path: root/sound/drivers/opl4
2008-08-13ALSA: Kill snd_assert() in other placesTakashi Iwai
Kill snd_assert() in other places, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2006-09-23[ALSA] opl4: Use SEEK_{SET,CUR,END} instead of hardcoded valuesJosef 'Jeff' Sipek
opl4: Use SEEK_{SET,CUR,END} instead of hardcoded values Signed-off-by: Josef 'Jeff' Sipek <jeffpc@josefsipek.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix disconnection of proc interfaceTakashi Iwai
- Add the linked list to each proc entry to enable a single-shot disconnection (unregister) - Deprecate snd_info_unregister(), use snd_info_free_entry() - Removed NULL checks of snd_info_free_entry() Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] add more sequencer port type information bitsClemens Ladisch
Add four new information flags SNDRV_SEQ_PORT_TYPE_HARDWARE, _SOFTWARE, _SYNTHESIZER, _PORT for sequencer ports. This makes it easier for apps like Rosegarden to make policy decisions based on the port type. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] opl4 - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
Move EXPORT_SYMBOL() to adjacent to each exported function/variable. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] semaphore -> mutex (driver part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] seq: set client name in snd_seq_create_kernel_client()Clemens Ladisch
All users of snd_seq_create_kernel_client() have to set the client name anyway, so we can just pass the name as parameter. This relieves us from having to muck around with a struct snd_seq_client_info in these cases. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] seq: remove struct snd_seq_client_callbackClemens Ladisch
The fields of struct snd_seq_client_callback either aren't used or are always set to the same value, so we can get rid of it altogether. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Remove xxx_t typedefs: OPL4Takashi Iwai
Modules: OPL4 Remove xxx_t typedefs from the OPL4 driver Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - othersTakashi Iwai
Documentation,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,OPL3 OPL4,Digigram VX core,I2C cs8427,I2C lib core,I2C tea6330t,L3 drivers AK4114 receiver,AK4117 receiver,PDAudioCF driver,PPC PMAC driver SPARC AMD7930 driver,SPARC cs4231 driver,Synth,Common EMU synth USB generic driver,USB USX2Y Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
