path: root/sound/atmel
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-06-28ALSA: atmel - update author email for ABDAC, AC97C and AT73C213Hans-Christian Egtvedt
This patch updates the email address of the sound drivers supported by me to an email account I will use on a more regular basis in the future. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-25ALSA: fix invalid hardware.h include in ac97c for AVR32 architectureHans-Christian Egtvedt
This patch fixes the non-compiling AC97C driver for AVR32 architecture by include mach/hardware.h only for AT91 architecture. The AVR32 architecture does not supply the hardware.h include file. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> CC: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: atmel - Fix the return value in error pathTakashi Iwai
In the commit c0763e687d0283d0db507813ca4462aa4073c5b5 ALSA: snd-atmel-abdac: test wrong variable the return value via PTR_ERR() had to be fixed as well. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-22ALSA: snd-atmel-abdac: test wrong variableVasiliy Kulikov
After clk_get() pclk is checked second time instead of sample_clk check. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-08ALSA: atmel: set "channel A event" output to debugYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-25ALSA: AC97: add full duplex support for atmel AT91 and AVR.Sedji Gaouaou
This patch add full duplex support on AT91 and AVR. It was a bug: we needed to check first if there are some chips opened so we could enable both reception and sending of the data. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-25ALSA: AC97: add AC97 support for AT91.Sedji Gaouaou
This patch add AC97 support for ATMEL AT91, using the AVR32 code. While AVR is using a DMA, the AT91 chips are using a Peripheral Data Controller. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-abdac: increase periods_min to 6 instead of 4Hans-Christian Egtvedt
This patch increases periods_min to 6 from 4, this will remove any hickups where the buffer is not filled fast enough from user space. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-abdac: replace bus_id with dev_name()Hans-Christian Egtvedt
This patch replaces the references to bus_id to the new dev_name() API. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: replace bus_id with dev_name()Hans-Christian Egtvedt
2009-04-06ALSA: snd-atmel-ac97c: cleanup registers when removing driverHans-Christian Egtvedt
This patch will set the channel A and control channel mode register to zero before disabling the AC97C peripheral. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: do a proper reset of the external codecHans-Christian Egtvedt
This patch will enable the AC97C before resetting the external codec, leaving the AC97C disabled will result in floating I/O lines that can affect the reset procedure. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: enable interrupts to catch events for error reportingHans-Christian Egtvedt
This patch will enable interrupts from AC97C and report about error conditions that occurs. On channel A both overrun and underrun will be enabled depending if playback and/or capture are enabled. On the control channel the overrun interrupt is enabled. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: set correct size for buffer hardware parameterHans-Christian Egtvedt
This patch will set a proper maximum bytes for the buffer, which is: channels * bytes per sample * maximum periods * maximum bytes per period. It also sets the minimum periods to 6, a value chosen from testing, with a minimum of 6 periods the system has good time to fill in new audio data without skipping. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: do not overwrite OCA and ICA when assigning channelsHans-Christian Egtvedt
This patch will take care not to overwrite OCA and ICA registers when assigning input and output channels. It will also make sure the registers are at a known state when enabling a channel and clean up properly in case of an error. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-06ALSA: snd-atmel-ac97c: remove dead break statements after return in switch caseHans-Christian Egtvedt
2009-04-06ALSA: snd-atmel-ac97c: cleanup register definitionsHans-Christian Egtvedt
This patch will remove traces of channel B registers, since they are not used by the AC97C driver. Channel B might be used for other purposes. The driver also adds channel status bits TXEMPTY and OVRUN and a AC97C_CH_MASK macro to ease clearing a channel settings. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: Add ALSA driver for Atmel AC97 controllerHans-Christian Egtvedt
This patch adds ALSA support for the AC97 controller found on Atmel AVR32 devices. Tested on ATSTK1006 + ATSTK1000 with a development board with a AC97 codec. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: Add ALSA driver for Atmel Audio Bitstream DACHans-Christian Egtvedt
This patch adds ALSA support for the Audio Bistream DAC found on Atmel AVR32 devices. The ABDAC is an Atmel IP which might show up on AT91 devices in the future, hence making a generic driver which can be utilized by AT91 arch if needed. Datasheet describing the ABDAC peripheral is available in the AT32AP7000 datasheet, http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 Tested on ATSTK1006 + ATSTK1000 with a class D amplifier stage. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
