path: root/sound/Kconfig
2007-07-20[ALSA] Add ALSA support for the SEGA Dreamcast PCM deviceAdrian McMenamin
ALSA support for the SEGA Dreamcast Yamaha AICA sound device (pcm) This patch adds ALSA sound support for pcm playback on two channels on the SEGA Dreamcast built-in sound device (the Yamaha AICA) Add driver for the AICA sound device built into the SEGA Dreamcast Hook it all up with the build system. Signed-off-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-10[S390] Kconfig: menus with depends on HAS_IOMEM.Martin Schwidefsky
Add "depends on HAS_IOMEM" to a number of menus to make them disappear for s390 which does not have I/O memory. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-09[ALSA] ASoC: Build filesLiam Girdwood
This patch adds support for building the ASoC core and the dynamic audio power management support. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-12[PATCH] remove config ordering/dependency between ucb1400-ts and sound subsystemNicolas Pitre
Commit 2d4ba4a3b9aef95d328d74a17ae84f8d658059e2 introduced a dependency that was never meant to exist when the ac97_bus.c module was created. Move ac97_bus.c up the directory hierarchy to make sure it is built when selected even if sound is configured out so things work as originally intended. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-30Fix misc Kconfig typosMatt LaPlante
Fix various Kconfig typos. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-22[ALSA] snd-aoa: add snd-aoaJohannes Berg
This large patch adds all of snd-aoa. Consisting of many modules, it currently replaces snd-powermac for all layout-id based machines and handles many more (for example new powerbooks and powermacs with digital output that previously couldn't be used at all). It also has support for all layout-IDs that Apple has (judging from their Info.plist file) but not all are tested. The driver currently has 2 known regressions over snd-powermac: * it doesn't handle powermac 7,2 and 7,3 * it doesn't have a DRC control on snapper-based machines I will fix those during the 2.6.18 development cycle. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] sound: align device drivers menusRandy Dunlap
Modules: Sound Core,Generic drivers AC97 Kconfig entries broke the ALSA device drivers menu, so move them to a location where that won't happen, enabling all device sub-menus to be presented together. Fixed for the latest ALSA tree by Takashi Iwai <tiwai@suse.de>. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] sound: align device drivers menusRandy Dunlap
Modules: Sound Core,PCI drivers AC97 Kconfig entries broke the ALSA device drivers menu, so move them to a location where that won't happen, enabling all device sub-menus to be presented together. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-23[PATCH] Kconfig fix (ISA_DMA_API and sound/*)Al Viro
fixed kconfig dependencies on ISA_DMA_API for parts of sound/* that rely on it. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-29[ALSA] Use standard form for URLTakashi Iwai
Sound Core Use the standard form with <> for URL in Kconfig help texts. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] Add comments for Takashi Iwai
Sound Core Added (minimal) comments for in Kconfig, so that configurators can choose this entry explicitly. A more descriptive comment by someone else is appreciated... Signed-off-by: Takashi Iwai <tiwai@suse.de>
