pcsp: locking fix.
Signed-off-by: Stas Sergeev <stsp@aknet.ru>
Simplify init code.
- make pcsp_start_timer_tasklet static
- remove redundant includes. <asm/i8253.h> is not available on all platforms.
Added PC-speaker sound driver (snd-pcsp).
when the time interval for a period is smaller than kernel HZ, then
snd-aloop and snd-dummy cannot call snd_pcm_period_elapsed as fast enough
annymore. this happens for example with games. but the app still needs to
see, that the buffer actually did go further, which is provided by these
patches.
Signed-off-by: Ahmet İnan <ainan <at> mathematik.uni-freiburg.de>
Reduce the number of times to check for a non-empty Tx FIFO from 100 to
2 because there is no MPU-401 implementation that needs more than one or
two reads to determine the actual FIFO status.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Add proper ifdef's to the patch loading code moved from the old instr
layer so that opl3 driver can be compiled without the sequencer support.
Fix section mismatches in mts64 by making a static variable __devinitdata.
WARNING: vmlinux.o(.data+0x2e33f0): Section mismatch: reference to .init.data:mts64_ctl_smpte_switch (between 'control.19929' and 'snd_mts64_rawmidi_output_ops')
WARNING: vmlinux.o(.data+0x2e33f8): Section mismatch: reference to .init.data:mts64_ctl_smpte_time_hours (between 'control.19929' and 'snd_mts64_rawmidi_output_ops')
WARNING: vmlinux.o(.data+0x2e3400): Section mismatch: reference to .init.data:mts64_ctl_smpte_time_minutes (between 'control.19929' and 'snd_mts64_rawmidi_output_ops')
WARNING: vmlinux.o(.data+0x2e3408): Section mismatch: reference to .init.data:mts64_ctl_smpte_time_seconds (between 'control.19929' and 'snd_mts64_rawmidi_output_ops')
WARNING: vmlinux.o(.data+0x2e3410): Section mismatch: reference to .init.data:mts64_ctl_smpte_time_frames (between 'control.19929' and 'snd_mts64_rawmidi_output_ops')
WARNING: vmlinux.o(.data+0x2e3418): Section mismatch: reference to .init.data:mts64_ctl_smpte_fps (between 'control.19929' and 'snd_mts64_rawmidi_output_ops')
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
The functions time_before, time_before_eq, time_after, and time_after_eq
are more robust for comparing jiffies against other values.
A simplified version of the semantic patch making this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@ change_compare_np @
expression E;
- jiffies <= E
+ time_before_eq(jiffies,E)
- jiffies >= E
+ time_after_eq(jiffies,E)
- jiffies < E
+ time_before(jiffies,E)
- jiffies > E
+ time_after(jiffies,E)
@ include depends on change_compare_np @
#include <linux/jiffies.h>
@ no_include depends on !include && change_compare_np @
#include <linux/...>
+ #include <linux/jiffies.h>
// </smpl>
Added the missing call of snd_card_set_dev() in drivers/*
Check the value ranges in ctl put callbacks properly (in the rest drivers).
Check the value ranges in ctl put callbacks in vxpocket driver.
We have to do fairly accurate counting of the minimal periods, instead
of being lazy and just setting the number to zero as soon as one period
elapses.
Signed-off-by: Joachim Foerster <JOFT@gmx.de>
Add ALSA support for the opb_ac97_controller_ref_v1_00_a ip core found
in Xilinx' ML403 reference design.
Known issue: Currently this driver hits a WARN_ON_ONCE(1) statement in
kernel/irq/resend.c (line 70). According to Linus
(http://lkml.org/lkml/2007/8/5/5) this may be ignored, right? I haven't
had a look into this 'problem' yet.
I applied a wrong patch for 'opl3 - simplify exclusive access lock'.
Fixed now.
Use the exclusive access lock in hwdep instead of the own one.
Use the hwdep device for loading OPL2/3 patch data instead of the
messy sequencer instrument layer.
Due to this change, the sbiload program should be updated, too.
Reported by Ingo Molnar,
when booting an allyesconfig bzImage kernel the bootup hangs in the
portman2x4 driver (on a box that does not have this hardware), at:
Pid: 1, comm: swapper
EIP: 0060:[<c02f763c>] CPU: 0
EIP is at parport_pc_read_status+0x4/0x8
EFLAGS: 00000202 Not tainted (2.6.23-rc9 #904)
EAX: f7e57a7f EBX: 00000010 ECX: c2b808c0 EDX: 00000379
ESI: f7cb8230 EDI: 00000010 EBP: f7cb8230 DS: 007b ES: 007b FS: 0000
CR0: 8005003b CR2: fff9c000 CR3: 007ec000 CR4: 00000690
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
[<c04613de>] portman_flush_input+0xde/0x12c
[<c0461a24>] snd_portman_probe+0x368/0x484
[<c02fbb8c>] __device_attach+0x0/0x8
[<c02fce68>] platform_drv_probe+0xc/0x10
[<c02fba6c>] driver_probe_device+0x74/0x194
[<c0587174>] klist_next+0x38/0x70
[<c02faea1>] bus_for_each_drv+0x35/0x68
[<c02fbc22>] device_attach+0x72/0x78
the reason is due to an inconsistent error return code of 1 or 2, while
snd_portman_probe only realizes negative error codes.
When the output and input ports are used at the same time, the timer can
be interrupted by the hardware interrupt, so we have to disable
interrupts when we take a lock in the timer.
None of the drivers with a struct pardevice's ->irq_func() hook ever
used the 'irq' argument passed to it, so remove it.
Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Since the last patch made the ENTER_UART command optional, the
enter_uart option and its corresponding flag have become superfluous.
The uart_enter option remains for backward compatibility but just prints
a warning when used.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
The original MPU-401 does not send an ACK byte after processing the
ENTER_UART command, so we better do not try to wait for it.
Many clones get this wrong and do send an ACK, but when interpreting it
as MIDI, it is just a harmless Active Sensing message, and it is likely
to be read and discarded by the interrupt handler before the MIDI input
device is triggered.
Clean up Makefile using xxx- style instead of
ifeq(CONFIG_XXX,y).
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks.
FIx section mismatch when CONFIG_HOTPLUG=n:
WARNING: sound/built-in.o(.exit.text+0x271): Section mismatch: reference to .init.text:snd_p
ortman_unregister_all (between 'snd_portman_module_exit' and 'alsa_mpu401_uart_exit')
Something about __init_or_module isn't working as expected (?).
CONFIG_HOTPLUG=y
CONFIG_MODULES=n
Fix shared init/exit code helper:
WARNING: sound/built-in.o(.exit.text+0x243): Section mismatch: reference to .init.text: (between 'alsa_card_mpu401_exit' and 'ac97_bus_exit')
WARNING: sound/built-in.o(.exit.text+0x21b): Section mismatch: reference to .init.text: (between 'alsa_card_dummy_exit' and 'alsa_card_serial_exit')
Fix shared init/exit function attributes:
WARNING: sound/built-in.o(.exit.text+0x4a1): Section mismatch: reference to .init.text: (between 'alsa_card_virmidi_exit' and 'alsa_card_serial_exit')
WARNING: sound/built-in.o(.exit.text+0x4c1): Section mismatch: reference to .init.text: (between 'alsa_card_serial_exit' and 'ac97_bus_exit')
Fix section mismatch warnings:
WARNING: sound/built-in.o(.exit.text+0x3ad): Section mismatch: reference to .init.text: (between 'sb_exit' and 'unload_uart6850')
WARNING: sound/built-in.o(.exit.text+0x753): Section mismatch: reference to .init.text: (between 'snd_mts64_module_exit' and 'snd_portman_module_exit')
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Add MODULE_FIRMWARE() entries, where appropriate.
The platform_device allocated by platform_device_alloc()
should be added to the device hierarchy by platform_device_add()
instead of platform_device_register().
Otherwise it will hit WARN_ON() in platform_device_register().
by illegal refcount.
This patch fixes such incorrect usages in portman2x4 and mts64 drivers.
Also it removes unnecessary trailing whitespaces.
Added MPU401_INFO_UART_ONLY bitflag to avoid issueing UART_ENTER command
at opening streams. Some devices support only UART mode and give errors
to UART_ENTER.
A new module option, uart_enter, is added to snd-mpu401 driver.
For UART-only devices, set uart_enter=0.
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa:
[ALSA] version 1.0.14rc2
[ALSA] Fix a typo in __dev* changes in portman2x4.c
[ALSA] Change AT91 PDC register defines for 2.6.20 kernel
[ALSA] SoC codecs - fix Kconfig - depends -> depends on
[ALSA] Fix __devinit and __devexit issues with sound drivers
[ALSA] hda-codec - Patch for enabling LFE on more Dell laptops
[ALSA] hda-codec - More fixes for Conexant HD Audio support
[ALSA] usb-audio: add PCR-A PCM support
[ALSA] emu10k1: fix typo
[ALSA] usbaudio - remove urb->bandwidth reference
[ALSA] ac97 - Fix silent output problem with Cx20551 codec
[ALSA] hda-codec - Fix Oops with probing sigmatel codec chips
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Fix a typo in the last __dev* changes in portman2x4.c.
Fix __devinit and __devexit issues with sound drivers.
Resolves MODPOST warnings similar to:
WARNING: sound/drivers/snd-dummy.o - Section mismatch: reference to .init.text:snd_dummy_probe from .data.rel.local between 'snd_dummy_driver' (at offset 0x0) and 'snd_dummy_controls'
WARNING: sound/drivers/snd-mtpav.o - Section mismatch: reference to .init.text:snd_mtpav_probe from .data.rel.local between 'snd_mtpav_driver' (at offset 0x0) and 'snd_mtpav_input'
WARNING: sound/drivers/snd-virmidi.o - Section mismatch: reference to .init.text:snd_virmidi_probe from .data.rel.local after 'snd_virmidi_driver' (at offset 0x0)
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Mark TLV data as 'const'
Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de>
snd-portman2x4 driver supports Midiman Portman 2x4 parallel port
MIDI device.
Signed-off-by: Matthias Koenig <mkoenig@suse.de>
Remove uesless typedefs and clean up the code a bit to follow
the standard coding style.
Commit 2d4ba4a3b9aef95d328d74a17ae84f8d658059e2 introduced a dependency
that was never meant to exist when the ac97_bus.c module was created.
Move ac97_bus.c up the directory hierarchy to make sure it is built when
selected even if sound is configured out so things work as originally
intended.
Signed-off-by: Nicolas Pitre <nico@cam.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Moved the entry of CONFIG_SND_AC97_POWER_SAVE from drivers/Kconfig to
more appropriate place, pci/Kconfig.
opl4: Use SEEK_{SET,CUR,END} instead of hardcoded values
Signed-off-by: Josef 'Jeff' Sipek <jeffpc@josefsipek.net>
Added the dB scale information to vxpocket and vx222 drivers.
Added the dB scale information to dummy driver.
