In a special case, some old samples are left in the capture ring buffer.
Fix it.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Obvious copy-and-paste error.
The snd-aloop module allows redirecting of the PCM playback in the
kernel back to the user space using the standard ALSA PCM capture API.
The module also allows time synchronization with another timing source
and notifications of playback stream parameter changes.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits)
ALSA: hda - Add pin-fix for HP dc5750
ALSA: als4000: Fix potentially invalid DMA mode setup
ALSA: als4000: enable burst mode
ALSA: hda - Fix initial capsrc selection in patch_alc269()
ASoC: TWL4030: Capture route runtime DAPM ordering fix
ALSA: hda - Add PC-beep whitelist for an Intel board
ALSA: hda - More relax for pending period handling
ALSA: hda - Define AC_FMT_* constants
ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs
ALSA: hda - Add support for HDMI HBR passthrough
ALSA: hda - Set Stream Type in Stream Format according to AES0
ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed
ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF
ASoC: wm9081: fix resource reclaim in wm9081_register error path
ASoC: wm8978: fix a memory leak if a wm8978_register fail
ASoC: wm8974: fix a memory leak if another WM8974 is registered
ASoC: wm8961: fix resource reclaim in wm8961_register error path
ASoC: wm8955: fix resource reclaim in wm8955_register error path
ASoC: wm8940: fix a memory leak if wm8940_register return error
ASoC: wm8904: fix resource reclaim in wm8904_register error path
The description has been expanded to explain the time-out
value provided by the power_save module parameter.
Signed-off-by: Michael Witten <mfwitten@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (250 commits)
ALSA: hda: Storage class should be before const qualifier
ASoC: tpa6130a2: Remove CPVSS and HPVdd supplies
ASoC: tpa6130a2: Define output pins with SND_SOC_DAPM_OUTPUT
ASoC: sdp4430 - add sdp4430 pcm ops to DAI.
ASoC: TWL6040: Enable earphone path in codec
ASoC: SDP4430: Add support for Earphone speaker
ASoC: SDP4430: Add sdp4430 machine driver
ASoC: tlv320dac33: Avoid powering off while in BIAS_OFF
ASoC: tlv320dac33: Use dev_dbg in dac33_hard_power function
ALSA: sound/pci/asihpi: Use kzalloc
ALSA: hdmi - dont fail on extra nodes
ALSA: intelhdmi - add id for the CougarPoint chipset
ALSA: intelhdmi - user friendly codec name
ALSA: intelhdmi - add dependency on SND_DYNAMIC_MINORS
ALSA: asihpi: incorrect range check
ALSA: asihpi: testing the wrong variable
ALSA: es1688: add pedantic range checks
ARM: McBSP: Add support for omap4 in McBSP driver
ARM: McBSP: Fix request for irq in OMAP4
OMAP: McBSP: Add 32-bit mode support
The commit 24e4a1211f691fc671de44685430dbad757d8487
ALSA: info - Use standard types for info callbacks
introduced a wrong type to snd_opl4_mem_proc_write() for pos argument.
Fixed now.
The llseek implementation is identical for existing driver implementations,
so let's merge to the common layer. The same code for the text proc file
can be used even for the binary proc file.
The driver can provide its own llseek method if needed. Then the common
code will be skipped.
Check the validity of the file position in the common info layer before
calling read or write callbacks in assumption that entry->size is set up
properly to indicate the max file size.
Removed the redundant checks from the callbacks as well.
Use loff_t, size_t and ssize_t for arguments of info callbacks
to follow the standard procfs.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
i8253_lock needs to be a real spinlock in preempt-rt, i.e. it can
not be converted to a sleeping lock.
Convert it to raw_spinlock and fix up all users.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Takashi Iwai <tiwai@suse.de>
Cc: Jens Axboe <jens.axboe@oracle.com>
LKML-Reference: <20100217163751.030764372@linutronix.de>
This is a cleanup for the dummy driver. The model kernel module parameter
is introduced to select the soundcard emulation.
pgprot_noncached() can be set for vmalloc'ed buffers safely, and we'd
need non-cached behavior more or less, even for the intermediate ring-
buffers.
Now snd_pcm_lib_mmap_vmalloc() is added as the common PCM mmap callback
that is coupled with snd_pcm_lib_alloc_vmalloc_buffer() & co.
Remove this duplicate of snd_pcm_alloc_vmalloc_buffer and use the
equivalent core functions instead.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
To avoid confusion in control names for the standard analog PC Beep generator
using a small Internal PC Speaker, rename all related "PC Speaker" and "PC
Beep" controls to "Beep" only. This name is more universal and can be also
used on more platforms without confusion.
Introduce also "Internal Speaker" in ControlNames.txt for systems with
full-featured build-in internal speaker.
Now up to 128 substreams are supported.
Reported-by: Adrian Bridgett <adrian@smop.co.uk>
Currently, if the high-res timers are unavailable, snd-pcsp does not
initialize. People who choose it over pcspkr, loose their console beeps
in that case and get annoyed.
With this patch, the console beeps remain regardless of the high-res
timers. Additionally, the "nopcm" modparam is added to forcibly
disable the PCM capabilities of the driver.
Signed-off-by: Stas Sergeev <stsp@aknet.ru>
In pcm.c, if the NULL test on pcm is needed, then the dereference should be
after the NULL test.
In dummy.c and ali5451.c, the context of the calls to
snd_card_dummy_new_mixer and snd_ali_free_voice show that dummy and pvoice,
respectively cannot be NULL.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
@match exists@
expression x, E;
identifier fld;
* x->fld
... when != \(x = E\|&x\)
* x == NULL
// </smpl>
The attached patch fixes the problems introduced in this commit:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=eea0579fc85e64e9f05361d5aacf496fe7a151aa
- Fix nForce workaround by honouring the pointer_update var
- Revert "ns" to u64, as per the hrtimer API
- Revert to the zero-delay timer startup, since I can't reproduce any
problem with it (please, give me the hint!)
Fix following circular locking in the opl3 driver.
[ INFO: possible circular locking dependency detected ]
2.6.32-rc3 #87
swapper/0 is trying to acquire lock:
(&opl3->voice_lock){..-...}, at: [<cca748fe>] snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth]
but task is already holding lock:
(&opl3->sys_timer_lock){..-...}, at: [<cca75169>] snd_opl3_timer_func+0x19/0xc0 [snd_opl3_synth]
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&opl3->sys_timer_lock){..-...}:
[<c02461d5>] validate_chain+0xa25/0x1040
[<c0246aca>] __lock_acquire+0x2da/0xab0
[<c024731a>] lock_acquire+0x7a/0xa0
[<c044c300>] _spin_lock_irqsave+0x40/0x60
[<cca75046>] snd_opl3_note_on+0x686/0x790 [snd_opl3_synth]
[<cca68912>] snd_midi_process_event+0x322/0x590 [snd_seq_midi_emul]
[<cca74245>] snd_opl3_synth_event_input+0x15/0x20 [snd_opl3_synth]
[<cca4dcc0>] snd_seq_deliver_single_event+0x100/0x200 [snd_seq]
[<cca4de07>] snd_seq_deliver_event+0x47/0x1f0 [snd_seq]
[<cca4e50b>] snd_seq_dispatch_event+0x3b/0x140 [snd_seq]
[<cca5008c>] snd_seq_check_queue+0x10c/0x120 [snd_seq]
[<cca5037b>] snd_seq_enqueue_event+0x6b/0xe0 [snd_seq]
[<cca4e0fd>] snd_seq_client_enqueue_event+0xdd/0x100 [snd_seq]
[<cca4eb7a>] snd_seq_write+0xea/0x190 [snd_seq]
[<c02827b6>] vfs_write+0x96/0x160
[<c0282c9d>] sys_write+0x3d/0x70
[<c0202c45>] syscall_call+0x7/0xb
-> #0 (&opl3->voice_lock){..-...}:
[<c02467e6>] validate_chain+0x1036/0x1040
[<cca751f0>] snd_opl3_timer_func+0xa0/0xc0 [snd_opl3_synth]
[<c022ac46>] run_timer_softirq+0x166/0x1e0
[<c02269e8>] __do_softirq+0x78/0x110
[<c0226ac6>] do_softirq+0x46/0x50
[<c0226e26>] irq_exit+0x36/0x40
[<c0204bd2>] do_IRQ+0x42/0xb0
[<c020328e>] common_interrupt+0x2e/0x40
[<c021092f>] apm_cpu_idle+0x10f/0x290
[<c0201b11>] cpu_idle+0x21/0x40
[<c04443cd>] rest_init+0x4d/0x60
[<c055c835>] start_kernel+0x235/0x280
[<c055c066>] i386_start_kernel+0x66/0x70
2 locks held by swapper/0:
#0: (&opl3->tlist){+.-...}, at: [<c022abd0>] run_timer_softirq+0xf0/0x1e0
#1: (&opl3->sys_timer_lock){..-...}, at: [<cca75169>] snd_opl3_timer_func+0x19/0xc0 [snd_opl3_synth]
stack backtrace:
Pid: 0, comm: swapper Not tainted 2.6.32-rc3 #87
Call Trace:
[<c0245188>] print_circular_bug+0xc8/0xd0
[<c0247f14>] ? check_usage_forwards+0x54/0xd0
[<cca748fe>] ? snd_opl3_note_off+0x1e/0xe0 [snd_opl3_synth]
[<c044c307>] ? _spin_lock_irqsave+0x47/0x60
[<c022abd0>] ? run_timer_softirq+0xf0/0x1e0
[<cca75150>] ? snd_opl3_timer_func+0x0/0xc0 [snd_opl3_synth]
[<c044c0fd>] ? _spin_unlock+0x1d/0x20
[<c025915f>] ? handle_level_irq+0xaf/0xe0
[<c024463c>] ? trace_hardirqs_on_caller+0x12c/0x180
[<c0208d88>] ? default_idle+0x38/0x50
[<c055c210>] ? unknown_bootoption+0x0/0x210
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Increase the limit of PCM substreams to 128. The default value is
unchanged; only the max accept value is increased.
Added the debug proc file to see or change the snd_pcm_hardware fields
to emulate. The parameters can be changed by writing to a proc file like:
# echo periods_min 4 > /proc/asound/card1/dummy_pcm
Instead of allocating the real buffers, use a fake buffer and ignore
read/write in the dummy driver so that we can save the resources.
For mmap, a single page (unique to the direction, though) is reused
to all buffers.
When the app requires to read/write the real buffers, pass fake_buffer=0
module option at loading time. This will get back to the old behavior.
Fix the expire-time calculation in the systimer mode when the buffer
size isn't aligned to the period size.
In the system-timer mode, snd-dummy driver issues each tick to update
the position. This is highly inefficient and even inaccurate if the
timer can't be triggered at each tick.
Now rewritten to wake up only at the period boundary. The position
is calculated from the current jiffies.
Allow snd-dummy driver to use high-res timer as its timing source
instead of the system timer. The new module option "hrtimer" is added
to turn on/off the high-res timer support. It can be switched even
dynamically via sysfs.
PIT_TICK_RATE is currently defined in four architectures, but in three
different places. While linux/timex.h is not the perfect place for it, it
is still a reasonable replacement for those drivers that traditionally use
asm/timex.h to get CLOCK_TICK_RATE and expect it to be the PIT frequency.
Note that for Alpha, the actual value changed from 1193182UL to 1193180UL.
This is unlikely to make a difference, and probably can only improve
accuracy. There was a discussion on the correct value of CLOCK_TICK_RATE
a few years ago, after which every existing instance was getting changed
to 1193182. According to the specification, it should be
1193181.818181...
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Len Brown <lenb@kernel.org>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Takashi Iwai <tiwai@suse.de>
Instead of mangling the CONFIG_* variables in the makefiles over and
over, set a few helper variables in Kconfig.
The commit 5a641bcd6398841cc4606b0a732d41a09256fd94 changed the
printk format to '%lu', but the value passed seems to be dependent
on the architecture. On x86-64, I got a new warning now because an
int value is passed actaully.
As a workaround, just cast the value always to unsigned long.
Fix printk format warning:
sound/drivers/pcsp/pcsp_mixer.c:54: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int'
Remove most of the serial port parameters from the card longname string
because it was way too long and overflowed into the mixername string.
arch/parisc/kernel/irq.c
arch/x86/include/asm/fixmap_64.h
arch/x86/include/asm/setup.h
kernel/irq/handle.c
Semantic merge:
arch/x86/include/asm/fixmap.h
Fix this sparse warning:
sound/drivers/vx/vx_uer.c:301:42: warning: incorrect type in argument 2 (different signedness)
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Fix the initial value for input hwport. The old value (-1) may cause
Oops when an realtime MIDI byte is received before the input port is
explicitly given.
Instead, now it's set to the broadcasting as default.
Tested-by: Holger Dehnhardt <dehnhardt@ahdehnhardt.de>
Cc: <stable@kernel.org>
Remove NOP hwdep ops in sound drivers.
X86_PC is the only remaining 'sub' architecture, so we dont need
it anymore.
This also cleans up a few spurious references to X86_PC in the
driver space - those certainly should be X86.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
