commit 6d1cff2a885850b78b40c34777b46cf5da5d1050 upstream.
We hit use after free on dereferncing pointer to task_smack struct in
smk_of_task() called from smack_task_to_inode().
task_security() macro uses task_cred_xxx() to get pointer to the task_smack.
task_cred_xxx() could be used only for non-pointer members of task's
credentials. It cannot be used for pointer members since what they point
to may disapper after dropping RCU read lock.
Mainly task_security() used this way:
smk_of_task(task_security(p))
Intead of this introduce function smk_of_task_struct() which
takes task_struct as argument and returns pointer to smk_known struct
and do this under RCU read lock.
Bogus task_security() macro is not used anymore, so remove it.
KASan's report for this:
AddressSanitizer: use after free in smack_task_to_inode+0x50/0x70 at addr c4635600
BUG kmalloc-64 (Tainted: PO): kasan error
Disabling lock debugging due to kernel taint
INFO: Allocated in new_task_smack+0x44/0xd8 age=39 cpu=0 pid=1866
kmem_cache_alloc_trace+0x88/0x1bc
smack_cred_prepare+0x48/0x21c
security_prepare_creds+0x44/0x4c
prepare_creds+0xdc/0x110
smack_setprocattr+0x104/0x150
security_setprocattr+0x4c/0x54
proc_pid_attr_write+0x12c/0x194
vfs_write+0x1b0/0x370
SyS_write+0x5c/0x94
ret_fast_syscall+0x0/0x48
INFO: Freed in smack_cred_free+0xc4/0xd0 age=27 cpu=0 pid=1564
kfree+0x270/0x290
security_cred_free+0x34/0x3c
put_cred_rcu+0x58/0xcc
rcu_process_callbacks+0x738/0x998
__do_softirq+0x264/0x4cc
do_softirq+0x94/0xf4
irq_exit+0xbc/0x120
handle_IRQ+0x104/0x134
gic_handle_irq+0x70/0xac
__irq_svc+0x44/0x78
_raw_spin_unlock+0x18/0x48
sync_inodes_sb+0x17c/0x1d8
sync_filesystem+0xac/0xfc
vdfs_file_fsync+0x90/0xc0
vfs_fsync_range+0x74/0x7c
INFO: Slab 0xd3b23f50 objects=32 used=31 fp=0xc4635600 flags=0x4080
INFO: Object 0xc4635600 @offset=5632 fp=0x (null)
Bytes b4 c46355f0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ
Object c4635600: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object c4635610: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object c4635620: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object c4635630: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5 kkkkkkkkkkkkkkk.
Redzone c4635640: bb bb bb bb ....
Padding c46356e8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZZZZZZZZZ
Padding c46356f8: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ
CPU: 5 PID: 834 Comm: launchpad_prelo Tainted: PBO 3.10.30 #1
Backtrace:
[<c00233a4>] (dump_backtrace+0x0/0x158) from [<c0023dec>] (show_stack+0x20/0x24)
r7:c4634010 r6:d3b23f50 r5:c4635600 r4:d1002140
[<c0023dcc>] (show_stack+0x0/0x24) from [<c06d6d7c>] (dump_stack+0x20/0x28)
[<c06d6d5c>] (dump_stack+0x0/0x28) from [<c01c1d50>] (print_trailer+0x124/0x144)
[<c01c1c2c>] (print_trailer+0x0/0x144) from [<c01c1e88>] (object_err+0x3c/0x44)
r7:c4635600 r6:d1002140 r5:d3b23f50 r4:c4635600
[<c01c1e4c>] (object_err+0x0/0x44) from [<c01cac18>] (kasan_report_error+0x2b8/0x538)
r6:d1002140 r5:d3b23f50 r4:c6429cf8 r3:c09e1aa7
[<c01ca960>] (kasan_report_error+0x0/0x538) from [<c01c9430>] (__asan_load4+0xd4/0xf8)
[<c01c935c>] (__asan_load4+0x0/0xf8) from [<c031e168>] (smack_task_to_inode+0x50/0x70)
r5:c4635600 r4:ca9da000
[<c031e118>] (smack_task_to_inode+0x0/0x70) from [<c031af64>] (security_task_to_inode+0x3c/0x44)
r5:cca25e80 r4:c0ba9780
[<c031af28>] (security_task_to_inode+0x0/0x44) from [<c023d614>] (pid_revalidate+0x124/0x178)
r6:00000000 r5:cca25e80 r4:cbabe3c0 r3:00008124
[<c023d4f0>] (pid_revalidate+0x0/0x178) from [<c01db98c>] (lookup_fast+0x35c/0x43y4)
r9:c6429efc r8:00000101 r7:c079d940 r6:c6429e90 r5:c6429ed8 r4:c83c4148
[<c01db630>] (lookup_fast+0x0/0x434) from [<c01deec8>] (do_last.isra.24+0x1c0/0x1108)
[<c01ded08>] (do_last.isra.24+0x0/0x1108) from [<c01dff04>] (path_openat.isra.25+0xf4/0x648)
[<c01dfe10>] (path_openat.isra.25+0x0/0x648) from [<c01e1458>] (do_filp_open+0x3c/0x88)
[<c01e141c>] (do_filp_open+0x0/0x88) from [<c01ccb28>] (do_sys_open+0xf0/0x198)
r7:00000001 r6:c0ea2180 r5:0000000b r4:00000000
[<c01cca38>] (do_sys_open+0x0/0x198) from [<c01ccc00>] (SyS_open+0x30/0x34)
[<c01ccbd0>] (SyS_open+0x0/0x34) from [<c001db80>] (ret_fast_syscall+0x0/0x48)
Read of size 4 by thread T834:
Memory state around the buggy address:
c4635380: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
c4635400: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc
c4635480: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
c4635500: 00 00 00 00 00 fc fc fc fc fc fc fc fc fc fc fc
c4635580: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>c4635600: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
c4635680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
c4635700: 00 00 00 00 04 fc fc fc fc fc fc fc fc fc fc fc
c4635780: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
c4635800: 00 00 00 00 00 00 04 fc fc fc fc fc fc fc fc fc
c4635880: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
When a key is being garbage collected, it's key->user would get put before
the ->destroy() callback is called, where the key is removed from it's
respective tracking structures.
This leaves a key hanging in a semi-invalid state which leaves a window open
for a different task to try an access key->user. An example is
find_keyring_by_name() which would dereference key->user for a key that is
in the process of being garbage collected (where key->user was freed but
->destroy() wasn't called yet - so it's still present in the linked list).
This would cause either a panic, or corrupt memory.
Fixes CVE-2014-9529.
We already checked if "desc" was NULL at the beginning of the function
and we've dereferenced it so this causes a static checker warning.
Signed-off-by: James Morris <james.l.morris@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into for-linus
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security layer updates from James Morris:
"In terms of changes, there's general maintenance to the Smack,
SELinux, and integrity code.
The IMA code adds a new kconfig option, IMA_APPRAISE_SIGNED_INIT,
which allows IMA appraisal to require signatures. Support for reading
keys from rootfs before init is call is also added"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits)
selinux: Remove security_ops extern
security: smack: fix out-of-bounds access in smk_parse_smack()
VFS: refactor vfs_read()
ima: require signature based appraisal
integrity: provide a hook to load keys when rootfs is ready
ima: load x509 certificate from the kernel
integrity: provide a function to load x509 certificate from the kernel
integrity: define a new function integrity_read_file()
Security: smack: replace kzalloc with kmem_cache for inode_smack
Smack: Lock mode for the floor and hat labels
ima: added support for new kernel cmdline parameter ima_template_fmt
ima: allocate field pointers array on demand in template_desc_init_fields()
ima: don't allocate a copy of template_fmt in template_desc_init_fields()
ima: display template format in meas. list if template name length is zero
ima: added error messages to template-related functions
ima: use atomic bit operations to protect policy update interface
ima: ignore empty and with whitespaces policy lines
ima: no need to allocate entry for comment
ima: report policy load status
ima: use path names cache
Pull VFS changes from Al Viro:
"First pile out of several (there _definitely_ will be more). Stuff in
this one:
- unification of d_splice_alias()/d_materialize_unique()
- iov_iter rewrite
- killing a bunch of ->f_path.dentry users (and f_dentry macro).
Getting that completed will make life much simpler for
unionmount/overlayfs, since then we'll be able to limit the places
sensitive to file _dentry_ to reasonably few. Which allows to have
file_inode(file) pointing to inode in a covered layer, with dentry
pointing to (negative) dentry in union one.
Still not complete, but much closer now.
- crapectomy in lustre (dead code removal, mostly)
- "let's make seq_printf return nothing" preparations
- assorted cleanups and fixes
There _definitely_ will be more piles"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
copy_from_iter_nocache()
new helper: iov_iter_kvec()
csum_and_copy_..._iter()
iov_iter.c: handle ITER_KVEC directly
iov_iter.c: convert copy_to_iter() to iterate_and_advance
iov_iter.c: convert copy_from_iter() to iterate_and_advance
iov_iter.c: get rid of bvec_copy_page_{to,from}_iter()
iov_iter.c: convert iov_iter_zero() to iterate_and_advance
iov_iter.c: convert iov_iter_get_pages_alloc() to iterate_all_kinds
iov_iter.c: convert iov_iter_get_pages() to iterate_all_kinds
iov_iter.c: convert iov_iter_npages() to iterate_all_kinds
iov_iter.c: iterate_and_advance
iov_iter.c: macros for iterating over iov_iter
kill f_dentry macro
dcache: fix kmemcheck warning in switch_names
new helper: audit_file()
nfsd_vfs_write(): use file_inode()
ncpfs: use file_inode()
kill f_dentry uses
lockd: get rid of ->f_path.dentry->d_sb
On powerpc we can end up with IMA=y and PPC_PSERIES=n which leads to:
warning: (IMA) selects TCG_IBMVTPM which has unmet direct dependencies (TCG_TPM && PPC_PSERIES)
tpm_ibmvtpm.c:(.text+0x14f3e8): undefined reference to `.plpar_hcall_norets'
I'm not sure why IMA needs to select those user-visible symbols, but if
it must then the simplest fix is to just express the proper dependencies
on the select.
Tested-by: Hon Ching (Vicky) Lo <lo1@us.ibm.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
When loading encrypted-keys module, if the last check of
aes_get_sizes() in init_encrypted() fails, the driver just returns an
error without unregistering its key type. This results in the stale
entry in the list. In addition to memory leaks, this leads to a kernel
crash when registering a new key type later.
This patch fixes the problem by swapping the calls of aes_get_sizes()
and register_key_type(), and releasing resources properly at the error
paths.
Bugzilla: https://bugzilla.opensuse.org/show_bug.cgi?id=908163
Cc: <stable@vger.kernel.org>
Since the keyring facility can be viewed as a cache (at least in some
applications), the local expiration time on the key should probably be viewed
as a 'needs updating after this time' property rather than an absolute 'anyone
now wanting to use this object is out of luck' property.
Since request_key() is the main interface for the usage of keys, this should
update or replace an expired key rather than issuing EKEYEXPIRED if the local
expiration has been reached (ie. it should refresh the cache).
For absolute conditions where refreshing the cache probably doesn't help, the
key can be negatively instantiated using KEYCTL_REJECT_KEY with EKEYEXPIRED
given as the error to issue. This will still cause request_key() to return
EKEYEXPIRED as that was explicitly set.
In the future, if the key type has an update op available, we might want to
upcall with the expired key and allow the upcall to update it. We would pass
a different operation name (the first column in /etc/request-key.conf) to the
request-key program.
request_key() returning EKEYEXPIRED is causing an NFS problem which Chuck
Lever describes thusly:
After about 10 minutes, my NFSv4 functional tests fail because the
ownership of the test files goes to "-2". Looking at /proc/keys
shows that the id_resolv keys that map to my test user ID have
expired. The ownership problem persists until the expired keys are
purged from the keyring, and fresh keys are obtained.
I bisected the problem to 3.13 commit b2a4df200d57 ("KEYS: Expand
the capacity of a keyring"). This commit inadvertantly changes the
API contract of the internal function keyring_search_aux().
The root cause appears to be that b2a4df200d57 made "no state check"
the default behavior. "No state check" means the keyring search
iterator function skips checking the key's expiry timeout, and
returns expired keys. request_key_and_link() depends on getting
an -EAGAIN result code to know when to perform an upcall to refresh
an expired key.
This patch can be tested directly by:
keyctl request2 user debug:fred a @s
keyctl timeout %user:debug:fred 3
sleep 4
Without the patch, the last command gives error EKEYEXPIRED, but with the
command it gives a new key.
Reported-by: Carl Hetherington <cth@carlh.net>
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Tested-by: Chuck Lever <chuck.lever@oracle.com>
Simplify KEYRING_SEARCH_{NO,DO}_STATE_CHECK flags to be two variations of the
same flag. They are effectively mutually exclusive and one or the other
should be provided, but not both.
Keyring cycle detection and key possession determination are the only things
that set NO_STATE_CHECK, except that neither flag really does anything there
because neither purpose makes use of the keyring_search_iterator() function,
but rather provides their own.
For cycle detection we definitely want to check inside of expired keyrings,
just so that we don't create a cycle we can't get rid of. Revoked keyrings
are cleared at revocation time and can't then be reused, so shouldn't be a
problem either way.
For possession determination, we *might* want to validate each keyring before
searching it: do you possess a key that's hidden behind an expired or just
plain inaccessible keyring? Currently, the answer is yes. Note that you
cannot, however, possess a key behind a revoked keyring because they are
cleared on revocation.
keyring_search() sets DO_STATE_CHECK, which is correct.
request_key_and_link() currently doesn't specify whether to check the key
state or not - but it should set DO_STATE_CHECK.
key_get_instantiation_authkey() also currently doesn't specify whether to
check the key state or not - but it probably should also set DO_STATE_CHECK.
When a key description argument is imported into the kernel from userspace, as
happens in add_key(), request_key(), KEYCTL_JOIN_SESSION_KEYRING,
KEYCTL_SEARCH, the description is copied into a buffer up to PAGE_SIZE in size.
PAGE_SIZE, however, is a variable quantity, depending on the arch. Fix this at
4096 instead (ie. 4095 plus a NUL termination) and define a constant
(KEY_MAX_DESC_SIZE) to this end.
When reading the description back with KEYCTL_DESCRIBE, a PAGE_SIZE internal
buffer is allocated into which the information and description will be
rendered. This means that the description will get truncated if an extremely
long description it has to be crammed into the buffer with the stringified
information. There is no particular need to copy the description into the
buffer, so just copy it directly to userspace in a separate operation.
Reported-by: Christian Kastner <debian@kvr.at>
Tested-by: Christian Kastner <debian@kvr.at>
security_ops is not used in this file.
Signed-off-by: Yao Dongdong <yaodongdong@huawei.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
into next
Setting smack label on file (e.g. 'attr -S -s SMACK64 -V "test" test')
triggered following spew on the kernel with KASan applied:
BUG: AddressSanitizer: out of bounds access in strncpy+0x28/0x60 at addr ffff8800059ad064
BUG kmalloc-8 (Not tainted): kasan error
INFO: Slab 0xffffea0000166b40 objects=128 used=7 fp=0xffff8800059ad080 flags=0x4000000000000080
INFO: Object 0xffff8800059ad060 @offset=96 fp=0xffff8800059ad080
Bytes b4 ffff8800059ad050: a0 df 9a 05 00 88 ff ff 5a 5a 5a 5a 5a 5a 5a 5a ........ZZZZZZZZ
Object ffff8800059ad060: 74 65 73 74 6b 6b 6b a5 testkkk.
Redzone ffff8800059ad068: cc cc cc cc cc cc cc cc ........
Padding ffff8800059ad078: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ
CPU: 0 PID: 528 Comm: attr Tainted: G B 3.18.0-rc1-mm1+ #5
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
0000000000000000 ffff8800059ad064 ffffffff81534cf2 ffff880005a5bc40
ffffffff8112fe1a 0000000100800006 0000000f059ad060 ffff880006000f90
0000000000000296 ffffea0000166b40 ffffffff8107ca97 ffff880005891060
Call Trace:
? dump_stack (lib/dump_stack.c:52)
? kasan_report_error (mm/kasan/report.c:102 mm/kasan/report.c:178)
? preempt_count_sub (kernel/sched/core.c:2651)
? __asan_load1 (mm/kasan/kasan.h:50 mm/kasan/kasan.c:248 mm/kasan/kasan.c:358)
? strncpy (lib/string.c:121)
? smk_parse_smack (security/smack/smack_access.c:457)
? setxattr (fs/xattr.c:343)
? smk_import_entry (security/smack/smack_access.c:514)
? smack_inode_setxattr (security/smack/smack_lsm.c:1093 (discriminator 1))
? security_inode_setxattr (security/security.c:602)
? vfs_setxattr (fs/xattr.c:134)
? setxattr (fs/xattr.c:360)
? get_parent_ip (kernel/sched/core.c:2606)
? __percpu_counter_add (arch/x86/include/asm/preempt.h:98 lib/percpu_counter.c:90)
? __mnt_want_write (arch/x86/include/asm/preempt.h:98 fs/namespace.c:359)
? path_setxattr (fs/xattr.c:380)
? SyS_lsetxattr (fs/xattr.c:397)
? system_call_fastpath (arch/x86/kernel/entry_64.S:423)
Read of size 1 by task attr:
ffff8800059ace80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8800059acf00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8800059acf80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffff8800059ad000: 00 fc fc fc 00 fc fc fc 05 fc fc fc 04 fc fc fc
ffff8800059ad080: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8800059ad100: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8800059ad180: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
strncpy() copies one byte more than the source string has.
Fix this by passing the correct length to strncpy().
Now we can remove initialization of the last byte in 'smack' string
because kzalloc() already did this for us.
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into next
integrity_kernel_read() duplicates the file read operations code
in vfs_read(). This patch refactors vfs_read() code creating a
helper function __vfs_read(). It is used by both vfs_read() and
integrity_kernel_read().
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
This patch provides CONFIG_IMA_APPRAISE_SIGNED_INIT kernel configuration
option to force IMA appraisal using signatures. This is useful, when EVM
key is not initialized yet and we want securely initialize integrity or
any other functionality.
It forces embedded policy to require signature. Signed initialization
script can initialize EVM key, update the IMA policy and change further
requirement of everything to be signed.
Changes in v3:
* kernel parameter fixed to configuration option in the patch description
Changes in v2:
* policy change of this patch separated from the key loading patch
Keys can only be loaded once the rootfs is mounted. Initcalls
are not suitable for that. This patch defines a special hook
to load the x509 public keys onto the IMA keyring, before
attempting to access any file. The keys are required for
verifying the file's signature. The hook is called after the
root filesystem is mounted and before the kernel calls 'init'.
Changes in v3:
* added more explanation to the patch description (Mimi)
Changes in v2:
* Hook renamed as 'integrity_load_keys()' to handle both IMA and EVM
keys by integrity subsystem.
* Hook patch moved after defining loading functions
Define configuration option to load X509 certificate into the
IMA trusted kernel keyring. It implements ima_load_x509() hook
to load X509 certificate into the .ima trusted kernel keyring
from the root filesystem.
Changes in v3:
* use ima_policy_flag in ima_get_action()
ima_load_x509 temporarily clears ima_policy_flag to disable
appraisal to load key. Use it to skip appraisal rules.
* Key directory path changed to /etc/keys (Mimi)
* Expand IMA_LOAD_X509 Kconfig help
Changes in v2:
* added '__init'
* use ima_policy_flag to disable appraisal to load keys
Provide the function to load x509 certificates from the kernel into the
integrity kernel keyring.
Changes in v2:
* configuration option removed
* function declared as '__init'
This patch defines a new function called integrity_read_file()
to read file from the kernel into a buffer. Subsequent patches
will read a file containing the public keys and load them onto
the IMA keyring.
This patch moves and renames ima_kernel_read(), the non-security
checking version of kernel_read(), to integrity_kernel_read().
Changes in v3:
* Patch descriptions improved (Mimi)
* Add missing cast (kbuild test robot)
Changes in v2:
into for-linus
Convert WARN_ONCE() to printk() in selinux_nlmsg_perm().
After conversion from audit_log() in commit e173fb26, WARN_ONCE() was
deemed too alarmist, so switch it to printk().
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
[PM: Changed to printk(WARNING) so we catch all of the different
invalid netlink messages. In Richard's defense, he brought this
point up earlier, but I didn't understand his point at the time.]
The patch use kmem_cache to allocate/free inode_smack since they are
alloced in high volumes making it a perfect case for kmem_cache.
As per analysis, 24 bytes of memory is wasted per allocation due
to internal fragmentation. With kmem_cache, this can be avoided.
Accounting of memory allocation is below :
total slack net count-alloc/free caller
Before (with kzalloc)
1919872 719952 1919872 29998/0 new_inode_smack+0x14
After (with kmem_cache)
1201680 0 1201680 30042/0 new_inode_smack+0x18
>From above data, we found that 719952 bytes(~700 KB) of memory is
saved on allocation of 29998 smack inodes.
Signed-off-by: Rohit <rohit.kr@samsung.com>
The lock access mode allows setting a read lock on a file
for with the process has only read access. The floor label is
defined to make it easy to have the basic system installed such
that everyone can read it. Once there's a desire to read lock
(rationally or otherwise) a floor file a rule needs to get set.
This happens all the time, so make the floor label a little bit
more special and allow everyone lock access, too. By implication,
give processes with the hat label (hat can read everything)
lock access as well. This reduces clutter in the Smack rule set.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
evm_inode_setxattr() can be called with no value. The function does not
check the length so that following command can be used to produce the
kernel oops: setfattr -n security.evm FOO. This patch fixes it.
Changes in v3:
* there is no reason to return different error codes for EVM_XATTR_HMAC
and non EVM_XATTR_HMAC. Remove unnecessary test then.
Changes in v2:
* testing for validity of xattr type
[ 1106.396921] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1106.398192] IP: [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.399244] PGD 29048067 PUD 290d7067 PMD 0
[ 1106.399953] Oops: 0000 [#1] SMP
[ 1106.400020] Modules linked in: bridge stp llc evdev serio_raw i2c_piix4 button fuse
[ 1106.400020] CPU: 0 PID: 3635 Comm: setxattr Not tainted 3.16.0-kds+ #2936
[ 1106.400020] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 1106.400020] task: ffff8800291a0000 ti: ffff88002917c000 task.ti: ffff88002917c000
[ 1106.400020] RIP: 0010:[<ffffffff812af7b8>] [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.400020] RSP: 0018:ffff88002917fd50 EFLAGS: 00010246
[ 1106.400020] RAX: 0000000000000000 RBX: ffff88002917fdf8 RCX: 0000000000000000
[ 1106.400020] RDX: 0000000000000000 RSI: ffffffff818136d3 RDI: ffff88002917fdf8
[ 1106.400020] RBP: ffff88002917fd68 R08: 0000000000000000 R09: 00000000003ec1df
[ 1106.400020] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8800438a0a00
[ 1106.400020] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 1106.400020] FS: 00007f7dfa7d7740(0000) GS:ffff88005da00000(0000) knlGS:0000000000000000
[ 1106.400020] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1106.400020] CR2: 0000000000000000 CR3: 000000003763e000 CR4: 00000000000006f0
[ 1106.400020] Stack:
[ 1106.400020] ffff8800438a0a00 ffff88002917fdf8 0000000000000000 ffff88002917fd98
[ 1106.400020] ffffffff812a1030 ffff8800438a0a00 ffff88002917fdf8 0000000000000000
[ 1106.400020] 0000000000000000 ffff88002917fde0 ffffffff8116d08a ffff88002917fdc8
[ 1106.400020] Call Trace:
[ 1106.400020] [<ffffffff812a1030>] security_inode_setxattr+0x5d/0x6a
[ 1106.400020] [<ffffffff8116d08a>] vfs_setxattr+0x6b/0x9f
[ 1106.400020] [<ffffffff8116d1e0>] setxattr+0x122/0x16c
[ 1106.400020] [<ffffffff811687e8>] ? mnt_want_write+0x21/0x45
[ 1106.400020] [<ffffffff8114d011>] ? __sb_start_write+0x10f/0x143
[ 1106.400020] [<ffffffff811687c0>] ? __mnt_want_write+0x48/0x4f
[ 1106.400020] [<ffffffff8116d3e6>] SyS_setxattr+0x6e/0xb0
[ 1106.400020] [<ffffffff81529da9>] system_call_fastpath+0x16/0x1b
[ 1106.400020] Code: c3 0f 1f 44 00 00 55 48 89 e5 41 55 49 89 d5 41 54 49 89 fc 53 48 89 f3 48 c7 c6 d3 36 81 81 48 89 df e8 18 22 04 00 85 c0 75 07 <41> 80 7d 00 02 74 0d 48 89 de 4c 89 e7 e8 5a fe ff ff eb 03 83
[ 1106.400020] RIP [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.400020] RSP <ffff88002917fd50>
[ 1106.428061] ---[ end trace ae08331628ba3050 ]---
Reported-by: Jan Kara <jack@suse.cz>
Cc: stable@vger.kernel.org
ima_inode_setxattr() can be called with no value. Function does not
kernel oops: setfattr -n security.ima FOO. This patch fixes it.
Changes in v3:
* for stable reverted "allow setting hash only in fix or log mode"
It will be a separate patch.
Changes in v2:
* testing validity of xattr type
* allow setting hash only in fix or log mode (Mimi)
[ 261.562522] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 261.564109] IP: [<ffffffff812af272>] ima_inode_setxattr+0x3e/0x5a
[ 261.564109] PGD 3112f067 PUD 42965067 PMD 0
[ 261.564109] Oops: 0000 [#1] SMP
[ 261.564109] Modules linked in: bridge stp llc evdev serio_raw i2c_piix4 button fuse
[ 261.564109] CPU: 0 PID: 3299 Comm: setxattr Not tainted 3.16.0-kds+ #2924
[ 261.564109] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 261.564109] task: ffff8800428c2430 ti: ffff880042be0000 task.ti: ffff880042be0000
[ 261.564109] RIP: 0010:[<ffffffff812af272>] [<ffffffff812af272>] ima_inode_setxattr+0x3e/0x5a
[ 261.564109] RSP: 0018:ffff880042be3d50 EFLAGS: 00010246
[ 261.564109] RAX: 0000000000000001 RBX: 0000000000000000 RCX: 0000000000000015
[ 261.564109] RDX: 0000001500000000 RSI: 0000000000000000 RDI: ffff8800375cc600
[ 261.564109] RBP: ffff880042be3d68 R08: 0000000000000000 R09: 00000000004d6256
[ 261.564109] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88002149ba00
[ 261.564109] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 261.564109] FS: 00007f6c1e219740(0000) GS:ffff88005da00000(0000) knlGS:0000000000000000
[ 261.564109] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 261.564109] CR2: 0000000000000000 CR3: 000000003b35a000 CR4: 00000000000006f0
[ 261.564109] Stack:
[ 261.564109] ffff88002149ba00 ffff880042be3df8 0000000000000000 ffff880042be3d98
[ 261.564109] ffffffff812a101b ffff88002149ba00 ffff880042be3df8 0000000000000000
[ 261.564109] 0000000000000000 ffff880042be3de0 ffffffff8116d08a ffff880042be3dc8
[ 261.564109] Call Trace:
[ 261.564109] [<ffffffff812a101b>] security_inode_setxattr+0x48/0x6a
[ 261.564109] [<ffffffff8116d08a>] vfs_setxattr+0x6b/0x9f
[ 261.564109] [<ffffffff8116d1e0>] setxattr+0x122/0x16c
[ 261.564109] [<ffffffff811687e8>] ? mnt_want_write+0x21/0x45
[ 261.564109] [<ffffffff8114d011>] ? __sb_start_write+0x10f/0x143
[ 261.564109] [<ffffffff811687c0>] ? __mnt_want_write+0x48/0x4f
[ 261.564109] [<ffffffff8116d3e6>] SyS_setxattr+0x6e/0xb0
[ 261.564109] [<ffffffff81529da9>] system_call_fastpath+0x16/0x1b
[ 261.564109] Code: 48 89 f7 48 c7 c6 58 36 81 81 53 31 db e8 73 27 04 00 85 c0 75 28 bf 15 00 00 00 e8 8a a5 d9 ff 84 c0 75 05 83 cb ff eb 15 31 f6 <41> 80 7d 00 03 49 8b 7c 24 68 40 0f 94 c6 e8 e1 f9 ff ff 89 d8
[ 261.564109] RIP [<ffffffff812af272>] ima_inode_setxattr+0x3e/0x5a
[ 261.564109] RSP <ffff880042be3d50>
[ 261.599998] ---[ end trace 39a89a3fc267e652 ]---
into for-linus2
sb_finish_set_opts() can race with inode_free_security()
when initializing inode security structures for inodes
created prior to initial policy load or by the filesystem
during ->mount(). This appears to have always been
a possible race, but commit 3dc91d4 ("SELinux: Fix possible
NULL pointer dereference in selinux_inode_permission()")
made it more evident by immediately reusing the unioned
list/rcu element of the inode security structure for call_rcu()
upon an inode_free_security(). But the underlying issue
was already present before that commit as a possible use-after-free
of isec.
Shivnandan Kumar reported the list corruption and proposed
a patch to split the list and rcu elements out of the union
as separate fields of the inode_security_struct so that setting
the rcu element would not affect the list element. However,
this would merely hide the issue and not truly fix the code.
This patch instead moves up the deletion of the list entry
prior to dropping the sbsec->isec_lock initially. Then,
if the inode is dropped subsequently, there will be no further
references to the isec.
Reported-by: Shivnandan Kumar <shivnandan.k@samsung.com>
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Replaced the use of a Variable Length Array In Struct (VLAIS) with a C99
compliant equivalent. This patch allocates the appropriate amount of memory
using a char array using the SHASH_DESC_ON_STACK macro.
The new code can be compiled with both gcc and clang.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Reviewed-by: Mark Charlebois <charlebm@gmail.com>
Reviewed-by: Jan-Simon Möller <dl9pf@gmx.de>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Cc: tglx@linutronix.de
This patch allows users to provide a custom template format through the
new kernel command line parameter 'ima_template_fmt'. If the supplied
format is not valid, IMA uses the default template descriptor.
Changelog:
- v3:
- added check for 'fields' and 'num_fields' in
template_desc_init_fields() (suggested by Mimi Zohar)
- v2:
- using template_desc_init_fields() to validate a format string
(Roberto Sassu)
- updated documentation by stating that only the chosen template
descriptor is initialized (Roberto Sassu)
- v1:
- simplified code of ima_template_fmt_setup()
(Roberto Sassu, suggested by Mimi Zohar)
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
The allocation of a field pointers array is moved at the end of
template_desc_init_fields() and done only if the value of the 'fields'
and 'num_fields' parameters is not NULL. For just validating a template
format string, retrieved template field pointers are placed in a temporary
array.
Changelog:
- v3:
- do not check in this patch if 'fields' and 'num_fields' are NULL
This patch removes the allocation of a copy of 'template_fmt', needed for
iterating over all fields in the passed template format string. The removal
was possible by replacing strcspn(), which modifies the passed string,
with strchrnul(). The currently processed template field is copied in
a temporary variable.
The purpose of this change is use template_desc_init_fields() in two ways:
for just validating a template format string (the function should work
if called by a setup function, when memory cannot be allocated), and for
actually initializing a template descriptor. The implementation of this
feature will be complete with the next patch.
Changelog:
- v3:
- added 'goto out' in template_desc_init_fields() to free allocated
memory if a template field length is not valid (suggested by
Mimi Zohar)
With the introduction of the 'ima_template_fmt' kernel cmdline parameter,
a user can define a new template descriptor with custom format. However,
in this case, userspace tools will be unable to parse the measurements
list because the new template is unknown. For this reason, this patch
modifies the current IMA behavior to display in the list the template
format instead of the name (only if the length of the latter is zero)
so that a tool can extract needed information if it can handle listed
fields.
This patch also correctly displays the error log message in
ima_init_template() if the selected template cannot be initialized.
Changelog:
- v3:
- check the first byte of 'e->template_desc->name' instead of using
strlen() in ima_fs.c (suggested by Mimi Zohar)
- v2:
- print the template format in ima_init_template(), if the selected
template is custom (Roberto Sassu)
- v1:
- fixed patch description (Roberto Sassu, suggested by Mimi Zohar)
- set 'template_name' variable in ima_fs.c only once
This patch adds some error messages to inform users about the following
events: template descriptor not found, invalid template descriptor,
template field not found and template initialization failed.
Changelog:
- v2:
- display an error message if the format string contains too many
fields (Roberto Sassu)
Pull security subsystem updates from James Morris.
Mostly ima, selinux, smack and key handling updates.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits)
integrity: do zero padding of the key id
KEYS: output last portion of fingerprint in /proc/keys
KEYS: strip 'id:' from ca_keyid
KEYS: use swapped SKID for performing partial matching
KEYS: Restore partial ID matching functionality for asymmetric keys
X.509: If available, use the raw subjKeyId to form the key description
KEYS: handle error code encoded in pointer
selinux: normalize audit log formatting
selinux: cleanup error reporting in selinux_nlmsg_perm()
KEYS: Check hex2bin()'s return when generating an asymmetric key ID
ima: detect violations for mmaped files
ima: fix race condition on ima_rdwr_violation_check and process_measurement
ima: added ima_policy_flag variable
ima: return an error code from ima_add_boot_aggregate()
ima: provide 'ima_appraise=log' kernel option
ima: move keyring initialization to ima_init()
PKCS#7: Handle PKCS#7 messages that contain no X.509 certs
PKCS#7: Better handling of unsupported crypto
KEYS: Overhaul key identification when searching for asymmetric keys
KEYS: Implement binary asymmetric key ID handling
The current implementation uses an atomic counter to provide exclusive
access to the sysfs 'policy' entry to update the IMA policy. While it is
highly unlikely, the usage of a counter might potentially allow another
process to overflow the counter, open the interface and insert additional
rules into the policy being loaded.
This patch replaces using an atomic counter with atomic bit operations
which is more reliable and a widely used method to provide exclusive access.
As bit operation keep the interface locked after successful update, it makes
it unnecessary to verify if the default policy was set or not during parsing
and interface closing. This patch also removes that code.
Changes in v3:
* move audit log message to ima_relead_policy() to report successful and
unsuccessful result
* unnecessary comment removed
Changes in v2:
* keep interface locked after successful policy load as in original design
* remove sysfs entry as in original design
Empty policy lines cause parsing failures which is, especially
for new users, hard to spot. This patch prevents it.
Changes in v2:
* strip leading blanks and tabs in rules to prevent parsing failures
If a rule is a comment, there is no need to allocate an entry.
Move the checking for comments before allocating the entry.
Audit messages are rate limited, often causing the policy update
info to not be visible. Report policy loading status also using
pr_info.
Changes in v2:
* reporting moved to ima_release_policy to notice parsing errors
* reporting both completed and failed status
Pull file locking related changes from Jeff Layton:
"This release is a little more busy for file locking changes than the
last:
- a set of patches from Kinglong Mee to fix the lockowner handling in
knfsd
- a pile of cleanups to the internal file lease API. This should get
us a bit closer to allowing for setlease methods that can block.
There are some dependencies between mine and Bruce's trees this cycle,
and I based my tree on top of the requisite patches in Bruce's tree"
* tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linux: (26 commits)
locks: fix fcntl_setlease/getlease return when !CONFIG_FILE_LOCKING
locks: flock_make_lock should return a struct file_lock (or PTR_ERR)
locks: set fl_owner for leases to filp instead of current->files
locks: give lm_break a return value
locks: __break_lease cleanup in preparation of allowing direct removal of leases
locks: remove i_have_this_lease check from __break_lease
locks: move freeing of leases outside of i_lock
locks: move i_lock acquisition into generic_*_lease handlers
locks: define a lm_setup handler for leases
locks: plumb a "priv" pointer into the setlease routines
nfsd: don't keep a pointer to the lease in nfs4_file
locks: clean up vfs_setlease kerneldoc comments
locks: generic_delete_lease doesn't need a file_lock at all
nfsd: fix potential lease memory leak in nfs4_setlease
locks: close potential race in lease_get_mtime
security: make security_file_set_fowner, f_setown and __f_setown void return
locks: consolidate "nolease" routines
locks: remove lock_may_read and lock_may_write
lockd: rip out deferred lock handling from testlock codepath
NFSD: Get reference of lockowner when coping file_lock
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"Nothing major: support for compressing modules, and auto-tainting
params.
PS. My virtio-next tree is empty: DaveM took the patches I had. There
might be a virtio-rng starvation fix, but so far it's a bit voodoo
so I will get to that in the next two days or it will wait"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
moduleparam: Resolve missing-field-initializer warning
kbuild: handle module compression while running 'make modules_install'.
modinst: wrap long lines in order to enhance cmd_modules_install
modsign: lookup lines ending in .ko in .mod files
modpost: simplify file name generation of *.mod.c files
modpost: reduce visibility of symbols and constify r/o arrays
param: check for tainting before calling set op.
drm/i915: taint the kernel if unsafe module parameters are set
module: add module_param_unsafe and module_param_named_unsafe
module: make it possible to have unsafe, tainting module params
module: rename KERNEL_PARAM_FL_NOARG to avoid confusion
