path: root/sound/core
2006-06-22[ALSA] Clean up EXPORT_SYMBOL()s in snd-seq moduleTakashi Iwai
Move EXPORT_SYMBOL()s to places adjacent to functions/variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Clean up EXPORT_SYMBOL()s in snd moduleTakashi Iwai
2006-06-22[ALSA] Change seq_midi.c so client name is card, rather than port, specificAlan Horstmann
Change snd_seq_midisynth_register_port() in seq_midi.c so that if a new client is created, the client name string is based on card->shortname not (port-specific) info->name. Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk> Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-04-27[ALSA] Fix Oops at rmmod with CONFIG_SND_VERBOSE_PROCFS=nTakashi Iwai
Fixed Oops at rmmod with CONFIG_SND_VERBOSE_PROCFS=n. Add ifdef to struct fields for optimization and better compile checks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] PCM core - introduce CONFIG_SND_PCM_XRUN_DEBUGJaroslav Kysela
This patch makes the XRUN (overrun/underrun) notification code optional. Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-04-27[ALSA] Handle the error correctly in SNDCTL_DSP_SETFMT ioctlSteven Finney
Handle the error returned from snd_pcm_oss_get_formats() correctly in SNDCTL_DSP_SETFMT ioctl handler of PCM OSS emulation. Signed-off-by: Steven Finney <sfinney@healthhero.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] sound/core/pcm.c: make snd_pcm_format_name() staticAdrian Bunk
Modules: PCM Midlevel This patch makes the needlessly global snd_pcm_format_name() static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] Fix Oops of PCM OSS emulationTakashi Iwai
Modules: PCM Midlevel,ALSA<-OSS emulation Fix Oops of PCM OSS emulation occuring when multiple playback is used. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] pcm_oss: fix snd_pcm_oss_release() oopsOGAWA Hirofumi
Modules: ALSA<-OSS emulation Fix Oops due to a typo in snd_pcm_oss.c. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] Kconfig SND_SEQUENCER_OSS help text fixFrederik Deweerdt
Fix misleading help text for SND_SEQUENCER_OSS config option. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] Fix / clean up PCM-OSS setup hooksTakashi Iwai
- Fix possible race of referring the setup hook from the running PCM - Fix memory leak in an error path of proc write - Clean up the setup hook parser Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] Clean up PCM codes (take 2)Takashi Iwai
- Clean up initialization and destruction of substream instance Now snd_pcm_open_substream() alone does most initialization jobs. Add pcm_release callback for cleaning up at snd_pcm_release_substream() - Tidy up PCM oss code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] Tiny clean up of PCM codesTakashi Iwai
- Make snd_pcm_prepare() static - Clean up snd_pcm_kernel_*_ioctl() functions, reduce exports Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] Cleanup unused argument for snd_power_wait()Takashi Iwai
Removed the unused file argument of snd_power_wait(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-28[PATCH] sound: Remove unneeded kmalloc() return value castsJesper Juhl
Get rid of unnessesary casts of kmalloc() return value in sound/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[ALSA] Fix memory leaks in error path of control.cTakashi Iwai
Modules: Control Midlevel Fix memory leaks in error path of control.c (only with CONFIG_SND_DEBUG=y). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] Fix seq_clientmgr dereferences before NULL checkEugene Teo
Modules: ALSA sequencer cptr->pool must be non-NULL there, so just the if (cptr->pool) is superfluous. Thanks Takashi. Signed-off-by: Eugene Teo <eugene.teo@eugeneteo.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] sound/core/: fix 3 off-by-one errorsAdrian Bunk
Modules: ALSA Core This patch fixes three off-by-one errors found by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] make control.c suspend awareGiuliano Pochini
Modules: Control Midlevel This patch prevents user-space apps from accessing the hardware via control interface while the soundcard is suspended. Signed-off-by: Giuliano Pochini <pochini@shiny.it> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] return ENODEV for disconnected devicesClemens Ladisch
Modules: ALSA Core Add dummy functions that return -ENODEV for the struct file_operations of a disconnected device. Without such functions, userspace would get ENOTTY. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] Fix sleep in atomic in virmidi driverTakashi Iwai
Modules: ALSA sequencer Debug: sleeping function called from invalid context at /usr/src/linux/include/linux/rwsem.h:43 in_atomic():1, irqs_disabled():0 [<f999d15e>] snd_seq_deliver_event+0xb4/0x1a8 [snd_seq] [<f999d2be>] snd_seq_kernel_client_dispatch+0x6c/0x7c [snd_seq] [<f93321fc>] snd_virmidi_output_trigger+0xca/0xe5 [snd_seq_virmidi] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] pcm - Move PAUSE ioctl to common ioctl handlerTakashi Iwai
Modules: PCM Midlevel Moved PAUSE ioctl to the common ioctl handler. A capture stream may issue PAUSE, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] Removed unneeded page-reserveTakashi Iwai
Modules: Memalloc module Removed unneeded page-reservation. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] Use dma_alloc_coherent() hack on i386 onlyTakashi Iwai
Modules: Memalloc module Use dma_alloc_coherent() hack on i386 only (as a valid arch). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] Fix mulaw -> linear conversion in OSS PCM emulationTakashi Iwai
Modules: ALSA<-OSS emulation Fixed the missing mulaw -> linear conversion in OSS PCM emulation code. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] snd_pcm_format_name() is no longer exportedJaroslav Kysela
Modules: PCM Midlevel,USB generic driver Because snd_pcm_format_name() function is used only for informational purposes, it is no longer exported from the PCM midlevel to reduce space and dependency. usbaudio module shows only numeric value for format. Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] semaphore -> mutex (core part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] Clean up pcm-oss pluginsTakashi Iwai
Modules: ALSA<-OSS emulation Clean up pcm-oss plugin codes. Removed dead codes, and simplified route/rate plugins. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] Fix a typoTakashi Iwai
Modules: ALSA<-OSS emulation Fixed a typo. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] PCM midlevel & PCM OSS - make procfs & OSS plugin code optionalJaroslav Kysela
Modules: ALSA Core,PCM Midlevel,ALSA<-OSS emulation,USB generic driver 1) The verbose procfs code for the PCM midlevel and usb audio can be removed now (more patches will follow). CONFIG_SND_VERBOSE_PROCFS 2) The PCM OSS plugin system can be also compiled optionaly. CONFIG_SND_PCM_OSS_PLUGINS Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-03-06[PATCH] alsa: fix error paths in snd_ctl_elem_add()Takashi Iwai
Fix bugs in error paths of snd_ctl_elem_add() - NULL reference - double free (already freed in snd_ctl_add()) Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] Fix snd-usb-audio in 32-bit compat environmentJuergen Kreileder
I'm getting oopses with snd-usb-audio in 32-bit compat environments: control_compat.c:get_ctl_type() doesn't initialize 'info', so 'itemlist[uinfo->value.enumerated.item]' in usbmixer.c:mixer_ctl_selector_info() might access random memory (The 'if ((int)uinfo->value.enumerated.item >= cval->max)' doesn't fix all problems because of the unsigned -> signed conversion.) Signed-off-by: Juergen Kreileder <jk@blackdown.de> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Greg KH <greg@kroah.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-22[ALSA] Remove BKL from sound/core/info.cIngo Molnar
Modules: ALSA Core Remove BKL from sound/core/info.c Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-04[ALSA] Revert the nested-device patchTakashi Iwai
Modules: ALSA Core Revert the nested-device patch to keep the compatibility with the current HAL configuration. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] seq: reorganize sequencer client numbersClemens Ladisch
Modules: ALSA sequencer Reduce the maximum possible number of global clients to 16 to make more numbers available for card clients, and allow dynamically allocated card client numbers to share the same range as application client numbers to make sure that all 32 cards can be used at the same time. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] seq: set client name in snd_seq_create_kernel_client()Clemens Ladisch
All users of snd_seq_create_kernel_client() have to set the client name anyway, so we can just pass the name as parameter. This relieves us from having to muck around with a struct snd_seq_client_info in these cases. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] seq: remove struct snd_seq_client_callbackClemens Ladisch
The fields of struct snd_seq_client_callback either aren't used or are always set to the same value, so we can get rid of it altogether. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] seq: remove superfluous fieldsClemens Ladisch
Modules: ALSA sequencer None of the fields of struct snd_seq_kernel_client was actually used, so remove them. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] pcm - Fix wrong assertsTakashi Iwai
Modules: PCM Midlevel Fixed wrong or supreflous snd_assert()'s. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Nest sound devicesClemens Ladisch
Modules: ALSA Core Make the control device parent of all other ALSA devices of a card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] pcm - Make the support of old API selectableTakashi Iwai
Modules: ALSA Core,PCM Midlevel Make the support of old API selectable via config option. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Optimize for config without PROC_FS (seq and oss parts)Takashi Iwai
Modules: ALSA<-OSS emulation,ALSA sequencer,ALSA<-OSS sequencer Optimize the code when compiled without CONFIG_PROC_FS (in seq and oss emulation parts). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Optimize for config without PROC_FSTakashi Iwai
Modules: HWDEP Midlevel,ALSA Core,PCM Midlevel,Timer Midlevel Optimize the code when compiled without CONFIG_PROC_FS. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] sound/: possible cleanupsAdrian Bunk
Modules: RawMidi Midlevel,HDA generic driver This patch contains the following possible cleanups: - pci/hda/hda_proc.c should #include 'hda_local.h' for including the prototype of it's global function snd_hda_codec_proc_new() - core/rawmidi.c: make the needlessly global and EXPORT_SYMBOL'ed function snd_rawmidi_info() static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Fix a missing includeTakashi Iwai
Modules: ALSA Core Fix missing include <linux/device.h> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] rawmidi: adjust runtime->avail when changing output buffer sizeClemens Ladisch
Modules: RawMidi Midlevel When the output buffer size is changed, runtime->avail must be adjusted to the new size; otherwise, draining of a bigger buffer would appear to fail because avail does not reach buffer_size. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] dynamic minors (6/6): increase maximum number of sound cardsClemens Ladisch
Modules: ALSA Core,Memalloc module,ALSA sequencer With dynamic minor numbers, we can increase the number of sound cards. This requires that the sequencer client numbers of some kernel drivers are allocated dynamically, too. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] dynamic minors (5/6): reduce maximum number of MIDI devices per cardClemens Ladisch
Modules: ALSA sequencer,Generic drivers To allow increasing the maximum number of sound cards, we have to limit the number of sequencer clients per card because client numbers are still allocated statically. Reducing the number of clients to four limits the number of sequencer MIDI ports to 1024 per card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
