path: root/sound/aoa/fabrics
2008-01-31[ALSA] aoa - Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in aoa drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-04-13[POWERPC] Rename get_property to of_get_property: soundStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] get_property returns constStephen Rothwell
This just tidies up some of the remains. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-09[ALSA] aoa: remove suspend/resume printksJohannes Berg
This just removes two useless printks. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] sound: aoa of_node_put and kfree cleanupMariusz Kozlowski
This patch removes redundant argument checks for of_node_put() and kfree(). Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] create driver symlink in snd-aoa /sys/bus/aoa-soundbus/devices/*/Olaf Hering
create sysfs driver symlink for snd-aoa in /sys/bus/aoa-soundbus/devices/*/ Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] create device symlink in snd-aoaOlaf Hering
create sysfs device symlinks for snd-aoa in /sys/class/sound/controlC0 This allows hald to recognize the device as sound device. Furthermore it allows the desktop user to actually access the sound device nodes. hald and related packages will modify the acl attributes. Fixes https://bugzilla.novell.com/show_bug.cgi?id=106294 Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-12kconfig: Standardize "depends" -> "depends on" in Kconfig filesRobert P. J. Day
Standardize the miniscule percentage of occurrences of "depends" in Kconfig files to "depends on", and update kconfig-language.txt to reflect that. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-07-10[PATCH] aoa: layout fabric: add missing module aliasesJohannes Berg
The layout fabric gained support for all IDs when I extracted those from the OSX description file. But apparently I had forgotten to add them all as module aliases so the module will also load. This patch adds them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] aoa fabric layout: clean up messagesBenjamin Herrenschmidt
This patch cleans up the printk's in the layout fabric and also makes it display which type of GPIO access it is going to use. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[ALSA] snd-aoa: support iMac G5 iSightJohannes Berg
This properly adds support for the iMac G5 iSight. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] snd-aoa: add snd-aoaJohannes Berg
This large patch adds all of snd-aoa. Consisting of many modules, it currently replaces snd-powermac for all layout-id based machines and handles many more (for example new powerbooks and powermacs with digital output that previously couldn't be used at all). It also has support for all layout-IDs that Apple has (judging from their Info.plist file) but not all are tested. The driver currently has 2 known regressions over snd-powermac: * it doesn't handle powermac 7,2 and 7,3 * it doesn't have a DRC control on snapper-based machines I will fix those during the 2.6.18 development cycle. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
