path: root/sound/Makefile
2015-03-23ALSA: hda - Make snd_hda_bus_type publicTakashi Iwai
Define the common hd-audio driver and device types to bind over snd_hda_bus_type publicly. This allows to implement other type of device and driver code over hd-audio bus. Now both struct hda_codec and struct hda_codec_driver inherit these new struct hdac_device and struct hdac_driver, respectively. The bus registration is done in subsys_initcall() to assure it before any other driver registrations. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driverClemens Ladisch
Add a driver for two playback-only FireWire devices based on the OXFW970 chip. v2: better AMDTP API abstraction; fix fw_unit leak; small fixes v3: cache the iPCR value v4: FireWave constraints; fix fw_device reference counting; fix PCR caching; small changes and fixes v5: volume/mute support; fix crashing due to pcm stop races v6: fix build; one-channel volume for LaCie v7: use signed values to make volume (range checks) work; fix function block IDs for volume/mute; always use channel 0 for LaCie volume Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: Add Atmel ALSA drivers directoryHans-Christian Egtvedt
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2007-10-16[ALSA] Add SPI devices to ALSA Kconfig and MakefileHans-Christian Egtvedt
This patch adds SPI devices in the ALSA diretory, including the Kconfig and Makefile. Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Add ALSA support for the SEGA Dreamcast PCM deviceAdrian McMenamin
ALSA support for the SEGA Dreamcast Yamaha AICA sound device (pcm) This patch adds ALSA sound support for pcm playback on two channels on the SEGA Dreamcast built-in sound device (the Yamaha AICA) Add driver for the AICA sound device built into the SEGA Dreamcast Hook it all up with the build system. Signed-off-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC: Build filesLiam Girdwood
This patch adds support for building the ASoC core and the dynamic audio power management support. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-12[PATCH] remove config ordering/dependency between ucb1400-ts and sound subsystemNicolas Pitre
Commit 2d4ba4a3b9aef95d328d74a17ae84f8d658059e2 introduced a dependency that was never meant to exist when the ac97_bus.c module was created. Move ac97_bus.c up the directory hierarchy to make sure it is built when selected even if sound is configured out so things work as originally intended. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] build sound/sound_firmware.c only for OSSAdrian Bunk
All sound/sound_firmware.c contains is mod_firmware_load() that is a legacy API only used by some OSS drivers. This patch builds it into an own sound_firmware module that is only built depending on CONFIG_SOUND_PRIME making the kernel slightly smaller for ALSA users. [alan@lxorguk.ukuu.org.uk: comment fix] Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[ALSA] fix build failure due to snd-aoaTakashi Iwai
When snd-aoa is not built or built as modules, but CONFIG_SND is yes, kernel build fails due to a bug I introduced when adding snd-aoa. This patch fixes it. From: Takashi Iwai <tiwai@suse.de> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] snd-aoa: add snd-aoaJohannes Berg
This large patch adds all of snd-aoa. Consisting of many modules, it currently replaces snd-powermac for all layout-id based machines and handles many more (for example new powerbooks and powermacs with digital output that previously couldn't be used at all). It also has support for all layout-IDs that Apple has (judging from their Info.plist file) but not all are tested. The driver currently has 2 known regressions over snd-powermac: * it doesn't handle powermac 7,2 and 7,3 * it doesn't have a DRC control on snapper-based machines I will fix those during the 2.6.18 development cycle. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
