path: root/sound/firewire/scs1x.c
2014-02-14ALSA: firewire: Convert to snd_card_new() with a device pointerTakashi Iwai
Also remove superfluous snd_card_set_dev() calls. Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-10-20ALSA: firewire: extend snd_fw_transaction()Clemens Ladisch
Add a flag to snd_fw_transaction() to allow it to abort when a bus reset happens. This removes most of the duplicated error handling loops that were required around calls to the low-level fw_run_transaction(). Also add a flag to suppress error messages; errors are expected when we attempt to clean up after the device was unplugged. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2013-07-10Merge tag 'firewire-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire updates from Stefan Richter: "Make struct ieee1394_device_id.driver_data actually avaliable to 1394 protocol drivers. This is especially useful to 1394 audio drivers for model-specific parameters and methods" * tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: remove support of fw_driver.driver.probe and .remove methods firewire: introduce fw_driver.probe and .remove methods
2013-06-18ALSA: firewire: fix error return code in scs_probe()Wei Yongjun
Fix to return -ENOMEM in the kmalloc() error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-09firewire: introduce fw_driver.probe and .remove methodsStefan Richter
FireWire upper layer drivers are converted from generic struct driver.probe() and .remove() to bus-specific struct fw_driver.probe() and .remove(). The new .probe() adds a const struct ieee1394_device_id *id argument, indicating the entry in the driver's device identifiers table which matched the fw_unit to be probed. This new argument is used by the snd-firewire-speakers driver to look up device-specific parameters and methods. There is at least one other FireWire audio driver currently in development in which this will be useful too. The new .remove() drops the unused error return code. Although all in-tree drivers are being converted to the new methods, support for the old methods is left in place in this commit. This allows public developer trees to merge this commit and then move to the new fw_driver methods. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Clemens Ladisch <clemens@ladisch.de> (for sound/firewire/) Cc: Peter Hurley <peter@hurleysoftware.com> (for drivers/staging/fwserial/)
2012-11-12ALSA: firewire: add Stanton SCS.1d/1m driverClemens Ladisch
Add a MIDI driver for the Stanton FireWire DJ controllers. Tested-by: Sean M. Pappalardo - D.J. Pegasus <spappalardo@mixxx.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
