In the small window between strnlen_user() and copy_from_user() userspace
could alter the terminating `\0' character.
Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com>
Cc: <stable@kernel.org>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Don't try to "validate" a non-existing timeval.
settime() with a NULL timeval is silly but legal.
Noticed by Dave Jones <davej@redhat.com>
[chrisw: seclvl only]
Permit add_key() to once again update a matching key rather than adding a
new one if a matching key already exists in the target keyring.
This bug causes add_key() to always add a new key, displacing the old from
the target keyring.
This patch extends the selinuxfs context interface to allow return the
canonical form of the context to userspace.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: James Morris <jmorris@namei.org>
This patch disables the setting of SELinux xattrs on files created in
filesystems labeled via mountpoint labeling (mounted with the context=
option). selinux_inode_setxattr already prevents explicit setxattr from
userspace on such filesystems, so this provides consistent behavior for
file creation.
This patch enables files created on a MLS-enabled SELinux system to be
accessible on a non-MLS SELinux system, by skipping the MLS component of
the security context in the non-MLS case.
This is the security/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in security/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: James Morris <jmorris@namei.org>
The attached patch removes a couple of incorrect and obsolete '!' operators
left over from the conversion of the key permission functions from
true/false returns to zero/error returns.
Signed-Off-By: David Howells <dhowells@redhat.com>
This patch simplifies some checks for magic siginfo values. It should not
change the behaviour in any way.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
This patch replaces hardcoded SEND_SIG_xxx constants with
their symbolic names.
No changes in affected .o files.
The attached patch adds LSM hooks for key management facilities. The notable
changes are:
(1) The key struct now supports a security pointer for the use of security
modules. This will permit key labelling and restrictions on which
programs may access a key.
(2) Security modules get a chance to note (or abort) the allocation of a key.
(3) The key permission checking can now be enhanced by the security modules;
the permissions check consults LSM if all other checks bear out.
(4) The key permissions checking functions now return an error code rather
than a boolean value.
(5) An extra permission has been added to govern the modification of
attributes (UID, GID, permissions).
Note that there isn't an LSM hook specifically for each keyctl() operation,
but rather the permissions hook allows control of individual operations based
on the permission request bits.
Key management access control through LSM is enabled by automatically if both
CONFIG_KEYS and CONFIG_SECURITY are enabled.
This should be applied on top of the patch ensubjected:
[PATCH] Keys: Possessor permissions should be additive
Signed-off-by: Chris Wright <chrisw@osdl.org>
Export user-defined key operations so that those who wish to define their
own key type based on the user-defined key operations may do so (as has
been requested).
The header file created has been placed into include/keys/user-type.h, thus
creating a directory where other key types may also be placed. Any
objections to doing this?
Signed-Off-By: Arjan van de Ven <arjan@infradead.org>
Now that RCU applied on 'struct file' seems stable, we can place f_rcuhead
in a memory location that is not anymore used at call_rcu(&f->f_rcuhead,
file_free_rcu) time, to reduce the size of this critical kernel object.
The trick I used is to move f_rcuhead and f_list in an union called f_u
The callers are changed so that f_rcuhead becomes f_u.fu_rcuhead and f_list
becomes f_u.f_list
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
This patch removes a bunch of unecessary checks for (size_t < 0) in
selinuxfs.
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
security/selinux/hooks.c: In function `selinux_inode_getxattr':
security/selinux/hooks.c:2193: warning: unused variable `sbsec'
Cc: Stephen Smalley <sds@tycho.nsa.gov>
This patch allows SELinux to canonicalize the value returned from
getxattr() via the security_inode_getsecurity() hook, which is called after
the fs level getxattr() function.
The purpose of this is to allow the in-core security context for an inode
to override the on-disk value. This could happen in cases such as
upgrading a system to a different labeling form (e.g. standard SELinux to
MLS) without needing to do a full relabel of the filesystem.
In such cases, we want getxattr() to return the canonical security context
that the kernel is using rather than what is stored on disk.
The implementation hooks into the inode_getsecurity(), adding another
parameter to indicate the result of the preceding fs-level getxattr() call,
so that SELinux knows whether to compare a value obtained from disk with
the kernel value.
We also now allow getxattr() to work for mountpoint labeled filesystems
(i.e. mount with option context=foo_t), as we are able to return the
kernel value to the user.
This patch converts SELinux code from kmalloc/memset to the new kazalloc
unction. On i386, this results in a text saving of over 1K.
Before:
86319 4642 15236 106197 19ed5 security/selinux/built-in.o
After:
85278 4642 15236 105156 19ac4 security/selinux/built-in.o
This patch fixes error handling in sel_make_bools(), where currently we'd
get a memory leak via security_get_bools() and try to kfree() the wrong
pointer if called again.
This patch fixes a possible NULL dereference in policydb_destroy, where
p->type_attr_map can be NULL if policydb_destroy is called to clean up a
partially loaded policy upon an error during policy load. Please apply.
This patch makes the possessor permissions on a key additive with
user/group/other permissions on the same key.
This permits extra rights to be granted to the possessor of a key without
taking away any rights conferred by them owning the key or having common group
membership.
The attached patch splits key permissions checking out of key-ui.h and
moves it into a .c file. It's quite large and called quite a lot, and
it's about to get bigger with the addition of LSM support for keys...
key_any_permission() is also discarded as it's no longer used.
The attached patch adds documentation for the process by which request-key
works, including how it permits helper processes to gain access to the
requestor's keyrings.
Plug request_key_auth memleak. This can be triggered by unprivileged
users, so is local DoS.
The following patch updates the way SELinux classifies and handles IP
based protocols.
Currently, IP sockets are classified by SELinux as being either TCP, UDP
or 'Raw', the latter being a default for IP socket that is not TCP or UDP.
The classification code is out of date and uses only the socket type
parameter to socket(2) to determine the class of IP socket. So, any
socket created with SOCK_STREAM will be classified by SELinux as TCP, and
SOCK_DGRAM as UDP. Also, other socket types such as SOCK_SEQPACKET and
SOCK_DCCP are currently ignored by SELinux, which classifies them as
generic sockets, which means they don't even get basic IP level checking.
This patch changes the SELinux IP socket classification logic, so that
only an IPPROTO_IP protocol value passed to socket(2) classify the socket
as TCP or UDP. The patch also drops the check for SOCK_RAW and converts
it into a default, so that socket types like SOCK_DCCP and SOCK_SEQPACKET
are classified as SECCLASS_RAWIP_SOCKET (instead of generic sockets).
Note that protocol-specific support for SCTP, DCCP etc. is not addressed
here, we're just getting these protocols checked at the IP layer.
This fixes a reported problem where SCTP sockets were being recognized as
generic SELinux sockets yet still being passed in one case to an IP level
check, which then fails for generic sockets.
It will also fix bugs where any SOCK_STREAM socket is classified as TCP or
any SOCK_DGRAM socket is classified as UDP.
This patch also unifies the way IP sockets classes are determined in
selinux_socket_bind(), so we use the already calculated value instead of
trying to recalculate it.
The attached patch adds extra permission grants to keys for the possessor of a
key in addition to the owner, group and other permissions bits. This makes
SUID binaries easier to support without going as far as labelling keys and key
targets using the LSM facilities.
This patch adds a second "pointer type" to key structures (struct key_ref *)
that can have the bottom bit of the address set to indicate the possession of
a key. This is propagated through searches from the keyring to the discovered
key. It has been made a separate type so that the compiler can spot attempts
to dereference a potentially incorrect pointer.
The "possession" attribute can't be attached to a key structure directly as
it's not an intrinsic property of a key.
Pointers to keys have been replaced with struct key_ref *'s wherever
possession information needs to be passed through.
This does assume that the bottom bit of the pointer will always be zero on
return from kmem_cache_alloc().
The key reference type has been made into a typedef so that at least it can be
located in the sources, even though it's basically a pointer to an undefined
type. I've also renamed the accessor functions to be more useful, and all
reference variables should now end in "_ref".
That should be -EINVAL for both.
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Cc: Greg KH <greg@kroah.com>
We don't put braces around single statements, thanks.
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: Chris Wright <chrisw@osdl.org>
With the use of RCU in files structure, the look-up of files using fds can now
be lock-free. The lookup is protected by rcu_read_lock()/rcu_read_unlock().
This patch changes the readers to use lock-free lookup.
Signed-off-by: Maneesh Soni <maneesh@in.ibm.com>
Signed-off-by: Ravikiran Thirumalai <kiran_th@gmail.com>
Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com>
In order for the RCU to work, the file table array, sets and their sizes must
be updated atomically. Instead of ensuring this through too many memory
barriers, we put the arrays and their sizes in a separate structure. This
patch takes the first step of putting the file table elements in a separate
structure fdtable that is embedded withing files_struct. It also changes all
the users to refer to the file table using files_fdtable() macro. Subsequent
applciation of RCU becomes easier after this.
This patch removes the inode_post_link and inode_post_rename LSM hooks as
they are unused (and likely useless).
This patch removes the inode_post_create/mkdir/mknod/symlink LSM hooks as
they are obsoleted by the new inode_init_security hook that enables atomic
inode security labeling.
If anyone sees any reason to retain these hooks, please speak now. Also,
is anyone using the post_rename/link hooks; if not, those could also be
removed.
This patch modifies tmpfs to call the inode_init_security LSM hook to set
up the incore inode security state for new inodes before the inode becomes
accessible via the dcache.
As there is no underlying storage of security xattrs in this case, it is
not necessary for the hook to return the (name, value, len) triple to the
tmpfs code, so this patch also modifies the SELinux hook function to
correctly handle the case where the (name, value, len) pointers are NULL.
The hook call is needed in tmpfs in order to support proper security
labeling of tmpfs inodes (e.g. for udev with tmpfs /dev in Fedora). With
this change in place, we should then be able to remove the
security_inode_post_create/mkdir/... hooks safely.
Cc: Hugh Dickins <hugh@veritas.com>
The following patch set enables atomic security labeling of newly created
inodes by altering the fs code to invoke a new LSM hook to obtain the security
attribute to apply to a newly created inode and to set up the incore inode
security state during the inode creation transaction. This parallels the
existing processing for setting ACLs on newly created inodes. Otherwise, it
is possible for new inodes to be accessed by another thread via the dcache
prior to complete security setup (presently handled by the
post_create/mkdir/... LSM hooks in the VFS) and a newly created inode may be
left unlabeled on the disk in the event of a crash. SELinux presently works
around the issue by ensuring that the incore inode security label is
initialized to a special SID that is inaccessible to unprivileged processes
(in accordance with policy), thereby preventing inappropriate access but
potentially causing false denials on legitimate accesses. A simple test
program demonstrates such false denials on SELinux, and the patch solves the
problem. Similar such false denials have been encountered in real
applications.
This patch defines a new inode_init_security LSM hook to obtain the security
security state for it, and adds a corresponding hook function implementation
to SELinux.
This patch adds endian notations to the SELinux code.
This patch improves memory use by SELinux by both reducing the avtab node
size and reducing the number of avtab nodes. The memory savings are
substantial, e.g. on a 64-bit system after boot, James Morris reported the
following data for the targeted and strict policies:
#objs objsize kernmem
Targeted:
Before: 237888 40 9.1MB
After: 19968 24 468KB
Strict:
Before: 571680 40 21.81MB
After: 221052 24 5.06MB
The improvement in memory use comes at a cost in the speed of security
server computations of access vectors, but these computations are only
required on AVC cache misses, and performance measurements by James Morris
using a number of benchmarks have shown that the change does not cause any
significant degradation.
Note that a rebuilt policy via an updated policy toolchain
(libsepol/checkpolicy) is required in order to gain the full benefits of
this patch, although some memory savings benefits are immediately applied
even to older policies (in particular, the reduction in avtab node size).
Sources for the updated toolchain are presently available from the
sourceforge CVS tree (http://sourceforge.net/cvs/?group_id=21266), and
tarballs are available from http://www.flux.utah.edu/~sds.
This patch goes through the current users of the crypto layer and sets
CRYPTO_TFM_REQ_MAY_SLEEP at crypto_alloc_tfm() where all crypto operations
are performed in process context.
Also, support dccp sockets.
netlink_broadcast users must initialize NETLINK_CB(skb).dst_groups to the
destination group mask for netlink_recvmsg.
- Remove bogus code for compiling netlink as module
- Add module refcounting support for modules implementing a netlink
protocol
- Add support for autoloading modules that implement a netlink protocol
as soon as someone opens a socket for that protocol
Signed-off-by: Harald Welte <laforge@netfilter.org>
CONFIG_SECURITY=y and CONFIG_SYSFS=n results in the following compile
error:
<-- snip -->
LD vmlinux
security/built-in.o: In function `securityfs_init':
inode.c:(.init.text+0x1c2): undefined reference to `kernel_subsys'
make: *** [vmlinux] Error 1
<-- snip -->
The attached patch makes sure that a keyring that failed to instantiate
properly is destroyed without oopsing [CAN-2005-2099].
The problem occurs in three stages:
(1) The key allocator initialises the type-specific data to all zeroes. In
the case of a keyring, this will become a link in the keyring name list
when the keyring is instantiated.
(2) If a user (any user) attempts to add a keyring with anything other than
an empty payload, the keyring instantiation function will fail with an
error and won't add the keyring to the name list.
(3) The keyring's destructor then sees that the keyring has a description
(name) and tries to remove the keyring from the name list, which oopses
because the link pointers are both zero.
This bug permits any user to take down a box trivially.
semaphore pinned
The attached patch prevents an error during the key session joining operation
from hanging future joins in the D state [CAN-2005-2098].
The problem is that the error handling path for the KEYCTL_JOIN_SESSION_KEYRING
operation has one error path that doesn't release the session management
semaphore. Further attempts to get the semaphore will then sleep for ever in
the D state.
This can happen in four situations, all involving an attempt to allocate a new
session keyring:
(1) ENOMEM.
(2) The users key quota being reached.
(3) A keyring name that is an empty string.
(4) A keyring name that is too long.
Any user may attempt this operation, and so any user can cause the problem to
occur.
This fixes five bugs in the key management syscall interface:
(1) add_key() returns 0 rather than EINVAL if the key type is "".
Checking the key type isn't "" should be left to lookup_user_key().
(2) request_key() returns ENOKEY rather than EPERM if the key type begins
with a ".".
lookup_user_key() can't do this because internal key types begin with a
(3) Key revocation always returns 0, even if it fails.
(4) Key read can return EAGAIN rather than EACCES under some circumstances.
A key is permitted to by read by a process if it doesn't grant read
access, but it does grant search access and it is in the process's
keyrings. That search returns EAGAIN if it fails, and this needs
translating to EACCES.
(5) request_key() never adds the new key to the destination keyring if one is
supplied.
The wrong macro was being used to test for an error condition: PTR_ERR()
will always return true, whether or not there's an error; this should've
been IS_ERR().
Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
