path: root/sound/firewire/amdtp.c
2012-05-14ALSA: firewire-lib: optimize packet flushingClemens Ladisch
Trying to flush completed packets is pointless when the pointer callback was called from the packet completion callback; avoid it. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-14ALSA: firewire-lib: flush completed packets when reading PCM positionClemens Ladisch
By flushing all completed but not yet reported packets before reading the PCM hardware position, the granularity of the pointer is improved from the interrupt interval to the packet size. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-14ALSA: firewire-lib: taskletize the snd_pcm_period_elapsed() callClemens Ladisch
The following patch might introduce this call chain: PCM .pointer callback + fw_iso_context_flush_completions + packet callback + snd_pcm_period_elapsed + PCM .pointer callback Recursive calls to the pointer callback are not possible due to the PCM group locking, so avoid this by moving the period notification into a separate tasklet. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-10firewire: optimize iso queueing by setting wake only after the last packetClemens Ladisch
When queueing iso packets, the run time is dominated by the two MMIO accesses that set the DMA context's wake bit. Because most drivers submit packets in batches, we can save much time by removing all but the last wakeup. The internal kernel API is changed to require a call to fw_iso_context_queue_flush() after a batch of queued packets. The user space API does not change, so one call to FW_CDEV_IOC_QUEUE_ISO must specify multiple packets to take advantage of this optimization. In my measurements, this patch reduces the time needed to queue fifty skip packets from userspace to one sixth on a 2.5 GHz CPU, or to one third at 800 MHz. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2011-03-15ALSA: firewire-lib, firewire-speakers: handle packet queueing errorsClemens Ladisch
Add an AMDTP stream error state that occurs when we fail to queue another packet. In this case, the stream is stopped, and the error can be reported when the application tries to restart the PCM stream. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: firewire-lib: use no-info SYT for packets without SYT sampleClemens Ladisch
In non-blocking mode, the SYT_INTERVAL is larger than the number of audio frames in each packet, so there are packets that do not contain any frame to which the SYT could be applied. For these packets, the SYT must not be the timestamp of the next valid SYT frame, but the special no-info SYT value. This fixes broken playback on the FireWave at 44.1 kHz. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driverClemens Ladisch
Add a driver for two playback-only FireWire devices based on the OXFW970 chip. v2: better AMDTP API abstraction; fix fw_unit leak; small fixes v3: cache the iPCR value v4: FireWave constraints; fix fw_device reference counting; fix PCR caching; small changes and fixes v5: volume/mute support; fix crashing due to pcm stop races v6: fix build; one-channel volume for LaCie v7: use signed values to make volume (range checks) work; fix function block IDs for volume/mute; always use channel 0 for LaCie volume Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
