path: root/sound/drivers/pcsp/pcsp_mixer.c
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-01ALSA: snd-pcsp: add nopcm modeStas Sergeev
Currently, if the high-res timers are unavailable, snd-pcsp does not initialize. People who choose it over pcspkr, loose their console beeps in that case and get annoyed. With this patch, the console beeps remain regardless of the high-res timers. Additionally, the "nopcm" modparam is added to forcibly disable the PCM capabilities of the driver. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-30ALSA: pcsp - Fix nforce workaroundStas Sergeev
The attached patch fixes the problems introduced in this commit: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=eea0579fc85e64e9f05361d5aacf496fe7a151aa - Fix nForce workaround by honouring the pointer_update var - Revert "ns" to u64, as per the hrtimer API - Revert to the zero-delay timer startup, since I can't reproduce any problem with it (please, give me the hint!) Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-20ALSA: pcsp - fix printk format warning againTakashi Iwai
The commit 5a641bcd6398841cc4606b0a732d41a09256fd94 changed the printk format to '%lu', but the value passed seems to be dependent on the architecture. On x86-64, I got a new warning now because an int value is passed actaully. As a workaround, just cast the value always to unsigned long. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-14ALSA: pcsp: fix printk format warningRandy Dunlap
Fix printk format warning: sound/drivers/pcsp/pcsp_mixer.c:54: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-25[ALSA] snd-pcsp - fix pcsp_treble_info() to honour an item numberStas Sergeev
This solves the problem with mixers wrongly displaying the PWM freq. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Add PC-speaker sound driverStas Sergeev
Added PC-speaker sound driver (snd-pcsp). Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
