path: root/sound/firewire/lib.h
2013-10-20ALSA: firewire: extend snd_fw_transaction()Clemens Ladisch
Add a flag to snd_fw_transaction() to allow it to abort when a bus reset happens. This removes most of the duplicated error handling loops that were required around calls to the low-level fw_run_transaction(). Also add a flag to suppress error messages; errors are expected when we attempt to clean up after the device was unplugged. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2012-04-17firewire: move rcode_string() to coreClemens Ladisch
There is nothing audio-specific about the rcode_string() helper, so move it from snd-firewire-lib into firewire-core to allow other code to use it. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (fixed sound/firewire/cmp.c)
2011-03-15ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driverClemens Ladisch
Add a driver for two playback-only FireWire devices based on the OXFW970 chip. v2: better AMDTP API abstraction; fix fw_unit leak; small fixes v3: cache the iPCR value v4: FireWave constraints; fix fw_device reference counting; fix PCR caching; small changes and fixes v5: volume/mute support; fix crashing due to pcm stop races v6: fix build; one-channel volume for LaCie v7: use signed values to make volume (range checks) work; fix function block IDs for volume/mute; always use channel 0 for LaCie volume Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
