path: root/security
2016-10-27security/keys: make BIG_KEYS dependent on stdrng.Artem Savkov
Since BIG_KEYS can't be compiled as module it requires one of the "stdrng" providers to be compiled into kernel. Otherwise big_key_crypto_init() fails on crypto_alloc_rng step and next dereference of big_key_skcipher (e.g. in big_key_preparse()) results in a NULL pointer dereference. Fixes: 13100a72f40f5748a04017e0ab3df4cf27c809ef ('Security: Keys: Big keys stored encrypted') Signed-off-by: Artem Savkov <asavkov@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Stephan Mueller <smueller@chronox.de> cc: Kirill Marinushkin <k.marinushkin@gmail.com> cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-10-27KEYS: Sort out big_key initialisationDavid Howells
big_key has two separate initialisation functions, one that registers the key type and one that registers the crypto. If the key type fails to register, there's no problem if the crypto registers successfully because there's no way to reach the crypto except through the key type. However, if the key type registers successfully but the crypto does not, big_key_rng and big_key_blkcipher may end up set to NULL - but the code neither checks for this nor unregisters the big key key type. Furthermore, since the key type is registered before the crypto, it is theoretically possible for the kernel to try adding a big_key before the crypto is set up, leading to the same effect. Fix this by merging big_key_crypto_init() and big_key_init() and calling the resulting function late. If they're going to be encrypted, we shouldn't be creating big_keys before we have the facilities to do the encryption available. The key type registration is also moved after the crypto initialisation. The fix also includes message printing on failure. If the big_key type isn't correctly set up, simply doing: dd if=/dev/zero bs=4096 count=1 | keyctl padd big_key a @s ought to cause an oops. Fixes: 13100a72f40f5748a04017e0ab3df4cf27c809ef ('Security: Keys: Big keys stored encrypted') Signed-off-by: David Howells <dhowells@redhat.com> cc: Peter Hlavaty <zer0mem@yahoo.com> cc: Kirill Marinushkin <k.marinushkin@gmail.com> cc: Artem Savkov <asavkov@redhat.com> cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-10-27KEYS: Fix short sprintf buffer in /proc/keys show functionDavid Howells
This fixes CVE-2016-7042. Fix a short sprintf buffer in proc_keys_show(). If the gcc stack protector is turned on, this can cause a panic due to stack corruption. The problem is that xbuf[] is not big enough to hold a 64-bit timeout rendered as weeks: (gdb) p 0xffffffffffffffffULL/(60*60*24*7) $2 = 30500568904943 That's 14 chars plus NUL, not 11 chars plus NUL. Expand the buffer to 16 chars. I think the unpatched code apparently works if the stack-protector is not enabled because on a 32-bit machine the buffer won't be overflowed and on a 64-bit machine there's a 64-bit aligned pointer at one side and an int that isn't checked again on the other side. The panic incurred looks something like: Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff81352ebe CPU: 0 PID: 1692 Comm: reproducer Not tainted 4.7.2-201.fc24.x86_64 #1 Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011 0000000000000086 00000000fbbd2679 ffff8800a044bc00 ffffffff813d941f ffffffff81a28d58 ffff8800a044bc98 ffff8800a044bc88 ffffffff811b2cb6 ffff880000000010 ffff8800a044bc98 ffff8800a044bc30 00000000fbbd2679 Call Trace: [<ffffffff813d941f>] dump_stack+0x63/0x84 [<ffffffff811b2cb6>] panic+0xde/0x22a [<ffffffff81352ebe>] ? proc_keys_show+0x3ce/0x3d0 [<ffffffff8109f7f9>] __stack_chk_fail+0x19/0x30 [<ffffffff81352ebe>] proc_keys_show+0x3ce/0x3d0 [<ffffffff81350410>] ? key_validate+0x50/0x50 [<ffffffff8134db30>] ? key_default_cmp+0x20/0x20 [<ffffffff8126b31c>] seq_read+0x2cc/0x390 [<ffffffff812b6b12>] proc_reg_read+0x42/0x70 [<ffffffff81244fc7>] __vfs_read+0x37/0x150 [<ffffffff81357020>] ? security_file_permission+0xa0/0xc0 [<ffffffff81246156>] vfs_read+0x96/0x130 [<ffffffff81247635>] SyS_read+0x55/0xc0 [<ffffffff817eb872>] entry_SYSCALL_64_fastpath+0x1a/0xa4 Reported-by: Ondrej Kozina <okozina@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ondrej Kozina <okozina@redhat.com> cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2016-10-22Merge branch 'mm-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull vmap stack fixes from Ingo Molnar: "This is fallout from CONFIG_HAVE_ARCH_VMAP_STACK=y on x86: stack accesses that used to be just somewhat questionable are now totally buggy. These changes try to do it without breaking the ABI: the fields are left there, they are just reporting zero, or reporting narrower information (the maps file change)" * 'mm-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: mm: Change vm_is_stack_for_task() to vm_is_stack_for_current() fs/proc: Stop trying to report thread stacks fs/proc: Stop reporting eip and esp in /proc/PID/stat mm/numa: Remove duplicated include from mprotect.c
2016-10-20mm: Change vm_is_stack_for_task() to vm_is_stack_for_current()Andy Lutomirski
Asking for a non-current task's stack can't be done without races unless the task is frozen in kernel mode. As far as I know, vm_is_stack_for_task() never had a safe non-current use case. The __unused annotation is because some KSTK_ESP implementations ignore their parameter, which IMO is further justification for this patch. Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Jann Horn <jann@thejh.net> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Linux API <linux-api@vger.kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tycho Andersen <tycho.andersen@canonical.com> Link: http://lkml.kernel.org/r/4c3f68f426e6c061ca98b4fc7ef85ffbb0a25b0c.1475257877.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-10-19mm: replace get_user_pages_remote() write/force parameters with gup_flagsLorenzo Stoakes
This removes the 'write' and 'force' from get_user_pages_remote() and replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in callers as use of this flag can result in surprising behaviour (and hence bugs) within the mm subsystem. Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-10-10Merge branch 'work.xattr' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs xattr updates from Al Viro: "xattr stuff from Andreas This completes the switch to xattr_handler ->get()/->set() from ->getxattr/->setxattr/->removexattr" * 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: Remove {get,set,remove}xattr inode operations xattr: Stop calling {get,set,remove}xattr inode operations vfs: Check for the IOP_XATTR flag in listxattr xattr: Add __vfs_{get,set,remove}xattr helpers libfs: Use IOP_XATTR flag for empty directory handling vfs: Use IOP_XATTR flag for bad-inode handling vfs: Add IOP_XATTR inode operations flag vfs: Move xattr_resolve_name to the front of fs/xattr.c ecryptfs: Switch to generic xattr handlers sockfs: Get rid of getxattr iop sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names kernfs: Switch to generic xattr handlers hfs: Switch to generic xattr handlers jffs2: Remove jffs2_{get,set,remove}xattr macros xattr: Remove unnecessary NULL attribute name check
2016-10-10Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "Assorted misc bits and pieces. There are several single-topic branches left after this (rename2 series from Miklos, current_time series from Deepa Dinamani, xattr series from Andreas, uaccess stuff from from me) and I'd prefer to send those separately" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (39 commits) proc: switch auxv to use of __mem_open() hpfs: support FIEMAP cifs: get rid of unused arguments of CIFSSMBWrite() posix_acl: uapi header split posix_acl: xattr representation cleanups fs/aio.c: eliminate redundant loads in put_aio_ring_file fs/internal.h: add const to ns_dentry_operations declaration compat: remove compat_printk() fs/buffer.c: make __getblk_slow() static proc: unsigned file descriptors fs/file: more unsigned file descriptors fs: compat: remove redundant check of nr_segs cachefiles: Fix attempt to read i_blocks after deleting file [ver #2] cifs: don't use memcpy() to copy struct iov_iter get rid of separate multipage fault-in primitives fs: Avoid premature clearing of capabilities fs: Give dentry to inode_change_ok() instead of inode fuse: Propagate dentry down to inode_change_ok() ceph: Propagate dentry down to inode_change_ok() xfs: Propagate dentry down to inode_change_ok() ...
2016-10-10Merge branch 'printk-cleanups'Linus Torvalds
Merge my system logging cleanups, triggered by the broken '\n' patches. The line continuation handling has been broken basically forever, and the code to handle the system log records was both confusing and dubious. And it would do entirely the wrong thing unless you always had a terminating newline, partly because it couldn't actually see whether a message was marked KERN_CONT or not (but partly because the LOG_CONT handling in the recording code was rather confusing too). This re-introduces a real semantically meaningful KERN_CONT, and fixes the few places I noticed where it was missing. There are probably more missing cases, since KERN_CONT hasn't actually had any semantic meaning for at least four years (other than the checkpatch meaning of "no log level necessary, this is a continuation line"). This also allows the combination of KERN_CONT and a log level. In that case the log level will be ignored if the merging with a previous line is successful, but if a new record is needed, that new record will now get the right log level. That also means that you can at least in theory combine KERN_CONT with the "pr_info()" style helpers, although any use of pr_fmt() prefixing would make that just result in a mess, of course (the prefix would end up in the middle of a continuing line). * printk-cleanups: printk: make reading the kernel log flush pending lines printk: re-organize log_output() to be more legible printk: split out core logging code into helper function printk: reinstate KERN_CONT for printing continuation lines
2016-10-09printk: reinstate KERN_CONT for printing continuation linesLinus Torvalds
Long long ago the kernel log buffer was a buffered stream of bytes, very much like stdio in user space. It supported log levels by scanning the stream and noticing the log level markers at the beginning of each line, but if you wanted to print a partial line in multiple chunks, you just did multiple printk() calls, and it just automatically worked. Except when it didn't, and you had very confusing output when different lines got all mixed up with each other. Then you got fragment lines mixing with each other, or with non-fragment lines, because it was traditionally impossible to tell whether a printk() call was a continuation or not. To at least help clarify the issue of continuation lines, we added a KERN_CONT marker back in 2007 to mark continuation lines: 474925277671 ("printk: add KERN_CONT annotation"). That continuation marker was initially an empty string, and didn't actuall make any semantic difference. But it at least made it possible to annotate the source code, and have check-patch notice that a printk() didn't need or want a log level marker, because it was a continuation of a previous line. To avoid the ambiguity between a continuation line that had that KERN_CONT marker, and a printk with no level information at all, we then in 2009 made KERN_CONT be a real log level marker which meant that we could now reliably tell the difference between the two cases. 5fd29d6ccbc9 ("printk: clean up handling of log-levels and newlines") and we could take advantage of that to make sure we didn't mix up continuation lines with lines that just didn't have any loglevel at all. Then, in 2012, the kernel log buffer was changed to be a "record" based log, where each line was a record that has a loglevel and a timestamp. You can see the beginning of that conversion in commits e11fea92e13f ("kmsg: export printk records to the /dev/kmsg interface") 7ff9554bb578 ("printk: convert byte-buffer to variable-length record buffer") with a number of follow-up commits to fix some painful fallout from that conversion. Over all, it took a couple of months to sort out most of it. But the upside was that you could have concurrent readers (and writers) of the kernel log and not have lines with mixed output in them. And one particular pain-point for the record-based kernel logging was exactly the fragmentary lines that are generated in smaller chunks. In order to still log them as one recrod, the continuation lines need to be attached to the previous record properly. However the explicit continuation record marker that is actually useful for this exact case was actually removed in aroundm the same time by commit 61e99ab8e35a ("printk: remove the now unnecessary "C" annotation for KERN_CONT") due to the incorrect belief that KERN_CONT wasn't meaningful. The ambiguity between "is this a continuation line" or "is this a plain printk with no log level information" was reintroduced, and in fact became an even bigger pain point because there was now the whole record-level merging of kernel messages going on. This patch reinstates the KERN_CONT as a real non-empty string marker, so that the ambiguity is fixed once again. But it's not a plain revert of that original removal: in the four years since we made KERN_CONT an empty string again, not only has the format of the log level markers changed, we've also had some usage changes in this area. For example, some ACPI code seems to use KERN_CONT _together_ with a log level, and now uses both the KERN_CONT marker and (for example) a KERN_INFO marker to show that it's an informational continuation of a line. Which is actually not a bad idea - if the continuation line cannot be attached to its predecessor, without the log level information we don't know what log level to assign to it (and we traditionally just assigned it the default loglevel). So having both a log level and the KERN_CONT marker is not necessarily a bad idea, but it does mean that we need to actually iterate over potentially multiple markers, rather than just a single one. Also, since KERN_CONT was still conceptually needed, and encouraged, but didn't actually _do_ anything, we've also had the reverse problem: rather than having too many annotations it has too few, and there is bit rot with code that no longer marks the continuation lines with the KERN_CONT marker. So this patch not only re-instates the non-empty KERN_CONT marker, it also fixes up the cases of bit-rot I noticed in my own logs. There are probably other cases where KERN_CONT will be needed to be added, either because it is new code that never dealt with the need for KERN_CONT, or old code that has bitrotted without anybody noticing. That said, we should strive to avoid the need for KERN_CONT. It does result in real problems for logging, and should generally not be seen as a good feature. If we some day can get rid of the feature entirely, because nobody does any fragmented printk calls, that would be lovely. But until that point, let's at mark the code that relies on the hacky multi-fragment kernel printk's. Not only does it avoid the ambiguity, it also annotates code as "maybe this would be good to fix some day". (That said, particularly during single-threaded bootup, the downsides of KERN_CONT are very limited. Things get much hairier when you have multiple threads going on and user level reading and writing logs too). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-08Merge remote-tracking branch 'ovl/misc' into work.miscAl Viro
2016-10-07xattr: Add __vfs_{get,set,remove}xattr helpersAndreas Gruenbacher
Right now, various places in the kernel check for the existence of getxattr, setxattr, and removexattr inode operations and directly call those operations. Switch to helper functions and test for the IOP_XATTR flag instead. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "The usual rocket science from the trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: tracing/syscalls: fix multiline in error message text lib/Kconfig.debug: fix DEBUG_SECTION_MISMATCH description doc: vfs: fix fadvise() sycall name x86/entry: spell EBX register correctly in documentation securityfs: fix securityfs_create_dir comment irq: Fix typo in tracepoint.xml
2016-10-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: SELinux/LSM: - overlayfs support, necessary for container filesystems LSM: - finally remove the kernel_module_from_file hook Smack: - treat signal delivery as an 'append' operation TPM: - lots of bugfixes & updates Audit: - new audit data type: LSM_AUDIT_DATA_FILE * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (47 commits) Revert "tpm/tpm_crb: implement tpm crb idle state" Revert "tmp/tpm_crb: fix Intel PTT hw bug during idle state" Revert "tpm/tpm_crb: open code the crb_init into acpi_add" Revert "tmp/tpm_crb: implement runtime pm for tpm_crb" lsm,audit,selinux: Introduce a new audit data type LSM_AUDIT_DATA_FILE tmp/tpm_crb: implement runtime pm for tpm_crb tpm/tpm_crb: open code the crb_init into acpi_add tmp/tpm_crb: fix Intel PTT hw bug during idle state tpm/tpm_crb: implement tpm crb idle state tpm: add check for minimum buffer size in tpm_transmit() tpm: constify TPM 1.x header structures tpm/tpm_crb: fix the over 80 characters checkpatch warring tpm/tpm_crb: drop useless cpu_to_le32 when writing to registers tpm/tpm_crb: cache cmd_size register value. tmp/tpm_crb: drop include to platform_device tpm/tpm_tis: remove unused itpm variable tpm_crb: fix incorrect values of cmdReady and goIdle bits tpm_crb: refine the naming of constants tpm_crb: remove wmb()'s tpm_crb: fix crb_req_canceled behavior ...
2016-10-04Merge branch 'stable-4.9' of git://git.infradead.org/users/pcmoore/auditLinus Torvalds
Pull audit updates from Paul Moore: "Another relatively small pull request for v4.9 with just two patches. The patch from Richard updates the list of features we support and report back to userspace; this should have been sent earlier with the rest of the v4.8 patches but it got lost in my inbox. The second patch fixes a problem reported by our Android friends where we weren't very consistent in recording PIDs" * 'stable-4.9' of git://git.infradead.org/users/pcmoore/audit: audit: add exclude filter extension to feature bitmap audit: consistently record PIDs with task_tgid_nr()
2016-09-29securityfs: fix securityfs_create_dir commentLaurent Georget
If there is an error creating a directory with securityfs_create_dir, the error is propagated via ERR_PTR but the function comment claims that NULL is returned. This is a similar commit to 88e6c94cda322ff2b32f72bb8d96f9675cdad8aa ("fix long-broken securityfs_create_file comment") that did not fix securityfs_create_dir comment at the same time. Signed-off-by: Laurent Georget <laurent.georget@supelec.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2016-09-27fs: Replace CURRENT_TIME with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME macro is not appropriate for filesystems as it doesn't use the right granularity for filesystem timestamps. Use current_time() instead. CURRENT_TIME is also not y2038 safe. This is also in preparation for the patch that transitions vfs timestamps to use 64 bit time and hence make them y2038 safe. As part of the effort current_time() will be extended to do range checks. Hence, it is necessary for all file system timestamps to use current_time(). Also, current_time() will be transitioned along with vfs to be y2038 safe. Note that whenever a single call to current_time() is used to change timestamps in different inodes, it is because they share the same time granularity. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Felipe Balbi <balbi@kernel.org> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: David Sterba <dsterba@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: rename "rename2" i_op to "rename"Miklos Szeredi
Generated patch: sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2` sed -i "s/\brename2\b/rename/g" `git grep -wl rename2` Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-09-27vfs: remove unused i_op->renameMiklos Szeredi
No in-tree uses remain. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-09-23Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fixes from Herbert Xu: "This fixes a regression in RSA that was only half-fixed earlier in the cycle. It also fixes an older regression that breaks the keyring subsystem" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: rsa-pkcs1pad - Handle leading zero for decryption KEYS: Fix skcipher IV clobbering
2016-09-22KEYS: Fix skcipher IV clobberingHerbert Xu
The IV must not be modified by the skcipher operation so we need to duplicate it. Fixes: c3917fd9dfbc ("KEYS: Use skcipher") Cc: stable@vger.kernel.org Reported-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-09-21Merge branch 'stable-4.9' of git://git.infradead.org/users/pcmoore/selinux ↵James Morris
into next
2016-09-19lsm,audit,selinux: Introduce a new audit data type LSM_AUDIT_DATA_FILEVivek Goyal
Right now LSM_AUDIT_DATA_PATH type contains "struct path" in union "u" of common_audit_data. This information is used to print path of file at the same time it is also used to get to dentry and inode. And this inode information is used to get to superblock and device and print device information. This does not work well for layered filesystems like overlay where dentry contained in path is overlay dentry and not the real dentry of underlying file system. That means inode retrieved from dentry is also overlay inode and not the real inode. SELinux helpers like file_path_has_perm() are doing checks on inode retrieved from file_inode(). This returns the real inode and not the overlay inode. That means we are doing check on real inode but for audit purposes we are printing details of overlay inode and that can be confusing while debugging. Hence, introduce a new type LSM_AUDIT_DATA_FILE which carries file information and inode retrieved is real inode using file_inode(). That way right avc denied information is given to user. For example, following is one example avc before the patch. type=AVC msg=audit(1473360868.399:214): avc: denied { read open } for pid=1765 comm="cat" path="/root/.../overlay/container1/merged/readfile" dev="overlay" ino=21443 scontext=unconfined_u:unconfined_r:test_overlay_client_t:s0:c10,c20 tcontext=unconfined_u:object_r:test_overlay_files_ro_t:s0 tclass=file permissive=0 It looks as follows after the patch. type=AVC msg=audit(1473360017.388:282): avc: denied { read open } for pid=2530 comm="cat" path="/root/.../overlay/container1/merged/readfile" dev="dm-0" ino=2377915 scontext=unconfined_u:unconfined_r:test_overlay_client_t:s0:c10,c20 tcontext=unconfined_u:object_r:test_overlay_files_ro_t:s0 tclass=file permissive=0 Notice that now dev information points to "dm-0" device instead of "overlay" device. This makes it clear that check failed on underlying inode and not on the overlay inode. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> [PM: slight tweaks to the description to make checkpatch.pl happy] Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-09-19Merge branch 'stable-4.9' of git://git.infradead.org/users/pcmoore/selinux ↵James Morris
into next
2016-09-16ima: use file_dentry()Miklos Szeredi
Ima tries to call ->setxattr() on overlayfs dentry after having locked underlying inode, which results in a deadlock. Reported-by: Krisztian Litkey <kli@iki.fi> Fixes: 4bacc9c9234c ("overlayfs: Make f_path always point to the overlay and f_inode to the underlay") Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Cc: <stable@vger.kernel.org> # v4.2 Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
2016-09-13selinux: fix error return code in policydb_read()Wei Yongjun
Fix to return error code -EINVAL from the error handling case instead of 0 (rc is overwrite to 0 when policyvers >= POLICYDB_VERSION_ROLETRANS), as done elsewhere in this function. Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> [PM: normalize "selinux" in patch subject, description line wrap] Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-09-08Smack: Signal delivery as an append operationCasey Schaufler
Under a strict subject/object security policy delivering a signal or delivering network IPC could be considered either a write or an append operation. The original choice to make both write operations leads to an issue where IPC delivery is desired under policy, but delivery of signals is not. This patch provides the option of making signal delivery an append operation, allowing Smack rules that deny signal delivery while allowing IPC. This was requested for Tizen. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2016-09-07Merge tag 'usercopy-v4.8-rc6-part2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux Pull more hardened usercopyfixes from Kees Cook: - force check_object_size() to be inline too - move page-spanning check behind a CONFIG since it's triggering false positives [ Changed the page-spanning config option to depend on EXPERT in the merge. That way it still gets build testing, and you can enable it if you want to, but is never enabled for "normal" configurations ] * tag 'usercopy-v4.8-rc6-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: usercopy: remove page-spanning test for now usercopy: force check_object_size() inline
2016-09-07usercopy: remove page-spanning test for nowKees Cook
A custom allocator without __GFP_COMP that copies to userspace has been found in vmw_execbuf_process[1], so this disables the page-span checker by placing it behind a CONFIG for future work where such things can be tracked down later. [1] https://bugzilla.redhat.com/show_bug.cgi?id=1373326 Reported-by: Vinson Lee <vlee@freedesktop.org> Fixes: f5509cc18daa ("mm: Hardened usercopy") Signed-off-by: Kees Cook <keescook@chromium.org>
2016-08-30audit: consistently record PIDs with task_tgid_nr()Paul Moore
Unfortunately we record PIDs in audit records using a variety of methods despite the correct way being the use of task_tgid_nr(). This patch converts all of these callers, except for the case of AUDIT_SET in audit_receive_msg() (see the comment in the code). Reported-by: Jeff Vander Stoep <jeffv@google.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-30selinux: fix overflow and 0 length allocationsWilliam Roberts
Throughout the SELinux LSM, values taken from sepolicy are used in places where length == 0 or length == <saturated> matter, find and fix these. Signed-off-by: William Roberts <william.c.roberts@intel.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-29selinux: initialize structuresWilliam Roberts
libsepol pointed out an issue where its possible to have an unitialized jmp and invalid dereference, fix this. While we're here, zero allocate all the *_val_to_struct structures. Signed-off-by: William Roberts <william.c.roberts@intel.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-29selinux: detect invalid ebitmapWilliam Roberts
When count is 0 and the highbit is not zero, the ebitmap is not valid and the internal node is not allocated. This causes issues when routines, like mls_context_isvalid() attempt to use the ebitmap_for_each_bit() and ebitmap_node_get_bit() as they assume a highbit > 0 will have a node allocated. Signed-off-by: William Roberts <william.c.roberts@intel.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-23Smack: Use memdup_user() rather than duplicating its implementationMarkus Elfring
Reuse existing functionality from memdup_user() instead of keeping duplicate source code. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Acked-by: Casey Schaufler <casey@schaufler-ca.com>
2016-08-19Make the hardened user-copy code depend on having a hardened allocatorLinus Torvalds
The kernel test robot reported a usercopy failure in the new hardened sanity checks, due to a page-crossing copy of the FPU state into the task structure. This happened because the kernel test robot was testing with SLOB, which doesn't actually do the required book-keeping for slab allocations, and as a result the hardening code didn't realize that the task struct allocation was one single allocation - and the sanity checks fail. Since SLOB doesn't even claim to support hardening (and you really shouldn't use it), the straightforward solution is to just make the usercopy hardening code depend on the allocator supporting it. Reported-by: kernel test robot <xiaolong.ye@intel.com> Cc: Kees Cook <keescook@chromium.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-18selinux: drop SECURITY_SELINUX_POLICYDB_VERSION_MAXWilliam Roberts
Remove the SECURITY_SELINUX_POLICYDB_VERSION_MAX Kconfig option Per: https://github.com/SELinuxProject/selinux/wiki/Kernel-Todo This was only needed on Fedora 3 and 4 and just causes issues now, so drop it. The MAX and MIN should just be whatever the kernel can support. Signed-off-by: William Roberts <william.c.roberts@intel.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-10selinux: Implement dentry_create_files_as() hookVivek Goyal
Calculate what would be the label of newly created file and set that secid in the passed creds. Context of the task which is actually creating file is retrieved from set of creds passed in. (old->security). Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08security, overlayfs: Provide hook to correctly label newly created filesVivek Goyal
During a new file creation we need to make sure new file is created with the right label. New file is created in upper/ so effectively file should get label as if task had created file in upper/. We switched to mounter's creds for actual file creation. Also if there is a whiteout present, then file will be created in work/ dir first and then renamed in upper. In none of the cases file will be labeled as we want it to be. This patch introduces a new hook dentry_create_files_as(), which determines the label/context dentry will get if it had been created by task in upper and modify passed set of creds appropriately. Caller makes use of these new creds for file creation. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> [PM: fix whitespace issues found with checkpatch.pl] [PM: changes to use stat->mode in ovl_create_or_link()] Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08selinux: Pass security pointer to determine_inode_label()Vivek Goyal
Right now selinux_determine_inode_label() works on security pointer of current task. Soon I need this to work on a security pointer retrieved from a set of creds. So start passing in a pointer and caller can decide where to fetch security pointer from. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08selinux: Implementation for inode_copy_up_xattr() hookVivek Goyal
When a file is copied up in overlay, we have already created file on upper/ with right label and there is no need to copy up selinux label/xattr from lower file to upper file. In fact in case of context mount, we don't want to copy up label as newly created file got its label from context= option. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08security,overlayfs: Provide security hook for copy up of xattrs for overlay fileVivek Goyal
Provide a security hook which is called when xattrs of a file are being copied up. This hook is called once for each xattr and LSM can return 0 if the security module wants the xattr to be copied up, 1 if the security module wants the xattr to be discarded on the copy, -EOPNOTSUPP if the security module does not handle/manage the xattr, or a -errno upon an error. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> [PM: whitespace cleanup for checkpatch.pl] Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08selinux: Implementation for inode_copy_up() hookVivek Goyal
A file is being copied up for overlay file system. Prepare a new set of creds and set create_sid appropriately so that new file is created with appropriate label. Overlay inode has right label for both context and non-context mount cases. In case of non-context mount, overlay inode will have the label of lower file and in case of context mount, overlay inode will have the label from context= mount option. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08security, overlayfs: provide copy up security hook for unioned filesVivek Goyal
Provide a security hook to label new file correctly when a file is copied up from lower layer to upper layer of a overlay/union mount. This hook can prepare a new set of creds which are suitable for new file creation during copy up. Caller will use new creds to create file and then revert back to old creds and release new creds. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> [PM: whitespace cleanup to appease checkpatch.pl] Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08Merge tag 'usercopy-v4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux Pull usercopy protection from Kees Cook: "Tbhis implements HARDENED_USERCOPY verification of copy_to_user and copy_from_user bounds checking for most architectures on SLAB and SLUB" * tag 'usercopy-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: mm: SLUB hardened usercopy support mm: SLAB hardened usercopy support s390/uaccess: Enable hardened usercopy sparc/uaccess: Enable hardened usercopy powerpc/uaccess: Enable hardened usercopy ia64/uaccess: Enable hardened usercopy arm64/uaccess: Enable hardened usercopy ARM: uaccess: Enable hardened usercopy x86/uaccess: Enable hardened usercopy mm: Hardened usercopy mm: Implement stack frame object validation mm: Add is_migrate_cma_page
2016-08-08selinux: print leading 0x on ioctlcmd auditsWilliam Roberts
ioctlcmd is currently printing hex numbers, but their is no leading 0x. Thus things like ioctlcmd=1234 are misleading, as the base is not evident. Correct this by adding 0x as a prefix, so ioctlcmd=1234 becomes ioctlcmd=0x1234. Signed-off-by: William Roberts <william.c.roberts@intel.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-08security: Use IS_ENABLED() instead of checking for built-in or moduleJavier Martinez Canillas
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled either built-in or as a module, use that macro instead of open coding the same. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-08-06Merge branch 'work.const-qstr' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull qstr constification updates from Al Viro: "Fairly self-contained bunch - surprising lot of places passes struct qstr * as an argument when const struct qstr * would suffice; it complicates analysis for no good reason. I'd prefer to feed that separately from the assorted fixes (those are in #for-linus and with somewhat trickier topology)" * 'work.const-qstr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: qstr: constify instances in adfs qstr: constify instances in lustre qstr: constify instances in f2fs qstr: constify instances in ext2 qstr: constify instances in vfat qstr: constify instances in procfs qstr: constify instances in fuse qstr constify instances in fs/dcache.c qstr: constify instances in nfs qstr: constify instances in ocfs2 qstr: constify instances in autofs4 qstr: constify instances in hfs qstr: constify instances in hfsplus qstr: constify instances in logfs qstr: constify dentry_init_security
2016-07-29Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - TPM core and driver updates/fixes - IPv6 security labeling (CALIPSO) - Lots of Apparmor fixes - Seccomp: remove 2-phase API, close hole where ptrace can change syscall #" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (156 commits) apparmor: fix SECURITY_APPARMOR_HASH_DEFAULT parameter handling tpm: Add TPM 2.0 support to the Nuvoton i2c driver (NPCT6xx family) tpm: Factor out common startup code tpm: use devm_add_action_or_reset tpm2_i2c_nuvoton: add irq validity check tpm: read burstcount from TPM_STS in one 32-bit transaction tpm: fix byte-order for the value read by tpm2_get_tpm_pt tpm_tis_core: convert max timeouts from msec to jiffies apparmor: fix arg_size computation for when setprocattr is null terminated apparmor: fix oops, validate buffer size in apparmor_setprocattr() apparmor: do not expose kernel stack apparmor: fix module parameters can be changed after policy is locked apparmor: fix oops in profile_unpack() when policy_db is not present apparmor: don't check for vmalloc_addr if kvzalloc() failed apparmor: add missing id bounds check on dfa verification apparmor: allow SYS_CAP_RESOURCE to be sufficient to prlimit another task apparmor: use list_next_entry instead of list_entry_next apparmor: fix refcount race when finding a child profile apparmor: fix ref count leak when profile sha1 hash is read apparmor: check that xindex is in trans_table bounds ...
