We can use finer-grained locking, which makes things easier when
we gain DMA support.
Since the recording and playback paths are now the same, eliminate
the needless conditionals.
There's no need for a specific rule; ALSA's generic AC'97 support
calculates the necessary rate constraint information itself, and
we can use this directly.
Fixed a typo of the max buffer size specified for buffer allocation
changed in the commit d6797322231af98b9bb4afb175dd614cf511e5f7.
Now snd_ac97_pcm_open() is called with the exactly same arguments
for both playback and capture directions. Remove the unneeded check.
pcm->r[1].slots is the double rate slot information, not the
capture information. For capture, 'pcm' will already be the
capture ac97 pcm structure.
Cc: <stable@kernel.org>
The call of dma_mmap_coherent() is done in the PCM core now.
Fix the buffer size calculation to use the size which ALSA is expecting.
After a reboot on an ARM1176 which amounts to a softreset, it has been
noted that the ALSA driver does not get registered and the probe fails
with the error "aaci-pl041 fpga:04: ac97 read back fail". In the process
of reading from a register the SL1TxBusy bit is set indicating that the
transceiver is busy and remains so until the default timeout occurs.
Set the Power down register 0x26 to an arbitrary value as specified in
the PL041 manual (page: 3-18) so that AACISL1TX/AACISL2TX registers take
their default state.
Signed-off-by: Philby John <pjohn@in.mvista.com>
I found the PrimeCell/AMBA Bus drivers distrusting the resource
passed in as part of the struct amba_device abstraction. This
patch removes all hard coded resource sizes found in the PrimeCell
drivers and move the responsibility of this definition back to
the platform/board device definition, which already exist and
appear to be correct for all in-tree users of these drivers.
We do this using the resource_size() inline function which was
also replicated in the only driver using the resource size, so
that has been changed too. The KMI_SIZE was left in kmi.h in case
someone likes it. Test-compiled against Versatile and Integrator
defconfigs, seems to work but I don't posess these boards and
cannot test them.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
The second argument of the probe method points to the amba_id
structure, so it's better passed with the correct type. None of the
current in-tree drivers uses the pointer, so they have only been
checked for a clean compile.
Change suggested by Russell King.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
With a postfix decrement the timeout will reach -1 rather than 0,
so the warning will not be issued.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Convert from snd_card_new() to the new snd_card_create() function
in other sound subdirectories.
The original fix by Julien Brunel <brunel@diku.dk>.
aaci_init_card() returns a pointer with ERR_PTR(), but in aaci_init()
NULL is supposed at this error path.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Found these while looking at printk uses.
Add missing newlines to dev_<level> uses
Add missing KERN_<level> prefixes to multiline dev_<level>s
Fixed a wierd->weird spelling typo
Added a newline to a printk
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: Greg KH <greg@kroah.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
Cc: James Smart <James.Smart@Emulex.Com>
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
CC [M] sound/arm/aaci.o
sound/arm/aaci.c:729: error: parse error before '*' token
sound/arm/aaci.c:731: warning: function declaration isn't a prototype
sound/arm/aaci.c:786: error: parse error before '*' token
sound/arm/aaci.c:786: warning: function declaration isn't a prototype
sound/arm/aaci.c:827: error: parse error before '*' token
sound/arm/aaci.c:828: warning: function declaration isn't a prototype
sound/arm/aaci.c:845: error: parse error before "aaci_capture_ops"
sound/arm/aaci.c:845: warning: type defaults to `int' in declaration of `aaci_capture_ops'
Add timeouts to hardware read/write/probe functions in order
to avoid lockups on buggy/broken hardware.
Signed-off-by: Kevin Hilman <khilman@mvista.com>
Add PCM audio capture support for AACI audio on Versatile platform.
Add AACI channel support to interrupt handler.
Also, clear underrun interrupt for correct channel.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
This is needed if we wish to change the size of the resource structures.
Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Patch from Catalin Marinas
AACI reports TX FIFO full after the first write to it if the AC97 is not
enabled. This patch enables the AC97 probing before the check for the TX
FIFO size. The patch also adds a warning if the TX FIFO size is not
multiple of 16.
Since the ARM AMBA bus is used on MIPS as well as ARM, we need
to make the bus available for other architectures to use. Move
the AMBA include files from include/asm-arm/hardware/ to
include/linux/amba/
Modules: ARM AACI PL041 driver,ARM PXA2XX driver
Fix PM support of aaci and pxa2xx drivers.
Modules: ARM AACI PL041 driver,ARM DMA routines
Remove xxx_t typedefs from the ARM AACI driver.
Fix up some pm_message_t types
Signed-Off-By: Richard Purdie <rpurdie@rpsys.net>
ARM AACI PL041 driver,PARISC Harmony driver
Added snd_card_set_dev() calls to register the device pointer for the card.
ARM,/arm/Makefile,ARM AACI PL041 driver
Add support for the ARM AACI Primecell, which provides an AC'97
based interface. This driver only provides playback support.
This has been extensively tested with an LM4549 AC'97 codec.
Signed-off-by: Russell King <rmk@arm.linux.org.uk>
