path: root/security
2013-10-04selinux: remove 'flags' parameter from avc_audit()Linus Torvalds
Now avc_audit() has no more users with that parameter. Remove it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-04selinux: avc_has_perm_flags has no more usersLinus Torvalds
.. so get rid of it. The only indirect users were all the avc_has_perm() callers which just expanded to have a zero flags argument. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-04selinux: remove 'flags' parameter from inode_has_permLinus Torvalds
Every single user passes in '0'. I think we had non-zero users back in some stone age when selinux_inode_permission() was implemented in terms of inode_has_perm(), but that complicated case got split up into a totally separate code-path so that we could optimize the much simpler special cases. See commit 2e33405785d3 ("SELinux: delay initialization of audit data in selinux_inode_permission") for example. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-30apparmor: fix suspicious RCU usage warning in policy.c/policy.hJohn Johansen
The recent 3.12 pull request for apparmor was missing a couple rcu _protected access modifiers. Resulting in the follow suspicious RCU usage [ 29.804534] [ INFO: suspicious RCU usage. ] [ 29.804539] 3.11.0+ #5 Not tainted [ 29.804541] ------------------------------- [ 29.804545] security/apparmor/include/policy.h:363 suspicious rcu_dereference_check() usage! [ 29.804548] [ 29.804548] other info that might help us debug this: [ 29.804548] [ 29.804553] [ 29.804553] rcu_scheduler_active = 1, debug_locks = 1 [ 29.804558] 2 locks held by apparmor_parser/1268: [ 29.804560] #0: (sb_writers#9){.+.+.+}, at: [<ffffffff81120a4c>] file_start_write+0x27/0x29 [ 29.804576] #1: (&ns->lock){+.+.+.}, at: [<ffffffff811f5d88>] aa_replace_profiles+0x166/0x57c [ 29.804589] [ 29.804589] stack backtrace: [ 29.804595] CPU: 0 PID: 1268 Comm: apparmor_parser Not tainted 3.11.0+ #5 [ 29.804599] Hardware name: ASUSTeK Computer Inc. UL50VT /UL50VT , BIOS 217 03/01/2010 [ 29.804602] 0000000000000000 ffff8800b95a1d90 ffffffff8144eb9b ffff8800b94db540 [ 29.804611] ffff8800b95a1dc0 ffffffff81087439 ffff880138cc3a18 ffff880138cc3a18 [ 29.804619] ffff8800b9464a90 ffff880138cc3a38 ffff8800b95a1df0 ffffffff811f5084 [ 29.804628] Call Trace: [ 29.804636] [<ffffffff8144eb9b>] dump_stack+0x4e/0x82 [ 29.804642] [<ffffffff81087439>] lockdep_rcu_suspicious+0xfc/0x105 [ 29.804649] [<ffffffff811f5084>] __aa_update_replacedby+0x53/0x7f [ 29.804655] [<ffffffff811f5408>] __replace_profile+0x11f/0x1ed [ 29.804661] [<ffffffff811f6032>] aa_replace_profiles+0x410/0x57c [ 29.804668] [<ffffffff811f16d4>] profile_replace+0x35/0x4c [ 29.804674] [<ffffffff81120fa3>] vfs_write+0xad/0x113 [ 29.804680] [<ffffffff81121609>] SyS_write+0x44/0x7a [ 29.804687] [<ffffffff8145bfd2>] system_call_fastpath+0x16/0x1b [ 29.804691] [ 29.804694] =============================== [ 29.804697] [ INFO: suspicious RCU usage. ] [ 29.804700] 3.11.0+ #5 Not tainted [ 29.804703] ------------------------------- [ 29.804706] security/apparmor/policy.c:566 suspicious rcu_dereference_check() usage! [ 29.804709] [ 29.804709] other info that might help us debug this: [ 29.804709] [ 29.804714] [ 29.804714] rcu_scheduler_active = 1, debug_locks = 1 [ 29.804718] 2 locks held by apparmor_parser/1268: [ 29.804721] #0: (sb_writers#9){.+.+.+}, at: [<ffffffff81120a4c>] file_start_write+0x27/0x29 [ 29.804733] #1: (&ns->lock){+.+.+.}, at: [<ffffffff811f5d88>] aa_replace_profiles+0x166/0x57c [ 29.804744] [ 29.804744] stack backtrace: [ 29.804750] CPU: 0 PID: 1268 Comm: apparmor_parser Not tainted 3.11.0+ #5 [ 29.804753] Hardware name: ASUSTeK Computer Inc. UL50VT /UL50VT , BIOS 217 03/01/2010 [ 29.804756] 0000000000000000 ffff8800b95a1d80 ffffffff8144eb9b ffff8800b94db540 [ 29.804764] ffff8800b95a1db0 ffffffff81087439 ffff8800b95b02b0 0000000000000000 [ 29.804772] ffff8800b9efba08 ffff880138cc3a38 ffff8800b95a1dd0 ffffffff811f4f94 [ 29.804779] Call Trace: [ 29.804786] [<ffffffff8144eb9b>] dump_stack+0x4e/0x82 [ 29.804791] [<ffffffff81087439>] lockdep_rcu_suspicious+0xfc/0x105 [ 29.804798] [<ffffffff811f4f94>] aa_free_replacedby_kref+0x4d/0x62 [ 29.804804] [<ffffffff811f4f47>] ? aa_put_namespace+0x17/0x17 [ 29.804810] [<ffffffff811f4f0b>] kref_put+0x36/0x40 [ 29.804816] [<ffffffff811f5423>] __replace_profile+0x13a/0x1ed [ 29.804822] [<ffffffff811f6032>] aa_replace_profiles+0x410/0x57c [ 29.804829] [<ffffffff811f16d4>] profile_replace+0x35/0x4c [ 29.804835] [<ffffffff81120fa3>] vfs_write+0xad/0x113 [ 29.804840] [<ffffffff81121609>] SyS_write+0x44/0x7a [ 29.804847] [<ffffffff8145bfd2>] system_call_fastpath+0x16/0x1b Reported-by: miles.lane@gmail.com CC: paulmck@linux.vnet.ibm.com Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-09-30apparmor: Use shash crypto API interface for profile hashesTyler Hicks
Use the shash interface, rather than the hash interface, when hashing AppArmor profiles. The shash interface does not use scatterlists and it is a better fit for what AppArmor needs. This fixes a kernel paging BUG when aa_calc_profile_hash() is passed a buffer from vmalloc(). The hash interface requires callers to handle vmalloc() buffers differently than what AppArmor was doing. Due to vmalloc() memory not being physically contiguous, each individual page behind the buffer must be assigned to a scatterlist with sg_set_page() and then the scatterlist passed to crypto_hash_update(). The shash interface does not have that limitation and allows vmalloc() and kmalloc() buffers to be handled in the same manner. BugLink: https://launchpad.net/bugs/1216294/ BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=62261 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Acked-by: Seth Arnold <seth.arnold@canonical.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull namespace changes from Eric Biederman: "This is an assorted mishmash of small cleanups, enhancements and bug fixes. The major theme is user namespace mount restrictions. nsown_capable is killed as it encourages not thinking about details that need to be considered. A very hard to hit pid namespace exiting bug was finally tracked and fixed. A couple of cleanups to the basic namespace infrastructure. Finally there is an enhancement that makes per user namespace capabilities usable as capabilities, and an enhancement that allows the per userns root to nice other processes in the user namespace" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: userns: Kill nsown_capable it makes the wrong thing easy capabilities: allow nice if we are privileged pidns: Don't have unshare(CLONE_NEWPID) imply CLONE_THREAD userns: Allow PR_CAPBSET_DROP in a user namespace. namespaces: Simplify copy_namespaces so it is clear what is going on. pidns: Fix hang in zap_pid_ns_processes by sending a potentially extra wakeup sysfs: Restrict mounting sysfs userns: Better restrictions on when proc and sysfs can be mounted vfs: Don't copy mount bind mounts of /proc/<pid>/ns/mnt between namespaces kernel/nsproxy.c: Improving a snippet of code. proc: Restrict mounting the proc filesystem vfs: Lock in place mounts from more privileged users
2013-09-07Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Nothing major for this kernel, just maintenance updates" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits) apparmor: add the ability to report a sha1 hash of loaded policy apparmor: export set of capabilities supported by the apparmor module apparmor: add the profile introspection file to interface apparmor: add an optional profile attachment string for profiles apparmor: add interface files for profiles and namespaces apparmor: allow setting any profile into the unconfined state apparmor: make free_profile available outside of policy.c apparmor: rework namespace free path apparmor: update how unconfined is handled apparmor: change how profile replacement update is done apparmor: convert profile lists to RCU based locking apparmor: provide base for multiple profiles to be replaced at once apparmor: add a features/policy dir to interface apparmor: enable users to query whether apparmor is enabled apparmor: remove minimum size check for vmalloc() Smack: parse multiple rules per write to load2, up to PAGE_SIZE-1 bytes Smack: network label match fix security: smack: add a hash table to quicken smk_find_entry() security: smack: fix memleak in smk_write_rules_list() xattr: Constify ->name member of "struct xattr". ...
2013-09-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: "Noteworthy changes this time around: 1) Multicast rejoin support for team driver, from Jiri Pirko. 2) Centralize and simplify TCP RTT measurement handling in order to reduce the impact of bad RTO seeding from SYN/ACKs. Also, when both timestamps and local RTT measurements are available prefer the later because there are broken middleware devices which scramble the timestamp. From Yuchung Cheng. 3) Add TCP_NOTSENT_LOWAT socket option to limit the amount of kernel memory consumed to queue up unsend user data. From Eric Dumazet. 4) Add a "physical port ID" abstraction for network devices, from Jiri Pirko. 5) Add a "suppress" operation to influence fib_rules lookups, from Stefan Tomanek. 6) Add a networking development FAQ, from Paul Gortmaker. 7) Extend the information provided by tcp_probe and add ipv6 support, from Daniel Borkmann. 8) Use RCU locking more extensively in openvswitch data paths, from Pravin B Shelar. 9) Add SCTP support to openvswitch, from Joe Stringer. 10) Add EF10 chip support to SFC driver, from Ben Hutchings. 11) Add new SYNPROXY netfilter target, from Patrick McHardy. 12) Compute a rate approximation for sending in TCP sockets, and use this to more intelligently coalesce TSO frames. Furthermore, add a new packet scheduler which takes advantage of this estimate when available. From Eric Dumazet. 13) Allow AF_PACKET fanouts with random selection, from Daniel Borkmann. 14) Add ipv6 support to vxlan driver, from Cong Wang" Resolved conflicts as per discussion. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1218 commits) openvswitch: Fix alignment of struct sw_flow_key. netfilter: Fix build errors with xt_socket.c tcp: Add missing braces to do_tcp_setsockopt caif: Add missing braces to multiline if in cfctrl_linkup_request bnx2x: Add missing braces in bnx2x:bnx2x_link_initialize vxlan: Fix kernel panic on device delete. net: mvneta: implement ->ndo_do_ioctl() to support PHY ioctls net: mvneta: properly disable HW PHY polling and ensure adjust_link() works icplus: Use netif_running to determine device state ethernet/arc/arc_emac: Fix huge delays in large file copies tuntap: orphan frags before trying to set tx timestamp tuntap: purge socket error queue on detach qlcnic: use standard NAPI weights ipv6:introduce function to find route for redirect bnx2x: VF RSS support - VF side bnx2x: VF RSS support - PF side vxlan: Notify drivers for listening UDP port changes net: usbnet: update addr_assign_type if appropriate driver/net: enic: update enic maintainers and driver driver/net: enic: Exposing symbols for Cisco's low latency driver ...
2013-09-04Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Minor fixes mainly, including a potential use-after-free on remove found by CONFIG_DEBUG_KOBJECT_RELEASE which may be theoretical" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: Fix mod->mkobj.kobj potentially freed too early kernel/params.c: use scnprintf() instead of sprintf() kernel/module.c: use scnprintf() instead of sprintf() module/lsm: Have apparmor module parameters work with no args module: Add NOARG flag for ops with param_set_bool_enable_only() set function module: Add flag to allow mod params to have no arguments modules: add support for soft module dependencies scripts/mod/modpost.c: permit '.cranges' secton for sh64 architecture. module: fix sprintf format specifier in param_get_byte()
2013-09-03Merge branch 'for-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot of activities on the cgroup front. Most changes aren't visible to userland at all at this point and are laying foundation for the planned unified hierarchy. - The biggest change is decoupling the lifetime management of css (cgroup_subsys_state) from that of cgroup's. Because controllers (cpu, memory, block and so on) will need to be dynamically enabled and disabled, css which is the association point between a cgroup and a controller may come and go dynamically across the lifetime of a cgroup. Till now, css's were created when the associated cgroup was created and stayed till the cgroup got destroyed. Assumptions around this tight coupling permeated through cgroup core and controllers. These assumptions are gradually removed, which consists bulk of patches, and css destruction path is completely decoupled from cgroup destruction path. Note that decoupling of creation path is relatively easy on top of these changes and the patchset is pending for the next window. - cgroup has its own event mechanism cgroup.event_control, which is only used by memcg. It is overly complex trying to achieve high flexibility whose benefits seem dubious at best. Going forward, new events will simply generate file modified event and the existing mechanism is being made specific to memcg. This pull request contains prepatory patches for such change. - Various fixes and cleanups" Fixed up conflict in kernel/cgroup.c as per Tejun. * 'for-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (69 commits) cgroup: fix cgroup_css() invocation in css_from_id() cgroup: make cgroup_write_event_control() use css_from_dir() instead of __d_cgrp() cgroup: make cgroup_event hold onto cgroup_subsys_state instead of cgroup cgroup: implement CFTYPE_NO_PREFIX cgroup: make cgroup_css() take cgroup_subsys * instead and allow NULL subsys cgroup: rename cgroup_css_from_dir() to css_from_dir() and update its syntax cgroup: fix cgroup_write_event_control() cgroup: fix subsystem file accesses on the root cgroup cgroup: change cgroup_from_id() to css_from_id() cgroup: use css_get() in cgroup_create() to check CSS_ROOT cpuset: remove an unncessary forward declaration cgroup: RCU protect each cgroup_subsys_state release cgroup: move subsys file removal to kill_css() cgroup: factor out kill_css() cgroup: decouple cgroup_subsys_state destruction from cgroup destruction cgroup: replace cgroup->css_kill_cnt with ->nr_css cgroup: bounce cgroup_subsys_state ref kill confirmation to a work item cgroup: move cgroup->subsys[] assignment to online_css() cgroup: reorganize css init / exit paths cgroup: add __rcu modifier to cgroup->subsys[] ...
2013-08-30capabilities: allow nice if we are privilegedSerge Hallyn
We allow task A to change B's nice level if it has a supserset of B's privileges, or of it has CAP_SYS_NICE. Also allow it if A has CAP_SYS_NICE with respect to B - meaning it is root in the same namespace, or it created B's namespace. Signed-off-by: Serge Hallyn <serge.hallyn@canonical.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2013-08-30userns: Allow PR_CAPBSET_DROP in a user namespace.Eric W. Biederman
As the capabilites and capability bounding set are per user namespace properties it is safe to allow changing them with just CAP_SETPCAP permission in the user namespace. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Tested-by: Richard Weinberger <richard@nod.at> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-08-23Merge branch 'smack-for-3.12' of git://git.gitorious.org/smack-next/kernel ↵James Morris
into ra-next
2013-08-20module/lsm: Have apparmor module parameters work with no argsSteven Rostedt
The apparmor module parameters for param_ops_aabool and param_ops_aalockpolicy are both based off of the param_ops_bool, and can handle a NULL value passed in as val. Have it enable the new KERNEL_PARAM_FL_NOARGS flag to allow the parameters to be set without having to state "=y" or "=1". Cc: John Johansen <john.johansen@canonical.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-08-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2013-08-14apparmor: add the ability to report a sha1 hash of loaded policyJohn Johansen
Provide userspace the ability to introspect a sha1 hash value for each profile currently loaded. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Seth Arnold <seth.arnold@canonical.com>
2013-08-14apparmor: export set of capabilities supported by the apparmor moduleJohn Johansen
2013-08-14apparmor: add the profile introspection file to interfaceJohn Johansen
Add the dynamic namespace relative profiles file to the interace, to allow introspection of loaded profiles and their modes. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Kees Cook <kees@ubuntu.com>
2013-08-14apparmor: add an optional profile attachment string for profilesJohn Johansen
Add the ability to take in and report a human readable profile attachment string for profiles so that attachment specifications can be easily inspected. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Seth Arnold <seth.arnold@canonical.com>
2013-08-14apparmor: add interface files for profiles and namespacesJohn Johansen
Add basic interface files to access namespace and profile information. The interface files are created when a profile is loaded and removed when the profile or namespace is removed. Signed-off-by: John Johansen <john.johansen@canonical.com>
2013-08-14apparmor: allow setting any profile into the unconfined stateJohn Johansen
Allow emulating the default profile behavior from boot, by allowing loading of a profile in the unconfined state into a new NS. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Seth Arnold <seth.arnold@canonical.com>
2013-08-14apparmor: make free_profile available outside of policy.cJohn Johansen
2013-08-14apparmor: rework namespace free pathJohn Johansen
namespaces now completely use the unconfined profile to track the refcount and rcu freeing cycle. So rework the code to simplify (track everything through the profile path right up to the end), and move the rcu_head from policy base to profile as the namespace no longer needs it. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Seth Arnold <seth.arnold@canonical.com>
2013-08-14apparmor: update how unconfined is handledJohn Johansen
ns->unconfined is being used read side without locking, nor rcu but is being updated when a namespace is removed. This works for the root ns which is never removed but has a race window and can cause failures when children namespaces are removed. Also ns and ns->unconfined have a circular refcounting dependency that is problematic and must be broken. Currently this is done incorrectly when the namespace is destroyed. Fix this by forward referencing unconfined via the replacedby infrastructure instead of directly updating the ns->unconfined pointer. Remove the circular refcount dependency by making the ns and its unconfined profile share the same refcount. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Seth Arnold <seth.arnold@canonical.com>
2013-08-14apparmor: change how profile replacement update is doneJohn Johansen
remove the use of replaced by chaining and move to profile invalidation and lookup to handle task replacement. Replacement chaining can result in large chains of profiles being pinned in memory when one profile in the chain is use. With implicit labeling this will be even more of a problem, so move to a direct lookup method. Signed-off-by: John Johansen <john.johansen@canonical.com>
2013-08-14apparmor: convert profile lists to RCU based lockingJohn Johansen
2013-08-14apparmor: provide base for multiple profiles to be replaced at onceJohn Johansen
previously profiles had to be loaded one at a time, which could result in cases where a replacement of a set would partially succeed, and then fail resulting in inconsistent policy. Allow multiple profiles to replaced "atomically" so that the replacement either succeeds or fails for the entire set of profiles. Signed-off-by: John Johansen <john.johansen@canonical.com>
2013-08-14apparmor: add a features/policy dir to interfaceJohn Johansen
Add a policy directory to features to contain features that can affect policy compilation but do not affect mediation. Eg of such features would be types of dfa compression supported, etc. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Kees Cook <kees@ubuntu.com>
2013-08-14apparmor: enable users to query whether apparmor is enabledJohn Johansen
2013-08-14apparmor: remove minimum size check for vmalloc()Tetsuo Handa
This is a follow-up to commit b5b3ee6c "apparmor: no need to delay vfree()". Since vmalloc() will do "size = PAGE_ALIGN(size);", we don't need to check for "size >= sizeof(struct work_struct)". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: John Johansen <john.johansen@canonical.com>
2013-08-12Smack: parse multiple rules per write to load2, up to PAGE_SIZE-1 bytesRafal Krypa
Smack interface for loading rules has always parsed only single rule from data written to it. This requires user program to call one write() per each rule it wants to load. This change makes it possible to write multiple rules, separated by new line character. Smack will load at most PAGE_SIZE-1 characters and properly return number of processed bytes. In case when user buffer is larger, it will be additionally truncated. All characters after last \n will not get parsed to avoid partial rule near input buffer boundary. Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
2013-08-08cgroup: make css_for_each_descendant() and friends include the origin css in ↵Tejun Heo
the iteration Previously, all css descendant iterators didn't include the origin (root of subtree) css in the iteration. The reasons were maintaining consistency with css_for_each_child() and that at the time of introduction more use cases needed skipping the origin anyway; however, given that css_is_descendant() considers self to be a descendant, omitting the origin css has become more confusing and looking at the accumulated use cases rather clearly indicates that including origin would result in simpler code overall. While this is a change which can easily lead to subtle bugs, cgroup API including the iterators has recently gone through major restructuring and no out-of-tree changes will be applicable without adjustments making this a relatively acceptable opportunity for this type of change. The conversions are mostly straight-forward. If the iteration block had explicit origin handling before or after, it's moved inside the iteration. If not, if (pos == origin) continue; is added. Some conversions add extra reference get/put around origin handling by consolidating origin handling and the rest. While the extra ref operations aren't strictly necessary, this shouldn't cause any noticeable difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com>
2013-08-08cgroup: make hierarchy iterators deal with cgroup_subsys_state instead of cgroupTejun Heo
cgroup is currently in the process of transitioning to using css (cgroup_subsys_state) as the primary handle instead of cgroup in subsystem API. For hierarchy iterators, this is beneficial because * In most cases, css is the only thing subsystems care about anyway. * On the planned unified hierarchy, iterations for different subsystems will need to skip over different subtrees of the hierarchy depending on which subsystems are enabled on each cgroup. Passing around css makes it unnecessary to explicitly specify the subsystem in question as css is intersection between cgroup and subsystem * For the planned unified hierarchy, css's would need to be created and destroyed dynamically independent from cgroup hierarchy. Having cgroup core manage css iteration makes enforcing deref rules a lot easier. Most subsystem conversions are straight-forward. Noteworthy changes are * blkio: cgroup_to_blkcg() is no longer used. Removed. * freezer: cgroup_freezer() is no longer used. Removed. * devices: cgroup_to_devcgroup() is no longer used. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Jens Axboe <axboe@kernel.dk>
2013-08-08cgroup: pass around cgroup_subsys_state instead of cgroup in file methodsTejun Heo
cgroup is currently in the process of transitioning to using struct cgroup_subsys_state * as the primary handle instead of struct cgroup. Please see the previous commit which converts the subsystem methods for rationale. This patch converts all cftype file operations to take @css instead of @cgroup. cftypes for the cgroup core files don't have their subsytem pointer set. These will automatically use the dummy_css added by the previous patch and can be converted the same way. Most subsystem conversions are straight forwards but there are some interesting ones. * freezer: update_if_frozen() is also converted to take @css instead of @cgroup for consistency. This will make the code look simpler too once iterators are converted to use css. * memory/vmpressure: mem_cgroup_from_css() needs to be exported to vmpressure while mem_cgroup_from_cont() can be made static. Updated accordingly. * cpu: cgroup_tg() doesn't have any user left. Removed. * cpuacct: cgroup_ca() doesn't have any user left. Removed. * hugetlb: hugetlb_cgroup_form_cgroup() doesn't have any user left. Removed. * net_cls: cgrp_cls_state() doesn't have any user left. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Steven Rostedt <rostedt@goodmis.org>
2013-08-08cgroup: pass around cgroup_subsys_state instead of cgroup in subsystem methodsTejun Heo
cgroup is currently in the process of transitioning to using struct cgroup_subsys_state * as the primary handle instead of struct cgroup * in subsystem implementations for the following reasons. * With unified hierarchy, subsystems will be dynamically bound and unbound from cgroups and thus css's (cgroup_subsys_state) may be created and destroyed dynamically over the lifetime of a cgroup, which is different from the current state where all css's are allocated and destroyed together with the associated cgroup. This in turn means that cgroup_css() should be synchronized and may return NULL, making it more cumbersome to use. * Differing levels of per-subsystem granularity in the unified hierarchy means that the task and descendant iterators should behave differently depending on the specific subsystem the iteration is being performed for. * In majority of the cases, subsystems only care about its part in the cgroup hierarchy - ie. the hierarchy of css's. Subsystem methods often obtain the matching css pointer from the cgroup and don't bother with the cgroup pointer itself. Passing around css fits much better. This patch converts all cgroup_subsys methods to take @css instead of @cgroup. The conversions are mostly straight-forward. A few noteworthy changes are * ->css_alloc() now takes css of the parent cgroup rather than the pointer to the new cgroup as the css for the new cgroup doesn't exist yet. Knowing the parent css is enough for all the existing subsystems. * In kernel/cgroup.c::offline_css(), unnecessary open coded css dereference is replaced with local variable access. This patch shouldn't cause any behavior differences. v2: Unnecessary explicit cgrp->subsys[] deref in css_online() replaced with local variable @css as suggested by Li Zefan. Rebased on top of new for-3.12 which includes for-3.11-fixes so that ->css_free() invocation added by da0a12caff ("cgroup: fix a leak when percpu_ref_init() fails") is converted too. Suggested by Li Zefan. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Steven Rostedt <rostedt@goodmis.org>
2013-08-08cgroup: add css_parent()Tejun Heo
Currently, controllers have to explicitly follow the cgroup hierarchy to find the parent of a given css. cgroup is moving towards using cgroup_subsys_state as the main controller interface construct, so let's provide a way to climb the hierarchy using just csses. This patch implements css_parent() which, given a css, returns its parent. The function is guarnateed to valid non-NULL parent css as long as the target css is not at the top of the hierarchy. freezer, cpuset, cpu, cpuacct, hugetlb, memory, net_cls and devices are converted to use css_parent() instead of accessing cgroup->parent directly. * __parent_ca() is dropped from cpuacct and its usage is replaced with parent_ca(). The only difference between the two was NULL test on cgroup->parent which is now embedded in css_parent() making the distinction moot. Note that eventually a css->parent field will be added to css and the NULL check in css_parent() will go away. This patch shouldn't cause any behavior differences. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-08-08cgroup: add/update accessors which obtain subsys specific data from cssTejun Heo
css (cgroup_subsys_state) is usually embedded in a subsys specific data structure. Subsystems either use container_of() directly to cast from css to such data structure or has an accessor function wrapping such cast. As cgroup as whole is moving towards using css as the main interface handle, add and update such accessors to ease dealing with css's. All accessors explicitly handle NULL input and return NULL in those cases. While this looks like an extra branch in the code, as all controllers specific data structures have css as the first field, the casting doesn't involve any offsetting and the compiler can trivially optimize out the branch. * blkio, freezer, cpuset, cpu, cpuacct and net_cls didn't have such accessor. Added. * memory, hugetlb and devices already had one but didn't explicitly handle NULL input. Updated. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-08-08cgroup: s/cgroup_subsys_state/cgroup_css/ s/task_subsys_state/task_css/Tejun Heo
The names of the two struct cgroup_subsys_state accessors - cgroup_subsys_state() and task_subsys_state() - are somewhat awkward. The former clashes with the type name and the latter doesn't even indicate it's somehow related to cgroup. We're about to revamp large portion of cgroup API, so, let's rename them so that they're less awkward. Most per-controller usages of the accessors are localized in accessor wrappers and given the amount of scheduled changes, this isn't gonna add any noticeable headache. Rename cgroup_subsys_state() to cgroup_css() and task_subsys_state() to task_css(). This patch is pure rename. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-08-06Smack: IPv6 casting error fix for 3.11Casey Schaufler
The original implementation of the Smack IPv6 port based local controls works most of the time using a sockaddr as a temporary variable, but not always as it overflows in some circumstances. The correct data is a sockaddr_in6. A struct sockaddr isn't as large as a struct sockaddr_in6. There would need to be casting one way or the other. This patch gets it the right way. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-08-01Smack: network label match fixCasey Schaufler
The Smack code that matches incoming CIPSO tags with Smack labels reaches through the NetLabel interfaces and compares the network data with the CIPSO header associated with a Smack label. This was done in a ill advised attempt to optimize performance. It works so long as the categories fit in a single capset, but this isn't always the case. This patch changes the Smack code to use the appropriate NetLabel interfaces to compare the incoming CIPSO header with the CIPSO header associated with a label. It will always match the CIPSO headers correctly. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2013-08-01security: smack: add a hash table to quicken smk_find_entry()Tomasz Stanislawski
Accepted for the smack-next tree after changing the number of slots from 128 to 16. This patch adds a hash table to quicken searching of a smack label by its name. Basically, the patch improves performance of SMACK initialization. Parsing of rules involves translation from a string to a smack_known (aka label) entity which is done in smk_find_entry(). The current implementation of the function iterates over a global list of smack_known resulting in O(N) complexity for smk_find_entry(). The total complexity of SMACK initialization becomes O(rules * labels). Therefore it scales quadratically with a complexity of a system. Applying the patch reduced the complexity of smk_find_entry() to O(1) as long as number of label is in hundreds. If the number of labels is increased please update SMACK_HASH_SLOTS constant defined in security/smack/smack.h. Introducing the configuration of this constant with Kconfig or cmdline might be a good idea. The size of the hash table was adjusted experimentally. The rule set used by TIZEN contains circa 17K rules for 500 labels. The table above contains results of SMACK initialization using 'time smackctl apply' bash command. The 'Ref' is a kernel without this patch applied. The consecutive values refers to value of SMACK_HASH_SLOTS. Every measurement was repeated three times to reduce noise. | Ref | 1 | 2 | 4 | 8 | 16 | 32 | 64 | 128 | 256 | 512 -------------------------------------------------------------------------------------------- Run1 | 1.156 | 1.096 | 0.883 | 0.764 | 0.692 | 0.667 | 0.649 | 0.633 | 0.634 | 0.629 | 0.620 Run2 | 1.156 | 1.111 | 0.885 | 0.764 | 0.694 | 0.661 | 0.649 | 0.651 | 0.634 | 0.638 | 0.623 Run3 | 1.160 | 1.107 | 0.886 | 0.764 | 0.694 | 0.671 | 0.661 | 0.638 | 0.631 | 0.624 | 0.638 AVG | 1.157 | 1.105 | 0.885 | 0.764 | 0.693 | 0.666 | 0.653 | 0.641 | 0.633 | 0.630 | 0.627 Surprisingly, a single hlist is slightly faster than a double-linked list. The speed-up saturates near 64 slots. Therefore I chose value 128 to provide some margin if more labels were used. It looks that IO becomes a new bottleneck. Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
2013-08-01security: smack: fix memleak in smk_write_rules_list()Tomasz Stanislawski
The smack_parsed_rule structure is allocated. If a rule is successfully installed then the last reference to the object is lost. This patch fixes this leak. Moreover smack_parsed_rule is allocated on stack because it no longer needed ofter smk_write_rules_list() is finished. Signed-off-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
2013-07-31net: split rt_genid for ipv4 and ipv6fan.du
Current net name space has only one genid for both IPv4 and IPv6, it has below drawbacks: - Add/delete an IPv4 address will invalidate all IPv6 routing table entries. - Insert/remove XFRM policy will also invalidate both IPv4/IPv6 routing table entries even when the policy is only applied for one address family. Thus, this patch attempt to split one genid for two to cater for IPv4 and IPv6 separately in a fine granularity. Signed-off-by: Fan Du <fan.du@windriver.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-25xattr: Constify ->name member of "struct xattr".Tetsuo Handa
Since everybody sets kstrdup()ed constant string to "struct xattr"->name but nobody modifies "struct xattr"->name , we can omit kstrdup() and its failure checking by constifying ->name member of "struct xattr". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Joel Becker <jlbec@evilplan.org> [ocfs2] Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Reviewed-by: Paul Moore <paul@paul-moore.com> Tested-by: Paul Moore <paul@paul-moore.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-07-11Merge branch 'for-3.11' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from Bruce Fields: "Changes this time include: - 4.1 enabled on the server by default: the last 4.1-specific issues I know of are fixed, so we're not going to find the rest of the bugs without more exposure. - Experimental support for NFSv4.2 MAC Labeling (to allow running selinux over NFS), from Dave Quigley. - Fixes for some delicate cache/upcall races that could cause rare server hangs; thanks to Neil Brown and Bodo Stroesser for extreme debugging persistence. - Fixes for some bugs found at the recent NFS bakeathon, mostly v4 and v4.1-specific, but also a generic bug handling fragmented rpc calls" * 'for-3.11' of git://linux-nfs.org/~bfields/linux: (31 commits) nfsd4: support minorversion 1 by default nfsd4: allow destroy_session over destroyed session svcrpc: fix failures to handle -1 uid's sunrpc: Don't schedule an upcall on a replaced cache entry. net/sunrpc: xpt_auth_cache should be ignored when expired. sunrpc/cache: ensure items removed from cache do not have pending upcalls. sunrpc/cache: use cache_fresh_unlocked consistently and correctly. sunrpc/cache: remove races with queuing an upcall. nfsd4: return delegation immediately if lease fails nfsd4: do not throw away 4.1 lock state on last unlock nfsd4: delegation-based open reclaims should bypass permissions svcrpc: don't error out on small tcp fragment svcrpc: fix handling of too-short rpc's nfsd4: minor read_buf cleanup nfsd4: fix decoding of compounds across page boundaries nfsd4: clean up nfs4_open_delegation NFSD: Don't give out read delegations on creates nfsd4: allow client to send no cb_sec flavors nfsd4: fail attempts to request gss on the backchannel nfsd4: implement minimal SP4_MACH_CRED ...
2013-07-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "This is a re-do of the net-next pull request for the current merge window. The only difference from the one I made the other day is that this has Eliezer's interface renames and the timeout handling changes made based upon your feedback, as well as a few bug fixes that have trickeled in. Highlights: 1) Low latency device polling, eliminating the cost of interrupt handling and context switches. Allows direct polling of a network device from socket operations, such as recvmsg() and poll(). Currently ixgbe, mlx4, and bnx2x support this feature. Full high level description, performance numbers, and design in commit 0a4db187a999 ("Merge branch 'll_poll'") From Eliezer Tamir. 2) With the routing cache removed, ip_check_mc_rcu() gets exercised more than ever before in the case where we have lots of multicast addresses. Use a hash table instead of a simple linked list, from Eric Dumazet. 3) Add driver for Atheros CQA98xx 802.11ac wireless devices, from Bartosz Markowski, Janusz Dziedzic, Kalle Valo, Marek Kwaczynski, Marek Puzyniak, Michal Kazior, and Sujith Manoharan. 4) Support reporting the TUN device persist flag to userspace, from Pavel Emelyanov. 5) Allow controlling network device VF link state using netlink, from Rony Efraim. 6) Support GRE tunneling in openvswitch, from Pravin B Shelar. 7) Adjust SOCK_MIN_RCVBUF and SOCK_MIN_SNDBUF for modern times, from Daniel Borkmann and Eric Dumazet. 8) Allow controlling of TCP quickack behavior on a per-route basis, from Cong Wang. 9) Several bug fixes and improvements to vxlan from Stephen Hemminger, Pravin B Shelar, and Mike Rapoport. In particular, support receiving on multiple UDP ports. 10) Major cleanups, particular in the area of debugging and cookie lifetime handline, to the SCTP protocol code. From Daniel Borkmann. 11) Allow packets to cross network namespaces when traversing tunnel devices. From Nicolas Dichtel. 12) Allow monitoring netlink traffic via AF_PACKET sockets, in a manner akin to how we monitor real network traffic via ptype_all. From Daniel Borkmann. 13) Several bug fixes and improvements for the new alx device driver, from Johannes Berg. 14) Fix scalability issues in the netem packet scheduler's time queue, by using an rbtree. From Eric Dumazet. 15) Several bug fixes in TCP loss recovery handling, from Yuchung Cheng. 16) Add support for GSO segmentation of MPLS packets, from Simon Horman. 17) Make network notifiers have a real data type for the opaque pointer that's passed into them. Use this to properly handle network device flag changes in arp_netdev_event(). From Jiri Pirko and Timo Teräs. 18) Convert several drivers over to module_pci_driver(), from Peter Huewe. 19) tcp_fixup_rcvbuf() can loop 500 times over loopback, just use a O(1) calculation instead. From Eric Dumazet. 20) Support setting of explicit tunnel peer addresses in ipv6, just like ipv4. From Nicolas Dichtel. 21) Protect x86 BPF JIT against spraying attacks, from Eric Dumazet. 22) Prevent a single high rate flow from overruning an individual cpu during RX packet processing via selective flow shedding. From Willem de Bruijn. 23) Don't use spinlocks in TCP md5 signing fast paths, from Eric Dumazet. 24) Don't just drop GSO packets which are above the TBF scheduler's burst limit, chop them up so they are in-bounds instead. Also from Eric Dumazet. 25) VLAN offloads are missed when configured on top of a bridge, fix from Vlad Yasevich. 26) Support IPV6 in ping sockets. From Lorenzo Colitti. 27) Receive flow steering targets should be updated at poll() time too, from David Majnemer. 28) Fix several corner case regressions in PMTU/redirect handling due to the routing cache removal, from Timo Teräs. 29) We have to be mindful of ipv4 mapped ipv6 sockets in upd_v6_push_pending_frames(). From Hannes Frederic Sowa. 30) Fix L2TP sequence number handling bugs, from James Chapman." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1214 commits) drivers/net: caif: fix wrong rtnl_is_locked() usage drivers/net: enic: release rtnl_lock on error-path vhost-net: fix use-after-free in vhost_net_flush net: mv643xx_eth: do not use port number as platform device id net: sctp: confirm route during forward progress virtio_net: fix race in RX VQ processing virtio: support unlocked queue poll net/cadence/macb: fix bug/typo in extracting gem_irq_read_clear bit Documentation: Fix references to defunct linux-net@vger.kernel.org net/fs: change busy poll time accounting net: rename low latency sockets functions to busy poll bridge: fix some kernel warning in multicast timer sfc: Fix memory leak when discarding scattered packets sit: fix tunnel update via netlink dt:net:stmmac: Add dt specific phy reset callback support. dt:net:stmmac: Add support to dwmac version 3.610 and 3.710 dt:net:stmmac: Allocate platform data only if its NULL. net:stmmac: fix memleak in the open method ipv6: rt6_check_neigh should successfully verify neigh if no NUD information are available net: ipv6: fix wrong ping_v6_sendmsg return value ...
2013-07-09Merge tag 'nfs-for-3.11-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Feature highlights include: - Add basic client support for NFSv4.2 - Add basic client support for Labeled NFS (selinux for NFSv4.2) - Fix the use of credentials in NFSv4.1 stateful operations, and add support for NFSv4.1 state protection. Bugfix highlights: - Fix another NFSv4 open state recovery race - Fix an NFSv4.1 back channel session regression - Various rpc_pipefs races - Fix another issue with NFSv3 auth negotiation Please note that Labeled NFS does require some additional support from the security subsystem. The relevant changesets have all been reviewed and acked by James Morris." * tag 'nfs-for-3.11-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (54 commits) NFS: Set NFS_CS_MIGRATION for NFSv4 mounts NFSv4.1 Refactor nfs4_init_session and nfs4_init_channel_attrs nfs: have NFSv3 try server-specified auth flavors in turn nfs: have nfs_mount fake up a auth_flavs list when the server didn't provide it nfs: move server_authlist into nfs_try_mount_request nfs: refactor "need_mount" code out of nfs_try_mount SUNRPC: PipeFS MOUNT notification optimization for dying clients SUNRPC: split client creation routine into setup and registration SUNRPC: fix races on PipeFS UMOUNT notifications SUNRPC: fix races on PipeFS MOUNT notifications NFSv4.1 use pnfs_device maxcount for the objectlayout gdia_maxcount NFSv4.1 use pnfs_device maxcount for the blocklayout gdia_maxcount NFSv4.1 Fix gdia_maxcount calculation to fit in ca_maxresponsesize NFS: Improve legacy idmapping fallback NFSv4.1 end back channel session draining NFS: Apply v4.1 capabilities to v4.2 NFSv4.1: Clean up layout segment comparison helper names NFSv4.1: layout segment comparison helpers should take 'const' parameters NFSv4: Move the DNS resolver into the NFSv4 module rpc_pipefs: only set rpc_dentry_ops if d_op isn't already set ...
2013-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this update, Smack learns to love IPv6 and to mount a filesystem with a transmutable hierarchy (i.e. security labels are inherited from parent directory upon creation rather than creating process). The rest of the changes are maintenance" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (37 commits) tpm/tpm_i2c_infineon: Remove unused header file tpm: tpm_i2c_infinion: Don't modify i2c_client->driver evm: audit integrity metadata failures integrity: move integrity_audit_msg() evm: calculate HMAC after initializing posix acl on tmpfs maintainers: add Dmitry Kasatkin Smack: Fix the bug smackcipso can't set CIPSO correctly Smack: Fix possible NULL pointer dereference at smk_netlbl_mls() Smack: Add smkfstransmute mount option Smack: Improve access check performance Smack: Local IPv6 port based controls tpm: fix regression caused by section type conflict of tpm_dev_release() in ppc builds maintainers: Remove Kent from maintainers tpm: move TPM_DIGEST_SIZE defintion tpm_tis: missing platform_driver_unregister() on error in init_tis() security: clarify cap_inode_getsecctx description apparmor: no need to delay vfree() apparmor: fix fully qualified name parsing apparmor: fix setprocattr arg processing for onexec apparmor: localize getting the security context to a few macros ...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second set of VFS changes from Al Viro: "Assorted f_pos race fixes, making do_splice_direct() safe to call with i_mutex on parent, O_TMPFILE support, Jeff's locks.c series, ->d_hash/->d_compare calling conventions changes from Linus, misc stuff all over the place." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) Document ->tmpfile() ext4: ->tmpfile() support vfs: export lseek_execute() to modules lseek_execute() doesn't need an inode passed to it block_dev: switch to fixed_size_llseek() cpqphp_sysfs: switch to fixed_size_llseek() tile-srom: switch to fixed_size_llseek() proc_powerpc: switch to fixed_size_llseek() ubi/cdev: switch to fixed_size_llseek() pci/proc: switch to fixed_size_llseek() isapnp: switch to fixed_size_llseek() lpfc: switch to fixed_size_llseek() locks: give the blocked_hash its own spinlock locks: add a new "lm_owner_key" lock operation locks: turn the blocked_list into a hashtable locks: convert fl_link to a hlist_node locks: avoid taking global lock if possible when waking up blocked waiters locks: protect most of the file_lock handling with i_lock locks: encapsulate the fl_link list handling locks: make "added" in __posix_lock_file a bool ...
2013-07-02Merge branch 'for-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: "This pull request contains the following changes. - cgroup_subsys_state (css) reference counting has been converted to percpu-ref. css is what each resource controller embeds into its own control structure and perform reference count against. It may be used in hot paths of various subsystems and is similar to module refcnt in that aspect. For example, block-cgroup's css refcnting was showing up a lot in Mikulaus's device-mapper scalability work and this should alleviate it. - cgroup subtree iterator has been updated so that RCU read lock can be released after grabbing reference. This allows simplifying its users which requires blocking which used to build iteration list under RCU read lock and then traverse it outside. This pull request contains simplification of cgroup core and device-cgroup. A separate pull request will update cpuset. - Fixes for various bugs including corner race conditions and RCU usage bugs. - A lot of cleanups and some prepartory work for the planned unified hierarchy support." * 'for-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (48 commits) cgroup: CGRP_ROOT_SUBSYS_BOUND should also be ignored when mounting an existing hierarchy cgroup: CGRP_ROOT_SUBSYS_BOUND should be ignored when comparing mount options cgroup: fix deadlock on cgroup_mutex via drop_parsed_module_refcounts() cgroup: always use RCU accessors for protected accesses cgroup: fix RCU accesses around task->cgroups cgroup: fix RCU accesses to task->cgroups cgroup: grab cgroup_mutex in drop_parsed_module_refcounts() cgroup: fix cgroupfs_root early destruction path cgroup: reserve ID 0 for dummy_root and 1 for unified hierarchy cgroup: implement for_each_[builtin_]subsys() cgroup: move init_css_set initialization inside cgroup_mutex cgroup: s/for_each_subsys()/for_each_root_subsys()/ cgroup: clean up find_css_set() and friends cgroup: remove cgroup->actual_subsys_mask cgroup: prefix global variables with "cgroup_" cgroup: convert CFTYPE_* flags to enums cgroup: rename cont to cgrp cgroup: clean up cgroup_serial_nr_cursor cgroup: convert cgroup_cft_commit() to use cgroup_for_each_descendant_pre() cgroup: make serial_nr_cursor available throughout cgroup.c ...
