Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Add a snd_pcm_rate_to_rate_bit() function to factor out common code used
by several drivers.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Merge the rates[] arrays from pcm_misc.c and pcm_native.c because they
are both the same.
Add the support of 3-bytes 24bit formats in PCM OSS emulation.
Also removed snd_pcm_build_linear_format() function. It's exported
just for OSS emulation, and now the code was changed without calling
this function.
Move EXPORT_SYMBOL()s to places adjacent to functions/variables.
Also move OSS-specific hw_params helper functions to pcm_oss.c.
Modules: PCM Midlevel
Remove xxx_t typedefs from the core PCM codes.
PCM Midlevel
Export snd_pcm_format_size(). This function is used by some out-of-kernel
drivers.
Make snd_pcm_format_cpu_endian() macro for optimization.
infrastructure for it.
Let it rip!
