Drop a few variables that are never read.
Signed-off-by: Luca Tettamanti <kronos.it@gmail.com>
The Patch below removes one to many "n's" in a word..
Change the core code where sparse complains. In most cases, this means
just adding annotations to confirm that we indeed want to do the dirty
things we're doing.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
If CONFIG_SND_DYNAMIC_MINORS is used, assign /dev/snd/seq and
/dev/snd/timer the usual static minors, and export specific
module aliases to generate udev module on-demand loading
instructions:
$ cat /lib/modules/2.6.33.4-smp/modules.devname
# Device nodes to trigger on-demand module loading.
microcode cpu/microcode c10:184
fuse fuse c10:229
ppp_generic ppp c108:0
tun net/tun c10:200
uinput uinput c10:223
dm_mod mapper/control c10:236
snd_timer snd/timer c116:33
snd_seq snd/seq c116:1
The last two lines instruct udev to create device nodes, even
when the modules are not loaded at that time.
As soon as userspace accesses any of these nodes, the in-kernel
module-loader will load the module, and the device can be used.
The header file minor calculation needed to be simplified to
make __stringify() (supports only two indirections) in
the MODULE_ALIAS macro work.
This is part of systemd's effort to get rid of unconditional
module load instructions and needless init scripts.
Cc: Lennart Poettering <lennart@poettering.net>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
The error handling in snd_seq_oss_open() has several bad codes that
do dereferecing released pointers and double-free of kmalloc'ed data.
The object dp is release in free_devinfo() that is called via
private_free callback. The rest shouldn't touch this object any more.
The patch changes delete_port() to call kfree() in any case, and gets
rid of unnecessary calls of destructors in snd_seq_oss_open().
Fixes CVE-2010-3080.
Reported-and-tested-by: Tavis Ormandy <taviso@cmpxchg8b.com>
Cc: <stable@kernel.org>
Set no_llseek to llseek file ops of each sound component (but for hwdep).
This avoids the implicit BKL invocation via generic_file_llseek() used
as default when fops.llseek is NULL.
Also call nonseekable_open() at each open ops to ensure the file flags
have no seek bit.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Instead of padding with blanks and printing "number=0x a", print
"number=0x0a".
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
As snd_seq_timer_set_tick_resolution() is always called with the same
three fields of struct snd_seq_timer, it suffices to give that as the
only parameter.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
* topic/midi:
sound: rawmidi: disable active-sensing-on-close by default
sound: seq_oss_midi: remove magic numbers
sound: seq_midi: do not send MIDI reset when closing
seq-midi: always log message on output overrun
When build SND_SEQUENCER in kernel then OSS sequencer(alsa_seq_oss_init)
is initialized before System (snd_seq_system_client_init) which leads to
memory leak :
unreferenced object 0xf6b0e680 (size 256):
comm "swapper", pid 1, jiffies 4294670753
backtrace:
[<c108ac5c>] create_object+0x135/0x204
[<c108adfe>] kmemleak_alloc+0x26/0x4c
[<c1087de2>] kmem_cache_alloc+0x72/0xff
[<c126d2ac>] seq_create_client1+0x22/0x160
[<c126e3b6>] snd_seq_create_kernel_client+0x72/0xef
[<c1485a05>] snd_seq_oss_create_client+0x86/0x142
[<c1485920>] alsa_seq_oss_init+0xf6/0x155
[<c1001059>] do_one_initcall+0x4f/0x111
[<c14655be>] kernel_init+0x115/0x166
[<c10032af>] kernel_thread_helper+0x7/0x10
[<ffffffff>] 0xffffffff
unreferenced object 0xf688a580 (size 64):
backtrace:
[<c126f964>] snd_seq_pool_new+0x1c/0xb8
[<c126d311>] seq_create_client1+0x87/0x160
unreferenced object 0xf6b0e480 (size 256):
comm "swapper", pid 1, jiffies 4294670754
backtrace:
[<c12725a0>] snd_seq_create_port+0x51/0x21c
[<c126de50>] snd_seq_ioctl_create_port+0x57/0x13c
[<c126d07a>] snd_seq_do_ioctl+0x4a/0x69
[<c126d0de>] snd_seq_kernel_client_ctl+0x33/0x49
[<c1485a74>] snd_seq_oss_create_client+0xf5/0x142
The correct order should be :
System (snd_seq_system_client_init) should be initialized before
OSS sequencer(alsa_seq_oss_init) which is equivalent to :
1. insmod sound/core/seq/snd-seq-device.ko
2. insmod sound/core/seq/snd-seq.ko
3. insmod sound/core/seq/snd-seq-midi-event.ko
4. insmod sound/core/seq/oss/snd-seq-oss.ko
Including sound/core/seq/oss/Makefile after other seq modules
fixes the ordering and memory leak.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Sending an Active Sensing message when closing a port can interfere with
the following data if the port is reopened and a note-on is sent before
the device's timeout has elapsed. Therefore, it is better to disable
this setting by default.
Instead of using magic numbers for the controlles sent when resetting
a port, use the symbols from asoundef.h.
Sending a MIDI reset message when closing a port is wrong because we
only want to shut the device up, not to reset all settings.
Furthermore, many devices ignore this message.
Fortunately, the RawMIDI layer already shuts the device up, so we can
ignore this matter here.
It turns out that the main cause of output buffer overruns is not slow
drivers but applications that generate too many messages. Therefore, it
makes more sense to make that error message always visible, and to
rate-limit it.
* topic/seq-midi-fix:
sound: seq_midi_event: fix decoding of (N)RPN events
When decoding (N)RPN sequencer events into raw MIDI commands, the
extra_decode_xrpn() function had accidentally swapped the MSB and LSB
controller values of both the parameter number and the data value.
Instead of mangling the CONFIG_* variables in the makefiles over and
over, set a few helper variables in Kconfig.
Remove open-coded memdup_user().
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Added the hrtimer backend for ALSA timer interface.
It can be used for the sequencer timer source.
Kill snd_assert() in sound/core/*, either removed or replaced with
if () with snd_BUG_ON().
snd_seq_oss_synth_make_info() incorrectly reports information
to userspace without first checking for the validity of the
device number, leading to possible information leak (CVE-2008-3272).
Reported-By: Tobias Klein <tk@trapkit.de>
Acked-and-tested-by: Takashi Iwai <tiwai@suse.de>
Cc: stable@kernel.org
Signed-off-by: Willy Tarreau <w@1wt.eu>
A bunch of things in alsa depend on CONFIG_KMOD,
use CONFIG_MODULES instead where the dependency
is needed at all.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Removed invalid BUG() - the driver should handle the error case properly
rather than issuing BUG().
The sound drivers and the pnpbios core test for current->root != NULL. This
test seems to be unnecessary since we always have rootfs mounted before
initializing the drivers.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Jaroslav Kysela <perex@suse.cz>
Acked-by: Takashi Iwai <tiwai@suse.de>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
proper headers
sound/core/seq: move declarations of globally visible variables to proper headers
Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com>
Remove sequencer instrument layer from the tree.
This mechanism hasn't been used much with the actual devices. The only
reasonable user was OPL3 loader, and now it was rewritten to use hwdep
instead. So, let's remove the rest of rotten codes.
Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Replace schedule_timeout() with schedule_timeout_uninterruptible()
to avoid signals in loop.
Signed-off-by: Rene Herman <rene.herman@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Check for a valid event type when encoding a system real-time message to
prevent the bytes F9 or FD resulting in an empty sequencer message.
Reorganize the encoder logic to prevent status bytes that appear where
data bytes are expected from being interpreted as data bytes.
Reset the event type after encoding a system message to prevent any
following data bytes from being interpreted as data for a running status
system message, which is not allowed in MIDI.
Create a new state ST_INVALID for the encoder to prevent data bytes at
the beginning of a stream or after a sysex message being interpreted as
note-off parameters.
This patch fixes:
1) a resource leak (CID: 1817)
2) various code cleanups
Signed-off-by: Eugene Teo <eugeneteo@kernel.sg>
Fixed the invalid use of schedule_timeout_interruptible() without
checking pending signals. Simply replaced with schedule_timeout().
Suggestions thanks to Jeff Garzik.
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc).
Here is a short excerpt of the semantic patch performing
this transformation:
type T2;
expression x;
identifier f,fld;
expression E;
expression E1,E2;
expression e1,e2,e3,y;
statement S;
x =
- kmalloc
+ kzalloc
(E1,E2)
... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\)
- memset((T2)x,0,E1);
expression E1,E2,E3;
- kzalloc(E1 * E2,E3)
+ kcalloc(E1,E2,E3)
[akpm@linux-foundation.org: get kcalloc args the right way around]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Fix possible rwsem deadlocks in sequencer code at removal of
sequencer ports. The list_lock of port group can be double
locked.
This patch converts most uses of list_for_each to list_for_each_entry all
across alsa. In some place apparently an item can be on a list with
different pointers so of course that isn't compatible with list_for_each, I
therefore didn't touch those places.
Use the roundup macro instead of manual calculations.
Orignally proposed by Sam Revitch <sam.revitch@gmail.com>.
Unregister device files at disconnection to avoid the futher accesses.
Also, the dev_unregister callback is removed and replaced with the
combination of disconnect + free.
A new function snd_card_free_when_closed() is introduced, which is
used in USB disconnect callback.
- Add the linked list to each proc entry to enable a single-shot
disconnection (unregister)
- Deprecate snd_info_unregister(), use snd_info_free_entry()
- Removed NULL checks of snd_info_free_entry()
sound: Conversions from kmalloc+memset to k(c|z)alloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
