path: root/sound/core/sound.c
2013-10-24consolidate the reassignments of ->f_op in ->open() instancesAl Viro
2013-03-12ALSA: add/change some comments describing function return valuesYacine Belkadi
script/kernel-doc reports the following type of warnings (when run in verbose mode): Warning(sound/core/init.c:152): No description found for return value of 'snd_card_create' To fix that: - add missing descriptions of function return values - use "Return:" sections to describe those return values Along the way: - complete some descriptions - fix some typos Signed-off-by: Yacine Belkadi <yacine.belkadi.1@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-08ALSA: Fix card refcount unbalanceTakashi Iwai
There are uncovered cases whether the card refcount introduced by the commit a0830dbd isn't properly increased or decreased: - OSS PCM and mixer success paths - When lookup function gets NULL This patch fixes these places. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=50251 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-30ALSA: Add a reference counter to card instanceTakashi Iwai
For more strict protection for wild disconnections, a refcount is introduced to the card instance, and let it up/down when an object is referred via snd_lookup_*() in the open ops. The free-after-last-close check is also changed to check this refcount instead of the empty list, too. Reported-by: Matthieu CASTET <matthieu.castet@parrot.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-09-04ALSA: remove the main version informationJaroslav Kysela
Remove the main ALSA version number from the kernel ALSA driver. The ALSA driver package release diverges from the upstream. This may confuse users to see the same ALSA version for many kernel releases and this version lost it's original purpose and connection. The "ioctl" APIs have own version numbers, so the user space may check for specific API changes only. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2011-12-23ALSA: core: add support for compressed devicesOmair Mohammed Abdullah
Use the minor numbers 2 and 3 for audio compressed offload devices. Also add support for these devices in core Signed-off-by: Omair Mohammed Abdullah <omair.m.abdullah@intel.com> Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-31sound: fix drivers needing module.h not moduleparam.hPaul Gortmaker
The implicit presence of module.h lured several users into incorrectly thinking that they only needed/used modparam.h but once we clean up the module.h presence, these will show up as build failures, so fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-12-13Merge branch 'topic/workq-update' into topic/miscTakashi Iwai
2010-11-24ALSA: support module on-demand loading for seq and timerKay Sievers
If CONFIG_SND_DYNAMIC_MINORS is used, assign /dev/snd/seq and /dev/snd/timer the usual static minors, and export specific module aliases to generate udev module on-demand loading instructions: $ cat /lib/modules/2.6.33.4-smp/modules.devname # Device nodes to trigger on-demand module loading. microcode cpu/microcode c10:184 fuse fuse c10:229 ppp_generic ppp c108:0 tun net/tun c10:200 uinput uinput c10:223 dm_mod mapper/control c10:236 snd_timer snd/timer c116:33 snd_seq snd/seq c116:1 The last two lines instruct udev to create device nodes, even when the modules are not loaded at that time. As soon as userspace accesses any of these nodes, the in-kernel module-loader will load the module, and the device can be used. The header file minor calculation needed to be simplified to make __stringify() (supports only two indirections) in the MODULE_ALIAS macro work. This is part of systemd's effort to get rid of unconditional module load instructions and needless init scripts. Cc: Lennart Poettering <lennart@poettering.net> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-04-09ALSA: Remove BKL from open multiplexerTakashi Iwai
Use a local mutex instead of BKL. This should suffice since each device type has also its open_mutex. Also, a bit of clean-up of the legacy device auto-loading code. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-14ALSA: use subsys_initcall for sound core instead of module_initThadeu Lima de Souza Cascardo
This is needed for built-in drivers which are built before the sound directory, like thinkpad_acpi. Otherwise, registering a card fails. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-06Check fops_get() return valueLaurent Pinchart
Several subsystem open handlers dereference the fops_get() return value without checking it for nullness. This opens a race condition between the open handler and module unloading. A module can be marked as being unloaded (MODULE_STATE_GOING) before its exit function is called and gets the chance to unregister the driver. During that window open handlers can still be called, and fops_get() will fail in try_module_get() and return a NULL pointer. This change checks the fops_get() return value and returns -ENODEV if NULL. Reported-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16device create: sound: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Cc: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13ALSA: Kill snd_assert() in sound/core/*Takashi Iwai
Kill snd_assert() in sound/core/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-01ALSA: Fix limit of 8 PCM devices in SNDRV_CTL_IOCTL_PCM_NEXT_DEVICEPawel MOLL
When compiled with CONFIG_SND_DYNAMIC_MINORS the ALSA core is fine to have more than 8 PCM devices per card, except one place - the SNDRV_CTL_IOCTL_PCM_NEXT_DEVICE ioctl, which will not enumerate devices > 7. This patch fixes the issue, changing the devices list organisation. Instead of adding new device to the tail, the list is now kept always ordered (by card number, then device number). Thus, during enumeration, it is easy to discover the fact that there is no more given card's devices. Additionally the device field of struct snd_pcm had to be changed to int, as its "unsignednity" caused a lot of problems when comparing it to potentially negative signed values. (-1 is 0xffffffff or even more then ;-) Signed-off-by: Pawel Moll <pawel.moll@st.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-01sound: Revert "ALSA: Fix limit of 8 PCM devices in ↵Jaroslav Kysela
SNDRV_CTL_IOCTL_PCM_NEXT_DEVICE" This reverts commit fb3d6f2b77bdec75d45aa9d4464287ed87927866. New, updated patch with same subject replaces this commit. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-29ALSA: Fix limit of 8 PCM devices in SNDRV_CTL_IOCTL_PCM_NEXT_DEVICEPawel MOLL
When compiled with CONFIG_SND_DYNAMIC_MINORS the ALSA core is fine to have more than 8 PCM devices per card, except one place - the SNDRV_CTL_IOCTL_PCM_NEXT_DEVICE ioctl, which will not enumerate devices > 7. This patch fixes the issue, changing the devices list organisation. Instead of adding new device to the tail, the list is now kept always ordered (by card number, then device number). Thus, during enumeration, it is easy to discover the fact that there is no more given card's devices. The same limit was present in OSS emulation code. It has been fixed as well. Additionally the device field of struct snd_pcm is now int, instead of unsigned int, as there is no obvious reason for keeping it unsigned. This caused a lot of problems with comparing this value with other (almost always signed) variables. There is just one more place where device number is unsigned - in struct snd_pcm_info, which should be also sorted out in future. Signed-off-by: Pawel MOLL <pawel.moll@st.com> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits) IB/umad: BKL is not needed for ib_umad_open() IB/uverbs: BKL is not needed for ib_uverbs_open() bf561-coreb: BKL unneeded for open() Call fasync() functions without the BKL snd/PCM: fasync BKL pushdown ipmi: fasync BKL pushdown ecryptfs: fasync BKL pushdown Bluetooth VHCI: fasync BKL pushdown tty_io: fasync BKL pushdown tun: fasync BKL pushdown i2o: fasync BKL pushdown mpt: fasync BKL pushdown Remove BKL from remote_llseek v2 Make FAT users happier by not deadlocking x86-mce: BKL pushdown vmwatchdog: BKL pushdown vmcp: BKL pushdown via-pmu: BKL pushdown uml-random: BKL pushdown uml-mmapper: BKL pushdown ...
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-10ALSA: remove CONFIG_KMOD from soundJohannes Berg
A bunch of things in alsa depend on CONFIG_KMOD, use CONFIG_MODULES instead where the dependency is needed at all. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-20sound: cdev lock_kernel() pushdownJonathan Corbet
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-05-20SOUND: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-14Dont touch fs_struct in driversJan Blunck
The sound drivers and the pnpbios core test for current->root != NULL. This test seems to be unnecessary since we always have rootfs mounted before initializing the drivers. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] sound: snd_register_device_for_dev fixMariusz Kozlowski
snd_register_device_for_dev() can oops when device_create() returns ERR_PTR(err). Scenario: preg->dev = device_create(...); /* fails */ if (preg->dev) /* contains ERR_PTR(err) */ dev_set_drvdata(preg->dev, private_data); and dev_set_drvdata() looks like this: static inline void dev_set_drvdata (struct device *dev, void *data) { dev->driver_data = data; <--- boom } This patch should prevent that. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-19unregister_chrdev(): ignore the return valueAkinobu Mita
unregister_chrdev() always returns 0. There is no need to check the return value. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 9Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[ALSA] allow registering an alsa device with struct device pointerJohannes Berg
This patch adds snd_register_device_for_dev taking a struct device pointer to link the new device to and makes snd_register_device a simple static inline wrapper around it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-01-29[PATCH] ALSA: Fix sysfs breakageTakashi Iwai
The recent change for a new sysfs tree with card* object breaks the /sys/class/sound tree if CONFIG_SYSFS_DEPRECATED is enabled. The device in each entry doesn't point the correct device object: /sys/class/sound ... |-- pcmC0D0c | |-- dev | |-- device -> ../../../class/sound/card0 | |-- pcm_class | |-- power | | `-- wakeup | |-- subsystem -> ../../../class/sound | `-- uevent Also, this change breaks some drivers (like sound/arm/*) referring card->dev directly to obtain the device object for memory handling. This patch reverts the semantics of card->dev to the former version, which points to a real device object. The card* object is stored in a new card->card_dev field, instead. The device parent is chosen either card->dev or card->card_dev according to CONFIG_SYSFS_DEPRECATED to keep the tree compatibility. Also, card* isn't created if CONFIG_SYSFS_DEPRECATED is enabled. The reason of card* object is a root of all beloing devices, and it makes little sense if each sound device points to the real device object directly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Monty Montgomery <xiphmont@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01Driver core: convert sound core to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. It also makes the struct sound_card to show up as a "real" device where all the different sound class devices are placed as childs and different card attribute files can hang off of. /sys/class/sound is still a flat directory, but the symlink targets of all devices belonging to the same card, point the the /sys/devices tree below the new card device object. Thanks to Kay for the updates to this patch. Signed-off-by: Kay Sievers <kay.sievers@novell.com> Acked-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-23[ALSA] Add pcm_class attribute to PCM sysfs entryTakashi Iwai
This patch adds a new attribute, pcm_class, to each PCM sysfs entry. It's useful to detect what kind of PCM stream is, for example, HAL can check whether it's a modem or not. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix disconnection of proc interfaceTakashi Iwai
- Add the linked list to each proc entry to enable a single-shot disconnection (unregister) - Deprecate snd_info_unregister(), use snd_info_free_entry() - Removed NULL checks of snd_info_free_entry() Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] remove unused snd_minor.name fieldClemens Ladisch
Drop the snd_minor structure's name field that was just a helper for devfs device deregistration. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-26[PATCH] devfs: Remove devfs support from the sound subsystemGreg Kroah-Hartman
2006-06-22[ALSA] Remove zero-initialization of static variablesTakashi Iwai
Removed zero-initializations of static variables. A tiny optimization. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Fix rwlock around snd_iprintf() in sound coreTakashi Iwai
Fixed rwlock around snd_iprintf() in sound core part. Replaced with mutex. Also, make mutex and flags static variables with addition of snd_card_locked() function (just for sound.c). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Clean up EXPORT_SYMBOL()s in snd moduleTakashi Iwai
Move EXPORT_SYMBOL()s to places adjacent to functions/variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[ALSA] sound/core/: fix 3 off-by-one errorsAdrian Bunk
Modules: ALSA Core This patch fixes three off-by-one errors found by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] semaphore -> mutex (core part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-04[ALSA] Revert the nested-device patchTakashi Iwai
Modules: ALSA Core Revert the nested-device patch to keep the compatibility with the current HAL configuration. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Nest sound devicesClemens Ladisch
Modules: ALSA Core Make the control device parent of all other ALSA devices of a card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Optimize for config without PROC_FSTakashi Iwai
Modules: HWDEP Midlevel,ALSA Core,PCM Midlevel,Timer Midlevel Optimize the code when compiled without CONFIG_PROC_FS. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Fix a missing includeTakashi Iwai
Modules: ALSA Core Fix missing include <linux/device.h> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] dynamic minors (6/6): increase maximum number of sound cardsClemens Ladisch
Modules: ALSA Core,Memalloc module,ALSA sequencer With dynamic minor numbers, we can increase the number of sound cards. This requires that the sequencer client numbers of some kernel drivers are allocated dynamically, too. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] dynamic minors (4/6): dynamic minor number allocationClemens Ladisch
Modules: ALSA Core,ALSA Minor Numbers Add an option to allocate device file minor numbers dynamically. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
