path: root/sound/atmel/ac97c.c
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-06-28ALSA: atmel - update author email for ABDAC, AC97C and AT73C213Hans-Christian Egtvedt
This patch updates the email address of the sound drivers supported by me to an email account I will use on a more regular basis in the future. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-25ALSA: fix invalid hardware.h include in ac97c for AVR32 architectureHans-Christian Egtvedt
This patch fixes the non-compiling AC97C driver for AVR32 architecture by include mach/hardware.h only for AT91 architecture. The AVR32 architecture does not supply the hardware.h include file. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> CC: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-08ALSA: atmel: set "channel A event" output to debugYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-25ALSA: AC97: add full duplex support for atmel AT91 and AVR.Sedji Gaouaou
This patch add full duplex support on AT91 and AVR. It was a bug: we needed to check first if there are some chips opened so we could enable both reception and sending of the data. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-25ALSA: AC97: add AC97 support for AT91.Sedji Gaouaou
This patch add AC97 support for ATMEL AT91, using the AVR32 code. While AVR is using a DMA, the AT91 chips are using a Peripheral Data Controller. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: replace bus_id with dev_name()Hans-Christian Egtvedt
This patch replaces the references to bus_id to the new dev_name() API. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: cleanup registers when removing driverHans-Christian Egtvedt
This patch will set the channel A and control channel mode register to zero before disabling the AC97C peripheral. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: do a proper reset of the external codecHans-Christian Egtvedt
This patch will enable the AC97C before resetting the external codec, leaving the AC97C disabled will result in floating I/O lines that can affect the reset procedure. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: enable interrupts to catch events for error reportingHans-Christian Egtvedt
This patch will enable interrupts from AC97C and report about error conditions that occurs. On channel A both overrun and underrun will be enabled depending if playback and/or capture are enabled. On the control channel the overrun interrupt is enabled. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: set correct size for buffer hardware parameterHans-Christian Egtvedt
This patch will set a proper maximum bytes for the buffer, which is: channels * bytes per sample * maximum periods * maximum bytes per period. It also sets the minimum periods to 6, a value chosen from testing, with a minimum of 6 periods the system has good time to fill in new audio data without skipping. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: do not overwrite OCA and ICA when assigning channelsHans-Christian Egtvedt
This patch will take care not to overwrite OCA and ICA registers when assigning input and output channels. It will also make sure the registers are at a known state when enabling a channel and clean up properly in case of an error. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: remove dead break statements after return in switch caseHans-Christian Egtvedt
2009-02-05ALSA: Add ALSA driver for Atmel AC97 controllerHans-Christian Egtvedt
This patch adds ALSA support for the AC97 controller found on Atmel AVR32 devices. Tested on ATSTK1006 + ATSTK1000 with a development board with a AC97 codec. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
