We may disable proc fs only for sound part, to reduce ALSA
memory footprint. So add CONFIG_SND_PROC_FS and replace the
old CONFIG_PROC_FSs in alsa code.
With sound proc fs disabled, we can save about 9KB memory
size on X86_64 platform.
Signed-off-by: Jie Yang <yang.jie@intel.com>
Reviewed-by: Mark Brown <broonie@kernel.org>
Minor cleanups of Makefile to build some codes conditionally so that
a few ifdefs can be reduced.
Acked-by: Jaroslav Kysela <perex@perex.cz>
So far we've ignored the errors at creating proc files in many places.
But they should be rather treated seriously.
Also, by assuring the error handling, we can get rid of superfluous
snd_info_free_entry() calls as they will be removed by the parent in
the caller side.
This patch fixes the missing error checks and reduces the superfluous
free calls.
Since each proc entry is freed automatically by the parent, we don't
have to take care of its life cycle any longer. This allows us to
reduce a few more lines of codes.
Drop the own refcount but use the standard device refcounting via
get_device() and put_device(). Introduce a new completion to snd_card
instead of the wait queue for syncing the last release, which is used
in snd_card_free().
The last argument, name, of snd_oss_register_device() is nowhere
referred in the function in the current code. Let's drop it.
Replace the lengthy #if defined(XXX) || defined(XXX_MODULE) with the
new IS_ENABLED() macro.
The patch still doesn't cover all ifdefs. For example, the dependency
on CONFIG_GAMEPORT is still open-coded because this also has an extra
dependency on MODULE. Similarly, an open-coded ifdef in pcm_oss.c and
some sequencer-related stuff are left untouched.
There are uncovered cases whether the card refcount introduced by the
commit a0830dbd isn't properly increased or decreased:
- OSS PCM and mixer success paths
- When lookup function gets NULL
This patch fixes these places.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=50251
Cc: <stable@vger.kernel.org>
For more strict protection for wild disconnections, a refcount is
introduced to the card instance, and let it up/down when an object is
referred via snd_lookup_*() in the open ops.
The free-after-last-close check is also changed to check this refcount
instead of the empty list, too.
Reported-by: Matthieu CASTET <matthieu.castet@parrot.com>
There are left-over codes from the ancient days with the static device
number limitation of 8. Actaully OSS can support up to 16 cards.
These aren't modules, but they do make use of these macros, so
they will need export.h to get that definition. Previously,
they got it via the implicit module.h inclusion.
When a card instance with a higher card number is registered, warning
messages are spewed eventually with stack traces due to the invalid minor
number for OSS device registration. For example, thinkpad-acpi registers
the card number 29 as default, and you'll see always these messages.
This is rather confusing (and worries users), thus better to return
simply the error code.
Kill snd_assert() in sound/core/*, either removed or replaced with
if () with snd_BUG_ON().
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
The recent change for a new sysfs tree with card* object breaks the
/sys/class/sound tree if CONFIG_SYSFS_DEPRECATED is enabled.
The device in each entry doesn't point the correct device object:
/sys/class/sound
|-- pcmC0D0c
| |-- dev
| |-- device -> ../../../class/sound/card0
| |-- pcm_class
| |-- power
| | `-- wakeup
| |-- subsystem -> ../../../class/sound
| `-- uevent
Also, this change breaks some drivers (like sound/arm/*) referring
card->dev directly to obtain the device object for memory handling.
This patch reverts the semantics of card->dev to the former version,
which points to a real device object. The card* object is stored in a
new card->card_dev field, instead. The device parent is chosen either
card->dev or card->card_dev according to CONFIG_SYSFS_DEPRECATED to
keep the tree compatibility.
Also, card* isn't created if CONFIG_SYSFS_DEPRECATED is enabled. The
reason of card* object is a root of all beloing devices, and it makes
little sense if each sound device points to the real device object
directly.
Acked-by: Monty Montgomery <xiphmont@gmail.com>
- Add the linked list to each proc entry to enable a single-shot
disconnection (unregister)
- Deprecate snd_info_unregister(), use snd_info_free_entry()
- Removed NULL checks of snd_info_free_entry()
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Removed zero-initializations of static variables.
A tiny optimization.
Remove unneeded read/write_size fields in proc text ops.
snd_info_set_text_ops() is fixed, too.
Move EXPORT_SYMBOL()s to places adjacent to functions/variables.
Mark the f_ops members of inodes as const, as well as fix the
ripple-through this causes by places that copy this f_ops and then "do
stuff" with it.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Modules: ALSA Core
This patch fixes three off-by-one errors found by the Coverity checker.
Semaphore to mutex conversion.
The conversion was generated via scripts, and the result was validated
automatically via a script as well.
Modules: HWDEP Midlevel,ALSA Core,PCM Midlevel,Timer Midlevel
Optimize the code when compiled without CONFIG_PROC_FS.
Modules: ALSA Core,Memalloc module,ALSA sequencer
With dynamic minor numbers, we can increase the number of sound cards.
This requires that the sequencer client numbers of some kernel drivers
are allocated dynamically, too.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Instead of storing the pointers to the device-specific structures in an
array, put them into the struct snd_minor, and look them up dynamically.
This makes the device type modules independent of the minor number
encoding.
Modules: ALSA Core
Store the snd_minor structure pointers in one array instead of using a
separate list for each card. This simplifies the mapping from device
files to minor struct by removing the need to know about the encoding
of the card number in the minor number.
Instead of a comment string, store the device type in the snd_minor
structure. This makes snd_minor more flexible, and has the nice side
effect that we don't need anymore to create a separate snd_minor
template for registering a device but can pass the file_operations
directly to snd_register_device().
Modules: ALSA Core
Remove xxx_t typedefs from the core OSS-emulation codes.
Add register_sound_special_device() function to allow assignment of
device pointer to a specific OSS device for HAL.
infrastructure for it.
Let it rip!
