path: root/security
2007-03-09Keys: Fix key serial number collision handlingDavid Howells
Fix the key serial number collision avoidance code in key_alloc_serial(). This didn't use to be so much of a problem as the key serial numbers were allocated from a simple incremental counter, and it would have to go through two billion keys before it could possibly encounter a collision. However, now that random numbers are used instead, collisions are much more likely. This is fixed by finding a hole in the rbtree where the next unused serial number ought to be and using that by going almost back to the top of the insertion routine and redoing the insertion with the new serial number rather than trying to be clever and attempting to work out the insertion point pointer directly. This fixes kernel BZ #7727. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-01-26[SELINUX]: Fix 2.6.20-rc6 build when no xfrmVenkat Yekkirala
This patch is an incremental fix to the flow_cache_genid patch for selinux that breaks the build of 2.6.20-rc6 when xfrm is not configured. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-23[SELINUX]: increment flow cache genidVenkat Yekkirala
Currently, old flow cache entries remain valid even after a reload of SELinux policy. This patch increments the flow cache generation id on policy (re)loads so that flow cache entries are revalidated as needed. Thanks to Herbet Xu for pointing this out. See: http://marc.theaimsgroup.com/?l=linux-netdev&m=116841378704536&w=2 There's also a general issue as well as a solution proposed by David Miller for when flow_cache_genid wraps. I might be submitting a separate patch for that later. I request that this be applied to 2.6.20 since it's a security relevant fix. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-09NetLabel: correct locking in selinux_netlbl_socket_setsid()Paul Moore
The spinlock protecting the update of the "sksec->nlbl_state" variable is not currently softirq safe which can lead to problems. This patch fixes this by changing the spin_{un}lock() functions into spin_{un}lock_bh() functions. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-01-08selinux: Delete mls_copy_contextVenkat Yekkirala
This deletes mls_copy_context() in favor of mls_context_cpy() and replaces mls_scopy_context() with mls_context_cpy_low(). Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-01-02[PATCH] selinux: fix selinux_netlbl_inode_permission() lockingParag Warudkar
do not call a sleeping lock API in an RCU read section. lock_sock_nested can sleep, its BH counterpart doesn't. selinux_netlbl_inode_permission() needs to use the BH counterpart unconditionally. Compile tested. From: Ingo Molnar <mingo@elte.hu> added BH disabling, because this function can be called from non-atomic contexts too, so a naked bh_lock_sock() would be deadlock-prone. Boot-tested the resulting kernel. Signed-off-by: Parag Warudkar <paragw@paragw.zapto.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] fdtable: Make fdarray and fdsets equal in sizeVadim Lobanov
Currently, each fdtable supports three dynamically-sized arrays of data: the fdarray and two fdsets. The code allows the number of fds supported by the fdarray (fdtable->max_fds) to differ from the number of fds supported by each of the fdsets (fdtable->max_fdset). In practice, it is wasteful for these two sizes to differ: whenever we hit a limit on the smaller-capacity structure, we will reallocate the entire fdtable and all the dynamic arrays within it, so any delta in the memory used by the larger-capacity structure will never be touched at all. Rather than hogging this excess, we shouldn't even allocate it in the first place, and keep the capacities of the fdarray and the fdsets equal. This patch removes fdtable->max_fdset. As an added bonus, most of the supporting code becomes simpler. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert selinuxJosef Sipek
2006-12-08[PATCH] tty: ->signal->tty lockingPeter Zijlstra
Fix the locking of signal->tty. Use ->sighand->siglock to protect ->signal->tty; this lock is already used by most other members of ->signal/->sighand. And unless we are 'current' or the tasklist_lock is held we need ->siglock to access ->signal anyway. (NOTE: sys_unshare() is broken wrt ->sighand locking rules) Note that tty_mutex is held over tty destruction, so while holding tty_mutex any tty pointer remains valid. Otherwise the lifetime of ttys are governed by their open file handles. This leaves some holes for tty access from signal->tty (or any other non file related tty access). It solves the tty SLAB scribbles we were seeing. (NOTE: the change from group_send_sig_info to __group_send_sig_info needs to be examined by someone familiar with the security framework, I think it is safe given the SEND_SIG_PRIV from other __group_send_sig_info invocations) [schwidefsky@de.ibm.com: 3270 fix] [akpm@osdl.org: various post-viro fixes] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Alan Cox <alan@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Roland McGrath <roland@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] lockdep: name some old style locksPeter Zijlstra
Name some of the remaning 'old_style_spin_init' locks Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] security/keys/*: user kmemdup()Eric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/ata/libata-scsi.c include/linux/libata.h Futher merge of Linus's head and compilation fixups. Signed-Off-By: David Howells <dhowells@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[PATCH] selinux endianness annotationsAl Viro
2006-12-02Rename class_destroy to avoid namespace conflicts.James Morris
We're seeing increasing namespace conflicts between the global class_destroy() function declared in linux/device.h, and the private function in the SELinux core code. This patch renames the SELinux function to cls_destroy() to avoid this conflict. Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: convert to an extensibile/sparse category bitmapPaul Moore
The original NetLabel category bitmap was a straight char bitmap which worked fine for the initial release as it only supported 240 bits due to limitations in the CIPSO restricted bitmap tag (tag type 0x01). This patch converts that straight char bitmap into an extensibile/sparse bitmap in order to lay the foundation for other CIPSO tag types and protocols. This patch also has a nice side effect in that all of the security attributes passed by NetLabel into the LSM are now in a format which is in the host's native byte/bit ordering which makes the LSM specific code much simpler; look at the changes in security/selinux/ss/ebitmap.c as an example. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02Compile fix for "peer secid consolidation for external network labeling"James Morris
Use a forward declaration instead of dragging in skbuff.h and related junk. Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02SELinux: peer secid consolidation for external network labelingPaul Moore
Now that labeled IPsec makes use of the peer_sid field in the sk_security_struct we can remove a lot of the special cases between labeled IPsec and NetLabel. In addition, create a new function, security_skb_extlbl_sid(), which we can use in several places to get the security context of the packet's external label which allows us to further simplify the code in a few places. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: SELinux cleanupsPaul Moore
This patch does a lot of cleanup in the SELinux NetLabel support code. A summary of the changes include: * Use RCU locking for the NetLabel state variable in the skk_security_struct instead of using the inode_security_struct mutex. * Remove unnecessary parameters in selinux_netlbl_socket_post_create(). * Rename selinux_netlbl_sk_clone_security() to selinux_netlbl_sk_security_clone() to better fit the other NetLabel sk_security functions. * Improvements to selinux_netlbl_inode_permission() to help reduce the cost of the common case. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: make netlbl_lsm_secattr struct easier/quicker to understandPaul Moore
The existing netlbl_lsm_secattr struct required the LSM to check all of the fields to determine if any security attributes were present resulting in a lot of work in the common case of no attributes. This patch adds a 'flags' field which is used to indicate which attributes are present in the structure; this should allow the LSM to do a quick comparison to determine if the structure holds any security attributes. Example: if (netlbl_lsm_secattr->flags) /* security attributes present */ else /* NO security attributes present */ Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02[IPv6] prefix: Convert RTM_NEWPREFIX notifications to use the new netlink apiThomas Graf
RTM_GETPREFIX is completely unused and is thus removed. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SELinux]: Add support for DCCPJames Morris
This patch implements SELinux kernel support for DCCP (http://linux-net.osdl.org/index.php/DCCP), which is similar in operation to TCP in terms of connected state between peers. The SELinux support for DCCP is thus modeled on existing handling of TCP. A new DCCP socket class is introduced, to allow protocol differentation. The permissions for this class inherit all of the socket permissions, as well as the current TCP permissions (node_bind, name_bind etc). IPv4 and IPv6 are supported, although labeled networking is not, at this stage. Patches for SELinux userspace are at: http://people.redhat.com/jmorris/selinux/dccp/user/ I've performed some basic testing, and it seems to be working as expected. Adding policy support is similar to TCP, the only real difference being that it's a different protocol. Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02SELinux: Fix SA selection semanticsVenkat Yekkirala
Fix the selection of an SA for an outgoing packet to be at the same context as the originating socket/flow. This eliminates the SELinux policy's ability to use/sendto SAs with contexts other than the socket's. With this patch applied, the SELinux policy will require one or more of the following for a socket to be able to communicate with/without SAs: 1. To enable a socket to communicate without using labeled-IPSec SAs: allow socket_t unlabeled_t:association { sendto recvfrom } 2. To enable a socket to communicate with labeled-IPSec SAs: allow socket_t self:association { sendto }; allow socket_t peer_sa_t:association { recvfrom }; Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02SELinux: Return correct context for SO_PEERSECVenkat Yekkirala
Fix SO_PEERSEC for tcp sockets to return the security context of the peer (as represented by the SA from the peer) as opposed to the SA used by the local/source socket. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02SELinux: Various xfrm labeling fixesVenkat Yekkirala
Since the upstreaming of the mlsxfrm modification a few months back, testing has resulted in the identification of the following issues/bugs that are resolved in this patch set. 1. Fix the security context used in the IKE negotiation to be the context of the socket as opposed to the context of the SPD rule. 2. Fix SO_PEERSEC for tcp sockets to return the security context of the peer as opposed to the source. 3. Fix the selection of an SA for an outgoing packet to be at the same context as the originating socket/flow. The following would be the result of applying this patchset: - SO_PEERSEC will now correctly return the peer's context. - IKE deamons will receive the context of the source socket/flow as opposed to the SPD rule's context so that the negotiated SA will be at the same context as the source socket/flow. - The SELinux policy will require one or more of the following for a socket to be able to communicate with/without SAs: 1. To enable a socket to communicate without using labeled-IPSec SAs: allow socket_t unlabeled_t:association { sendto recvfrom } 2. To enable a socket to communicate with labeled-IPSec SAs: allow socket_t self:association { sendto }; allow socket_t peer_sa_t:association { recvfrom }; This Patch: Pass correct security context to IKE for use in negotiation Fix the security context passed to IKE for use in negotiation to be the context of the socket as opposed to the context of the SPD rule so that the SA carries the label of the originating socket/flow. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-01Merge branch 'for-2.6.20' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6 * 'for-2.6.20' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6: SELinux: validate kernel object classes and permissions SELinux: ensure keys constant in hashtab_search SELinux: export object class and permission definitions SELinux: remove current object class and permission validation mechanism
2006-11-28SELinux: validate kernel object classes and permissionsChad Sellers
This is a new object class and permission validation scheme that validates against the defined kernel headers. This scheme allows extra classes and permissions that do not conflict with the kernel definitions to be added to the policy. This validation is now done for all policy loads, not just subsequent loads after the first policy load. The implementation walks the three structrures containing the defined object class and permission values and ensures their values are the same in the policy being loaded. This includes verifying the object classes themselves, the permissions they contain, and the permissions they inherit from commons. Classes or permissions that are present in the kernel but missing from the policy cause a warning (printed to KERN_INFO) to be printed, but do not stop the policy from loading, emulating current behavior. Any other inconsistencies cause the load to fail. Signed-off-by: Chad Sellers <csellers@tresys.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2006-11-28SELinux: ensure keys constant in hashtab_searchChad Sellers
Makes the key argument passed into hashtab_search and all the functions it calls constant. These functions include hash table function pointers hash_value and keycmp. The only implementations of these currently are symhash and symcmp, which do not modify the key. The key parameter should never be changed by any of these, so it should be const. This is necessary to allow calling these functions with keys found in kernel object class and permission definitions. Signed-off-by: Chad Sellers <csellers@tresys.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2006-11-28SELinux: export object class and permission definitionsChad Sellers
Moves the definition of the 3 structs containing object class and permission definitions from avc.c to avc_ss.h so that the security server can access them for validation on policy load. This also adds a new struct type, defined_classes_perms_t, suitable for allowing the security server to access these data structures from the avc. Signed-off-by: Chad Sellers <csellers@tresys.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2006-11-28SELinux: remove current object class and permission validation mechanismChad Sellers
Removes the current SELinux object class and permission validation code, as the current code makes it impossible to change or remove object classes and permissions on a running system. Additionally, the current code does not actually validate that the classes and permissions are correct, but instead merely validates that they do not change between policy reloads. Signed-off-by: Chad Sellers <csellers@tresys.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2006-11-27selinux: fix dentry_open() error checkAkinobu Mita
The return value of dentry_open() shoud be checked by IS_ERR(). Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-30[NetLabel]: protect the CIPSOv4 socket option from setsockopt()Paul Moore
This patch makes two changes to protect applications from either removing or tampering with the CIPSOv4 IP option on a socket. The first is the requirement that applications have the CAP_NET_RAW capability to set an IPOPT_CIPSO option on a socket; this prevents untrusted applications from setting their own CIPSOv4 security attributes on the packets they send. The second change is to SELinux and it prevents applications from setting any IPv4 options when there is an IPOPT_CIPSO option already present on the socket; this prevents applications from removing CIPSOv4 security attributes from the packets they send. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-15NetLabel: better error handling involving mls_export_cat()Paul Moore
Upon inspection it looked like the error handling for mls_export_cat() was rather poor. This patch addresses this by NULL'ing out kfree()'d pointers before returning and checking the return value of the function everywhere it is called. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-11SELinux: Bug fix in polidydb_destroyChad Sellers
This patch fixes two bugs in policydb_destroy. Two list pointers (policydb.ocontexts[i] and policydb.genfs) were not being reset to NULL when the lists they pointed to were being freed. This caused a problem when the initial policy load failed, as the policydb being destroyed was not a temporary new policydb that was thrown away, but rather was the global (active) policydb. Consequently, later functions, particularly sys_bind->selinux_socket_bind->security_node_sid and do_rw_proc->selinux_sysctl->selinux_proc_get_sid->security_genfs_sid tried to dereference memory that had previously been freed. Signed-off-by: Chad Sellers <csellers@tresys.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-11IPsec: correct semantics for SELinux policy matchingVenkat Yekkirala
Currently when an IPSec policy rule doesn't specify a security context, it is assumed to be "unlabeled" by SELinux, and so the IPSec policy rule fails to match to a flow that it would otherwise match to, unless one has explicitly added an SELinux policy rule allowing the flow to "polmatch" to the "unlabeled" IPSec policy rules. In the absence of such an explicitly added SELinux policy rule, the IPSec policy rule fails to match and so the packet(s) flow in clear text without the otherwise applicable xfrm(s) applied. The above SELinux behavior violates the SELinux security notion of "deny by default" which should actually translate to "encrypt by default" in the above case. This was first reported by Evgeniy Polyakov and the way James Morris was seeing the problem was when connecting via IPsec to a confined service on an SELinux box (vsftpd), which did not have the appropriate SELinux policy permissions to send packets via IPsec. With this patch applied, SELinux "polmatching" of flows Vs. IPSec policy rules will only come into play when there's a explicit context specified for the IPSec policy rule (which also means there's corresponding SELinux policy allowing appropriate domains/flows to polmatch to this context). Secondly, when a security module is loaded (in this case, SELinux), the security_xfrm_policy_lookup() hook can return errors other than access denied, such as -EINVAL. We were not handling that correctly, and in fact inverting the return logic and propagating a false "ok" back up to xfrm_lookup(), which then allowed packets to pass as if they were not associated with an xfrm policy. The solution for this is to first ensure that errno values are correctly propagated all the way back up through the various call chains from security_xfrm_policy_lookup(), and handled correctly. Then, flow_cache_lookup() is modified, so that if the policy resolver fails (typically a permission denied via the security module), the flow cache entry is killed rather than having a null policy assigned (which indicates that the packet can pass freely). This also forces any future lookups for the same flow to consult the security module (e.g. SELinux) for current security policy (rather than, say, caching the error on the flow cache entry). This patch: Fix the selinux side of things. This makes sure SELinux polmatching of flow contexts to IPSec policy rules comes into play only when an explicit context is associated with the IPSec policy rule. Also, this no longer defaults the context of a socket policy to the context of the socket since the "no explicit context" case is now handled properly. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-11NetLabel: use SECINITSID_UNLABELED for a base SIDpaul.moore@hp.com
This patch changes NetLabel to use SECINITSID_UNLABLELED as it's source of SELinux type information when generating a NetLabel context. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-11NetLabel: fix a cache race conditionpaul.moore@hp.com
Testing revealed a problem with the NetLabel cache where a cached entry could be freed while in use by the LSM layer causing an oops and other problems. This patch fixes that problem by introducing a reference counter to the cache entry so that it is only freed when it is no longer in use. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-03Still more typo fixesMatt LaPlante
2006-10-03more misc typo fixesMatt LaPlante
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] MLSXFRM: fix mis-labelling of child socketsDavid Woodhouse
Accepted connections of types other than AF_INET, AF_INET6, AF_UNIX won't have an appropriate label derived from the peer, so don't use it. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] pidspace: is_init()Sukadev Bhattiprolu
This is an updated version of Eric Biederman's is_init() patch. (http://lkml.org/lkml/2006/2/6/280). It applies cleanly to 2.6.18-rc3 and replaces a few more instances of ->pid == 1 with is_init(). Further, is_init() checks pid and thus removes dependency on Eric's other patches for now. Eric's original description: There are a lot of places in the kernel where we test for init because we give it special properties. Most significantly init must not die. This results in code all over the kernel test ->pid == 1. Introduce is_init to capture this case. With multiple pid spaces for all of the cases affected we are looking for only the first process on the system, not some other process that has pid == 1. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: <lxc-devel@lists.sourceforge.net> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] LSM: remove BSD secure level security moduleChris Wright
This code has suffered from broken core design and lack of developer attention. Broken security modules are too dangerous to leave around. It is time to remove this one. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Davi Arnaut <davi.arnaut@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: James Morris <jmorris@namei.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] SELinux: support mls categories for context mountsCory Olmo
Allows commas to be embedded into context mount options (i.e. "-o context=some_selinux_context_t"), to better support multiple categories, which are separated by commas and confuse mount. For example, with the current code: mount -t iso9660 /dev/cdrom /media/cdrom -o \ ro,context=system_u:object_r:iso9660_t:s0:c1,c3,c4,exec The context option that will be interpreted by SELinux is context=system_u:object_r:iso9660_t:s0:c1 instead of context=system_u:object_r:iso9660_t:s0:c1,c3,c4 The options that will be passed on to the file system will be ro,c3,c4,exec. The proposed solution is to allow/require the SELinux context option specified to mount to use quotes when the context contains a comma. This patch modifies the option parsing in parse_opts(), contained in mount.c, to take options after finding a comma only if it hasn't seen a quote or if the quotes are matched. It also introduces a new function that will strip the quotes from the context option prior to translation. The quotes are replaced after the translation is completed to insure that in the event the raw context contains commas the kernel will be able to interpret the correct context. Signed-off-by: Cory Olmo <colmo@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
