path: root/security
2013-11-25ima: make a copy of template_fmt in template_desc_init_fields()Roberto Sassu
This patch makes a copy of the 'template_fmt' function argument so that the latter will not be modified by strsep(), which does the splitting by replacing the given separator with '\0'.  IMA: No TPM chip found, activating TPM-bypass!  Unable to handle kernel pointer dereference at virtual kernel address 0000000000842000  Oops: 0004 [#1] SMP  Modules linked in:  CPU: 3 PID: 1 Comm: swapper/0 Not tainted 3.12.0-rc2-00098-g3ce1217d6cd5 #17  task: 000000003ffa0000 ti: 000000003ff84000 task.ti: 000000003ff84000  Krnl PSW : 0704e00180000000 000000000044bf88 (strsep+0x7c/0xa0)             R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:3 CC:2 PM:0 EA:3  Krnl GPRS: 000000000000007c 000000000000007c 000000003ff87d90 0000000000821fd8             0000000000000000 000000000000007c 0000000000aa37e0 0000000000aa9008             0000000000000051 0000000000a114d8 0000000100000002 0000000000842bde             0000000000842bdf 00000000006f97f0 000000000040062c 000000003ff87cf0  Krnl Code: 000000000044bf7c: a7f4000a           brc     15,44bf90             000000000044bf80: b90200cc           ltgr    %r12,%r12            #000000000044bf84: a7840006           brc     8,44bf90            >000000000044bf88: 9200c000           mvi     0(%r12),0             000000000044bf8c: 41c0c001           la      %r12,1(%r12)             000000000044bf90: e3c020000024       stg     %r12,0(%r2)             000000000044bf96: b904002b           lgr     %r2,%r11             000000000044bf9a: ebbcf0700004       lmg     %r11,%r12,112(%r15)  Call Trace:  ([<00000000004005fe>] ima_init_template+0xa2/0x1bc)   [<0000000000a7c896>] ima_init+0x7a/0xa8   [<0000000000a7c938>] init_ima+0x24/0x40   [<00000000001000e8>] do_one_initcall+0x68/0x128   [<0000000000a4eb56>] kernel_init_freeable+0x20a/0x2b4   [<00000000006a1ff4>] kernel_init+0x30/0x178   [<00000000006b69fe>] kernel_thread_starter+0x6/0xc   [<00000000006b69f8>] kernel_thread_starter+0x0/0xc  Last Breaking-Event-Address:   [<000000000044bf42>] strsep+0x36/0xa0 Fixes commit: adf53a7 ima: new templates management mechanism Changelog v1: - make template_fmt 'const char *' (reported-by James Morris) - fix kstrdup memory leak (reported-by James Morris) Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Tested-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2013-11-25ima: do not send field length to userspace for digest of ima templateRoberto Sassu
This patch defines a new value for the 'ima_show_type' enumerator (IMA_SHOW_BINARY_NO_FIELD_LEN) to prevent that the field length is transmitted through the 'binary_runtime_measurements' interface for the digest field of the 'ima' template. Fixes commit: 3ce1217 ima: define template fields library and new helpers Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-11-25ima: do not include field length in template digest calc for ima templateRoberto Sassu
To maintain compatibility with userspace tools, the field length must not be included in the template digest calculation for the 'ima' template. Fixes commit: a71dc65 ima: switch to new template management mechanism Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-11-23Revert "ima: define '_ima' as a builtin 'trusted' keyring"Linus Torvalds
This reverts commit 217091dd7a7a1bdac027ddb7c5a25f6ac0b8e241, which caused the following build error: security/integrity/digsig.c:70:5: error: redefinition of ‘integrity_init_keyring’ security/integrity/integrity.h:149:12: note: previous definition of ‘integrity_init_keyring’ w security/integrity/integrity.h:149:12: warning: ‘integrity_init_keyring’ defined but not used reported by Krzysztof Kolasa. Mimi says: "I made the classic mistake of requesting this patch to be upstreamed at the last second, rather than waiting until the next open window. At this point, the best course would probably be to revert the two commits and fix them for the next open window" Reported-by: Krzysztof Kolasa <kkolasa@winsoft.pl> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-21Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this patchset, we finally get an SELinux update, with Paul Moore taking over as maintainer of that code. Also a significant update for the Keys subsystem, as well as maintenance updates to Smack, IMA, TPM, and Apparmor" and since I wanted to know more about the updates to key handling, here's the explanation from David Howells on that: "Okay. There are a number of separate bits. I'll go over the big bits and the odd important other bit, most of the smaller bits are just fixes and cleanups. If you want the small bits accounting for, I can do that too. (1) Keyring capacity expansion. KEYS: Consolidate the concept of an 'index key' for key access KEYS: Introduce a search context structure KEYS: Search for auth-key by name rather than target key ID Add a generic associative array implementation. KEYS: Expand the capacity of a keyring Several of the patches are providing an expansion of the capacity of a keyring. Currently, the maximum size of a keyring payload is one page. Subtract a small header and then divide up into pointers, that only gives you ~500 pointers on an x86_64 box. However, since the NFS idmapper uses a keyring to store ID mapping data, that has proven to be insufficient to the cause. Whatever data structure I use to handle the keyring payload, it can only store pointers to keys, not the keys themselves because several keyrings may point to a single key. This precludes inserting, say, and rb_node struct into the key struct for this purpose. I could make an rbtree of records such that each record has an rb_node and a key pointer, but that would use four words of space per key stored in the keyring. It would, however, be able to use much existing code. I selected instead a non-rebalancing radix-tree type approach as that could have a better space-used/key-pointer ratio. I could have used the radix tree implementation that we already have and insert keys into it by their serial numbers, but that means any sort of search must iterate over the whole radix tree. Further, its nodes are a bit on the capacious side for what I want - especially given that key serial numbers are randomly allocated, thus leaving a lot of empty space in the tree. So what I have is an associative array that internally is a radix-tree with 16 pointers per node where the index key is constructed from the key type pointer and the key description. This means that an exact lookup by type+description is very fast as this tells us how to navigate directly to the target key. I made the data structure general in lib/assoc_array.c as far as it is concerned, its index key is just a sequence of bits that leads to a pointer. It's possible that someone else will be able to make use of it also. FS-Cache might, for example. (2) Mark keys as 'trusted' and keyrings as 'trusted only'. KEYS: verify a certificate is signed by a 'trusted' key KEYS: Make the system 'trusted' keyring viewable by userspace KEYS: Add a 'trusted' flag and a 'trusted only' flag KEYS: Separate the kernel signature checking keyring from module signing These patches allow keys carrying asymmetric public keys to be marked as being 'trusted' and allow keyrings to be marked as only permitting the addition or linkage of trusted keys. Keys loaded from hardware during kernel boot or compiled into the kernel during build are marked as being trusted automatically. New keys can be loaded at runtime with add_key(). They are checked against the system keyring contents and if their signatures can be validated with keys that are already marked trusted, then they are marked trusted also and can thus be added into the master keyring. Patches from Mimi Zohar make this usable with the IMA keyrings also. (3) Remove the date checks on the key used to validate a module signature. X.509: Remove certificate date checks It's not reasonable to reject a signature just because the key that it was generated with is no longer valid datewise - especially if the kernel hasn't yet managed to set the system clock when the first module is loaded - so just remove those checks. (4) Make it simpler to deal with additional X.509 being loaded into the kernel. KEYS: Load *.x509 files into kernel keyring KEYS: Have make canonicalise the paths of the X.509 certs better to deduplicate The builder of the kernel now just places files with the extension ".x509" into the kernel source or build trees and they're concatenated by the kernel build and stuffed into the appropriate section. (5) Add support for userspace kerberos to use keyrings. KEYS: Add per-user_namespace registers for persistent per-UID kerberos caches KEYS: Implement a big key type that can save to tmpfs Fedora went to, by default, storing kerberos tickets and tokens in tmpfs. We looked at storing it in keyrings instead as that confers certain advantages such as tickets being automatically deleted after a certain amount of time and the ability for the kernel to get at these tokens more easily. To make this work, two things were needed: (a) A way for the tickets to persist beyond the lifetime of all a user's sessions so that cron-driven processes can still use them. The problem is that a user's session keyrings are deleted when the session that spawned them logs out and the user's user keyring is deleted when the UID is deleted (typically when the last log out happens), so neither of these places is suitable. I've added a system keyring into which a 'persistent' keyring is created for each UID on request. Each time a user requests their persistent keyring, the expiry time on it is set anew. If the user doesn't ask for it for, say, three days, the keyring is automatically expired and garbage collected using the existing gc. All the kerberos tokens it held are then also gc'd. (b) A key type that can hold really big tickets (up to 1MB in size). The problem is that Active Directory can return huge tickets with lots of auxiliary data attached. We don't, however, want to eat up huge tracts of unswappable kernel space for this, so if the ticket is greater than a certain size, we create a swappable shmem file and dump the contents in there and just live with the fact we then have an inode and a dentry overhead. If the ticket is smaller than that, we slap it in a kmalloc()'d buffer" * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (121 commits) KEYS: Fix keyring content gc scanner KEYS: Fix error handling in big_key instantiation KEYS: Fix UID check in keyctl_get_persistent() KEYS: The RSA public key algorithm needs to select MPILIB ima: define '_ima' as a builtin 'trusted' keyring ima: extend the measurement list to include the file signature kernel/system_certificate.S: use real contents instead of macro GLOBAL() KEYS: fix error return code in big_key_instantiate() KEYS: Fix keyring quota misaccounting on key replacement and unlink KEYS: Fix a race between negating a key and reading the error set KEYS: Make BIG_KEYS boolean apparmor: remove the "task" arg from may_change_ptraced_domain() apparmor: remove parent task info from audit logging apparmor: remove tsk field from the apparmor_audit_struct apparmor: fix capability to not use the current task, during reporting Smack: Ptrace access check mode ima: provide hash algo info in the xattr ima: enable support for larger default filedata hash algorithms ima: define kernel parameter 'ima_template=' to change configured default ima: add Kconfig default measurement list template ...
2013-11-21Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris: "Nothing amazing. Formatting, small bug fixes, couple of fixes where we didn't get records due to some old VFS changes, and a change to how we collect execve info..." Fixed conflict in fs/exec.c as per Eric and linux-next. * git://git.infradead.org/users/eparis/audit: (28 commits) audit: fix type of sessionid in audit_set_loginuid() audit: call audit_bprm() only once to add AUDIT_EXECVE information audit: move audit_aux_data_execve contents into audit_context union audit: remove unused envc member of audit_aux_data_execve audit: Kill the unused struct audit_aux_data_capset audit: do not reject all AUDIT_INODE filter types audit: suppress stock memalloc failure warnings since already managed audit: log the audit_names record type audit: add child record before the create to handle case where create fails audit: use given values in tty_audit enable api audit: use nlmsg_len() to get message payload length audit: use memset instead of trying to initialize field by field audit: fix info leak in AUDIT_GET requests audit: update AUDIT_INODE filter rule to comparator function audit: audit feature to set loginuid immutable audit: audit feature to only allow unsetting the loginuid audit: allow unsetting the loginuid (with priv) audit: remove CONFIG_AUDIT_LOGINUID_IMMUTABLE audit: loginuid functions coding style selinux: apply selinux checks on new audit message types ...
2013-11-14KEYS: Fix keyring content gc scannerDavid Howells
Key pointers stored in the keyring are marked in bit 1 to indicate if they point to a keyring. We need to strip off this bit before using the pointer when iterating over the keyring for the purpose of looking for links to garbage collect. This means that expirable keyrings aren't correctly expiring because the checker is seeing their key pointer with 2 added to it. Since the fix for this involves knowing about the internals of the keyring, key_gc_keyring() is moved to keyring.c and merged into keyring_gc(). This can be tested by: echo 2 >/proc/sys/kernel/keys/gc_delay keyctl timeout `keyctl add keyring qwerty "" @s` 2 cat /proc/keys sleep 5; cat /proc/keys which should see a keyring called "qwerty" appear in the session keyring and then disappear after it expires, and: echo 2 >/proc/sys/kernel/keys/gc_delay a=`keyctl get_persistent @s` b=`keyctl add keyring 0 "" $a` keyctl add user a a $b keyctl timeout $b 2 cat /proc/keys sleep 5; cat /proc/keys which should see a keyring called "0" with a key called "a" in it appear in the user's persistent keyring (which will be attached to the session keyring) and then both the "0" keyring and the "a" key should disappear when the "0" keyring expires. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Simo Sorce <simo@redhat.com>
2013-11-13KEYS: Fix error handling in big_key instantiationDavid Howells
In the big_key_instantiate() function we return 0 if kernel_write() returns us an error rather than returning an error. This can potentially lead to dentry_open() giving a BUG when called from big_key_read() with an unset tmpfile path. ------------[ cut here ]------------ kernel BUG at fs/open.c:798! ... RIP: 0010:[<ffffffff8119bbd1>] dentry_open+0xd1/0xe0 ... Call Trace: [<ffffffff812350c5>] big_key_read+0x55/0x100 [<ffffffff81231084>] keyctl_read_key+0xb4/0xe0 [<ffffffff81231e58>] SyS_keyctl+0xf8/0x1d0 [<ffffffff815bb799>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Stephen Gallagher <sgallagh@redhat.com>
2013-11-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) The addition of nftables. No longer will we need protocol aware firewall filtering modules, it can all live in userspace. At the core of nftables is a, for lack of a better term, virtual machine that executes byte codes to inspect packet or metadata (arriving interface index, etc.) and make verdict decisions. Besides support for loading packet contents and comparing them, the interpreter supports lookups in various datastructures as fundamental operations. For example sets are supports, and therefore one could create a set of whitelist IP address entries which have ACCEPT verdicts attached to them, and use the appropriate byte codes to do such lookups. Since the interpreted code is composed in userspace, userspace can do things like optimize things before giving it to the kernel. Another major improvement is the capability of atomically updating portions of the ruleset. In the existing netfilter implementation, one has to update the entire rule set in order to make a change and this is very expensive. Userspace tools exist to create nftables rules using existing netfilter rule sets, but both kernel implementations will need to co-exist for quite some time as we transition from the old to the new stuff. Kudos to Patrick McHardy, Pablo Neira Ayuso, and others who have worked so hard on this. 2) Daniel Borkmann and Hannes Frederic Sowa made several improvements to our pseudo-random number generator, mostly used for things like UDP port randomization and netfitler, amongst other things. In particular the taus88 generater is updated to taus113, and test cases are added. 3) Support 64-bit rates in HTB and TBF schedulers, from Eric Dumazet and Yang Yingliang. 4) Add support for new 577xx tigon3 chips to tg3 driver, from Nithin Sujir. 5) Fix two fatal flaws in TCP dynamic right sizing, from Eric Dumazet, Neal Cardwell, and Yuchung Cheng. 6) Allow IP_TOS and IP_TTL to be specified in sendmsg() ancillary control message data, much like other socket option attributes. From Francesco Fusco. 7) Allow applications to specify a cap on the rate computed automatically by the kernel for pacing flows, via a new SO_MAX_PACING_RATE socket option. From Eric Dumazet. 8) Make the initial autotuned send buffer sizing in TCP more closely reflect actual needs, from Eric Dumazet. 9) Currently early socket demux only happens for TCP sockets, but we can do it for connected UDP sockets too. Implementation from Shawn Bohrer. 10) Refactor inet socket demux with the goal of improving hash demux performance for listening sockets. With the main goals being able to use RCU lookups on even request sockets, and eliminating the listening lock contention. From Eric Dumazet. 11) The bonding layer has many demuxes in it's fast path, and an RCU conversion was started back in 3.11, several changes here extend the RCU usage to even more locations. From Ding Tianhong and Wang Yufen, based upon suggestions by Nikolay Aleksandrov and Veaceslav Falico. 12) Allow stackability of segmentation offloads to, in particular, allow segmentation offloading over tunnels. From Eric Dumazet. 13) Significantly improve the handling of secret keys we input into the various hash functions in the inet hashtables, TCP fast open, as well as syncookies. From Hannes Frederic Sowa. The key fundamental operation is "net_get_random_once()" which uses static keys. Hannes even extended this to ipv4/ipv6 fragmentation handling and our generic flow dissector. 14) The generic driver layer takes care now to set the driver data to NULL on device removal, so it's no longer necessary for drivers to explicitly set it to NULL any more. Many drivers have been cleaned up in this way, from Jingoo Han. 15) Add a BPF based packet scheduler classifier, from Daniel Borkmann. 16) Improve CRC32 interfaces and generic SKB checksum iterators so that SCTP's checksumming can more cleanly be handled. Also from Daniel Borkmann. 17) Add a new PMTU discovery mode, IP_PMTUDISC_INTERFACE, which forces using the interface MTU value. This helps avoid PMTU attacks, particularly on DNS servers. From Hannes Frederic Sowa. 18) Use generic XPS for transmit queue steering rather than internal (re-)implementation in virtio-net. From Jason Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits) random32: add test cases for taus113 implementation random32: upgrade taus88 generator to taus113 from errata paper random32: move rnd_state to linux/random.h random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized random32: add periodic reseeding random32: fix off-by-one in seeding requirement PHY: Add RTL8201CP phy_driver to realtek xtsonic: add missing platform_set_drvdata() in xtsonic_probe() macmace: add missing platform_set_drvdata() in mace_probe() ethernet/arc/arc_emac: add missing platform_set_drvdata() in arc_emac_probe() ipv6: protect for_each_sk_fl_rcu in mem_check with rcu_read_lock_bh vlan: Implement vlan_dev_get_egress_qos_mask as an inline. ixgbe: add warning when max_vfs is out of range. igb: Update link modes display in ethtool netfilter: push reasm skb through instead of original frag skbs ip6_output: fragment outgoing reassembled skb properly MAINTAINERS: mv643xx_eth: take over maintainership from Lennart net_sched: tbf: support of 64bit rates ixgbe: deleting dfwd stations out of order can cause null ptr deref ixgbe: fix build err, num_rx_queues is only available with CONFIG_RPS ...
2013-11-13Merge branch 'for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: "Not too much activity this time around. css_id is finally killed and a minor update to device_cgroup" * 'for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: device_cgroup: remove can_attach cgroup: kill css_id memcg: stop using css id memcg: fail to create cgroup if the cgroup id is too big memcg: convert to use cgroup id memcg: convert to use cgroup_is_descendant()
2013-11-06KEYS: Fix UID check in keyctl_get_persistent()David Howells
If the UID is specified by userspace when calling the KEYCTL_GET_PERSISTENT function and the process does not have the CAP_SETUID capability, then the function will return -EPERM if the current process's uid, suid, euid and fsuid all match the requested UID. This is incorrect. Fix it such that when a non-privileged caller requests a persistent keyring by a specific UID they can only request their own (ie. the specified UID matches either then process's UID or the process's EUID). This can be tested by logging in as the user and doing: keyctl get_persistent @p keyctl get_persistent @p `id -u` keyctl get_persistent @p 0 The first two should successfully print the same key ID. The third should do the same if called by UID 0 or indicate Operation Not Permitted otherwise. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Stephen Gallagher <sgallagh@redhat.com>
2013-11-05audit: suppress stock memalloc failure warnings since already managedRichard Guy Briggs
Supress the stock memory allocation failure warnings for audit buffers since audit alreay takes care of memory allocation failure warnings, including rate-limiting, in audit_log_start(). Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-11-05selinux: apply selinux checks on new audit message typesEric Paris
We use the read check to get the feature set (like AUDIT_GET) and the write check to set the features (like AUDIT_SET). Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-10-31ima: define '_ima' as a builtin 'trusted' keyringMimi Zohar
Require all keys added to the IMA keyring be signed by an existing trusted key on the system trusted keyring. Changelog: - define stub integrity_init_keyring() function (reported-by Fengguang Wu) - differentiate between regular and trusted keyring names. - replace printk with pr_info (D. Kasatkin) Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2013-10-31ima: extend the measurement list to include the file signatureMimi Zohar
This patch defines a new template called 'ima-sig', which includes the file signature in the template data, in addition to the file's digest and pathname. A template is composed of a set of fields. Associated with each field is an initialization and display function. This patch defines a new template field called 'sig', the initialization function ima_eventsig_init(), and the display function ima_show_template_sig(). This patch modifies the .field_init() function definition to include the 'security.ima' extended attribute and length. Changelog: - remove unused code (Dmitry Kasatkin) - avoid calling ima_write_template_field_data() unnecesarily (Roberto Sassu) - rename DATA_FMT_SIG to DATA_FMT_HEX - cleanup ima_eventsig_init() based on Roberto's comments Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
2013-10-31Merge branch 'keys-devel' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into ra-next
2013-10-30KEYS: fix error return code in big_key_instantiate()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David Howells <dhowells@redhat.com>
2013-10-30KEYS: Fix keyring quota misaccounting on key replacement and unlinkDavid Howells
If a key is displaced from a keyring by a matching one, then four more bytes of quota are allocated to the keyring - despite the fact that the keyring does not change in size. Further, when a key is unlinked from a keyring, the four bytes of quota allocated the link isn't recovered and returned to the user's pool. The first can be tested by repeating: keyctl add big_key a fred @s cat /proc/key-users (Don't put it in a shell loop otherwise the garbage collector won't have time to clear the displaced keys, thus affecting the result). This was causing the kerberos keyring to run out of room fairly quickly. The second can be tested by: cat /proc/key-users a=`keyctl add user a a @s` cat /proc/key-users keyctl unlink $a sleep 1 # Give RCU a chance to delete the key cat /proc/key-users assuming no system activity that otherwise adds/removes keys, the amount of key data allocated should go up (say 40/20000 -> 47/20000) and then return to the original value at the end. Reported-by: Stephen Gallagher <sgallagh@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2013-10-30KEYS: Fix a race between negating a key and reading the error setDavid Howells
key_reject_and_link() marking a key as negative and setting the error with which it was negated races with keyring searches and other things that read that error. The fix is to switch the order in which the assignments are done in key_reject_and_link() and to use memory barriers. Kudos to Dave Wysochanski <dwysocha@redhat.com> and Scott Mayhew <smayhew@redhat.com> for tracking this down. This may be the cause of: BUG: unable to handle kernel NULL pointer dereference at 0000000000000070 IP: [<ffffffff81219011>] wait_for_key_construction+0x31/0x80 PGD c6b2c3067 PUD c59879067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/system/cpu/cpu3/cache/index2/shared_cpu_map CPU 0 Modules linked in: ... Pid: 13359, comm: amqzxma0 Not tainted 2.6.32-358.20.1.el6.x86_64 #1 IBM System x3650 M3 -[7945PSJ]-/00J6159 RIP: 0010:[<ffffffff81219011>] wait_for_key_construction+0x31/0x80 RSP: 0018:ffff880c6ab33758 EFLAGS: 00010246 RAX: ffffffff81219080 RBX: 0000000000000000 RCX: 0000000000000002 RDX: ffffffff81219060 RSI: 0000000000000000 RDI: 0000000000000000 RBP: ffff880c6ab33768 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffff880adfcbce40 R13: ffffffffa03afb84 R14: ffff880adfcbce40 R15: ffff880adfcbce43 FS: 00007f29b8042700(0000) GS:ffff880028200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000070 CR3: 0000000c613dc000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process amqzxma0 (pid: 13359, threadinfo ffff880c6ab32000, task ffff880c610deae0) Stack: ffff880adfcbce40 0000000000000000 ffff880c6ab337b8 ffffffff81219695 <d> 0000000000000000 ffff880a000000d0 ffff880c6ab337a8 000000000000000f <d> ffffffffa03afb93 000000000000000f ffff88186c7882c0 0000000000000014 Call Trace: [<ffffffff81219695>] request_key+0x65/0xa0 [<ffffffffa03a0885>] nfs_idmap_request_key+0xc5/0x170 [nfs] [<ffffffffa03a0eb4>] nfs_idmap_lookup_id+0x34/0x80 [nfs] [<ffffffffa03a1255>] nfs_map_group_to_gid+0x75/0xa0 [nfs] [<ffffffffa039a9ad>] decode_getfattr_attrs+0xbdd/0xfb0 [nfs] [<ffffffff81057310>] ? __dequeue_entity+0x30/0x50 [<ffffffff8100988e>] ? __switch_to+0x26e/0x320 [<ffffffffa039ae03>] decode_getfattr+0x83/0xe0 [nfs] [<ffffffffa039b610>] ? nfs4_xdr_dec_getattr+0x0/0xa0 [nfs] [<ffffffffa039b69f>] nfs4_xdr_dec_getattr+0x8f/0xa0 [nfs] [<ffffffffa02dada4>] rpcauth_unwrap_resp+0x84/0xb0 [sunrpc] [<ffffffffa039b610>] ? nfs4_xdr_dec_getattr+0x0/0xa0 [nfs] [<ffffffffa02cf923>] call_decode+0x1b3/0x800 [sunrpc] [<ffffffff81096de0>] ? wake_bit_function+0x0/0x50 [<ffffffffa02cf770>] ? call_decode+0x0/0x800 [sunrpc] [<ffffffffa02d99a7>] __rpc_execute+0x77/0x350 [sunrpc] [<ffffffff81096c67>] ? bit_waitqueue+0x17/0xd0 [<ffffffffa02d9ce1>] rpc_execute+0x61/0xa0 [sunrpc] [<ffffffffa02d03a5>] rpc_run_task+0x75/0x90 [sunrpc] [<ffffffffa02d04c2>] rpc_call_sync+0x42/0x70 [sunrpc] [<ffffffffa038ff80>] _nfs4_call_sync+0x30/0x40 [nfs] [<ffffffffa038836c>] _nfs4_proc_getattr+0xac/0xc0 [nfs] [<ffffffff810aac87>] ? futex_wait+0x227/0x380 [<ffffffffa038b856>] nfs4_proc_getattr+0x56/0x80 [nfs] [<ffffffffa0371403>] __nfs_revalidate_inode+0xe3/0x220 [nfs] [<ffffffffa037158e>] nfs_revalidate_mapping+0x4e/0x170 [nfs] [<ffffffffa036f147>] nfs_file_read+0x77/0x130 [nfs] [<ffffffff811811aa>] do_sync_read+0xfa/0x140 [<ffffffff81096da0>] ? autoremove_wake_function+0x0/0x40 [<ffffffff8100bb8e>] ? apic_timer_interrupt+0xe/0x20 [<ffffffff8100b9ce>] ? common_interrupt+0xe/0x13 [<ffffffff81228ffb>] ? selinux_file_permission+0xfb/0x150 [<ffffffff8121bed6>] ? security_file_permission+0x16/0x20 [<ffffffff81181a95>] vfs_read+0xb5/0x1a0 [<ffffffff81181bd1>] sys_read+0x51/0x90 [<ffffffff810dc685>] ? __audit_syscall_exit+0x265/0x290 [<ffffffff8100b072>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> cc: Dave Wysochanski <dwysocha@redhat.com> cc: Scott Mayhew <smayhew@redhat.com>
2013-10-30KEYS: Make BIG_KEYS booleanJosh Boyer
Having the big_keys functionality as a module is very marginally useful. The userspace code that would use this functionality will get odd error messages from the keys layer if the module isn't loaded. The code itself is fairly small, so just have this as a boolean option and not a tristate. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: David Howells <dhowells@redhat.com>
2013-10-29apparmor: remove the "task" arg from may_change_ptraced_domain()Oleg Nesterov
Unless task == current ptrace_parent(task) is not safe even under rcu_read_lock() and most of the current users are not right. So may_change_ptraced_domain(task) looks wrong as well. However it is always called with task == current so the code is actually fine. Remove this argument to make this fact clear. Note: perhaps we should simply kill ptrace_parent(), it buys almost nothing. And it is obviously racy, perhaps this should be fixed. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: John Johansen <john.johansen@canonical.com>
2013-10-29apparmor: remove parent task info from audit loggingJohn Johansen
The reporting of the parent task info is a vestage from old versions of apparmor. The need for this information was removed by unique null- profiles before apparmor was upstreamed so remove this info from logging. Signed-off-by: John Johansen <john.johansen@canonical.com>
2013-10-29apparmor: remove tsk field from the apparmor_audit_structJohn Johansen
Now that aa_capabile no longer sets the task field it can be removed and the lsm_audit version of the field can be used. Signed-off-by: John Johansen <john.johansen@canonical.com>
2013-10-29apparmor: fix capability to not use the current task, during reportingJohn Johansen
Mediation is based off of the cred but auditing includes the current task which may not be related to the actual request. Signed-off-by: John Johansen <john.johansen@canonical.com>
2013-10-30Merge branch 'smack-for-3.13' of git://git.gitorious.org/smack-next/kernel ↵James Morris
into ra-next
2013-10-28Smack: Ptrace access check modeCasey Schaufler
When the ptrace security hooks were split the addition of a mode parameter was not taken advantage of in the Smack ptrace access check. This changes the access check from always looking for read and write access to using the passed mode. This will make use of /proc much happier. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2013-10-26ima: provide hash algo info in the xattrDmitry Kasatkin
All files labeled with 'security.ima' hashes, are hashed using the same hash algorithm. Changing from one hash algorithm to another, requires relabeling the filesystem. This patch defines a new xattr type, which includes the hash algorithm, permitting different files to be hashed with different algorithms. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-26ima: enable support for larger default filedata hash algorithmsMimi Zohar
The IMA measurement list contains two hashes - a template data hash and a filedata hash. The template data hash is committed to the TPM, which is limited, by the TPM v1.2 specification, to 20 bytes. The filedata hash is defined as 20 bytes as well. Now that support for variable length measurement list templates was added, the filedata hash is not limited to 20 bytes. This patch adds Kconfig support for defining larger default filedata hash algorithms and replacing the builtin default with one specified on the kernel command line. <uapi/linux/hash_info.h> contains a list of hash algorithms. The Kconfig default hash algorithm is a subset of this list, but any hash algorithm included in the list can be specified at boot, using the 'ima_hash=' kernel command line option. Changelog v2: - update Kconfig Changelog: - support hashes that are configured - use generic HASH_ALGO_ definitions - add Kconfig support - hash_setup must be called only once (Dmitry) - removed trailing whitespaces (Roberto Sassu) Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
2013-10-26ima: define kernel parameter 'ima_template=' to change configured defaultRoberto Sassu
This patch allows users to specify from the kernel command line the template descriptor, among those defined, that will be used to generate and display measurement entries. If an user specifies a wrong template, IMA reverts to the template descriptor set in the kernel configuration. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-26ima: add Kconfig default measurement list templateMimi Zohar
This patch adds a Kconfig option to select the default IMA measurement list template. The 'ima' template limited the filedata hash to 20 bytes and the pathname to 255 charaters. The 'ima-ng' measurement list template permits larger hash digests and longer pathnames. Changelog: - keep 'select CRYPTO_HASH_INFO' in 'config IMA' section (Kconfig) (Roberto Sassu); - removed trailing whitespaces (Roberto Sassu). - Lindent fixes Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
2013-10-26ima: defer determining the appraisal hash algorithm for 'ima' templateRoberto Sassu
The same hash algorithm should be used for calculating the file data hash for the IMA measurement list, as for appraising the file data integrity. (The appraise hash algorithm is stored in the 'security.ima' extended attribute.) The exception is when the reference file data hash digest, stored in the extended attribute, is larger than the one supported by the template. In this case, the file data hash needs to be calculated twice, once for the measurement list and, again, for appraisal. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-26ima: add audit log support for larger hashesMimi Zohar
Different files might be signed based on different hash algorithms. This patch prefixes the audit log measurement hash with the hash algorithm. Changelog: - use generic HASH_ALGO defintions - use ':' as delimiter between the hash algorithm and the digest (Roberto Sassu) - always include the hash algorithm used when audit-logging a measurement Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Peter Moody <pmoody@google.com>
2013-10-25ima: switch to new template management mechanismRoberto Sassu
This patch performs the switch to the new template mechanism by modifying the functions ima_alloc_init_template(), ima_measurements_show() and ima_ascii_measurements_show(). The old function ima_template_show() was removed as it is no longer needed. Also, if the template descriptor used to generate a measurement entry is not 'ima', the whole length of field data stored for an entry is provided before the data itself through the binary_runtime_measurement interface. Changelog: - unnecessary to use strncmp() (Mimi Zohar) - create new variable 'field' in ima_alloc_init_template() (Roberto Sassu) - use GFP_NOFS flag in ima_alloc_init_template() (Roberto Sassu) - new variable 'num_fields' in ima_store_template() (Roberto Sassu, proposed by Mimi Zohar) - rename ima_calc_buffer_hash/template_hash() to ima_calc_field_array_hash(), something more generic (Mimi, requested by Dmitry) - sparse error fix - Fengguang Wu - fix lindent warnings - always include the field length in the template data length - include the template field length variable size in the template data length - include both the template field data and field length in the template digest calculation. Simplifies verifying the template digest. (Mimi) Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: define new template ima-ng and template fields d-ng and n-ngRoberto Sassu
This patch adds support for the new template 'ima-ng', whose format is defined as 'd-ng|n-ng'. These new field definitions remove the size limitations of the original 'ima' template. Further, the 'd-ng' field prefixes the inode digest with the hash algorithim, when displaying the new larger digest sizes. Change log: - scripts/Lindent fixes - Mimi - "always true comparison" - reported by Fengguang Wu, resolved Dmitry - initialize hash_algo variable to HASH_ALGO__LAST - always prefix digest with hash algorithm - Mimi Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: define template fields library and new helpersRoberto Sassu
This patch defines a library containing two initial template fields, inode digest (d) and file name (n), the 'ima' template descriptor, whose format is 'd|n', and two helper functions, ima_write_template_field_data() and ima_show_template_field_data(). Changelog: - replace ima_eventname_init() parameter NULL checking with BUG_ON. (suggested by Mimi) - include "new template fields for inode digest (d) and file name (n)" definitions to fix a compiler warning. - Mimi - unnecessary to prefix static function names with 'ima_'. remove prefix to resolve Lindent formatting changes. - Mimi - abbreviated/removed inline comments - Mimi - always send the template field length - Mimi Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: new templates management mechanismRoberto Sassu
The original 'ima' template is fixed length, containing the filedata hash and pathname. The filedata hash is limited to 20 bytes (md5/sha1). The pathname is a null terminated string, limited to 255 characters. To overcome these limitations and to add additional file metadata, it is necessary to extend the current version of IMA by defining additional templates. The main reason to introduce this feature is that, each time a new template is defined, the functions that generate and display the measurement list would include the code for handling a new format and, thus, would significantly grow over time. This patch set solves this problem by separating the template management from the remaining IMA code. The core of this solution is the definition of two new data structures: a template descriptor, to determine which information should be included in the measurement list, and a template field, to generate and display data of a given type. To define a new template field, developers define the field identifier and implement two functions, init() and show(), respectively to generate and display measurement entries. Initially, this patch set defines the following template fields (support for additional data types will be added later):  - 'd': the digest of the event (i.e. the digest of a measured file),         calculated with the SHA1 or MD5 hash algorithm;  - 'n': the name of the event (i.e. the file name), with size up to         255 bytes;  - 'd-ng': the digest of the event, calculated with an arbitrary hash            algorithm (field format: [<hash algo>:]digest, where the digest            prefix is shown only if the hash algorithm is not SHA1 or MD5);  - 'n-ng': the name of the event, without size limitations. Defining a new template descriptor requires specifying the template format, a string of field identifiers separated by the '|' character. This patch set defines the following template descriptors:  - "ima": its format is 'd|n';  - "ima-ng" (default): its format is 'd-ng|n-ng' Further details about the new template architecture can be found in Documentation/security/IMA-templates.txt. Changelog: - don't defer calling ima_init_template() - Mimi - don't define ima_lookup_template_desc() until used - Mimi - squashed with documentation patch - Mimi Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: define new function ima_alloc_init_template() to APIRoberto Sassu
Instead of allocating and initializing the template entry from multiple places (eg. boot aggregate, violation, and regular measurements), this patch defines a new function called ima_alloc_init_template(). The new function allocates and initializes the measurement entry with the inode digest and the filename. In respect to the current behavior, it truncates the file name passed in the 'filename' argument if the latter's size is greater than 255 bytes and the passed file descriptor is NULL. Changelog: - initialize 'hash' variable for non TPM case - Mimi - conform to expectation for 'iint' to be defined as a pointer. - Mimi - add missing 'file' dependency for recalculating file hash. - Mimi Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: pass the filename argument up to ima_add_template_entry()Roberto Sassu
Pass the filename argument to ima_add_template_entry() in order to eliminate a dependency on template specific data (third argument of integrity_audit_msg). This change is required because, with the new template management mechanism, the generation of a new measurement entry will be performed by new specific functions (introduced in next patches) and the current IMA code will not be aware anymore of how data is stored in the entry payload. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: pass the file descriptor to ima_add_violation()Roberto Sassu
Pass the file descriptor instead of the inode to ima_add_violation(), to make the latter consistent with ima_store_measurement() in preparation for the new template architecture. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: ima_calc_boot_agregate must use SHA1Dmitry Kasatkin
With multiple hash algorithms, ima_hash_tfm is no longer guaranteed to be sha1. Need to force to use sha1. Changelog: - pass ima_digest_data to ima_calc_boot_aggregate() instead of char * (Roberto Sassu); - create an ima_digest_data structure in ima_add_boot_aggregate() (Roberto Sassu); - pass hash->algo to ima_alloc_tfm() (Roberto Sassu, reported by Dmitry). - "move hash definition in ima_add_boot_aggregate()" commit hunk to here. - sparse warning fix - Fengguang Wu Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: support arbitrary hash algorithms in ima_calc_buffer_hashDmitry Kasatkin
ima_calc_buffer_hash will be used with different hash algorithms. This patch provides support for arbitrary hash algorithms in ima_calc_buffer_hash. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: provide dedicated hash algo allocation functionDmitry Kasatkin
This patch provides dedicated hash algo allocation and deallocation function which can be used by different clients. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: differentiate between template hash and file data hash sizesMimi Zohar
The TPM v1.2 limits the template hash size to 20 bytes. This patch differentiates between the template hash size, as defined in the ima_template_entry, and the file data hash size, as defined in the ima_template_data. Subsequent patches add support for different file data hash algorithms. Change log: - hash digest definition in ima_store_template() should be TPM_DIGEST_SIZE Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2013-10-25ima: use dynamically allocated hash storageDmitry Kasatkin
For each inode in the IMA policy, an iint is allocated. To support larger hash digests, the iint digest size changed from 20 bytes to the maximum supported hash digest size. Instead of allocating the maximum size, which most likely is not needed, this patch dynamically allocates the needed hash storage. Changelog: - fix krealloc bug Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: pass full xattr with the signatureDmitry Kasatkin
For possibility to use xattr type for new signature formats, pass full xattr to the signature verification function. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: read and use signature hash algorithmDmitry Kasatkin
All files on the filesystem, currently, are hashed using the same hash algorithm. In preparation for files from different packages being signed using different hash algorithms, this patch adds support for reading the signature hash algorithm from the 'security.ima' extended attribute and calculates the appropriate file data hash based on it. Changelog: - fix scripts Lindent and checkpatch msgs - Mimi - fix md5 support for older version, which occupied 20 bytes in the xattr, not the expected 16 bytes. Fix the comparison to compare only the first 16 bytes. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25ima: provide support for arbitrary hash algorithmsDmitry Kasatkin
In preparation of supporting more hash algorithms with larger hash sizes needed for signature verification, this patch replaces the 20 byte sized digest, with a more flexible structure. The new structure includes the hash algorithm, digest size, and digest. Changelog: - recalculate filedata hash for the measurement list, if the signature hash digest size is greater than 20 bytes. - use generic HASH_ALGO_ - make ima_calc_file_hash static - scripts lindent and checkpatch fixes Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25Revert "ima: policy for RAMFS"Mimi Zohar
This reverts commit 4c2c392763a682354fac65b6a569adec4e4b5387. Everything in the initramfs should be measured and appraised, but until the initramfs has extended attribute support, at least measured. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Cc: Stable Kernel <stable@kernel.org>
2013-10-25ima: fix script messagesDmitry Kasatkin
Fix checkpatch, lindent, etc, warnings/errors Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-24device_cgroup: remove can_attachSerge Hallyn
It is really only wanting to duplicate a check which is already done by the cgroup subsystem. With this patch, user jdoe still cannot move pid 1 into a devices cgroup he owns, but now he can move his own other tasks into devices cgroups. Signed-off-by: Serge Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Aristeu Rozanski <aris@redhat.com>
