path: root/security
2014-06-26evm: prohibit userspace writing 'security.evm' HMAC valueMimi Zohar
commit 2fb1c9a4f2dbc2f0bd2431c7fa64d0b5483864e4 upstream. Calculating the 'security.evm' HMAC value requires access to the EVM encrypted key. Only the kernel should have access to it. This patch prevents userspace tools(eg. setfattr, cp --preserve=xattr) from setting/modifying the 'security.evm' HMAC value directly. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-14selinux: correctly label /proc inodes in use before the policy is loadedPaul Moore
commit f64410ec665479d7b4b77b7519e814253ed0f686 upstream. This patch is based on an earlier patch by Eric Paris, he describes the problem below: "If an inode is accessed before policy load it will get placed on a list of inodes to be initialized after policy load. After policy load we call inode_doinit() which calls inode_doinit_with_dentry() on all inodes accessed before policy load. In the case of inodes in procfs that means we'll end up at the bottom where it does: /* Default to the fs superblock SID. */ isec->sid = sbsec->sid; if ((sbsec->flags & SE_SBPROC) && !S_ISLNK(inode->i_mode)) { if (opt_dentry) { isec->sclass = inode_mode_to_security_class(...) rc = selinux_proc_get_sid(opt_dentry, isec->sclass, &sid); if (rc) goto out_unlock; isec->sid = sid; } } Since opt_dentry is null, we'll never call selinux_proc_get_sid() and will leave the inode labeled with the label on the superblock. I believe a fix would be to mimic the behavior of xattrs. Look for an alias of the inode. If it can't be found, just leave the inode uninitialized (and pick it up later) if it can be found, we should be able to call selinux_proc_get_sid() ..." On a system exhibiting this problem, you will notice a lot of files in /proc with the generic "proc_t" type (at least the ones that were accessed early in the boot), for example: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:proc_t:s0 /proc/sys/kernel/shmmax However, with this patch in place we see the expected result: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:sysctl_kernel_t:s0 /proc/sys/kernel/shmmax Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-11SELinux: bigendian problems with filename trans rulesEric Paris
commit 9085a6422900092886da8c404e1c5340c4ff1cbf upstream. When writing policy via /sys/fs/selinux/policy I wrote the type and class of filename trans rules in CPU endian instead of little endian. On x86_64 this works just fine, but it means that on big endian arch's like ppc64 and s390 userspace reads the policy and converts it from le32_to_cpu. So the values are all screwed up. Write the values in le format like it should have been to start. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-20SELinux: Fix kernel BUG on empty security contexts.Stephen Smalley
commit 2172fa709ab32ca60e86179dc67d0857be8e2c98 upstream. Setting an empty security context (length=0) on a file will lead to incorrectly dereferencing the type and other fields of the security context structure, yielding a kernel BUG. As a zero-length security context is never valid, just reject all such security contexts whether coming from userspace via setxattr or coming from the filesystem upon a getxattr request by SELinux. Setting a security context value (empty or otherwise) unknown to SELinux in the first place is only possible for a root process (CAP_MAC_ADMIN), and, if running SELinux in enforcing mode, only if the corresponding SELinux mac_admin permission is also granted to the domain by policy. In Fedora policies, this is only allowed for specific domains such as livecd for setting down security contexts that are not defined in the build host policy. Reproducer: su setenforce 0 touch foo setfattr -n security.selinux foo Caveat: Relabeling or removing foo after doing the above may not be possible without booting with SELinux disabled. Any subsequent access to foo after doing the above will also trigger the BUG. BUG output from Matthew Thode: [ 473.893141] ------------[ cut here ]------------ [ 473.962110] kernel BUG at security/selinux/ss/services.c:654! [ 473.995314] invalid opcode: 0000 [#6] SMP [ 474.027196] Modules linked in: [ 474.058118] CPU: 0 PID: 8138 Comm: ls Tainted: G D I 3.13.0-grsec #1 [ 474.116637] Hardware name: Supermicro X8ST3/X8ST3, BIOS 2.0 07/29/10 [ 474.149768] task: ffff8805f50cd010 ti: ffff8805f50cd488 task.ti: ffff8805f50cd488 [ 474.183707] RIP: 0010:[<ffffffff814681c7>] [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 474.219954] RSP: 0018:ffff8805c0ac3c38 EFLAGS: 00010246 [ 474.252253] RAX: 0000000000000000 RBX: ffff8805c0ac3d94 RCX: 0000000000000100 [ 474.287018] RDX: ffff8805e8aac000 RSI: 00000000ffffffff RDI: ffff8805e8aaa000 [ 474.321199] RBP: ffff8805c0ac3cb8 R08: 0000000000000010 R09: 0000000000000006 [ 474.357446] R10: 0000000000000000 R11: ffff8805c567a000 R12: 0000000000000006 [ 474.419191] R13: ffff8805c2b74e88 R14: 00000000000001da R15: 0000000000000000 [ 474.453816] FS: 00007f2e75220800(0000) GS:ffff88061fc00000(0000) knlGS:0000000000000000 [ 474.489254] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 474.522215] CR2: 00007f2e74716090 CR3: 00000005c085e000 CR4: 00000000000207f0 [ 474.556058] Stack: [ 474.584325] ffff8805c0ac3c98 ffffffff811b549b ffff8805c0ac3c98 ffff8805f1190a40 [ 474.618913] ffff8805a6202f08 ffff8805c2b74e88 00068800d0464990 ffff8805e8aac860 [ 474.653955] ffff8805c0ac3cb8 000700068113833a ffff880606c75060 ffff8805c0ac3d94 [ 474.690461] Call Trace: [ 474.723779] [<ffffffff811b549b>] ? lookup_fast+0x1cd/0x22a [ 474.778049] [<ffffffff81468824>] security_compute_av+0xf4/0x20b [ 474.811398] [<ffffffff8196f419>] avc_compute_av+0x2a/0x179 [ 474.843813] [<ffffffff8145727b>] avc_has_perm+0x45/0xf4 [ 474.875694] [<ffffffff81457d0e>] inode_has_perm+0x2a/0x31 [ 474.907370] [<ffffffff81457e76>] selinux_inode_getattr+0x3c/0x3e [ 474.938726] [<ffffffff81455cf6>] security_inode_getattr+0x1b/0x22 [ 474.970036] [<ffffffff811b057d>] vfs_getattr+0x19/0x2d [ 475.000618] [<ffffffff811b05e5>] vfs_fstatat+0x54/0x91 [ 475.030402] [<ffffffff811b063b>] vfs_lstat+0x19/0x1b [ 475.061097] [<ffffffff811b077e>] SyS_newlstat+0x15/0x30 [ 475.094595] [<ffffffff8113c5c1>] ? __audit_syscall_entry+0xa1/0xc3 [ 475.148405] [<ffffffff8197791e>] system_call_fastpath+0x16/0x1b [ 475.179201] Code: 00 48 85 c0 48 89 45 b8 75 02 0f 0b 48 8b 45 a0 48 8b 3d 45 d0 b6 00 8b 40 08 89 c6 ff ce e8 d1 b0 06 00 48 85 c0 49 89 c7 75 02 <0f> 0b 48 8b 45 b8 4c 8b 28 eb 1e 49 8d 7d 08 be 80 01 00 00 e8 [ 475.255884] RIP [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 475.296120] RSP <ffff8805c0ac3c38> [ 475.328734] ---[ end trace f076482e9d754adc ]--- Reported-by: Matthew Thode <mthode@mthode.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13SELinux: Fix memory leak upon loading policyTetsuo Handa
commit 8ed814602876bec9bad2649ca17f34b499357a1c upstream. Hello. I got below leak with linux-3.10.0-54.0.1.el7.x86_64 . [ 681.903890] kmemleak: 5538 new suspected memory leaks (see /sys/kernel/debug/kmemleak) Below is a patch, but I don't know whether we need special handing for undoing ebitmap_set_bit() call. ---------- >>From fe97527a90fe95e2239dfbaa7558f0ed559c0992 Mon Sep 17 00:00:00 2001 From: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Date: Mon, 6 Jan 2014 16:30:21 +0900 Subject: SELinux: Fix memory leak upon loading policy Commit 2463c26d "SELinux: put name based create rules in a hashtable" did not check return value from hashtab_insert() in filename_trans_read(). It leaks memory if hashtab_insert() returns error. unreferenced object 0xffff88005c9160d0 (size 8): comm "systemd", pid 1, jiffies 4294688674 (age 235.265s) hex dump (first 8 bytes): 57 0b 00 00 6b 6b 6b a5 W...kkk. backtrace: [<ffffffff816604ae>] kmemleak_alloc+0x4e/0xb0 [<ffffffff811cba5e>] kmem_cache_alloc_trace+0x12e/0x360 [<ffffffff812aec5d>] policydb_read+0xd1d/0xf70 [<ffffffff812b345c>] security_load_policy+0x6c/0x500 [<ffffffff812a623c>] sel_write_load+0xac/0x750 [<ffffffff811eb680>] vfs_write+0xc0/0x1f0 [<ffffffff811ec08c>] SyS_write+0x4c/0xa0 [<ffffffff81690419>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff However, we should not return EEXIST error to the caller, or the systemd will show below message and the boot sequence freezes. systemd[1]: Failed to load SELinux policy. Freezing. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-29SELinux: Fix possible NULL pointer dereference in selinux_inode_permission()Steven Rostedt
commit 3dc91d4338d698ce77832985f9cb183d8eeaf6be upstream. While running stress tests on adding and deleting ftrace instances I hit this bug: BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 IP: selinux_inode_permission+0x85/0x160 PGD 63681067 PUD 7ddbe067 PMD 0 Oops: 0000 [#1] PREEMPT CPU: 0 PID: 5634 Comm: ftrace-test-mki Not tainted 3.13.0-rc4-test-00033-gd2a6dde-dirty #20 Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006 task: ffff880078375800 ti: ffff88007ddb0000 task.ti: ffff88007ddb0000 RIP: 0010:[<ffffffff812d8bc5>] [<ffffffff812d8bc5>] selinux_inode_permission+0x85/0x160 RSP: 0018:ffff88007ddb1c48 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000800000 RCX: ffff88006dd43840 RDX: 0000000000000001 RSI: 0000000000000081 RDI: ffff88006ee46000 RBP: ffff88007ddb1c88 R08: 0000000000000000 R09: ffff88007ddb1c54 R10: 6e6576652f6f6f66 R11: 0000000000000003 R12: 0000000000000000 R13: 0000000000000081 R14: ffff88006ee46000 R15: 0000000000000000 FS: 00007f217b5b6700(0000) GS:ffffffff81e21000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033^M CR2: 0000000000000020 CR3: 000000006a0fe000 CR4: 00000000000007f0 Call Trace: security_inode_permission+0x1c/0x30 __inode_permission+0x41/0xa0 inode_permission+0x18/0x50 link_path_walk+0x66/0x920 path_openat+0xa6/0x6c0 do_filp_open+0x43/0xa0 do_sys_open+0x146/0x240 SyS_open+0x1e/0x20 system_call_fastpath+0x16/0x1b Code: 84 a1 00 00 00 81 e3 00 20 00 00 89 d8 83 c8 02 40 f6 c6 04 0f 45 d8 40 f6 c6 08 74 71 80 cf 02 49 8b 46 38 4c 8d 4d cc 45 31 c0 <0f> b7 50 20 8b 70 1c 48 8b 41 70 89 d9 8b 78 04 e8 36 cf ff ff RIP selinux_inode_permission+0x85/0x160 CR2: 0000000000000020 Investigating, I found that the inode->i_security was NULL, and the dereference of it caused the oops. in selinux_inode_permission(): isec = inode->i_security; rc = avc_has_perm_noaudit(sid, isec->sid, isec->sclass, perms, 0, &avd); Note, the crash came from stressing the deletion and reading of debugfs files. I was not able to recreate this via normal files. But I'm not sure they are safe. It may just be that the race window is much harder to hit. What seems to have happened (and what I have traced), is the file is being opened at the same time the file or directory is being deleted. As the dentry and inode locks are not held during the path walk, nor is the inodes ref counts being incremented, there is nothing saving these structures from being discarded except for an rcu_read_lock(). The rcu_read_lock() protects against freeing of the inode, but it does not protect freeing of the inode_security_struct. Now if the freeing of the i_security happens with a call_rcu(), and the i_security field of the inode is not changed (it gets freed as the inode gets freed) then there will be no issue here. (Linus Torvalds suggested not setting the field to NULL such that we do not need to check if it is NULL in the permission check). Note, this is a hack, but it fixes the problem at hand. A real fix is to restructure the destroy_inode() to call all the destructor handlers from the RCU callback. But that is a major job to do, and requires a lot of work. For now, we just band-aid this bug with this fix (it works), and work on a more maintainable solution in the future. Link: http://lkml.kernel.org/r/20140109101932.0508dec7@gandalf.local.home Link: http://lkml.kernel.org/r/20140109182756.17abaaa8@gandalf.local.home Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-08selinux: process labeled IPsec TCP SYN-ACK packets properly in ↵Paul Moore
selinux_ip_postroute() commit c0828e50485932b7e019df377a6b0a8d1ebd3080 upstream. Due to difficulty in arriving at the proper security label for TCP SYN-ACK packets in selinux_ip_postroute(), we need to check packets while/before they are undergoing XFRM transforms instead of waiting until afterwards so that we can determine the correct security label. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-08selinux: look for IPsec labels on both inbound and outbound packetsPaul Moore
commit 817eff718dca4e54d5721211ddde0914428fbb7c upstream. Previously selinux_skb_peerlbl_sid() would only check for labeled IPsec security labels on inbound packets, this patch enables it to check both inbound and outbound traffic for labeled IPsec security labels. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-08selinux: selinux_setprocattr()->ptrace_parent() needs rcu_read_lock()Oleg Nesterov
commit c0c1439541f5305b57a83d599af32b74182933fe upstream. selinux_setprocattr() does ptrace_parent(p) under task_lock(p), but task_struct->alloc_lock doesn't pin ->parent or ->ptrace, this looks confusing and triggers the "suspicious RCU usage" warning because ptrace_parent() does rcu_dereference_check(). And in theory this is wrong, spin_lock()->preempt_disable() doesn't necessarily imply rcu_read_lock() we need to access the ->parent. Reported-by: Evan McNabb <emcnabb@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-08selinux: fix broken peer recv checkChad Hanson
commit 46d01d63221c3508421dd72ff9c879f61053cffc upstream. Fix a broken networking check. Return an error if peer recv fails. If secmark is active and the packet recv succeeds the peer recv error is ignored. Signed-off-by: Chad Hanson <chanson@trustedcs.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute()Paul Moore
commit 446b802437f285de68ffb8d6fac3c44c3cab5b04 upstream. In selinux_ip_postroute() we perform access checks based on the packet's security label. For locally generated traffic we get the packet's security label from the associated socket; this works in all cases except for TCP SYN-ACK packets. In the case of SYN-ACK packet's the correct security label is stored in the connection's request_sock, not the server's socket. Unfortunately, at the point in time when selinux_ip_postroute() is called we can't query the request_sock directly, we need to recreate the label using the same logic that originally labeled the associated request_sock. See the inline comments for more explanation. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output()Paul Moore
commit 47180068276a04ed31d24fe04c673138208b07a9 upstream. In selinux_ip_output() we always label packets based on the parent socket. While this approach works in almost all cases, it doesn't work in the case of TCP SYN-ACK packets when the correct label is not the label of the parent socket, but rather the label of the larval socket represented by the request_sock struct. Unfortunately, since the request_sock isn't queued on the parent socket until *after* the SYN-ACK packet is sent, we can't lookup the request_sock to determine the correct label for the packet; at this point in time the best we can do is simply pass/NF_ACCEPT the packet. It must be said that simply passing the packet without any explicit labeling action, while far from ideal, is not terrible as the SYN-ACK packet will inherit any IP option based labeling from the initial connection request so the label *should* be correct and all our access controls remain in place so we shouldn't have to worry about information leaks. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04selinux: correct locking in selinux_netlbl_socket_connect)Paul Moore
commit 42d64e1add3a1ce8a787116036163b8724362145 upstream. The SELinux/NetLabel glue code has a locking bug that affects systems with NetLabel enabled, see the kernel error message below. This patch corrects this problem by converting the bottom half socket lock to a more conventional, and correct for this call-path, lock_sock() call. =============================== [ INFO: suspicious RCU usage. ] 3.11.0-rc3+ #19 Not tainted ------------------------------- net/ipv4/cipso_ipv4.c:1928 suspicious rcu_dereference_protected() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by ping/731: #0: (slock-AF_INET/1){+.-...}, at: [...] selinux_netlbl_socket_connect #1: (rcu_read_lock){.+.+..}, at: [<...>] netlbl_conn_setattr stack backtrace: CPU: 1 PID: 731 Comm: ping Not tainted 3.11.0-rc3+ #19 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 0000000000000001 ffff88006f659d28 ffffffff81726b6a ffff88003732c500 ffff88006f659d58 ffffffff810e4457 ffff88006b845a00 0000000000000000 000000000000000c ffff880075aa2f50 ffff88006f659d90 ffffffff8169bec7 Call Trace: [<ffffffff81726b6a>] dump_stack+0x54/0x74 [<ffffffff810e4457>] lockdep_rcu_suspicious+0xe7/0x120 [<ffffffff8169bec7>] cipso_v4_sock_setattr+0x187/0x1a0 [<ffffffff8170f317>] netlbl_conn_setattr+0x187/0x190 [<ffffffff8170f195>] ? netlbl_conn_setattr+0x5/0x190 [<ffffffff8131ac9e>] selinux_netlbl_socket_connect+0xae/0xc0 [<ffffffff81303025>] selinux_socket_connect+0x135/0x170 [<ffffffff8119d127>] ? might_fault+0x57/0xb0 [<ffffffff812fb146>] security_socket_connect+0x16/0x20 [<ffffffff815d3ad3>] SYSC_connect+0x73/0x130 [<ffffffff81739a85>] ? sysret_check+0x22/0x5d [<ffffffff810e5e2d>] ? trace_hardirqs_on_caller+0xfd/0x1c0 [<ffffffff81373d4e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff815d52be>] SyS_connect+0xe/0x10 [<ffffffff81739a59>] system_call_fastpath+0x16/0x1b Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29Revert "ima: policy for RAMFS"Mimi Zohar
commit 08de59eb144d7c41351a467442f898d720f0f15f upstream. This reverts commit 4c2c392763a682354fac65b6a569adec4e4b5387. Everything in the initramfs should be measured and appraised, but until the initramfs has extended attribute support, at least measured. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28key: Fix resource leakAlan Cox
commit a84a921978b7d56e0e4b87ffaca6367429b4d8ff upstream. On an error iov may still have been reallocated and need freeing Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20selinux: use GFP_ATOMIC under spin_lockDan Carpenter
commit 4502403dcf8f5c76abd4dbab8726c8e4ecb5cd34 upstream. The call tree here is: sk_clone_lock() <- takes bh_lock_sock(newsk); xfrm_sk_clone_policy() __xfrm_sk_clone_policy() clone_policy() <- uses GFP_ATOMIC for allocations security_xfrm_policy_clone() security_ops->xfrm_policy_clone_security() selinux_xfrm_policy_clone() Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-14Fix: compat_rw_copy_check_uvector() misuse in aio, readv, writev, and ↵Mathieu Desnoyers
security keys commit 8aec0f5d4137532de14e6554fd5dd201ff3a3c49 upstream. Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to compat_process_vm_rw() shows that the compatibility code requires an explicit "access_ok()" check before calling compat_rw_copy_check_uvector(). The same difference seems to appear when we compare fs/read_write.c:do_readv_writev() to fs/compat.c:compat_do_readv_writev(). This subtle difference between the compat and non-compat requirements should probably be debated, as it seems to be error-prone. In fact, there are two others sites that use this function in the Linux kernel, and they both seem to get it wrong: Now shifting our attention to fs/aio.c, we see that aio_setup_iocb() also ends up calling compat_rw_copy_check_uvector() through aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to be missing. Same situation for security/keys/compat.c:compat_keyctl_instantiate_key_iov(). I propose that we add the access_ok() check directly into compat_rw_copy_check_uvector(), so callers don't have to worry about it, and it therefore makes the compat call code similar to its non-compat counterpart. Place the access_ok() check in the same location where copy_from_user() can trigger a -EFAULT error in the non-compat code, so the ABI behaviors are alike on both compat and non-compat. While we are here, fix compat_do_readv_writev() so it checks for compat_rw_copy_check_uvector() negative return values. And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error handling. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-14keys: fix race with concurrent install_user_keyrings()David Howells
commit 0da9dfdd2cd9889201bc6f6f43580c99165cd087 upstream. This fixes CVE-2013-1792. There is a race in install_user_keyrings() that can cause a NULL pointer dereference when called concurrently for the same user if the uid and uid-session keyrings are not yet created. It might be possible for an unprivileged user to trigger this by calling keyctl() from userspace in parallel immediately after logging in. Assume that we have two threads both executing lookup_user_key(), both looking for KEY_SPEC_USER_SESSION_KEYRING. THREAD A THREAD B =============================== =============================== ==>call install_user_keyrings(); if (!cred->user->session_keyring) ==>call install_user_keyrings() ... user->uid_keyring = uid_keyring; if (user->uid_keyring) return 0; <== key = cred->user->session_keyring [== NULL] user->session_keyring = session_keyring; atomic_inc(&key->usage); [oops] At the point thread A dereferences cred->user->session_keyring, thread B hasn't updated user->session_keyring yet, but thread A assumes it is populated because install_user_keyrings() returned ok. The race window is really small but can be exploited if, for example, thread B is interrupted or preempted after initializing uid_keyring, but before doing setting session_keyring. This couldn't be reproduced on a stock kernel. However, after placing systemtap probe on 'user->session_keyring = session_keyring;' that introduced some delay, the kernel could be crashed reliably. Fix this by checking both pointers before deciding whether to return. Alternatively, the test could be done away with entirely as it is checked inside the mutex - but since the mutex is global, that may not be the best way. Signed-off-by: David Howells <dhowells@redhat.com> Reported-by: Mateusz Guzik <mguzik@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27evm: checking if removexattr is not a NULLDmitry Kasatkin
commit a67adb997419fb53540d4a4f79c6471c60bc69b6 upstream. The following lines of code produce a kernel oops. fd = socket(PF_FILE, SOCK_STREAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0); fchmod(fd, 0666); [ 139.922364] BUG: unable to handle kernel NULL pointer dereference at (null) [ 139.924982] IP: [< (null)>] (null) [ 139.924982] *pde = 00000000 [ 139.924982] Oops: 0000 [#5] SMP [ 139.924982] Modules linked in: fuse dm_crypt dm_mod i2c_piix4 serio_raw evdev binfmt_misc button [ 139.924982] Pid: 3070, comm: acpid Tainted: G D 3.8.0-rc2-kds+ #465 Bochs Bochs [ 139.924982] EIP: 0060:[<00000000>] EFLAGS: 00010246 CPU: 0 [ 139.924982] EIP is at 0x0 [ 139.924982] EAX: cf5ef000 EBX: cf5ef000 ECX: c143d600 EDX: c15225f2 [ 139.924982] ESI: cf4d2a1c EDI: cf4d2a1c EBP: cc02df10 ESP: cc02dee4 [ 139.924982] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 [ 139.924982] CR0: 80050033 CR2: 00000000 CR3: 0c059000 CR4: 000006d0 [ 139.924982] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 [ 139.924982] DR6: ffff0ff0 DR7: 00000400 [ 139.924982] Process acpid (pid: 3070, ti=cc02c000 task=d7705340 task.ti=cc02c000) [ 139.924982] Stack: [ 139.924982] c1203c88 00000000 cc02def4 cf4d2a1c ae21eefa 471b60d5 1083c1ba c26a5940 [ 139.924982] e891fb5e 00000041 00000004 cc02df1c c1203964 00000000 cc02df4c c10e20c3 [ 139.924982] 00000002 00000000 00000000 22222222 c1ff2222 cf5ef000 00000000 d76efb08 [ 139.924982] Call Trace: [ 139.924982] [<c1203c88>] ? evm_update_evmxattr+0x5b/0x62 [ 139.924982] [<c1203964>] evm_inode_post_setattr+0x22/0x26 [ 139.924982] [<c10e20c3>] notify_change+0x25f/0x281 [ 139.924982] [<c10cbf56>] chmod_common+0x59/0x76 [ 139.924982] [<c10e27a1>] ? put_unused_fd+0x33/0x33 [ 139.924982] [<c10cca09>] sys_fchmod+0x39/0x5c [ 139.924982] [<c13f4f30>] syscall_call+0x7/0xb [ 139.924982] Code: Bad EIP value. This happens because sockets do not define the removexattr operation. Before removing the xattr, verify the removexattr function pointer is not NULL. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26selinux: fix sel_netnode_insert() suspicious rcu dereferenceDave Jones
commit 88a693b5c1287be4da937699cb82068ce9db0135 upstream. =============================== [ INFO: suspicious RCU usage. ] 3.5.0-rc1+ #63 Not tainted ------------------------------- security/selinux/netnode.c:178 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 1 lock held by trinity-child1/8750: #0: (sel_netnode_lock){+.....}, at: [<ffffffff812d8f8a>] sel_netnode_sid+0x16a/0x3e0 stack backtrace: Pid: 8750, comm: trinity-child1 Not tainted 3.5.0-rc1+ #63 Call Trace: [<ffffffff810cec2d>] lockdep_rcu_suspicious+0xfd/0x130 [<ffffffff812d91d1>] sel_netnode_sid+0x3b1/0x3e0 [<ffffffff812d8e20>] ? sel_netnode_find+0x1a0/0x1a0 [<ffffffff812d24a6>] selinux_socket_bind+0xf6/0x2c0 [<ffffffff810cd1dd>] ? trace_hardirqs_off+0xd/0x10 [<ffffffff810cdb55>] ? lock_release_holdtime.part.9+0x15/0x1a0 [<ffffffff81093841>] ? lock_hrtimer_base+0x31/0x60 [<ffffffff812c9536>] security_socket_bind+0x16/0x20 [<ffffffff815550ca>] sys_bind+0x7a/0x100 [<ffffffff816c03d5>] ? sysret_check+0x22/0x5d [<ffffffff810d392d>] ? trace_hardirqs_on_caller+0x10d/0x1a0 [<ffffffff8133b09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff816c03a9>] system_call_fastpath+0x16/0x1b This patch below does what Paul McKenney suggested in the previous thread. Signed-off-by: Dave Jones <davej@redhat.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-07Yama: handle 32-bit userspace prctlKees Cook
commit 2e4930eb7c8fb20a39dfb5f8a8f80402710dcea8 upstream. When running a 64-bit kernel and receiving prctls from a 32-bit userspace, the "-1" used as an unsigned long will end up being misdetected. The kernel is looking for 0xffffffffffffffff instead of 0xffffffff. Since prctl lacks a distinct compat interface, Yama needs to handle this translation itself. As such, support either value as meaning PR_SET_PTRACER_ANY, to avoid breaking the ABI for 64-bit. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09posix_types.h: Cleanup stale __NFDBITS and related definitionsJosh Boyer
commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream. Recently, glibc made a change to suppress sign-conversion warnings in FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the kernel's definition of __NFDBITS if applications #include <linux/types.h> after including <sys/select.h>. A build failure would be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2 flags to gcc. It was suggested that the kernel should either match the glibc definition of __NFDBITS or remove that entirely. The current in-kernel uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no uses of the related __FDELT and __FDMASK defines. Given that, we'll continue the cleanup that was started with commit 8b3d1cda4f5f ("posix_types: Remove fd_set macros") and drop the remaining unused macros. Additionally, linux/time.h has similar macros defined that expand to nothing so we'll remove those at the same time. Reported-by: Jeff Law <law@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> [ .. and fix up whitespace as per akpm ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01SELinux: if sel_make_bools errors don't leave inconsistent stateEric Paris
commit 154c50ca4eb9ae472f50b6a481213e21ead4457d upstream. We reset the bool names and values array to NULL, but do not reset the number of entries in these arrays to 0. If we error out and then get back into this function we will walk these NULL pointers based on the belief that they are non-zero length. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-19security: fix compile error in commoncap.cJonghwan Choi
Add missing "personality.h" security/commoncap.c: In function 'cap_bprm_set_creds': security/commoncap.c:510: error: 'PER_CLEAR_ON_SETID' undeclared (first use in this function) security/commoncap.c:510: error: (Each undeclared identifier is reported only once security/commoncap.c:510: error: for each function it appears in.) Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-04-18fcaps: clear the same personality flags as suid when fcaps are usedEric Paris
If a process increases permissions using fcaps all of the dangerous personality flags which are cleared for suid apps should also be cleared. Thus programs given priviledge with fcaps will continue to have address space randomization enabled even if the parent tried to disable it to make it easier to attack. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-04-18Smack: move label list initializationCasey Schaufler
A kernel with Smack enabled will fail if tmpfs has xattr support. Move the initialization of predefined Smack label list entries to the LSM initialization from the smackfs setup. This became an issue when tmpfs acquired xattr support, but was never correct. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-04-10Smack: build when CONFIG_AUDIT not definedKees Cook
This fixes builds where CONFIG_AUDIT is not defined and CONFIG_SECURITY_SMACK=y. This got introduced by the stack-usage reducation commit 48c62af68a40 ("LSM: shrink the common_audit_data data union"). Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03lsm_audit: don't specify the audit pre/post callbacks in 'struct ↵Linus Torvalds
common_audit_data' It just bloats the audit data structure for no good reason, since the only time those fields are filled are just before calling the common_lsm_audit() function, which is also the only user of those fields. So just make them be the arguments to common_lsm_audit(), rather than bloating that structure that is passed around everywhere, and is initialized in hot paths. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03SELinux: do not allocate stack space for AVC data unless neededEric Paris
Instead of declaring the entire selinux_audit_data on the stack when we start an operation on declare it on the stack if we are going to use it. We know it's usefulness at the end of the security decision and can declare it there. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03SELinux: remove avd from slow_avc_audit()Eric Paris
We don't use the argument, so remove it. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03SELinux: remove avd from selinux_audit_dataEric Paris
We do not use it. Remove it. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03LSM: shrink the common_audit_data data unionEric Paris
After shrinking the common_audit_data stack usage for private LSM data I'm not going to shrink the data union. To do this I'm going to move anything larger than 2 void * ptrs to it's own structure and require it to be declared separately on the calling stack. Thus hot paths which don't need more than a couple pointer don't have to declare space to hold large unneeded structures. I could get this down to one void * by dealing with the key struct and the struct path. We'll see if that is helpful after taking care of networking. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03LSM: shrink sizeof LSM specific portion of common_audit_dataEric Paris
Linus found that the gigantic size of the common audit data caused a big perf hit on something as simple as running stat() in a loop. This patch requires LSMs to declare the LSM specific portion separately rather than doing it in a union. Thus each LSM can be responsible for shrinking their portion and don't have to pay a penalty just because other LSMs have a bigger space requirement. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second try at vfs part d#2 from Al Viro: "Miklos' first series (with do_lookup() rewrite split into edible chunks) + assorted bits and pieces. The 'untangling of do_lookup()' series is is a splitup of what used to be a monolithic patch from Miklos, so this series is basically "how do I convince myself that his patch is correct (or find a hole in it)". No holes found and I like the resulting cleanup, so in it went..." Changes from try 1: Fix a boot problem with selinux, and commit messages prettied up a bit. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (24 commits) vfs: fix out-of-date dentry_unhash() comment vfs: split __lookup_hash untangling do_lookup() - take __lookup_hash()-calling case out of line. untangling do_lookup() - switch to calling __lookup_hash() untangling do_lookup() - merge d_alloc_and_lookup() callers untangling do_lookup() - merge failure exits in !dentry case untangling do_lookup() - massage !dentry case towards __lookup_hash() untangling do_lookup() - get rid of need_reval in !dentry case untangling do_lookup() - eliminate a loop. untangling do_lookup() - expand the area under ->i_mutex untangling do_lookup() - isolate !dentry stuff from the rest of it. vfs: move MAY_EXEC check from __lookup_hash() vfs: don't revalidate just looked up dentry vfs: fix d_need_lookup/d_revalidate order in do_lookup ext3: move headers to fs/ext3/ migrate ext2_fs.h guts to fs/ext2/ext2.h new helper: ext2_image_size() get rid of pointless includes of ext2_fs.h ext2: No longer export ext2_fs.h to user space mtdchar: kill persistently held vfsmount ...
2012-03-31get rid of pointless includes of ext2_fs.hAl Viro
2012-03-31selinuxfs: merge dentry allocation into sel_make_dir()Al Viro
2012-03-31selinux: inline avc_audit() and avc_has_perm_noaudit() into callerLinus Torvalds
Now that all the slow-path code is gone from these functions, we can inline them into the main caller - avc_has_perm_flags(). Now the compiler can see that 'avc' is allocated on the stack for this case, which helps register pressure a bit. It also actually shrinks the total stack frame, because the stack frame that avc_has_perm_flags() always needed (for that 'avc' allocation) is now sufficient for the inlined functions too. Inlining isn't bad - but mindless inlining of cold code (see the previous commit) is. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-31selinux: don't inline slow-path code into avc_has_perm_noaudit()Linus Torvalds
The selinux AVC paths remain some of the hottest (and deepest) codepaths at filename lookup time, and we make it worse by having the slow path cases take up I$ and stack space even when they don't trigger. Gcc tends to always want to inline functions that are just called once - never mind that this might make for slower and worse code in the caller. So this tries to improve on it a bit by making the slow-path cases explicitly separate functions that are marked noinline, causing gcc to at least no longer allocate stack space for them unless they are actually called. It also seems to help register allocation a tiny bit, since gcc now doesn't take the slow case code into account. Uninlining the slow path may also allow us to inline the remaining hot path into the one caller that actually matters: avc_has_perm_flags(). I'll have to look at that separately, but both avc_audit() and avc_has_perm_noaudit() are now small and lean enough that inlining them may make sense. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28apparmor: Fix change_onexec when called from a confined taskJohn Johansen
Fix failure in aa_change_onexec api when the request is made from a confined task. This failure was caused by two problems The AA_MAY_ONEXEC perm was not being mapped correctly for this case. The executable name was being checked as second time instead of using the requested onexec profile name, which may not be the same as the exec profile name. This mistake can not be exploited to grant extra permission because of the above flaw where the ONEXEC permission was not being mapped so it will not be granted. BugLink: http://bugs.launchpad.net/bugs/963756 Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-03-26SELinux: selinux/xfrm.h needs net/flow.hDavid Howells
selinux/xfrm.h needs to #include net/flow.h or else suffer: In file included from security/selinux/ss/services.c:69:0: security/selinux/include/xfrm.h: In function 'selinux_xfrm_notify_policyload': security/selinux/include/xfrm.h:53:14: error: 'flow_cache_genid' undeclared (first use in this function) security/selinux/include/xfrm.h:53:14: note: each undeclared identifier is reported only once for each function it appears in Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-23usermodehelper: kill umh_wait, renumber UMH_* constantsOleg Nesterov
No functional changes. It is not sane to use UMH_KILLABLE with enum umh_wait, but obviously we do not want another argument in call_usermodehelper_* helpers. Kill this enum, use the plain int. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23usermodehelper: use UMH_WAIT_PROC consistentlyOleg Nesterov
A few call_usermodehelper() callers use the hardcoded constant instead of the proper UMH_WAIT_PROC, fix them. Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Michal Januszewski <spock@gentoo.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates for Linux 3.4 from Trond Myklebust: "New features include: - Add NFS client support for containers. This should enable most of the necessary functionality, including lockd support, and support for rpc.statd, NFSv4 idmapper and RPCSEC_GSS upcalls into the correct network namespace from which the mount system call was issued. - NFSv4 idmapper scalability improvements Base the idmapper cache on the keyring interface to allow concurrent access to idmapper entries. Start the process of migrating users from the single-threaded daemon-based approach to the multi-threaded request-key based approach. - NFSv4.1 implementation id. Allows the NFSv4.1 client and server to mutually identify each other for logging and debugging purposes. - Support the 'vers=4.1' mount option for mounting NFSv4.1 instead of having to use the more counterintuitive 'vers=4,minorversion=1'. - SUNRPC tracepoints. Start the process of adding tracepoints in order to improve debugging of the RPC layer. - pNFS object layout support for autologin. Important bugfixes include: - Fix a bug in rpc_wake_up/rpc_wake_up_status that caused them to fail to wake up all tasks when applied to priority waitqueues. - Ensure that we handle read delegations correctly, when we try to truncate a file. - A number of fixes for NFSv4 state manager loops (mostly to do with delegation recovery)." * tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (224 commits) NFS: fix sb->s_id in nfs debug prints xprtrdma: Remove assumption that each segment is <= PAGE_SIZE xprtrdma: The transport should not bug-check when a dup reply is received pnfs-obj: autologin: Add support for protocol autologin NFS: Remove nfs4_setup_sequence from generic rename code NFS: Remove nfs4_setup_sequence from generic unlink code NFS: Remove nfs4_setup_sequence from generic read code NFS: Remove nfs4_setup_sequence from generic write code NFS: Fix more NFS debug related build warnings SUNRPC/LOCKD: Fix build warnings when CONFIG_SUNRPC_DEBUG is undefined nfs: non void functions must return a value SUNRPC: Kill compiler warning when RPC_DEBUG is unset SUNRPC/NFS: Add Kbuild dependencies for NFS_DEBUG/RPC_DEBUG NFS: Use cond_resched_lock() to reduce latencies in the commit scans NFSv4: It is not safe to dereference lsp->ls_state in release_lockowner NFS: ncommit count is being double decremented SUNRPC: We must not use list_for_each_entry_safe() in rpc_wake_up() Try using machine credentials for RENEW calls NFSv4.1: Fix a few issues in filelayout_commit_pagelist NFSv4.1: Clean ups and bugfixes for the pNFS read/writeback/commit code ...
2012-03-22security: optimize avc_audit() common pathLinus Torvalds
avc_audit() did a lot of jumping around and had a big stack frame, all for the uncommon case. Split up the uncommon case (which we really can't make go fast anyway) into its own slow function, and mark the conditional branches appropriately for the common likely case. This causes avc_audit() to no longer show up as one of the hottest functions on the branch profiles (the new "perf -b" thing), and makes the cycle profiles look really nice and dense too. The whole audit path is still annoyingly very much one of the biggest costs of name lookup, so these things are worth optimizing for. I wish we could just tell people to turn it off, but realistically we do need it: we just need to make sure that the overhead of the necessary evil is as low as possible. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates for 3.4 from James Morris: "The main addition here is the new Yama security module from Kees Cook, which was discussed at the Linux Security Summit last year. Its purpose is to collect miscellaneous DAC security enhancements in one place. This also marks a departure in policy for LSM modules, which were previously limited to being standalone access control systems. Chromium OS is using Yama, and I believe there are plans for Ubuntu, at least. This patchset also includes maintenance updates for AppArmor, TOMOYO and others." Fix trivial conflict in <net/sock.h> due to the jumo_label->static_key rename. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) AppArmor: Fix location of const qualifier on generated string tables TOMOYO: Return error if fails to delete a domain AppArmor: add const qualifiers to string arrays AppArmor: Add ability to load extended policy TOMOYO: Return appropriate value to poll(). AppArmor: Move path failure information into aa_get_name and rename AppArmor: Update dfa matching routines. AppArmor: Minor cleanup of d_namespace_path to consolidate error handling AppArmor: Retrieve the dentry_path for error reporting when path lookup fails AppArmor: Add const qualifiers to generated string tables AppArmor: Fix oops in policy unpack auditing AppArmor: Fix error returned when a path lookup is disconnected KEYS: testing wrong bit for KEY_FLAG_REVOKED TOMOYO: Fix mount flags checking order. security: fix ima kconfig warning AppArmor: Fix the error case for chroot relative path name lookup AppArmor: fix mapping of META_READ to audit and quiet flags AppArmor: Fix underflow in xindex calculation AppArmor: Fix dropping of allowed operations that are force audited AppArmor: Add mising end of structure test to caps unpacking ...
2012-03-21Merge branch 'kmap_atomic' of git://github.com/congwang/linuxLinus Torvalds
Pull kmap_atomic cleanup from Cong Wang. It's been in -next for a long time, and it gets rid of the (no longer used) second argument to k[un]map_atomic(). Fix up a few trivial conflicts in various drivers, and do an "evil merge" to catch some new uses that have come in since Cong's tree. * 'kmap_atomic' of git://github.com/congwang/linux: (59 commits) feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] drbd: remove the second argument of k[un]map_atomic() zcache: remove the second argument of k[un]map_atomic() gma500: remove the second argument of k[un]map_atomic() dm: remove the second argument of k[un]map_atomic() tomoyo: remove the second argument of k[un]map_atomic() sunrpc: remove the second argument of k[un]map_atomic() rds: remove the second argument of k[un]map_atomic() net: remove the second argument of k[un]map_atomic() mm: remove the second argument of k[un]map_atomic() lib: remove the second argument of k[un]map_atomic() power: remove the second argument of k[un]map_atomic() kdb: remove the second argument of k[un]map_atomic() udf: remove the second argument of k[un]map_atomic() ubifs: remove the second argument of k[un]map_atomic() squashfs: remove the second argument of k[un]map_atomic() reiserfs: remove the second argument of k[un]map_atomic() ocfs2: remove the second argument of k[un]map_atomic() ntfs: remove the second argument of k[un]map_atomic() ...
