path: root/sound/firewire/iso-resources.c
2011-03-15ALSA: firewire-lib: allocate DMA buffer separatelyClemens Ladisch
For correct cache coherency on some architectures, DMA buffers must be allocated in a different cache line than data that is concurrently used by the CPU. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driverClemens Ladisch
Add a driver for two playback-only FireWire devices based on the OXFW970 chip. v2: better AMDTP API abstraction; fix fw_unit leak; small fixes v3: cache the iPCR value v4: FireWave constraints; fix fw_device reference counting; fix PCR caching; small changes and fixes v5: volume/mute support; fix crashing due to pcm stop races v6: fix build; one-channel volume for LaCie v7: use signed values to make volume (range checks) work; fix function block IDs for volume/mute; always use channel 0 for LaCie volume Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
