CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
To avoid confusion in control names for the standard analog PC Beep generator
using a small Internal PC Speaker, rename all related "PC Speaker" and "PC
Beep" controls to "Beep" only. This name is more universal and can be also
used on more platforms without confusion.
Introduce also "Internal Speaker" in ControlNames.txt for systems with
full-featured build-in internal speaker.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Currently, if the high-res timers are unavailable, snd-pcsp does not
initialize. People who choose it over pcspkr, loose their console beeps
in that case and get annoyed.
With this patch, the console beeps remain regardless of the high-res
timers. Additionally, the "nopcm" modparam is added to forcibly
disable the PCM capabilities of the driver.
Signed-off-by: Stas Sergeev <stsp@aknet.ru>
The attached patch fixes the problems introduced in this commit:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=eea0579fc85e64e9f05361d5aacf496fe7a151aa
- Fix nForce workaround by honouring the pointer_update var
- Revert "ns" to u64, as per the hrtimer API
- Revert to the zero-delay timer startup, since I can't reproduce any
problem with it (please, give me the hint!)
The commit 5a641bcd6398841cc4606b0a732d41a09256fd94 changed the
printk format to '%lu', but the value passed seems to be dependent
on the architecture. On x86-64, I got a new warning now because an
int value is passed actaully.
As a workaround, just cast the value always to unsigned long.
Fix printk format warning:
sound/drivers/pcsp/pcsp_mixer.c:54: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int'
This solves the problem with mixers wrongly displaying the PWM freq.
Added PC-speaker sound driver (snd-pcsp).
