path: root/sound/drivers/virmidi.c
2010-09-07sound: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-24Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-02-05ALSA: Add missing KERN_* prefix to printk in sound/driversTakashi Iwai
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-07-20[ALSA] fix section mismatchRandy Dunlap
Fix shared init/exit function attributes: WARNING: sound/built-in.o(.exit.text+0x4a1): Section mismatch: reference to .init.text: (between 'alsa_card_virmidi_exit' and 'alsa_card_serial_exit') WARNING: sound/built-in.o(.exit.text+0x4c1): Section mismatch: reference to .init.text: (between 'alsa_card_serial_exit' and 'ac97_bus_exit') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-14Merge branch 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: [ALSA] version 1.0.14rc2 [ALSA] Fix a typo in __dev* changes in portman2x4.c [ALSA] Change AT91 PDC register defines for 2.6.20 kernel [ALSA] SoC codecs - fix Kconfig - depends -> depends on [ALSA] Fix __devinit and __devexit issues with sound drivers [ALSA] hda-codec - Patch for enabling LFE on more Dell laptops [ALSA] hda-codec - More fixes for Conexant HD Audio support [ALSA] usb-audio: add PCR-A PCM support [ALSA] emu10k1: fix typo [ALSA] usbaudio - remove urb->bandwidth reference [ALSA] ac97 - Fix silent output problem with Cx20551 codec [ALSA] hda-codec - Fix Oops with probing sigmatel codec chips
2007-02-14[ALSA] Fix __devinit and __devexit issues with sound driversPrarit Bhargava
Fix __devinit and __devexit issues with sound drivers. Resolves MODPOST warnings similar to: WARNING: sound/drivers/snd-dummy.o - Section mismatch: reference to .init.text:snd_dummy_probe from .data.rel.local between 'snd_dummy_driver' (at offset 0x0) and 'snd_dummy_controls' WARNING: sound/drivers/snd-mtpav.o - Section mismatch: reference to .init.text:snd_mtpav_probe from .data.rel.local between 'snd_mtpav_driver' (at offset 0x0) and 'snd_mtpav_input' WARNING: sound/drivers/snd-virmidi.o - Section mismatch: reference to .init.text:snd_virmidi_probe from .data.rel.local after 'snd_virmidi_driver' (at offset 0x0) Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] virmidi: revert erroneous removal of zero initializationClemens Ladisch
The last patch that tried to remove zero initializations of static variables accidentally removed a not-quite-zero initialization too. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] Remove zero-initialization of static variablesTakashi Iwai
Removed zero-initializations of static variables. A tiny optimization. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
This second one unregisters the platform device again when the probe is unsuccesful for sound/drivers, sound/arm/sa11xx-uda1341.c and sound/ppc/powermac.c. This gets them all. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] continue on IS_ERR from platform device registrationRene Herman
I previously only concerned myself with sound/isa. When I now checked for more platform_device_register_simple() usages in ALSA I found a couple more drivers that needed the same patches as already submitted for all the ISA drivers. This first one is the continue-on-iserr patch for sound/drivers. This gets them all. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] Fix check of enable module optionTakashi Iwai
Fix the check of enable module option in probe of platform_device drivers. It shouldn't break the loop but just ignore if enable[i] is false. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] unregister platform devicesClemens Ladisch
Call platform_device_unregister() for all platform devices that we've registered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] dynamic minors (5/6): reduce maximum number of MIDI devices per cardClemens Ladisch
Modules: ALSA sequencer,Generic drivers To allow increasing the maximum number of sound cards, we have to limit the number of sequencer clients per card because client numbers are still allocated statically. Reducing the number of clients to four limits the number of sequencer MIDI ports to 1024 per card. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] virmidi - Use platform_deviceTakashi Iwai
Modules: Generic drivers Rewrite the probe/remove code using platform_device. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: Generic driversTakashi Iwai
Modules: Generic drivers Remove xxx_t typedefs from the generic drivers (dummy, mtpav, serial-u16550 and virmidi). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Add snd_card_set_generic_dev() callTakashi Iwai
ARM,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,MIPS MIPS AU1x00 driver,PPC,PPC PowerMac driver,SPARC,SPARC AMD7930 driver SPARC cs4231 driver,SPARC DBRI driver - Added snd_card_set_generic_dev() call. - Added SND_GENERIC_DRIVER to Kconfig. - Clean up the error path in probe if necessary. Signed-off-by: Takashi Iwai <tiwai@suse.de>
