the string pass in a
'salt' pointer of NULL.
* merge branch 'salted-string-hash':
fs/dcache.c: Save one 32-bit multiply in dcache lookup
vfs: make the string hashes salt the hash
The newly added Kconfig option could never work and just causes a build error
when disabled:
security/apparmor/lsm.c:675:25: error: 'CONFIG_SECURITY_APPARMOR_HASH_DEFAULT' undeclared here (not in a function)
bool aa_g_hash_policy = CONFIG_SECURITY_APPARMOR_HASH_DEFAULT;
The problem is that the macro undefined in this case, and we need to use the IS_ENABLED()
helper to turn it into a boolean constant.
Another minor problem with the original patch is that the option is even offered
in sysfs when SECURITY_APPARMOR_HASH is not enabled, so this also hides the option
in that case.
Fixes: 6059f71f1e94 ("apparmor: add parameter to control whether policy hashing is used")
Signed-off-by: John Johansen <john.johansen@canonical.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
This is the start of porting PAX_USERCOPY into the mainline kernel. This
is the first set of features, controlled by CONFIG_HARDENED_USERCOPY. The
work is based on code by PaX Team and Brad Spengler, and an earlier port
from Casey Schaufler. Additional non-slab page tests are from Rik van Riel.
This patch contains the logic for validating several conditions when
performing copy_to_user() and copy_from_user() on the kernel object
being copied to/from:
- address range doesn't wrap around
- address range isn't NULL or zero-allocated (with a non-zero copy size)
- if on the slab allocator:
- object size must be less than or equal to copy size (when check is
implemented in the allocator, which appear in subsequent patches)
- otherwise, object must not span page allocations (excepting Reserved
and CMA ranges)
- if on the stack
- object must not extend before/after the current process stack
- object must be contained by a valid stack frame (when there is
arch/build support for identifying stack frames)
- object must not overlap with kernel text
Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Tested-by: Michael Ellerman <mpe@ellerman.id.au>
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"Here is the crypto update for 4.8:
API:
- first part of skcipher low-level conversions
- add KPP (Key-agreement Protocol Primitives) interface.
Algorithms:
- fix IPsec/cryptd reordering issues that affects aesni
- RSA no longer does explicit leading zero removal
- add SHA3
- add DH
- add ECDH
- improve DRBG performance by not doing CTR by hand
Drivers:
- add x86 AVX2 multibuffer SHA256/512
- add POWER8 optimised crc32c
- add xts support to vmx
- add DH support to qat
- add RSA support to caam
- add Layerscape support to caam
- add SEC1 AEAD support to talitos
- improve performance by chaining requests in marvell/cesa
- add support for Araneus Alea I USB RNG
- add support for Broadcom BCM5301 RNG
- add support for Amlogic Meson RNG
- add support Broadcom NSP SoC RNG"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (180 commits)
crypto: vmx - Fix aes_p8_xts_decrypt build failure
crypto: vmx - Ignore generated files
crypto: vmx - Adding support for XTS
crypto: vmx - Adding asm subroutines for XTS
crypto: skcipher - add comment for skcipher_alg->base
crypto: testmgr - Print akcipher algorithm name
crypto: marvell - Fix wrong flag used for GFP in mv_cesa_dma_add_iv_op
crypto: nx - off by one bug in nx_of_update_msc()
crypto: rsa-pkcs1pad - fix rsa-pkcs1pad request struct
crypto: scatterwalk - Inline start/map/done
crypto: scatterwalk - Remove unnecessary BUG in scatterwalk_start
crypto: scatterwalk - Remove unnecessary advance in scatterwalk_pagedone
crypto: scatterwalk - Fix test in scatterwalk_done
crypto: api - Optimise away crypto_yield when hard preemption is on
crypto: scatterwalk - add no-copy support to copychunks
crypto: scatterwalk - Remove scatterwalk_bytes_sglen
crypto: omap - Stop using crypto scatterwalk_bytes_sglen
crypto: skcipher - Remove top-level givcipher interface
crypto: user - Remove crypto_lookup_skcipher call
crypto: cts - Convert to skcipher
When proc_pid_attr_write() was changed to use memdup_user apparmor's
(interface violating) assumption that the setprocattr buffer was always
a single page was violated.
The size test is not strictly speaking needed as proc_pid_attr_write()
will reject anything larger, but for the sake of robustness we can keep
it in.
SMACK and SELinux look safe to me, but somebody else should probably
have a look just in case.
Based on original patch from Vegard Nossum <vegard.nossum@oracle.com>
modified for the case that apparmor provides null termination.
Fixes: bb646cdb12e75d82258c2f2e7746d5952d3e321a
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
Cc: John Johansen <john.johansen@canonical.com>
Cc: Paul Moore <paul@paul-moore.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Eric Paris <eparis@parisplace.org>
Cc: Casey Schaufler <casey@schaufler-ca.com>
Cc: stable@kernel.org
Reviewed-by: Tyler Hicks <tyhicks@canonical.com>
Do not copy uninitalized fields th.td_hilen, th.td_data.
the policy_lock parameter is a one way switch that prevents policy
from being further modified. Unfortunately some of the module parameters
can effectively modify policy by turning off enforcement.
split policy_admin_capable into a view check and a full admin check,
and update the admin check to test the policy_lock parameter.
BugLink: http://bugs.launchpad.net/bugs/1592547
If unpack_dfa() returns NULL due to the dfa not being present,
profile_unpack() is not checking if the dfa is not present (NULL).
While using AppArmor, SYS_CAP_RESOURCE is insufficient to call prlimit
on another task. The only other example of a AppArmor mediating access to
another, already running, task (ignoring fork+exec) is ptrace.
The AppArmor model for ptrace is that one of the following must be true:
1) The tracer is unconfined
2) The tracer is in complain mode
3) The tracer and tracee are confined by the same profile
4) The tracer is confined but has SYS_CAP_PTRACE
1), 2, and 3) are already true for setrlimit.
We can match the ptrace model just by allowing CAP_SYS_RESOURCE.
We still test the values of the rlimit since it can always be overridden
using a value that means unlimited for a particular resource.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
list_next_entry has been defined in list.h, so I replace list_entry_next
with it.
Signed-off-by: Geliang Tang <geliangtang@163.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
When finding a child profile via an rcu critical section, the profile
may be put and scheduled for deletion after the child is found but
before its refcount is incremented.
Protect against this by repeating the lookup if the profiles refcount
is 0 and is one its way to deletion.
Acked-by: Seth Arnold <seth.arnold@canonical.com>
The target profile name was not being correctly audited in a few
cases because the target variable was not being set and gotos
passed the code to set it at apply:
Since it is always based on new_profile just drop the target var
and conditionally report based on new_profile.
Currently logging of a successful profile load only logs the basename
of the profile. This can result in confusion when a child profile has
the same name as the another profile in the set. Logging the hname
will ensure there is no confusion.
currently only the profile that is causing the failure is logged. This
makes it more confusing than necessary about which profiles loaded
and which didn't. So make sure to log success and failure messages for
all profiles in the set being loaded.
Acked-by: Tyler Hicks <tyhicks@canonical.com>
Internal mounts are not mounted anywhere and as such should be treated
as disconnected paths.
Bind mounts can fail to be properly reconnected when PATH_CONNECT is
specified. Ensure that when PATH_CONNECT is specified the path has
a root.
BugLink: http://bugs.launchpad.net/bugs/1319984
The current behavior is confusing as it causes exec failures to report
the executable is missing instead of identifying that apparmor
caused the failure.
BugLink: http://bugs.launchpad.net/bugs/1268727
The task field in the lsm_audit struct needs to be initialized if
a change_hat fails, otherwise the following oops will occur
BUG: unable to handle kernel paging request at 0000002fbead7d08
IP: [<ffffffff8171153e>] _raw_spin_lock+0xe/0x50
PGD 1e3f35067 PUD 0
Oops: 0002 [#1] SMP
Modules linked in: pppox crc_ccitt p8023 p8022 psnap llc ax25 btrfs raid6_pq xor xfs libcrc32c dm_multipath scsi_dh kvm_amd dcdbas kvm microcode amd64_edac_mod joydev edac_core psmouse edac_mce_amd serio_raw k10temp sp5100_tco i2c_piix4 ipmi_si ipmi_msghandler acpi_power_meter mac_hid lp parport hid_generic usbhid hid pata_acpi mpt2sas ahci raid_class pata_atiixp bnx2 libahci scsi_transport_sas [last unloaded: tipc]
CPU: 2 PID: 699 Comm: changehat_twice Tainted: GF O 3.13.0-7-generic #25-Ubuntu
Hardware name: Dell Inc. PowerEdge R415/08WNM9, BIOS 1.8.6 12/06/2011
task: ffff8802135c6000 ti: ffff880212986000 task.ti: ffff880212986000
RIP: 0010:[<ffffffff8171153e>] [<ffffffff8171153e>] _raw_spin_lock+0xe/0x50
RSP: 0018:ffff880212987b68 EFLAGS: 00010006
RAX: 0000000000020000 RBX: 0000002fbead7500 RCX: 0000000000000000
RDX: 0000000000000292 RSI: ffff880212987ba8 RDI: 0000002fbead7d08
RBP: ffff880212987b68 R08: 0000000000000246 R09: ffff880216e572a0
R10: ffffffff815fd677 R11: ffffea0008469580 R12: ffffffff8130966f
R13: ffff880212987ba8 R14: 0000002fbead7d08 R15: ffff8800d8c6b830
FS: 00002b5e6c84e7c0(0000) GS:ffff880216e40000(0000) knlGS:0000000055731700
CR2: 0000002fbead7d08 CR3: 000000021270f000 CR4: 00000000000006e0
Stack:
ffff880212987b98 ffffffff81075f17 ffffffff8130966f 0000000000000009
0000000000000000 0000000000000000 ffff880212987bd0 ffffffff81075f7c
0000000000000292 ffff880212987c08 ffff8800d8c6b800 0000000000000026
Call Trace:
[<ffffffff81075f17>] __lock_task_sighand+0x47/0x80
[<ffffffff8130966f>] ? apparmor_cred_prepare+0x2f/0x50
[<ffffffff81075f7c>] do_send_sig_info+0x2c/0x80
[<ffffffff81075fee>] send_sig_info+0x1e/0x30
[<ffffffff8130242d>] aa_audit+0x13d/0x190
[<ffffffff8130c1dc>] aa_audit_file+0xbc/0x130
[<ffffffff81304cc2>] aa_change_hat+0x202/0x530
[<ffffffff81308fc6>] aa_setprocattr_changehat+0x116/0x1d0
[<ffffffff8130a11d>] apparmor_setprocattr+0x25d/0x300
[<ffffffff812cee56>] security_setprocattr+0x16/0x20
[<ffffffff8121fc87>] proc_pid_attr_write+0x107/0x130
[<ffffffff811b7604>] vfs_write+0xb4/0x1f0
[<ffffffff811b8039>] SyS_write+0x49/0xa0
[<ffffffff8171a1bf>] tracesys+0xe1/0xe6
When set atomic replacement is used and the parent is updated before the
child, and the child did not exist in the old parent so there is no
direct replacement then the new child is incorrectly added to the old
parent. This results in the new parent not having the child(ren) that
it should and the old parent when being destroyed asserting the
following error.
AppArmor: policy_destroy: internal error, policy '<profile/name>' still
contains profiles
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into next
into next
it in.
into next
The EVM HMAC should be calculated using the on disk user and
group ids, so the k[ug]ids in the inode must be translated
relative to the s_user_ns of the inode's super block.
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs into work.misc
Extend the PCR supplied as a parameter, instead of assuming that the
measurement entry uses the default configured PCR.
Signed-off-by: Eric Richter <erichte@linux.vnet.ibm.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
