The dereference snd_pcm_plug_stream(plug) should come after the NULL
check snd_BUG_ON(!plug).
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Change the core code where sparse complains. In most cases, this means
just adding annotations to confirm that we indeed want to do the dirty
things we're doing.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Kill snd_assert() in sound/core/*, either removed or replaced with
if () with snd_BUG_ON().
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Add the support of 3-bytes 24bit formats in PCM OSS emulation.
Also removed snd_pcm_build_linear_format() function. It's exported
just for OSS emulation, and now the code was changed without calling
this function.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Fix Makefile to compile files conditionally to CONFIG_SND_PCM_OSS_PLUGINS,
and remove unneeded ifdefs in these files.
Modules: ALSA<-OSS emulation
Fixed the missing mulaw -> linear conversion in OSS PCM emulation code.
Clean up pcm-oss plugin codes.
Removed dead codes, and simplified route/rate plugins.
Modules: ALSA Core,PCM Midlevel,ALSA<-OSS emulation,USB generic driver
1) The verbose procfs code for the PCM midlevel and usb audio
can be removed now (more patches will follow).
CONFIG_SND_VERBOSE_PROCFS
2) The PCM OSS plugin system can be also compiled optionaly.
Remove xxx_t typedefs from the core PCM OSS-emulation codes.
Use standard bitmap functions instead of in-house ones.
Control Midlevel,ALSA Core,HWDEP Midlevel,PCM Midlevel,RawMidi Midlevel
Timer Midlevel,ALSA<-OSS emulation
Replace kcalloc(1,..) with kzalloc().
ALSA<-OSS emulation
The Coverity checker found this obviously dead code.
I'm not sure which of the if (plugin == NULL) is correct - this patch
removes the one that couldn't be true.
infrastructure for it.
Let it rip!
