path: root/sound/arm/pxa2xx-ac97-lib.c
2009-05-11pxa2xx-ac97: fix reset gpio mode settingMike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-15[ARM] pxa: merge AC97 platform data structuresMark Brown
Currently there are two possible platform datas for the PXA AC97 driver: one supported by the generic AC97 driver only which provides callbacks to allow board-specific configuration at stream startup and teardown, and another for pxa2xx-ac97-lib which allows configuration of the reset GPIO for PXA2xx CPUs. Obviously this won't actually work when using the generic AC97 driver since the drivers will attempt to parse the platform data in both formats. Fix this by merging the two structures. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-04-06Merge branch 'topic/asoc' into for-linusTakashi Iwai
2009-04-02pxa2xx-ac97: fix displaying GSR after reset timeoutLuotao Fu
the variable gsr_bit is set in isr. It is however set to 0 and interrupts are disabled prior to reset. Hence it doesn't make a lot of sense to show the content of gsr_bit in case of a reset timeout. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-28Merge branch 'origin' into develRussell King
Conflicts: sound/soc/pxa/pxa2xx-i2s.c
2009-03-19ALSA: Fix wrong pointer to dev_err() in arm/pxa2xx-ac97-lib.cTakashi Iwai
Fix the wrong device pointer passed to dev_err(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-15ASoC: Allow choice of ac97 gpio reset lineRobert Jarzmik
As the PXA27x series allow 2 gpios to reset the ac97 bus, allow through platform data configuration the definition of the correct gpio which will reset the AC97 bus. This comes from a silicon defect on the PXA27x series, where the gpio must be manually controlled in warm reset cases. Signed-off-by: Robert Jarzmik <rjarzmik@free.fr> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-09[ARM] pxa: remove unnecessary #include of pxa-regs.h and hardware.hEric Miao
pxa-regs.h and hardware.h are not intended for use directly in driver code, remove those unnecessary references. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-01-05pxa2xx-ac97: switch AC unit to correct state before probingDmitry Baryshkov
If AC97 unit is in partially enabled state, early request_irq can trigger IRQ storm or even full hang up. Workaround this by forcibly switching ACLINK off at the start of the probe. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-02[ARM] pxa: move AC97 register definitions into dedicated regs-ac97.hEric Miao
The optimal change would be to move the AC97 register definitions into the AC97 driver, unfortunately, the registers are shared between several files. Move them into a dedicated regs-ac97.h first. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-10-14ALSA: Fix pxa2xx-ac97-lib.c compilationMarc Zyngier
The last ALSA merge broke pxa2xx-ac97-lib.c, as it brought back references to cpu_is_pxa21x that Eric Miao removed in commit 0ffcbfd54ea81ca24c0749f55ca4fcf3e2bdc23e: [ARM] pxa: make cpu_is_pxa2* macros more consistent This patch gets rid of those references, and only keeps cpu_is_pxa25x(). Signed-off-by: Marc Zyngier <maz@misterjones.org> Acked-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-09-23ALSA: pxa2xx-ac97-lib: support building for several CPUsDmitry Baryshkov
Support building of pxa2xx-ac97-lib for several CPUs by making code run-time selected, not only compile-time. [Fixed 3XX->3xx typos in ifdef checks -- broonie.] Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-09-23ALSA: Separate common pxa2xx-ac97 codeDmitry Baryshkov
ASoC and non-ASoC drivers for ACLINK on PXA share lot's of common code. Move all common code into separate module snd-pxa2xx-lib. [Fixed handing of SND_AC97_CODEC in Kconfig and some checkpatch warnings -- broonie] Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
