path: root/sound/core
2010-05-25ALSA: pcm: fix delta calculation at boundary wraparoundClemens Ladisch
In the cleanup of the hw_ptr update functions in 2.6.33, the calculation of the delta value was changed to use the modulo operator to protect against a negative difference due to the pointer wrapping around at the boundary. However, the ptr variables are unsigned, so a negative difference would result in the two complement's value which has no relation to the actual difference relative to the boundary; the result is typically some value near LONG_MAX-boundary. Furthermore, even if the modulo operation would be done with signed types, the result of a negative dividend could be negative. The invalid delta value is then caught by the following checks, but this means that the pointer update is ignored. To fix this, use a range check as in the other pointer calculations. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-21ALSA: pcm: fix the fix of the runtime->boundary calculationClemens Ladisch
Commit 7910b4a1db63fefc3d291853d33c34c5b6352e8e in 2.6.34 changed the runtime->boundary calculation to make this value a multiple of both the buffer_size and the period_size, because the latter is assumed by the runtime->hw_ptr_interrupt calculation. However, due to the lack of a ioctl that could read the software parameters before they are set, the kernel requires that alsa-lib calculates the boundary value, too. The changed algorithm leads to a different boundary value used by alsa-lib, which makes, e.g., mplayer fail to play a 44.1 kHz file because the silence_size parameter is now invalid; bug report: <https://bugtrack.alsa-project.org/alsa-bug/view.php?id=5015>. This patch reverts the change to the boundary calculation, and instead fixes the hw_ptr_interrupt calculation to be period-aligned regardless of the boundary value. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (250 commits) ALSA: hda: Storage class should be before const qualifier ASoC: tpa6130a2: Remove CPVSS and HPVdd supplies ASoC: tpa6130a2: Define output pins with SND_SOC_DAPM_OUTPUT ASoC: sdp4430 - add sdp4430 pcm ops to DAI. ASoC: TWL6040: Enable earphone path in codec ASoC: SDP4430: Add support for Earphone speaker ASoC: SDP4430: Add sdp4430 machine driver ASoC: tlv320dac33: Avoid powering off while in BIAS_OFF ASoC: tlv320dac33: Use dev_dbg in dac33_hard_power function ALSA: sound/pci/asihpi: Use kzalloc ALSA: hdmi - dont fail on extra nodes ALSA: intelhdmi - add id for the CougarPoint chipset ALSA: intelhdmi - user friendly codec name ALSA: intelhdmi - add dependency on SND_DYNAMIC_MINORS ALSA: asihpi: incorrect range check ALSA: asihpi: testing the wrong variable ALSA: es1688: add pedantic range checks ARM: McBSP: Add support for omap4 in McBSP driver ARM: McBSP: Fix request for irq in OMAP4 OMAP: McBSP: Add 32-bit mode support ...
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: PM QOS update fix Freezer / cgroup freezer: Update stale locking comments PM / platform_bus: Allow runtime PM by default i2c: Fix bus-level power management callbacks PM QOS update PM / Hibernate: Fix block_io.c printk warning PM / Hibernate: Group swap ops PM / Hibernate: Move the first_sector out of swsusp_write PM / Hibernate: Separate block_io PM / Hibernate: Snapshot cleanup FS / libfs: Implement simple_write_to_buffer PM / Hibernate: document open(/dev/snapshot) side effects PM / Runtime: Add sysfs debug files PM: Improve device power management document PM: Update device power management document PM: Allow runtime_suspend methods to call pm_schedule_suspend() PM: pm_wakeup - switch to using bool
2010-05-20Merge branch 'topic/jack' into for-linusTakashi Iwai
2010-05-20Merge branch 'topic/nomm' into for-linusTakashi Iwai
2010-05-20Merge branch 'topic/core-cleanup' into for-linusTakashi Iwai
2010-05-12ALSA: pcm - Use pgprot_noncached() for MIPS non-coherent archsTakashi Iwai
MIPS non-coherent archs need the noncached pgprot in mmap of PCM buffers. But, since the coherency needs to be checked dynamically via plat_device_is_coherent(), we need an ugly check dependent on MIPS in ALSA core code. This should be cleaned up in MIPS arch side (e.g. creating dma_mmap_coherent()) in near future. Tested-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-10PM QOS updateMark Gross
This patch changes the string based list management to a handle base implementation to help with the hot path use of pm-qos, it also renames much of the API to use "request" as opposed to "requirement" that was used in the initial implementation. I did this because request more accurately represents what it actually does. Also, I added a string based ABI for users wanting to use a string interface. So if the user writes 0xDDDDDDDD formatted hex it will be accepted by the interface. (someone asked me for it and I don't think it hurts anything.) This patch updates some documentation input I got from Randy. Signed-off-by: markgross <mgross@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-05ALSA: take tu->qlock with irqs disabledDan Carpenter
We should disable irqs when we take the tu->qlock because it is used in the irq handler. The only place that doesn't is snd_timer_user_ccallback(). Most of the time snd_timer_user_ccallback() is called with interrupts disabled but the the first ti->ccallback() call in snd_timer_notify1() has interrupts enabled. This was caught by lockdep which generates the following message: > ================================= > [ INFO: inconsistent lock state ] > 2.6.34-rc5 #5 > --------------------------------- > inconsistent {HARDIRQ-ON-W} -> {IN-HARDIRQ-W} usage. > dolphin/4003 [HC1[1]:SC0[0]:HE0:SE1] takes: > (&(&tu->qlock)->rlock){?.+...}, at: [<f84ec472>] snd_timer_user_tinterrupt+0x28/0x132 [snd_timer] > {HARDIRQ-ON-W} state was registered at: > [<c1048de9>] __lock_acquire+0x654/0x1482 > [<c1049c73>] lock_acquire+0x5c/0x73 > [<c125ac3e>] _raw_spin_lock+0x25/0x34 > [<f84ec370>] snd_timer_user_ccallback+0x55/0x95 [snd_timer] > [<f84ecc4b>] snd_timer_notify1+0x53/0xca [snd_timer] Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: core - Define llseek fopsTakashi Iwai
Set no_llseek to llseek file ops of each sound component (but for hwdep). This avoids the implicit BKL invocation via generic_file_llseek() used as default when fops.llseek is NULL. Also call nonseekable_open() at each open ops to ensure the file flags have no seek bit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Implement common llseek for binary modeTakashi Iwai
The llseek implementation is identical for existing driver implementations, so let's merge to the common layer. The same code for the text proc file can be used even for the binary proc file. The driver can provide its own llseek method if needed. Then the common code will be skipped. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13ALSA: info - Check file position validity in common layerTakashi Iwai
Check the validity of the file position in the common info layer before calling read or write callbacks in assumption that entry->size is set up properly to indicate the max file size. Removed the redundant checks from the callbacks as well. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-13Merge branch 'topic/bkl' into topic/core-cleanupTakashi Iwai
2010-04-09ALSA: Remove BKL from open multiplexerTakashi Iwai
Use a local mutex instead of BKL. This should suffice since each device type has also its open_mutex. Also, a bit of clean-up of the legacy device auto-loading code. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-07ALSA: info - Remove BKLTakashi Iwai
Use the fine-grained mutex for the assigned info object, instead. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-07ALSA: pcm - Remove BKL from async callbackTakashi Iwai
It's simply calling fasync_helper(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-26ALSA: pcm_lib - fix xrun functionalityJarkko Nikula
The commit 4d96eb255c53ab5e39b37fd4d484ea3dc39ab456 broke the interrupt time xrun functionality (stream stop etc.) if the CONFIG_SND_PCM_XRUN_DEBUG is not set. This is because the xrun() is null defined without it. Fix this by letting the function xrun() to be always defined as it was before. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-17ALSA: Add support for key reporting via the jack interfaceMark Brown
Some devices provide support for detection of a small number of buttons on their jacks. One common implementation provides a single button, implemented by shorting the microphone to ground and detected along with microphone presence detection by detecting varying current draws on the microphone bias signal. Provide support for up to three buttons via the jack interface. These default to reporting BTN_n but an API is provided to allow these to be remapped to other keys by the machine driver where it knows what the keys are. More keys can be added with ease if required. This is only intended to support simple accessory button designs. If the interface is limiting then either creating a child device for the accessory or accessing the input device in the jack directly is recommended. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-17ALSA: Rename jack switch table in preparation for button supportMark Brown
Avoids confusion when we have button support. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-10ALSA: provide a more useful get_unmapped_area handler for pcmDaniel Glöckner
Shared memory mappings on nommu machines require a get_unmapped_area file operation that suggests an address for the mapping. The current implementation returns 0 and thus forces the driver to implement an mmap handler that fixes up the start and end address of the vma. This patch returns the address of the dma buffer, so it should work out of the box for all drivers that use the snd_pcm_runtime->dma_area pointer. Addresses for mapping the status and control pages are returned as well, but to make those work the conditional compilation of snd_pcm_mmap_{status,control} would need to be revised. URL: http://thread.gmane.org/gmane.linux.alsa.devel/61230 Signed-off-by: Daniel Glöckner <dg@emlix.com> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-03ALSA: timer - pass real event in snd_timer_notify1() to instance callbackJaroslav Kysela
Do not use hardcoded SNDRV_TIMER_EVENT_START value. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-17Merge branch 'fix/misc' into topic/miscTakashi Iwai
Conflicts: sound/pci/hda/patch_realtek.c
2010-02-17Merge remote branch 'alsa/fixes' into fix/miscTakashi Iwai
2010-02-16ALSA: pcm core - fix fifo_size channels interval checkJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz> Cc: <stable@kernel.org>
2010-02-02ALSA: trivial: sound seq ioctl dbg: print hexadecimal value padded with 0sThadeu Lima de Souza Cascardo
Instead of padding with blanks and printing "number=0x a", print "number=0x0a". Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-01Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-02-01sound: control: fix minimum TLV lengthClemens Ladisch
Allow TLV blocks that do not have any values; the smallest possible TLV is an empty container or one where the information is only in the tag. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-02-01sound: control: actually allow TLV command accessClemens Ladisch
Creating a control with TLV_COMMAND access was not possible because snd_ctl_new1() forgot to include it in the mask of allowable access bits. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-27ALSA: pcm_native - fix runtime->boundary calculationJaroslav Kysela
The code in pcm_lib updating runtime->hw_ptr_interrupt expects that runtime->boundary is divisible with runtime->period_size. Thanks are going to Clemens Ladisch for the notice. Fix the runtime->boundary calculation using buffer_size * period_size as base and find a least common multiple for 32bit platforms when the expression might overflow. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-26Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-01-26ALSA: pcm_lib - return back hw_ptr_interruptJaroslav Kysela
Clemens Ladisch noted for hw_ptr_removal in "cleanup & merge hw_ptr update functions" commit: "It is possible for the status/delay ioctls to be called when the sound card's pointer register alreay shows a position at the beginning of the new period, but immediately before the interrupt is actually executed. (This happens regularly on a SMP machine with mplayer.) When that happens, the code thinks that the position must be at least one period ahead of the current position and drops an entire buffer of data." Return back the hw_ptr_interrupt variable. The last interrupt pointer is always computed from the latest hw_ptr instead of tracking it separately (in this case all hw_ptr checks and modifications might influence also hw_ptr_interrupt and it is difficult to keep it consistent). Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-21Merge branch 'topic/noncached-mmap' into topic/miscTakashi Iwai
2010-01-21Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-01-21ALSA: pcm_core: Fix wake_up() optimizationJaroslav Kysela
This change fixes the "ALSA: pcm_lib - optimize wake_up() calls for PCM I/O" commit. New sleeping queue is introduced to separate user space and kernel space wake_ups. runtime->nowake is renamed to twake (transfer wake). Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-18Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-01-18sound: seq_timer: simplify snd_seq_timer_set_tick_resolution() parametersClemens Ladisch
As snd_seq_timer_set_tick_resolution() is always called with the same three fields of struct snd_seq_timer, it suffices to give that as the only parameter. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-18ALSA: pcm - Call pgprot_noncached() for vmalloc'ed buffersTakashi Iwai
pgprot_noncached() can be set for vmalloc'ed buffers safely, and we'd need non-cached behavior more or less, even for the intermediate ring- buffers. Now snd_pcm_lib_mmap_vmalloc() is added as the common PCM mmap callback that is coupled with snd_pcm_lib_alloc_vmalloc_buffer() & co. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-18ALSA: pcm - Remove unneeded ifdef pgprot_noncachedTakashi Iwai
2010-01-18ALSA: Remove warning message for invalid OSS minor rangesTakashi Iwai
When a card instance with a higher card number is registered, warning messages are spewed eventually with stack traces due to the invalid minor number for OSS device registration. For example, thinkpad-acpi registers the card number 29 as default, and you'll see always these messages. This is rather confusing (and worries users), thus better to return simply the error code. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-14ALSA: use subsys_initcall for sound core instead of module_initThadeu Lima de Souza Cascardo
This is needed for built-in drivers which are built before the sound directory, like thinkpad_acpi. Otherwise, registering a card fails. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-14ALSA: Add snd_pci_quirk_lookup_id()Takashi Iwai
Added a new function to look up a quirk entry with the given PCI SSID instead of a pci device pointer. This can be used when the searched ID is overridden for debugging or such a purpose. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-01-13Merge branch 'devel' of git.alsa-project.org:alsa-kernel into topic/miscTakashi Iwai
2010-01-13ALSA: pcm_lib - fix wrong delta print for jiffies checkJaroslav Kysela
The previous jiffies delta was 0 in all cases. Use hw_ptr variable to store and print original value. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-12Merge commit alsa/devel into topic/miscTakashi Iwai
Conflicts: include/sound/version.h
2010-01-08Merge branch 'topic/hda' of ↵Jaroslav Kysela
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 into devel
2010-01-08ALSA: pcm_lib: fix "something must be really wrong" conditionJaroslav Kysela
When runtime->periods == 1 or when pointer crosses end of ring buffer, the delta might be greater than buffer_size. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-07ALSA: pcm_lib - optimize wake_up() calls for PCM I/OJaroslav Kysela
As noted by pl bossart <bossart.nospam@gmail.com>, the PCM I/O routines (snd_pcm_lib_write1, snd_pcm_lib_read1) should block wake_up() calls until all samples are not processed. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-07ALSA: pcm_lib - cleanup & merge hw_ptr update functionsJaroslav Kysela
Do general cleanup in snd_pcm_update_hw_ptr*() routines and merge them. The main change is hw_ptr_interrupt variable removal to simplify code logic. This variable can be computed directly from hw_ptr. Ensure that updated hw_ptr is not lower than previous one (it was possible with old code in some obscure situations when interrupt was delayed or the lowlevel driver returns wrong ring buffer position value). Signed-off-by: Jaroslav Kysela <perex@perex.cz>
