path: root/sound/drivers/portman2x4.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] drivers - Add missing snd_card_set_dev()Takashi Iwai
Added the missing call of snd_card_set_dev() in drivers/* Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-20[ALSA] portman2x4 - Fix probe errorTakashi Iwai
Reported by Ingo Molnar, when booting an allyesconfig bzImage kernel the bootup hangs in the portman2x4 driver (on a box that does not have this hardware), at: Pid: 1, comm: swapper EIP: 0060:[<c02f763c>] CPU: 0 EIP is at parport_pc_read_status+0x4/0x8 EFLAGS: 00000202 Not tainted (2.6.23-rc9 #904) EAX: f7e57a7f EBX: 00000010 ECX: c2b808c0 EDX: 00000379 ESI: f7cb8230 EDI: 00000010 EBP: f7cb8230 DS: 007b ES: 007b FS: 0000 CR0: 8005003b CR2: fff9c000 CR3: 007ec000 CR4: 00000690 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 [<c04613de>] portman_flush_input+0xde/0x12c [<c0461a24>] snd_portman_probe+0x368/0x484 [<c02fbb8c>] __device_attach+0x0/0x8 [<c02fce68>] platform_drv_probe+0xc/0x10 [<c02fba6c>] driver_probe_device+0x74/0x194 [<c0587174>] klist_next+0x38/0x70 [<c02fbb8c>] __device_attach+0x0/0x8 [<c02faea1>] bus_for_each_drv+0x35/0x68 [<c02fbc22>] device_attach+0x72/0x78 the reason is due to an inconsistent error return code of 1 or 2, while snd_portman_probe only realizes negative error codes. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[PARPORT] Remove unused 'irq' argument from parport irq functionsJeff Garzik
None of the drivers with a struct pardevice's ->irq_func() hook ever used the 'irq' argument passed to it, so remove it. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-07-20[ALSA] portman2x4 section mismatchRandy Dunlap
FIx section mismatch when CONFIG_HOTPLUG=n: WARNING: sound/built-in.o(.exit.text+0x271): Section mismatch: reference to .init.text:snd_p ortman_unregister_all (between 'snd_portman_module_exit' and 'alsa_mpu401_uart_exit') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] sound: fix incorrect use of platform_device_register()Akinobu Mita
The platform_device allocated by platform_device_alloc() should be added to the device hierarchy by platform_device_add() instead of platform_device_register(). Otherwise it will hit WARN_ON() in platform_device_register(). by illegal refcount. This patch fixes such incorrect usages in portman2x4 and mts64 drivers. Also it removes unnecessary trailing whitespaces. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-14[ALSA] Fix a typo in __dev* changes in portman2x4.cTakashi Iwai
Fix a typo in the last __dev* changes in portman2x4.c. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-14[ALSA] Fix __devinit and __devexit issues with sound driversPrarit Bhargava
Fix __devinit and __devexit issues with sound drivers. Resolves MODPOST warnings similar to: WARNING: sound/drivers/snd-dummy.o - Section mismatch: reference to .init.text:snd_dummy_probe from .data.rel.local between 'snd_dummy_driver' (at offset 0x0) and 'snd_dummy_controls' WARNING: sound/drivers/snd-mtpav.o - Section mismatch: reference to .init.text:snd_mtpav_probe from .data.rel.local between 'snd_mtpav_driver' (at offset 0x0) and 'snd_mtpav_input' WARNING: sound/drivers/snd-virmidi.o - Section mismatch: reference to .init.text:snd_virmidi_probe from .data.rel.local after 'snd_virmidi_driver' (at offset 0x0) Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add snd-portman2x4 driver for Midiman Portman 2x4 MIDI deviceMatthias Koenig
snd-portman2x4 driver supports Midiman Portman 2x4 parallel port MIDI device. Signed-off-by: Matthias Koenig <mkoenig@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
