path: root/sound/drivers/pcsp/pcsp.h
2010-03-02i8253: Convert i8253_lock to raw_spinlockThomas Gleixner
i8253_lock needs to be a real spinlock in preempt-rt, i.e. it can not be converted to a sleeping lock. Convert it to raw_spinlock and fix up all users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> LKML-Reference: <20100217163751.030764372@linutronix.de>
2009-11-01ALSA: snd-pcsp: add nopcm modeStas Sergeev
Currently, if the high-res timers are unavailable, snd-pcsp does not initialize. People who choose it over pcspkr, loose their console beeps in that case and get annoyed. With this patch, the console beeps remain regardless of the high-res timers. Additionally, the "nopcm" modparam is added to forcibly disable the PCM capabilities of the driver. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-16time: move PIT_TICK_RATE to linux/timex.hArnd Bergmann
PIT_TICK_RATE is currently defined in four architectures, but in three different places. While linux/timex.h is not the perfect place for it, it is still a reasonable replacement for those drivers that traditionally use asm/timex.h to get CLOCK_TICK_RATE and expect it to be the PIT frequency. Note that for Alpha, the actual value changed from 1193182UL to 1193180UL. This is unlikely to make a difference, and probably can only improve accuracy. There was a discussion on the correct value of CLOCK_TICK_RATE a few years ago, after which every existing instance was getting changed to 1193182. According to the specification, it should be 1193181.818181... Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Len Brown <lenb@kernel.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-26ALSA: pcsp - Fix starting the stream with HRTIMER_CB_IRQSAFE_UNLOCKTakashi Iwai
With the callback mode HRTIMER_CB_IRQSAFE_UNLOCK, the start of the stream with zero delay doesn't work. Since IRQSAFE mode is removed, we have to change the pcsp start-up code. This patch splits the callback function to two parts, the triggering of the port and the calculation of the expire time, and the update of the ALSA PCM core. The first part is called both from the trigger-start and the hrtimer callback while the latter is handled only in the hrtimer callback. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-20ALSA: pcsp - Fix locking messes in snd-pcspTakashi Iwai
snd-pcsp driver takes chip->substream_lock together with PCM substream lock. These are even mixed up with hrtimer's lock, resulting in messy lock depencies. Right now, snd-pcsp driver resolves the deadlock by using HRTIMER_CB_SOFTIRQ. However, this isn't nice for a really fast path like bit-flipping. This patch introduces a tasklet for PCM period handling so that the hrtimer callback can be handled fast. This also reduce the use of chip->substream_lock to avoid deadlocks. It's still used in pointer callback, but even this could be removed with a proper barrier. Another good solution is to introduce async trigger callback. But, this will involve with a major rewrite of the PCM core code, so I take first this easy fix. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-25[ALSA] snd-pcsp - fix pcsp_treble_info() to honour an item numberStas Sergeev
This solves the problem with mixers wrongly displaying the PWM freq. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Add PC-speaker sound driverStas Sergeev
Added PC-speaker sound driver (snd-pcsp). Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
