commit a48fda9de94500a3152a56b723d0a64ae236547c upstream.
ima_inode_setxattr() can be called with no value. Function does not
check the length so that following command can be used to produce
kernel oops: setfattr -n security.ima FOO. This patch fixes it.
Changes in v3:
* for stable reverted "allow setting hash only in fix or log mode"
It will be a separate patch.
Changes in v2:
* testing validity of xattr type
* allow setting hash only in fix or log mode (Mimi)
[ 261.562522] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 261.564109] IP: [<ffffffff812af272>] ima_inode_setxattr+0x3e/0x5a
[ 261.564109] PGD 3112f067 PUD 42965067 PMD 0
[ 261.564109] Oops: 0000 [#1] SMP
[ 261.564109] Modules linked in: bridge stp llc evdev serio_raw i2c_piix4 button fuse
[ 261.564109] CPU: 0 PID: 3299 Comm: setxattr Not tainted 3.16.0-kds+ #2924
[ 261.564109] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 261.564109] task: ffff8800428c2430 ti: ffff880042be0000 task.ti: ffff880042be0000
[ 261.564109] RIP: 0010:[<ffffffff812af272>] [<ffffffff812af272>] ima_inode_setxattr+0x3e/0x5a
[ 261.564109] RSP: 0018:ffff880042be3d50 EFLAGS: 00010246
[ 261.564109] RAX: 0000000000000001 RBX: 0000000000000000 RCX: 0000000000000015
[ 261.564109] RDX: 0000001500000000 RSI: 0000000000000000 RDI: ffff8800375cc600
[ 261.564109] RBP: ffff880042be3d68 R08: 0000000000000000 R09: 00000000004d6256
[ 261.564109] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88002149ba00
[ 261.564109] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 261.564109] FS: 00007f6c1e219740(0000) GS:ffff88005da00000(0000) knlGS:0000000000000000
[ 261.564109] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 261.564109] CR2: 0000000000000000 CR3: 000000003b35a000 CR4: 00000000000006f0
[ 261.564109] Stack:
[ 261.564109] ffff88002149ba00 ffff880042be3df8 0000000000000000 ffff880042be3d98
[ 261.564109] ffffffff812a101b ffff88002149ba00 ffff880042be3df8 0000000000000000
[ 261.564109] 0000000000000000 ffff880042be3de0 ffffffff8116d08a ffff880042be3dc8
[ 261.564109] Call Trace:
[ 261.564109] [<ffffffff812a101b>] security_inode_setxattr+0x48/0x6a
[ 261.564109] [<ffffffff8116d08a>] vfs_setxattr+0x6b/0x9f
[ 261.564109] [<ffffffff8116d1e0>] setxattr+0x122/0x16c
[ 261.564109] [<ffffffff811687e8>] ? mnt_want_write+0x21/0x45
[ 261.564109] [<ffffffff8114d011>] ? __sb_start_write+0x10f/0x143
[ 261.564109] [<ffffffff811687c0>] ? __mnt_want_write+0x48/0x4f
[ 261.564109] [<ffffffff8116d3e6>] SyS_setxattr+0x6e/0xb0
[ 261.564109] [<ffffffff81529da9>] system_call_fastpath+0x16/0x1b
[ 261.564109] Code: 48 89 f7 48 c7 c6 58 36 81 81 53 31 db e8 73 27 04 00 85 c0 75 28 bf 15 00 00 00 e8 8a a5 d9 ff 84 c0 75 05 83 cb ff eb 15 31 f6 <41> 80 7d 00 03 49 8b 7c 24 68 40 0f 94 c6 e8 e1 f9 ff ff 89 d8
[ 261.564109] RIP [<ffffffff812af272>] ima_inode_setxattr+0x3e/0x5a
[ 261.564109] RSP <ffff880042be3d50>
[ 261.599998] ---[ end trace 39a89a3fc267e652 ]---
Reported-by: Jan Kara <jack@suse.cz>
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 923190d32de4428afbea5e5773be86bea60a9925 upstream.
sb_finish_set_opts() can race with inode_free_security()
when initializing inode security structures for inodes
created prior to initial policy load or by the filesystem
during ->mount(). This appears to have always been
a possible race, but commit 3dc91d4 ("SELinux: Fix possible
NULL pointer dereference in selinux_inode_permission()")
made it more evident by immediately reusing the unioned
list/rcu element of the inode security structure for call_rcu()
upon an inode_free_security(). But the underlying issue
was already present before that commit as a possible use-after-free
of isec.
Shivnandan Kumar reported the list corruption and proposed
a patch to split the list and rcu elements out of the union
as separate fields of the inode_security_struct so that setting
the rcu element would not affect the list element. However,
this would merely hide the issue and not truly fix the code.
This patch instead moves up the deletion of the list entry
prior to dropping the sbsec->isec_lock initially. Then,
if the inode is dropped subsequently, there will be no further
references to the isec.
Reported-by: Shivnandan Kumar <shivnandan.k@samsung.com>
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit 3b1deef6b1289a99505858a3b212c5b50adf0c2f upstream.
evm_inode_setxattr() can be called with no value. The function does not
check the length so that following command can be used to produce the
kernel oops: setfattr -n security.evm FOO. This patch fixes it.
Changes in v3:
* there is no reason to return different error codes for EVM_XATTR_HMAC
and non EVM_XATTR_HMAC. Remove unnecessary test then.
Changes in v2:
* testing for validity of xattr type
[ 1106.396921] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1106.398192] IP: [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.399244] PGD 29048067 PUD 290d7067 PMD 0
[ 1106.399953] Oops: 0000 [#1] SMP
[ 1106.400020] Modules linked in: bridge stp llc evdev serio_raw i2c_piix4 button fuse
[ 1106.400020] CPU: 0 PID: 3635 Comm: setxattr Not tainted 3.16.0-kds+ #2936
[ 1106.400020] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 1106.400020] task: ffff8800291a0000 ti: ffff88002917c000 task.ti: ffff88002917c000
[ 1106.400020] RIP: 0010:[<ffffffff812af7b8>] [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.400020] RSP: 0018:ffff88002917fd50 EFLAGS: 00010246
[ 1106.400020] RAX: 0000000000000000 RBX: ffff88002917fdf8 RCX: 0000000000000000
[ 1106.400020] RDX: 0000000000000000 RSI: ffffffff818136d3 RDI: ffff88002917fdf8
[ 1106.400020] RBP: ffff88002917fd68 R08: 0000000000000000 R09: 00000000003ec1df
[ 1106.400020] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8800438a0a00
[ 1106.400020] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
[ 1106.400020] FS: 00007f7dfa7d7740(0000) GS:ffff88005da00000(0000) knlGS:0000000000000000
[ 1106.400020] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1106.400020] CR2: 0000000000000000 CR3: 000000003763e000 CR4: 00000000000006f0
[ 1106.400020] Stack:
[ 1106.400020] ffff8800438a0a00 ffff88002917fdf8 0000000000000000 ffff88002917fd98
[ 1106.400020] ffffffff812a1030 ffff8800438a0a00 ffff88002917fdf8 0000000000000000
[ 1106.400020] 0000000000000000 ffff88002917fde0 ffffffff8116d08a ffff88002917fdc8
[ 1106.400020] Call Trace:
[ 1106.400020] [<ffffffff812a1030>] security_inode_setxattr+0x5d/0x6a
[ 1106.400020] [<ffffffff8116d08a>] vfs_setxattr+0x6b/0x9f
[ 1106.400020] [<ffffffff8116d1e0>] setxattr+0x122/0x16c
[ 1106.400020] [<ffffffff811687e8>] ? mnt_want_write+0x21/0x45
[ 1106.400020] [<ffffffff8114d011>] ? __sb_start_write+0x10f/0x143
[ 1106.400020] [<ffffffff811687c0>] ? __mnt_want_write+0x48/0x4f
[ 1106.400020] [<ffffffff8116d3e6>] SyS_setxattr+0x6e/0xb0
[ 1106.400020] [<ffffffff81529da9>] system_call_fastpath+0x16/0x1b
[ 1106.400020] Code: c3 0f 1f 44 00 00 55 48 89 e5 41 55 49 89 d5 41 54 49 89 fc 53 48 89 f3 48 c7 c6 d3 36 81 81 48 89 df e8 18 22 04 00 85 c0 75 07 <41> 80 7d 00 02 74 0d 48 89 de 4c 89 e7 e8 5a fe ff ff eb 03 83
[ 1106.400020] RIP [<ffffffff812af7b8>] evm_inode_setxattr+0x2a/0x48
[ 1106.400020] RSP <ffff88002917fd50>
[ 1106.428061] ---[ end trace ae08331628ba3050 ]---
commit 3dcbad52cf18c3c379e96b992d22815439ebbe53 upstream.
Unless an LSM labels a file during d_instantiate(), newly created
files are not labeled with an initial security.evm xattr, until
the file closes. EVM, before allowing a protected, security xattr
to be written, verifies the existing 'security.evm' value is good.
For newly created files without a security.evm label, this
verification prevents writing any protected, security xattrs,
until the file closes.
Following is the example when this happens:
fd = open("foo", O_CREAT | O_WRONLY, 0644);
setxattr("foo", "security.SMACK64", value, sizeof(value), 0);
close(fd);
While INTEGRITY_NOXATTRS status is handled in other places, such
as evm_inode_setattr(), it does not handle it in all cases in
evm_protect_xattr(). By limiting the use of INTEGRITY_NOXATTRS to
newly created files, we can now allow setting "protected" xattrs.
Changelog:
- limit the use of INTEGRITY_NOXATTRS to IMA identified new files
commit 3034a146820c26fe6da66a45f6340fe87fe0983a upstream.
Empty files and missing xattrs do not guarantee that a file was
just created. This patch passes FILE_CREATED flag to IMA to
reliably identify new files.
commit b151d6b00bbb798c58f2f21305e7d43fa763f34f upstream.
On ima_file_free(), newly created empty files are not labeled with
an initial security.ima value, because the iversion did not change.
Commit dff6efc "fs: fix iversion handling" introduced a change in
iversion behavior. To verify this change use the shell command:
$ (exec >foo)
$ getfattr -h -e hex -d -m security foo
This patch defines the IMA_NEW_FILE flag. The flag is initially
set, when IMA detects that a new file is created, and subsequently
checked on the ima_file_free() hook to set the initial security.ima
value.
commit 27cd1fc3ae5374a4a86662c67033f15ef27b2461 upstream.
3.16 commit aad4f8bb42af06371aa0e85bf0cd9d52c0494985
'switch simple generic_file_aio_read() users to ->read_iter()'
replaced ->aio_read with ->read_iter in most of the file systems
and introduced new_sync_read() as a replacement for do_sync_read().
Most of file systems set '->read' and ima_kernel_read is not affected.
When ->read is not set, this patch adopts fallback call changes from the
vfs_read.
Now that NFS client uses the kernel key ring facility to store the NFSv4
id/gid mappings, the defaults for root_maxkeys and root_maxbytes need to be
substantially increased.
These values have been soak tested:
https://bugzilla.redhat.com/show_bug.cgi?id=1033708#c73
Signed-off-by: Steve Dickson <steved@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
Commit 7177a9c4b509 ("fs: call rename2 if exists") changed
"struct inode_operations"->rename == NULL if
"struct inode_operations"->rename2 != NULL .
TOMOYO needs to check for both ->rename and ->rename2 , or
a system on (e.g.) ext4 filesystem won't boot.
Signed-off-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Pull SElinux fixes from Paul Moore:
"Two small patches to fix a couple of build warnings in SELinux and
NetLabel. The patches are obvious enough that I don't think any
additional explanation is necessary, but it basically boils down to
the usual: I was stupid, and these patches fix some of the stupid.
Both patches were posted earlier this week to the SELinux list, and
that is where they sat as I didn't think there were noteworthy enough
to go upstream at this point in time, but DaveM would rather see them
upstream now so who am I to argue. As the patches are both very
small"
* 'stable-3.17' of git://git.infradead.org/users/pcmoore/selinux:
selinux: remove unused variabled in the netport, netnode, and netif caches
netlabel: fix the netlbl_catmap_setlong() dummy function
This patch removes the unused return code variable in the netport,
netnode, and netif initialization functions.
Reported-by: fengguang.wu@intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"In this release:
- PKCS#7 parser for the key management subsystem from David Howells
- appoint Kees Cook as seccomp maintainer
- bugfixes and general maintenance across the subsystem"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (94 commits)
X.509: Need to export x509_request_asymmetric_key()
netlabel: shorter names for the NetLabel catmap funcs/structs
netlabel: fix the catmap walking functions
netlabel: fix the horribly broken catmap functions
netlabel: fix a problem when setting bits below the previously lowest bit
PKCS#7: X.509 certificate issuer and subject are mandatory fields in the ASN.1
tpm: simplify code by using %*phN specifier
tpm: Provide a generic means to override the chip returned timeouts
tpm: missing tpm_chip_put in tpm_get_random()
tpm: Properly clean sysfs entries in error path
tpm: Add missing tpm_do_selftest to ST33 I2C driver
PKCS#7: Use x509_request_asymmetric_key()
Revert "selinux: fix the default socket labeling in sock_graft()"
X.509: x509_request_asymmetric_keys() doesn't need string length arguments
PKCS#7: fix sparse non static symbol warning
KEYS: revert encrypted key change
ima: add support for measuring and appraising firmware
firmware_class: perform new LSM checks
security: introduce kernel_fw_from_file hook
PKCS#7: Missing inclusion of linux/err.h
Pull timer and time updates from Thomas Gleixner:
"A rather large update of timers, timekeeping & co
- Core timekeeping code is year-2038 safe now for 32bit machines.
Now we just need to fix all in kernel users and the gazillion of
user space interfaces which rely on timespec/timeval :)
- Better cache layout for the timekeeping internal data structures.
- Proper nanosecond based interfaces for in kernel users.
- Tree wide cleanup of code which wants nanoseconds but does hoops
and loops to convert back and forth from timespecs. Some of it
definitely belongs into the ugly code museum.
- Consolidation of the timekeeping interface zoo.
- A fast NMI safe accessor to clock monotonic for tracing. This is a
long standing request to support correlated user/kernel space
traces. With proper NTP frequency correction it's also suitable
for correlation of traces accross separate machines.
- Checkpoint/restart support for timerfd.
- A few NOHZ[_FULL] improvements in the [hr]timer code.
- Code move from kernel to kernel/time of all time* related code.
- New clocksource/event drivers from the ARM universe. I'm really
impressed that despite an architected timer in the newer chips SoC
manufacturers insist on inventing new and differently broken SoC
specific timers.
[ Ed. "Impressed"? I don't think that word means what you think it means ]
- Another round of code move from arch to drivers. Looks like most
of the legacy mess in ARM regarding timers is sorted out except for
a few obnoxious strongholds.
- The usual updates and fixlets all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits)
timekeeping: Fixup typo in update_vsyscall_old definition
clocksource: document some basic timekeeping concepts
timekeeping: Use cached ntp_tick_length when accumulating error
timekeeping: Rework frequency adjustments to work better w/ nohz
timekeeping: Minor fixup for timespec64->timespec assignment
ftrace: Provide trace clocks monotonic
timekeeping: Provide fast and NMI safe access to CLOCK_MONOTONIC
seqcount: Add raw_write_seqcount_latch()
seqcount: Provide raw_read_seqcount()
timekeeping: Use tk_read_base as argument for timekeeping_get_ns()
timekeeping: Create struct tk_read_base and use it in struct timekeeper
timekeeping: Restructure the timekeeper some more
clocksource: Get rid of cycle_last
clocksource: Move cycle_last validation to core code
clocksource: Make delta calculation a function
wireless: ath9k: Get rid of timespec conversions
drm: vmwgfx: Use nsec based interfaces
drm: i915: Use nsec based interfaces
timekeeping: Provide ktime_get_raw()
hangcheck-timer: Use ktime_get_ns()
Pull scheduler updates from Ingo Molnar:
- Move the nohz kick code out of the scheduler tick to a dedicated IPI,
from Frederic Weisbecker.
This necessiated quite some background infrastructure rework,
including:
* Clean up some irq-work internals
* Implement remote irq-work
* Implement nohz kick on top of remote irq-work
* Move full dynticks timer enqueue notification to new kick
* Move multi-task notification to new kick
* Remove unecessary barriers on multi-task notification
- Remove proliferation of wait_on_bit() action functions and allow
wait_on_bit_action() functions to support a timeout. (Neil Brown)
- Another round of sched/numa improvements, cleanups and fixes. (Rik
van Riel)
- Implement fast idling of CPUs when the system is partially loaded,
for better scalability. (Tim Chen)
- Restructure and fix the CPU hotplug handling code that may leave
cfs_rq and rt_rq's throttled when tasks are migrated away from a dead
cpu. (Kirill Tkhai)
- Robustify the sched topology setup code. (Peterz Zijlstra)
- Improve sched_feat() handling wrt. static_keys (Jason Baron)
- Misc fixes.
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits)
sched/fair: Fix 'make xmldocs' warning caused by missing description
sched: Use macro for magic number of -1 for setparam
sched: Robustify topology setup
sched: Fix sched_setparam() policy == -1 logic
sched: Allow wait_on_bit_action() functions to support a timeout
sched: Remove proliferation of wait_on_bit() action functions
sched/numa: Revert "Use effective_load() to balance NUMA loads"
sched: Fix static_key race with sched_feat()
sched: Remove extra static_key*() function indirection
sched/rt: Fix replenish_dl_entity() comments to match the current upstream code
sched: Transform resched_task() into resched_curr()
sched/deadline: Kill task_struct->pi_top_task
sched: Rework check_for_tasks()
sched/rt: Enqueue just unthrottled rt_rq back on the stack in __disable_runtime()
sched/fair: Disable runtime_enabled on dying rq
sched/numa: Change scan period code to match intent
sched/numa: Rework best node setting in task_numa_migrate()
sched/numa: Examine a task move when examining a task swap
sched/numa: Simplify task_numa_compare()
sched/numa: Use effective_load() to balance NUMA loads
Historically the NetLabel LSM secattr catmap functions and data
structures have had very long names which makes a mess of the NetLabel
code and anyone who uses NetLabel. This patch renames the catmap
functions and structures from "*_secattr_catmap_*" to just "*_catmap_*"
which improves things greatly.
There are no substantial code or logic changes in this patch.
Tested-by: Casey Schaufler <casey@schaufler-ca.com>
The NetLabel secattr catmap functions, and the SELinux import/export
glue routines, were broken in many horrible ways and the SELinux glue
code fiddled with the NetLabel catmap structures in ways that we
probably shouldn't allow. At some point this "worked", but that was
likely due to a bit of dumb luck and sub-par testing (both inflicted
by yours truly). This patch corrects these problems by basically
gutting the code in favor of something less obtuse and restoring the
NetLabel abstractions in the SELinux catmap glue code.
Everything is working now, and if it decides to break itself in the
future this code will be much easier to debug than the code it
replaces.
One noteworthy side effect of the changes is that it is no longer
necessary to allocate a NetLabel catmap before calling one of the
NetLabel APIs to set a bit in the catmap. NetLabel will automatically
allocate the catmap nodes when needed, resulting in less allocations
when the lowest bit is greater than 255 and less code in the LSMs.
Cc: stable@vger.kernel.org
Reported-by: Christian Evans <frodox@zoho.com>
The NetLabel category (catmap) functions have a problem in that they
assume categories will be set in an increasing manner, e.g. the next
category set will always be larger than the last. Unfortunately, this
is not a valid assumption and could result in problems when attempting
to set categories less than the startbit in the lowest catmap node.
In some cases kernel panics and other nasties can result.
This patch corrects the problem by checking for this and allocating a
new catmap node instance and placing it at the front of the list.
into next
This reverts commit 4da6daf4d3df5a977e4623963f141a627fd2efce.
Unfortunately, the commit in question caused problems with Bluetooth
devices, specifically it caused them to get caught in the newly
created BUG_ON() check. The AF_ALG problem still exists, but will be
addressed in a future patch.
Commit fc7c70e "KEYS: struct key_preparsed_payload should have two
payload pointers" erroneously modified encrypted-keys. This patch
reverts the change to that file.
The "security: introduce kernel_fw_from_file hook" patch defined a
new security hook to evaluate any loaded firmware that wasn't built
into the kernel.
This patch defines ima_fw_from_file(), which is called from the new
security hook, to measure and/or appraise the loaded firmware's
integrity.
In order to validate the contents of firmware being loaded, there must be
a hook to evaluate any loaded firmware that wasn't built into the kernel
itself. Without this, there is a risk that a root user could load malicious
firmware designed to mount an attack against kernel memory (e.g. via DMA).
Reviewed-by: Takashi Iwai <tiwai@suse.de>
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into next
In function cap_task_prctl(), we would allocate a credential
unconditionally and then check if we support the requested function.
If not we would release this credential with abort_creds() by using
RCU method. But on some archs such as powerpc, the sys_prctl is heavily
used to get/set the floating point exception mode. So the unnecessary
allocating/releasing of credential not only introduce runtime overhead
but also do cause OOM due to the RCU implementation.
This patch removes abort_creds() from cap_task_prctl() by calling
prepare_creds() only when we need to modify it.
Reported-by: Kevin Hao <haokexin@gmail.com>
Reviewed-by: Paul Moore <paul@paul-moore.com>
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
Provide key preparsing for the request_key_auth key type so that we can make
preparsing mandatory. This does nothing as this type can only be set up
internally to the kernel.
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: Jeff Layton <jlayton@primarydata.com>
Provide key preparsing in the keyring so that we can make preparsing
mandatory. For keyrings, however, only an empty payload is permitted.
Make use of key preparsing in the big key type so that quota size determination
can take place prior to keyring locking when a key is being added.
Make use of key preparsing in user-defined and logon keys so that quota size
determination can take place prior to keyring locking when a key is being
added.
Also the idmapper key types need to change to match as they use the
user-defined key type routines.
Call the ->free_preparse() key type op even after ->preparse() returns an
error as it does cleaning up type stuff.
Reviewed-by: Sage Weil <sage@redhat.com>
Allow a key type's preparsing routine to set the expiry time for a key.
struct key_preparsed_payload should have two payload pointers to correspond
with those in struct key.
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux into next
Since seccomp transitions between threads requires updates to the
no_new_privs flag to be atomic, the flag must be part of an atomic flag
set. This moves the nnp flag into a separate task field, and introduces
accessors.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
Provide a generic instantiation function for key types that use the preparse
hook. This makes it easier to prereserve key quota before keyrings get locked
to retain the new key.
Special kernel keys, such as those used to hold DNS results for AFS, CIFS and
NFS and those used to hold idmapper results for NFS, used to be
'invalidateable' with key_revoke(). However, since the default permissions for
keys were reduced:
Commit: 96b5c8fea6c0861621051290d705ec2e971963f1
KEYS: Reduce initial permissions on keys
it has become impossible to do this.
Add a key flag (KEY_FLAG_ROOT_CAN_INVAL) that will permit a key to be
invalidated by root. This should not be used for system keyrings as the
garbage collector will try and remove any invalidate key. For system keyrings,
KEY_FLAG_ROOT_CAN_CLEAR can be used instead.
After this, from userspace, keyctl_invalidate() and "keyctl invalidate" can be
used by any possessor of CAP_SYS_ADMIN (typically root) to invalidate DNS and
idmapper keys. Invalidated keys are immediately garbage collected and will be
immediately rerequested if needed again.
Tested-by: Steve Dickson <steved@redhat.com>
Require all keys added to the IMA keyring be signed by an
existing trusted key on the system trusted keyring.
Changelog v6:
- remove ifdef CONFIG_IMA_TRUSTED_KEYRING in C code - Dmitry
- update Kconfig dependency and help
- select KEYS_DEBUG_PROC_KEYS - Dmitry
Changelog v5:
- Move integrity_init_keyring() to init_ima() - Dmitry
- reset keyring[id] on failure - Dmitry
Changelog v1:
- don't link IMA trusted keyring to user keyring
Changelog:
- define stub integrity_init_keyring() function (reported-by Fengguang Wu)
- differentiate between regular and trusted keyring names.
- replace printk with pr_info (D. Kasatkin)
- only make the IMA keyring a trusted keyring (reported-by D. Kastatkin)
- define stub integrity_init_keyring() definition based on
CONFIG_INTEGRITY_SIGNATURE, not CONFIG_INTEGRITY_ASYMMETRIC_KEYS.
(reported-by Jim Davis)
Dot prefixed keyring names are supposed to be reserved for the
kernel, but add_key() calls key_get_type_from_user(), which
incorrectly verifies the 'type' field, not the 'description' field.
This patch verifies the 'description' field isn't dot prefixed,
when creating a new keyring, and removes the dot prefix test in
key_get_type_from_user().
Changelog v6:
- whitespace and other cleanup
Changelog v5:
- Only prevent userspace from creating a dot prefixed keyring, not
regular keys - Dmitry
Reported-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
The asynchronous hash API allows initiating a hash calculation and
then performing other tasks, while waiting for the hash calculation
to complete.
This patch introduces usage of double buffering for simultaneous
hashing and reading of the next chunk of data from storage.
Changes in v3:
- better comments
Use of multiple-page collect buffers reduces:
1) the number of block IO requests
2) the number of asynchronous hash update requests
Second is important for HW accelerated hashing, because significant
amount of time is spent for preparation of hash update operation,
which includes configuring acceleration HW, DMA engine, etc...
Thus, HW accelerators are more efficient when working on large
chunks of data.
This patch introduces usage of multi-page collect buffers. Buffer size
can be specified using 'ahash_bufsize' module parameter. Default buffer
size is 4096 bytes.
Changes in v3:
- kernel parameter replaced with module parameter
Async hash API allows the use of HW acceleration for hash calculation.
It may give significant performance gain and/or reduce power consumption,
which might be very beneficial for battery powered devices.
This patch introduces hash calculation using ahash API. ahash performance
depends on the data size and the particular HW. Depending on the specific
system, shash performance may be better.
This patch defines 'ahash_minsize' module parameter, which is used to
define the minimal file size to use with ahash. If this minimum file size
is not set or the file is smaller than defined by the parameter, shash will
be used.
Changes in v3:
- pr_crit replaced with pr_crit_ratelimited
- more comment changes - Mimi
Changes in v2:
- ima_ahash_size became as ima_ahash
- ahash pre-allocation moved out from __init code to be able to use
ahash crypto modules. Ahash allocated once on the first use.
- hash calculation falls back to shash if ahash allocation/calculation fails
- complex initialization separated from variable declaration
- improved comments
Replace spaces in op keyword labels in log output since userspace audit tools
can't parse orphaned keywords.
Reported-by: Steve Grubb <sgrubb@redhat.com>
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
process_measurement() always calls ima_template_desc_current(),
including when an IMA policy has not been defined.
This patch delays template descriptor lookup until action is
determined.
Before 2.6.39 inode->i_readcount was maintained by IMA. It was not atomic
and protected using spinlock. For 2.6.39, i_readcount was converted to
atomic and maintaining was moved VFS layer. Spinlock for some unclear
reason was replaced by i_mutex.
After analyzing the code, we came to conclusion that i_mutex locking is
unnecessary, especially when an IMA policy has not been defined.
This patch removes i_mutex locking from ima_rdwr_violation_check().
Reason: Bring in upstream modifications, so the pending changes which
depend on them can be queued.
into next
