callback
[ Upstream commit 51e68fb0929c29e47e9074ca3e99ffd6021a1c5a ]
In some error paths, reference count of firewire unit is not decreased.
This commit fixes the bug.
Fixes: 5b14ec25a79b('ALSA: firewire: release reference count of firewire unit in .remove callback of bus driver')
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Saffire Pro i/o series
commit 706ad6746a66546daf96d4e4a95e46faf6cf689a upstream.
For Focusrite Saffire Pro i/o, the lowest 8 bits of register represents
configured source of sampling clock. The next lowest 8 bits represents
whether the configured source is actually detected or not just after
the register is changed for the source.
Current implementation evaluates whole the register to detect configured
source. This results in failure due to the next lowest 8 bits when the
source is connected in advance.
Fixes: 25784ec2d034 ("ALSA: bebob: Add support for Focusrite Saffire/SaffirePro series")
Cc: <stable@vger.kernel.org> # v3.16+
Link: https://lore.kernel.org/r/20191102150920.20367-1-o-takashi@sakamocchi.jp
commit f2bbdbcb075f3977a53da3bdcb7cd460bc8ae5f2 upstream.
A helper function of ALSA bebob driver returns negative value in a
function which has a prototype to return unsigned value.
This commit fixes it by changing the prototype.
Fixes: eb7b3a056cd8 ("ALSA: bebob: Add commands and connections/streams management")
Link: https://lore.kernel.org/r/20191026030620.12077-1-o-takashi@sakamocchi.jp
commit e1a00b5b253a4f97216b9a33199a863987075162 upstream.
2 bytes in MSB of register for clock status is zero during intermediate
state after changing status of sampling clock in models of TASCAM FireWire
series. The duration of this state differs depending on cases. During the
state, it's better to retry reading the register for current status of
the clock.
In current implementation, the intermediate state is checked only when
getting current sampling transmission frequency, then retry reading.
This care is required for the other operations to read the register.
This commit moves the codes of check and retry into helper function
commonly used for operations to read the register.
Fixes: e453df44f0d6 ("ALSA: firewire-tascam: add PCM functionality")
Cc: <stable@vger.kernel.org> # v4.4+
Link: https://lore.kernel.org/r/20190910135152.29800-3-o-takashi@sakamocchi.jp
commit 2617120f4de6d0423384e0e86b14c78b9de84d5a upstream.
The return value of snd_tscm_stream_get_clock() is ignored. This commit
checks the value and handle error.
Link: https://lore.kernel.org/r/20190910135152.29800-2-o-takashi@sakamocchi.jp
commit 1be3c1fae6c1e1f5bb982b255d2034034454527a upstream.
In iso_packets_buffer_init(), 'b->packets' is allocated through
kmalloc_array(). Then, the aligned packet size is checked. If it is
larger than PAGE_SIZE, -EINVAL will be returned to indicate the error.
However, the allocated 'b->packets' is not deallocated on this path,
leading to a memory leak.
To fix the above issue, free 'b->packets' before returning the error code.
Fixes: 31ef9134eb52 ("ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver")
Signed-off-by: Wenwen Wang <wenwen@cs.uga.edu>
Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
Cc: <stable@vger.kernel.org> # v2.6.39+
commit 7fbd1753b64eafe21cf842348a40a691d0dee440 upstream.
In IEC 61883-6, 8 MIDI data streams are multiplexed into single
MIDI conformant data channel. The index of stream is calculated by
modulo 8 of the value of data block counter.
In fireworks, the value of data block counter in CIP header has a quirk
with firmware version v5.0.0, v5.7.3 and v5.8.0. This brings ALSA
IEC 61883-1/6 packet streaming engine to miss detection of MIDI
messages.
This commit fixes the miss detection to modify the value of data block
counter for the modulo calculation.
For maintainers, this bug exists since a commit 18f5ed365d3f ("ALSA:
fireworks/firewire-lib: add support for recent firmware quirk") in Linux
kernel v4.2. There're many changes since the commit. This fix can be
backported to Linux kernel v4.4 or later. I tagged a base commit to the
backport for your convenience.
Besides, my work for Linux kernel v5.3 brings heavy code refactoring and
some structure members are renamed in 'sound/firewire/amdtp-stream.h'.
The content of this patch brings conflict when merging -rc tree with
this patch and the latest tree. I request maintainers to solve the
conflict to replace 'tx_first_dbc' with 'ctx_data.tx.first_dbc'.
Fixes: df075feefbd3 ("ALSA: firewire-lib: complete AM824 data block processing layer")
commit 0e3fb6995bfabb23c172e8b883bf5ac57102678e upstream.
The data for isochronous resources is not destroyed in expected place.
Cc: <stable@vger.kernel.org> # v4.12+
Fixes: 9b2bb4f2f4a2 ("ALSA: firewire-motu: add stream management functionality")
commit d8fa87c368f5b4096c4746894fdcc195da285df1 upstream.
Stanton SCS.1m can transfer isochronous packet with Multi Bit Linear
Audio data channels, therefore it allows software to capture PCM
substream. However, ALSA oxfw driver doesn't.
This commit changes the driver to add one PCM substream for capture
direction.
Fixes: de5126cc3c0b ("ALSA: oxfw: add stream format quirk for SCS.1 models")
Cc: <stable@vger.kernel.org> # v4.5+
commit f97a0944a72b26a2bece72516294e112a890f98a upstream.
In data blocks of common isochronous packet for MOTU devices, PCM
frames are multiplexed in a shape of '24 bit * 4 Audio Pack', described
in IEC 61883-6. The frames are not aligned to quadlet.
For capture PCM substream, ALSA firewire-motu driver constructs PCM
frames by reading data blocks byte-by-byte. However this operation
includes bug for lower byte of the PCM sample. This brings invalid
content of the PCM samples.
Reported-by: Peter Sjöberg <autopeter@gmail.com>
Fixes: 4641c9394010 ("ALSA: firewire-motu: add MOTU specific protocol layer")
Liquid Saffire 56
commit 7dc661bd8d3261053b69e4e2d0050cd1ee540fc1 upstream.
ALSA bebob driver has an entry for Focusrite Saffire Pro 10 I/O. The
entry matches vendor_id in root directory and model_id in unit
directory of configuration ROM for IEEE 1394 bus.
On the other hand, configuration ROM of Focusrite Liquid Saffire 56
has the same vendor_id and model_id. This device is an application of
TCAT Dice (TCD2220 a.k.a Dice Jr.) however ALSA bebob driver can be
bound to it randomly instead of ALSA dice driver. At present, drivers
in ALSA firewire stack can not handle this situation appropriately.
This commit uses more identical mod_alias for Focusrite Saffire Pro 10
I/O in ALSA bebob driver.
$ python2 crpp < /sys/bus/firewire/devices/fw1/config_rom
ROM header and bus information block
400 042a829d bus_info_length 4, crc_length 42, crc 33437
404 31333934 bus_name "1394"
408 f0649222 irmc 1, cmc 1, isc 1, bmc 1, pmc 0, cyc_clk_acc 100,
max_rec 9 (1024), max_rom 2, gen 2, spd 2 (S400)
40c 00130e01 company_id 00130e |
410 000606e0 device_id 01000606e0 | EUI-64 00130e01000606e0
root directory
414 0009d31c directory_length 9, crc 54044
418 04000014 hardware version
41c 0c0083c0 node capabilities per IEEE 1394
420 0300130e vendor
424 81000012 --> descriptor leaf at 46c
428 17000006 model
42c 81000016 --> descriptor leaf at 484
430 130120c2 version
434 d1000002 --> unit directory at 43c
438 d4000006 --> dependent info directory at 450
43c 0004707c directory_length 4, crc 28796
440 1200a02d specifier id: 1394 TA
444 13010001 version: AV/C
448 17000006 model
44c 81000013 --> descriptor leaf at 498
450 000637c7 directory_length 6, crc 14279
454 120007f5 specifier id
458 13000001 version
45c 3affffc7 (immediate value)
460 3b100000 (immediate value)
464 3cffffc7 (immediate value)
468 3d600000 (immediate value)
46c 00056f3b leaf_length 5, crc 28475
470 00000000 textual descriptor
474 00000000 minimal ASCII
478 466f6375 "Focu"
47c 73726974 "srit"
480 65000000 "e"
484 0004a165 leaf_length 4, crc 41317
488 00000000 textual descriptor
48c 00000000 minimal ASCII
490 50726f31 "Pro1"
494 30494f00 "0IO"
498 0004a165 leaf_length 4, crc 41317
49c 00000000 textual descriptor
4a0 00000000 minimal ASCII
4a4 50726f31 "Pro1"
4a8 30494f00 "0IO"
400 040442e4 bus_info_length 4, crc_length 4, crc 17124
408 e0ff8112 irmc 1, cmc 1, isc 1, bmc 0, pmc 0, cyc_clk_acc 255,
max_rec 8 (512), max_rom 1, gen 1, spd 2 (S400)
40c 00130e04 company_id 00130e |
410 018001e9 device_id 04018001e9 | EUI-64 00130e04018001e9
root directory
414 00065612 directory_length 6, crc 22034
418 0300130e vendor
41c 8100000a --> descriptor leaf at 444
420 17000006 model
424 8100000e --> descriptor leaf at 45c
428 0c0087c0 node capabilities per IEEE 1394
42c d1000001 --> unit directory at 430
430 000418a0 directory_length 4, crc 6304
434 1200130e specifier id
438 13000001 version
43c 17000006 model
440 8100000f --> descriptor leaf at 47c
444 00056f3b leaf_length 5, crc 28475
448 00000000 textual descriptor
44c 00000000 minimal ASCII
450 466f6375 "Focu"
454 73726974 "srit"
458 65000000 "e"
45c 000762c6 leaf_length 7, crc 25286
460 00000000 textual descriptor
464 00000000 minimal ASCII
468 4c495155 "LIQU"
46c 49445f53 "ID_S"
470 41464649 "AFFI"
474 52455f35 "RE_5"
478 36000000 "6"
47c 000762c6 leaf_length 7, crc 25286
480 00000000 textual descriptor
484 00000000 minimal ASCII
488 4c495155 "LIQU"
48c 49445f53 "ID_S"
490 41464649 "AFFI"
494 52455f35 "RE_5"
498 36000000 "6"
[ Upstream commit 644b2e97405b0b74845e1d3c2b4fe4c34858062b ]
This commit fixes hard-coded model-id for an unit of Apogee Ensemble with
a correct value. This unit uses DM1500 ASIC produced ArchWave AG (formerly
known as BridgeCo AG).
I note that this model supports three modes in the number of data channels
in tx/rx streams; 8 ch pairs, 10 ch pairs, 18 ch pairs. The mode is
switched by Vendor-dependent AV/C command, like:
$ cd linux-firewire-utils
$ ./firewire-request /dev/fw1 fcp 0x00ff000003dbeb0600000000 (8ch pairs)
$ ./firewire-request /dev/fw1 fcp 0x00ff000003dbeb0601000000 (10ch pairs)
$ ./firewire-request /dev/fw1 fcp 0x00ff000003dbeb0602000000 (18ch pairs)
When switching between different mode, the unit disappears from IEEE 1394
bus, then appears on the bus with different combination of stream formats.
In a mode of 18 ch pairs, available sampling rate is up to 96.0 kHz, else
up to 192.0 kHz.
$ ./hinawa-config-rom-printer /dev/fw1
{ 'bus-info': { 'adj': False,
'bmc': True,
'chip_ID': 21474898341,
'cmc': True,
'cyc_clk_acc': 100,
'generation': 2,
'imc': True,
'isc': True,
'link_spd': 2,
'max_ROM': 1,
'max_rec': 512,
'name': '1394',
'node_vendor_ID': 987,
'pmc': False},
'root-directory': [ ['HARDWARE_VERSION', 19],
[ 'NODE_CAPABILITIES',
{ 'addressing': {'64': True, 'fix': True, 'prv': False},
'misc': {'int': False, 'ms': False, 'spt': True},
'state': { 'atn': False,
'ded': False,
'drq': True,
'elo': False,
'init': False,
'lst': True,
'off': False},
'testing': {'bas': False, 'ext': False}}],
['VENDOR', 987],
['DESCRIPTOR', 'Apogee Electronics'],
['MODEL', 126702],
['DESCRIPTOR', 'Ensemble'],
['VERSION', 5297],
[ 'UNIT',
[ ['SPECIFIER_ID', 41005],
['VERSION', 65537],
['MODEL', 126702],
['DESCRIPTOR', 'Ensemble']]],
[ 'DEPENDENT_INFO',
[ ['SPECIFIER_ID', 2037],
['VERSION', 1],
[(58, 'IMMEDIATE'), 16777159],
[(59, 'IMMEDIATE'), 1048576],
[(60, 'IMMEDIATE'), 16777159],
[(61, 'IMMEDIATE'), 6291456]]]]}
[ Upstream commit fba43f454cdf9caa3185219d116bd2a6e6354552 ]
This commit adds support for APOGEE duet FireWire, launched 2007, already
discontinued. This model uses Oxford Semiconductor FW971 as its
communication engine. Below is information on Configuration ROM of this
unit. The unit supports some AV/C commands defined by Audio subunit
specification and vendor dependent commands.
'bmc': False,
'chip_ID': 42949742248,
'cmc': False,
'cyc_clk_acc': 255,
'generation': 0,
'imc': False,
'isc': True,
'link_spd': 3,
'max_ROM': 0,
'max_rec': 64,
'name': '1394',
'pmc': False},
'root-directory': [ ['VENDOR', 987],
['MODEL', 122333],
['DESCRIPTOR', 'Duet'],
'ded': False,
'drq': True,
'elo': False,
'init': False,
'lst': True,
'off': False},
[ 'UNIT',
['VERSION', 65537],
['MODEL', 122333],
['DESCRIPTOR', 'Duet']]]]}
commit 5ef108c53e6efd695e32aad969638ccbc35b4be9 upstream.
An initial commit to add tracepoints for packets without CIP headers
uses different print formats for added tracepoints. However this is not
convenient for users/developers to prepare debug tools.
This commit uses the same format for the two tracepoints.
Fixes: b164d2fd6e49 ('ALSA: firewire_lib: add tracepoints for packets without CIP headers')
tracepoint
commit aa9a9e39b4f65733bf19d90cbd026e85a74efb99 upstream.
introduces a wrong assignment to 'data_blocks' value of
'out_packet_without_header' tracepoint.
commit ada79fa5a0b374dd2c2262137c734da7524a8263 upstream.
In IEC 61883-1/6 engine of ALSA firewire stack, a packet handler has a
second argument for 'the number of bytes in payload of isochronous
packet'. However, an incoming packet handler without CIP header uses the
value as 'the number of quadlets in the payload'. This brings userspace
applications to receive the number of PCM frames as four times against
real time.
Fixes: 3b196c394dd ('ALSA: firewire-lib: add no-header packet processing')
commit 3d16200a3e55a39caa1c88419cb559c00316f721 upstream.
According to my memo at hand and saved records, writing 0x00000001 to
SND_FF_REG_FETCH_PCM_FRAMES disables fetching PCM frames in corresponding
channel, however current implement uses reversed logic. This results in
muted volume in device side during playback.
This commit corrects the bug.
Fixes: 76fdb3a9e13a ('ALSA: fireface: add support for Fireface 400')
commit fa9c98e4b975bb3192ed6af09d9fa282ed3cd8a0 upstream.
In an initial commit, 'SYNC_STATUS' register is referred to get
clock configuration, however this is wrong, according to my local
note at hand for reverse-engineering about packet dump. It should
be 'CLOCK_CONFIG' register. Actually, ff400_dump_clock_config()
is correctly programmed.
commit 498fe23aad8e3b5a9554f55719c537603b4476ea upstream.
Although private data of sound card instance is usually allocated in the
tail of the instance, drivers in ALSA firewire stack allocate the private
data before allocating the instance. In this case, the private data
should be released explicitly at .private_free callback of the instance.
This commit fixes memory leak following to the above design.
Fixes: 6c29230e2a5f ('ALSA: oxfw: delayed registration of sound card')
Cc: <stable@vger.kernel.org> # v4.7+
commit 1064bc685d359f549f91c2d5f111965a9284f328 upstream.
After finishing discover of stream formats, ALSA OXFW driver has memory
leak of allocated memory object at error path.
This commit releases the memory object at the error path.
commit ce925f088b979537f22f9e05eb923ef9822ca139 upstream.
After allocating model-dependent data, ALSA OXFW driver has memory leak
of the data at error path.
This commit releases the data at the error path.
commit c3b55e2ec9c76e7a0de2a0b1dc851fdc9440385b upstream.
After allocating memory object for response buffer, ALSA fireworks
driver has leak of the memory object at error path.
This commit releases the object at the error path.
Fixes: 7d3c1d5901aa('ALSA: fireworks: delayed registration of sound card')
commit 8d28277c065a974873c6781d44b7bcdcd8fb4e8a upstream.
Fixes: b610386c8afb ('ALSA: firewire-tascam: deleyed registration of sound card')
commit a49a83ab05e34edd6c71a4fbd062c9a7ba6d18aa upstream.
Fixes: 86c8dd7f4da3 ('ALSA: firewire-digi00x: delayed registration of sound card')
commit 36f3a6e02c143a7e9e4e143e416371f67bc1fae6 upstream.
An allocated memory forgets to be released.
Fixes: 76fdb3a9e13 ('ALSA: fireface: add support for Fireface 400')
Cc: <stable@vger.kernel.org> # 4.12+
streaming DMA mapping
commit 493626f2d87a74e6dbea1686499ed6e7e600484e upstream.
When executing 'fw_run_transaction()' with 'TCODE_WRITE_BLOCK_REQUEST',
an address of 'payload' argument is used for streaming DMA mapping by
'firewire_ohci' module if 'size' argument is larger than 8 byte.
Although in this case the address should not be on kernel stack, current
implementation of ALSA bebob driver uses data in kernel stack for a cue
to boot M-Audio devices. This often brings unexpected result, especially
for a case of CONFIG_VMAP_STACK=y.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=201021
Reference: https://forum.manjaro.org/t/firewire-m-audio-410-driver-wont-load-firmware/51165
Fixes: a2b2a7798fb6('ALSA: bebob: Send a cue to load firmware for M-Audio Firewire series')
commit b1fbebd4164b3d170ad916dcd692cf843c9c065d upstream.
After allocating model-dependent data for M-Audio FW1814 and ProjectMix
I/O, ALSA bebob driver has memory leak at error path.
This commit releases the allocated data at the error path.
Fixes: 04a2c73c97eb('ALSA: bebob: delayed registration of sound card')
for array index
commit 52759c0963510a2843774aac9b65ccaed3308dc0 upstream.
At a commit f91c9d7610a ('ALSA: firewire-lib: cache maximum length of
payload to reduce function calls'), maximum size of payload for tx
isochronous packet is cached to reduce the number of function calls.
This cache was programmed to updated at a first callback of ohci1394 IR
context. However, the maximum size is required to queueing packets before
starting the isochronous context.
As a result, the cached value is reused to queue packets in next time to
starting the isochronous context. Then the cache is updated in a first
callback of the isochronous context. This can cause kernel NULL pointer
dereference in a below call graph:
(sound/firewire/amdtp-stream.c)
amdtp_stream_start()
->queue_in_packet()
->queue_packet()
(drivers/firewire/core-iso.c)
->fw_iso_context_queue()
->struct fw_card_driver.queue_iso()
(drivers/firewire/ohci.c)
= ohci_queue_iso()
->queue_iso_packet_per_buffer()
buffer->pages[page]
The issued dereference occurs in a case that:
- target unit supports different stream formats for sampling transmission
frequency.
- maximum length of payload for tx stream in a first trial is bigger
than the length in a second trial.
In this case, correct number of pages are allocated for DMA and the 'pages'
array has enough elements, while index of the element is wrongly calculated
according to the old value of length of payload in a call of
'queue_in_packet()'. Then it causes the issue.
This commit fixes the critical bug. This affects all of drivers in ALSA
firewire stack in Linux kernel v4.12 or later.
[12665.302360] BUG: unable to handle kernel NULL pointer dereference at 0000000000000030
[12665.302415] IP: ohci_queue_iso+0x47c/0x800 [firewire_ohci]
[12665.302439] PGD 0
[12665.302440] P4D 0
[12665.302450]
[12665.302470] Oops: 0000 [#1] SMP PTI
[12665.302487] Modules linked in: ...
[12665.303096] CPU: 1 PID: 12760 Comm: jackd Tainted: P OE 4.13.0-38-generic #43-Ubuntu
[12665.303154] Hardware name: /DH77DF, BIOS KCH7710H.86A.0069.2012.0224.1825 02/24/2012
[12665.303215] task: ffff9ce87da2ae80 task.stack: ffffb5b8823d0000
[12665.303258] RIP: 0010:ohci_queue_iso+0x47c/0x800 [firewire_ohci]
[12665.303301] RSP: 0018:ffffb5b8823d3ab8 EFLAGS: 00010086
[12665.303337] RAX: ffff9ce4f4876930 RBX: 0000000000000008 RCX: ffff9ce88a3955e0
[12665.303384] RDX: 0000000000000000 RSI: 0000000034877f00 RDI: 0000000000000000
[12665.303427] RBP: ffffb5b8823d3b68 R08: ffff9ce8ccb390a0 R09: ffff9ce877639ab0
[12665.303475] R10: 0000000000000108 R11: 0000000000000000 R12: 0000000000000003
[12665.303513] R13: 0000000000000000 R14: ffff9ce4f4876950 R15: 0000000000000000
[12665.303554] FS: 00007f2ec467f8c0(0000) GS:ffff9ce8df280000(0000) knlGS:0000000000000000
[12665.303600] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[12665.303633] CR2: 0000000000000030 CR3: 00000002dcf90004 CR4: 00000000000606e0
[12665.303674] Call Trace:
[12665.303698] fw_iso_context_queue+0x18/0x20 [firewire_core]
[12665.303735] queue_packet+0x88/0xe0 [snd_firewire_lib]
[12665.303770] amdtp_stream_start+0x19b/0x270 [snd_firewire_lib]
[12665.303811] start_streams+0x276/0x3c0 [snd_dice]
[12665.303840] snd_dice_stream_start_duplex+0x1bf/0x480 [snd_dice]
[12665.303882] ? vma_gap_callbacks_rotate+0x1e/0x30
[12665.303914] ? __rb_insert_augmented+0xab/0x240
[12665.303936] capture_prepare+0x3c/0x70 [snd_dice]
[12665.303961] snd_pcm_do_prepare+0x1d/0x30 [snd_pcm]
[12665.303985] snd_pcm_action_single+0x3b/0x90 [snd_pcm]
[12665.304009] snd_pcm_action_nonatomic+0x68/0x70 [snd_pcm]
[12665.304035] snd_pcm_prepare+0x68/0x90 [snd_pcm]
[12665.304058] snd_pcm_common_ioctl1+0x4c0/0x940 [snd_pcm]
[12665.304083] snd_pcm_capture_ioctl1+0x19b/0x250 [snd_pcm]
[12665.304108] snd_pcm_capture_ioctl+0x27/0x40 [snd_pcm]
[12665.304131] do_vfs_ioctl+0xa8/0x630
[12665.304148] ? entry_SYSCALL_64_after_hwframe+0xe9/0x139
[12665.304172] ? entry_SYSCALL_64_after_hwframe+0xe2/0x139
[12665.304195] ? entry_SYSCALL_64_after_hwframe+0xdb/0x139
[12665.304218] ? entry_SYSCALL_64_after_hwframe+0xd4/0x139
[12665.304242] ? entry_SYSCALL_64_after_hwframe+0xcd/0x139
[12665.304265] ? entry_SYSCALL_64_after_hwframe+0xc6/0x139
[12665.304288] ? entry_SYSCALL_64_after_hwframe+0xbf/0x139
[12665.304312] ? entry_SYSCALL_64_after_hwframe+0xb8/0x139
[12665.304335] ? entry_SYSCALL_64_after_hwframe+0xb1/0x139
[12665.304358] SyS_ioctl+0x79/0x90
[12665.304374] ? entry_SYSCALL_64_after_hwframe+0x72/0x139
[12665.304397] entry_SYSCALL_64_fastpath+0x24/0xab
[12665.304417] RIP: 0033:0x7f2ec3750ef7
[12665.304433] RSP: 002b:00007fff99e31388 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[12665.304465] RAX: ffffffffffffffda RBX: 00007fff99e312f0 RCX: 00007f2ec3750ef7
[12665.304494] RDX: 0000000000000000 RSI: 0000000000004140 RDI: 0000000000000007
[12665.304522] RBP: 0000556ebc63fd60 R08: 0000556ebc640560 R09: 0000000000000000
[12665.304553] R10: 0000000000000001 R11: 0000000000000246 R12: 0000556ebc63fcf0
[12665.304584] R13: 0000000000000000 R14: 0000000000000007 R15: 0000000000000000
[12665.304612] Code: 01 00 00 44 89 eb 45 31 ed 45 31 db 66 41 89 1e 66 41 89 5e 0c 66 45 89 5e 0e 49 8b 49 08 49 63 d4 4d 85 c0 49 63 ff 48 8b 14 d1 <48> 8b 72 30 41 8d 14 37 41 89 56 04 48 63 d3 0f 84 ce 00 00 00
[12665.304713] RIP: ohci_queue_iso+0x47c/0x800 [firewire_ohci] RSP: ffffb5b8823d3ab8
[12665.304743] CR2: 0000000000000030
[12665.317701] ---[ end trace 9d55b056dd52a19f ]---
Fixes: f91c9d7610a ('ALSA: firewire-lib: cache maximum length of payload to reduce function calls')
commit 0f925660a7bc49b269c163249a5d06da3a0c7b0a upstream.
In error path of snd_dice_stream_init_duplex(), stream data for incoming
packet can be left to be initialized.
This commit fixes it.
Fixes: 436b5abe2224 ('ALSA: dice: handle whole available isochronous streams')
Cc: <stable@vger.kernel.org> # v4.6+
commit 10412c420af9ba1f3de8483a95d360e5eb5bfc84 upstream.
OUI for TC Electronic is 0x000166, for TC GROUP A/S. 0x001486 is for Echo
Digital Audio Corporation.
Fixes: 7cafc65b3aa1 ('ALSA: dice: force to add two pcm devices for listed models')
Reference: http://standards-oui.ieee.org/oui/oui.txt
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Add a jump target so that a bit of exception handling can be better reused
at the end of this function.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Drivers in ALSA firewire stack still includes some symbols which can be
moved to a section for read-only symbols.
sound/core/control.c
MOTU Audio Express is one of third generation in MOTU FireWire
series, produced in 2011. This model consists of three chips:
* TI TSB41AB2 (Physical layer for IEEE 1394 bus)
* Microchip USB3300 (Hi-Speed USB Device with ULPI interface)
* Xilinx Spartan-3A FPGA, XC3S400A (Link layer for IEEE 1394 bus, packet
processing and data block processing layer)
This commit adds support for this model. As I expected, it works with
current implementaion of protocol version 3. On the other hand, the unit
has a quirk to request subaction originated by any driver.
11:45:51.287643 firewire_ohci 0000:03:00.0: AT spd 2 tl 1f, ffc1 -> ffc0, -reserved-, QW req, fffff0000b14 = 02000200
11:45:51.289193 firewire_ohci 0000:03:00.0: AR spd 2 tl 1f, ffc0 -> ffc1, ack_complete, W resp
11:45:51.289381 fireire_core 0000:03:00.0: unsolicited response (source ffc0, tlabel 1f)
11:45:51.313071 firewire_ohci 0000:03:00.0: AT spd 2 tl 20, ffc1 -> ffc0, ack_pending , QW req, fffff0000b14 = 02000200
11:45:51.314539 firewire_ohci 0000:03:00.0: AR spd 2 tl 20, ffc0 -> ffc1, ack_complete, W resp
In 1394 OHCI (rev.1.1), after OUTPUT_LAST* descriptors is processed,
'xferStaus' field is filled with 'ContextControl[0:15]' (see clause 7.1.3).
5 bits in LSB side of the field has ack code in acknowledge from the unit
(see clause 7.2.2). A list of the code is shown in Table 3-2.
As long as I investigated, in a case of the '-reserved-' acknowledge
message from the unit, the field has 0x10. On the table, this value is
'Reserved for definition by future 1394 standards'. As long as I know,
any specifications of IEEE 1394 has no such extensions, thus the unit is
out of specification. Besides, I note that the unit does not always
acknowledge with the invalid code. I guess this is a bug of firmware. I
confirmed the bug in firmware version 1.04 and this is the latest one.
$ python2 ./src/crpp < /sys/bus/firewire/devices/fw1/config_rom
400 0410a756 bus_info_length 4, crc_length 16, crc 42838
408 20ff7000 irmc 0, cmc 0, isc 1, bmc 0, cyc_clk_acc 255, max_rec 7 (256)
40c 0001f200 company_id 0001f2 |
410 000a8a7b device_id 00000a8a7b | EUI-64 0001f200000a8a7b
root directory
414 0004ef04 directory_length 4, crc 61188
418 030001f2 vendor
420 d1000002 --> unit directory at 428
424 8d000005 --> eui-64 leaf at 438
428 00031680 directory_length 3, crc 5760
42c 120001f2 specifier id
430 13000033 version
434 17104800 model
eui-64 leaf at 438
438 00025ef3 leaf_length 2, crc 24307
43c 0001f200 company_id 0001f2 |
440 000a8a7b device_id 00000a8a7b | EUI-64 0001f200000a8a7b
messages
In protocols of MOTU FireWire series, when transferring MIDI messages,
transmitter set existence flag to one byte on first several quadlets. The
position differs depending on protocols and models, however two cases are
confirmed; in 5th byte and 8th byte from MSB side.
This commit adds a series of specification flag to describe them. When
the existence flag is in the 5th byte, SND_MOTU_SPEC_[R|T]X_MIDI_2ND_Q is
used. Else, another set of the flag is used. Here, '_Q' means quadlet.
initialization
When failing sound card registration after initializing stream data, this
module leaves allocated data in stream data. This commit fixes the bug.
Fixes: 9b2bb4f2f4a2 ('ALSA: firewire-motu: add stream management functionality')
data of iso-resource
When calling 'iso_resource_free()' for uninitialized data, this function
causes NULL pointer dereference due to its 'unit' member. This occurs when
unplugging audio and music units on IEEE 1394 bus at failure of card
registration.
This commit fixes the bug. The bug exists since kernel v4.5.
Fixes: 324540c4e05c ('ALSA: fireface: postpone sound card registration') at v4.12
Fixes: 8865a31e0fd8 ('ALSA: firewire-motu: postpone sound card registration') at v4.12
Fixes: b610386c8afb ('ALSA: firewire-tascam: deleyed registration of sound card') at v4.7
Fixes: 86c8dd7f4da3 ('ALSA: firewire-digi00x: delayed registration of sound card') at v4.7
Fixes: 6c29230e2a5f ('ALSA: oxfw: delayed registration of sound card') at v4.7
Fixes: 7d3c1d5901aa ('ALSA: fireworks: delayed registration of sound card') at v4.7
Fixes: 04a2c73c97eb ('ALSA: bebob: delayed registration of sound card') at v4.7
Fixes: b59fb1900b4f ('ALSA: dice: postpone card registration') at v4.5
snd_pcm_ops are not supposed to change at runtime. All functions
working with snd_pcm_ops provided by <sound/pcm.h> work with
const snd_pcm_ops. So mark the non-const structs as const.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
These snd_rawmidi_ops structures are only passed as the third
argument of snd_rawmidi_set_ops. This argument is const, so the
snd_rawmidi_ops structures can be const too.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
At Linux v3.5, packet processing can be done in process context of ALSA
PCM application as well as software IRQ context for OHCI 1394. Below is
an example of the callgraph (some calls are omitted).
ioctl(2) with e.g. HWSYNC
(sound/core/pcm_native.c)
->snd_pcm_common_ioctl1()
->snd_pcm_hwsync()
->snd_pcm_stream_lock_irq
(sound/core/pcm_lib.c)
->snd_pcm_update_hw_ptr()
->snd_pcm_udpate_hw_ptr0()
->struct snd_pcm_ops.pointer()
(sound/firewire/*)
= Each handler on drivers in ALSA firewire stack
->amdtp_stream_pcm_pointer()
->fw_iso_context_flush_completions()
->struct fw_card_driver.flush_iso_completion()
= flush_iso_completions()
->struct fw_iso_context.callback.sc
= in_stream_callback() or out_stream_callback()
->snd_pcm_stream_unlock_irq
When packet queueing error occurs or detecting invalid packets in
'in_stream_callback()' or 'out_stream_callback()', 'snd_pcm_stop_xrun()'
is called on local CPU with disabled IRQ.
->amdtp_stream_pcm_abort()
->snd_pcm_stop_xrun()
->snd_pcm_stream_lock_irqsave()
->snd_pcm_stop()
->snd_pcm_stream_unlock_irqrestore()
The process is stalled on the CPU due to attempt to acquire recursive lock.
[ 562.630853] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 562.630861] 2-...: (1 GPs behind) idle=37d/140000000000000/0 softirq=38323/38323 fqs=7140
[ 562.630862] (detected by 3, t=15002 jiffies, g=21036, c=21035, q=5933)
[ 562.630866] Task dump for CPU 2:
[ 562.630867] alsa-source-OXF R running task 0 6619 1 0x00000008
[ 562.630870] Call Trace:
[ 562.630876] ? vt_console_print+0x79/0x3e0
[ 562.630880] ? msg_print_text+0x9d/0x100
[ 562.630883] ? up+0x32/0x50
[ 562.630885] ? irq_work_queue+0x8d/0xa0
[ 562.630886] ? console_unlock+0x2b6/0x4b0
[ 562.630888] ? vprintk_emit+0x312/0x4a0
[ 562.630892] ? dev_vprintk_emit+0xbf/0x230
[ 562.630895] ? do_sys_poll+0x37a/0x550
[ 562.630897] ? dev_printk_emit+0x4e/0x70
[ 562.630900] ? __dev_printk+0x3c/0x80
[ 562.630903] ? _raw_spin_lock+0x20/0x30
[ 562.630909] ? snd_pcm_stream_lock+0x31/0x50 [snd_pcm]
[ 562.630914] ? _snd_pcm_stream_lock_irqsave+0x2e/0x40 [snd_pcm]
[ 562.630918] ? snd_pcm_stop_xrun+0x16/0x70 [snd_pcm]
[ 562.630922] ? in_stream_callback+0x3e6/0x450 [snd_firewire_lib]
[ 562.630925] ? handle_ir_packet_per_buffer+0x8e/0x1a0 [firewire_ohci]
[ 562.630928] ? ohci_flush_iso_completions+0xa3/0x130 [firewire_ohci]
[ 562.630932] ? fw_iso_context_flush_completions+0x15/0x20 [firewire_core]
[ 562.630935] ? amdtp_stream_pcm_pointer+0x2d/0x40 [snd_firewire_lib]
[ 562.630938] ? pcm_capture_pointer+0x19/0x20 [snd_oxfw]
[ 562.630943] ? snd_pcm_update_hw_ptr0+0x47/0x3d0 [snd_pcm]
[ 562.630945] ? poll_select_copy_remaining+0x150/0x150
[ 562.630947] ? poll_select_copy_remaining+0x150/0x150
[ 562.630952] ? snd_pcm_update_hw_ptr+0x10/0x20 [snd_pcm]
[ 562.630956] ? snd_pcm_hwsync+0x45/0xb0 [snd_pcm]
[ 562.630960] ? snd_pcm_common_ioctl1+0x1ff/0xc90 [snd_pcm]
[ 562.630962] ? futex_wake+0x90/0x170
[ 562.630966] ? snd_pcm_capture_ioctl1+0x136/0x260 [snd_pcm]
[ 562.630970] ? snd_pcm_capture_ioctl+0x27/0x40 [snd_pcm]
[ 562.630972] ? do_vfs_ioctl+0xa3/0x610
[ 562.630974] ? vfs_read+0x11b/0x130
[ 562.630976] ? SyS_ioctl+0x79/0x90
[ 562.630978] ? entry_SYSCALL_64_fastpath+0x1e/0xad
This commit fixes the above bug. This assumes two cases:
1. Any error is detected in software IRQ context of OHCI 1394 context.
In this case, PCM substream should be aborted in packet handler. On the
other hand, it should not be done in any process context. TO distinguish
these two context, use 'in_interrupt()' macro.
2. Any error is detect in process context of ALSA PCM application.
In this case, PCM substream should not be aborted in packet handler
because PCM substream lock is acquired. The task to abort PCM substream
should be done in ALSA PCM core. For this purpose, SNDRV_PCM_POS_XRUN is
returned at 'struct snd_pcm_ops.pointer()'.
Suggested-by: Clemens Ladisch <clemens@ladisch.de>
Fixes: e9148dddc3c7("ALSA: firewire-lib: flush completed packets when reading PCM position")
Cc: <stable@vger.kernel.org> # 4.9+
applications
In ALSA firewire stack, 8 drivers uses IEC 61883-1/6 engine for data
transmission. They have common PCM info/constraints and duplicated codes.
This commit unifies the codes into fireiwre-lib.
ALSA fireface driver has ALSA specific operations for MIDI/PCM data.
Structured data for the operations can be constified. Additionally,
The structured data can be function local.
In recent commit for ALSA PCM core, some arrangement is done for
'struct snd_pcm_ops.ack' callback. This is called when appl_ptr is
explicitly moved in intermediate buffer for PCM frames, except for
some cases described later.
For drivers in ALSA firewire stack, usage of this callback has a merit to
reduce latency between time of PCM frame queueing and handling actual
packets in recent isochronous cycle, because no need to wait for software
IRQ context from isochronous context of OHCI 1394.
If this works well in a case that mapped page frame is used for the
intermediate buffer, user process should execute some commands for ioctl(2)
to tell the number of handled PCM frames in the intermediate buffer just
after handling them. Therefore, at present, with a combination of below
conditions, this doesn't work as expected and user process should wait for
the software IRQ context as usual:
- when ALSA PCM core judges page frame mapping is available for status
data (struct snd_pcm_mmap_status) and control data
(struct snd_pcm_mmap_control).
- user process handles PCM frames by loop just with 'snd_pcm_mmap_begin()'
and 'snd_pcm_mmap_commit()'.
- user process uses PCM hw plugin in alsa-lib to operate I/O without
'sync_ptr_ioctl' option.
Unfortunately, major use case include these three conditions.
Declare snd_kcontrol_new structures as const as they are only passed an
argument to the function snd_ctl_new1. This argument is of type const,
so snd_kcontrol_new structures having this property can be made const.
Done using Coccinelle:
@r disable optional_qualifier@
identifier x;
position p;
static struct snd_kcontrol_new x@p={...};
@ok@
identifier r.x;
position p;
snd_ctl_new1(&x@p,...)
@bad@
position p != {r.p,ok.p};
identifier r.x;
x@p
@depends on !bad disable optional_qualifier@
identifier r.x;
+const
struct snd_kcontrol_new x;
Cross compiled these files:
sound/aoa/codecs/tas.c - powerpc
sound/mips/{hal2.c/sgio2audio.c} - mips
sound/ppc/{awacs.c/beep.c/tumbler.c} - powerpc
sound/soc/sh/siu_dai.c - sh
Could not find an architecture to compile sound/sh/aica.c.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
Acked-by: Mark Brown <broonie@kernel.org>
In IEC 61883-6, AM824 is described as format of data block. In this
format, one data block consists of several data channels, which is aligned
to 32 bit. One data channel has 8 bit label field and 24 bit data field.
PCM frames are transferred in Multi Bit Linear Audio (MBLA) data channel.
This channel can include 16/20/24 bit PCM sample.
As long as I know, models which support IEC 61883-1/6 doesn't allow to
switch bit length of PCM sample in MBLA data channel. They always
transmit/receive PCM frames of 24 bit length. This can be seen for the
other models which support protocols similar to IEC 61883-1/6.
On the other hand, current drivers for these protocols supports 16 bit
length PCM sample in playback substream. In this case, PCM sample is put
into the MBLA data channel with 8 bit padding in LSB side. Although 16
bit PCM sample is major because it's in CD format, this doesn't represent
device capability as is.
This commit removes support for 16 bit PCM samples in playback substream.
Acked-by: Clemens Ladisch <clemens@ladisch.de>
In development period for Linux v4.10, ktime_t became an alias of s64,
instead of union. I forgot it. We can just assign zero, instead of usage
of ktime_set(0, 0).
Fixes: 19174295788 ("ALSA: fireface: add transaction support")
Two functions were introduced for the purpose of tracing but cause warnings
when tracing is disabled:
sound/firewire/motu/amdtp-motu.c:284:13: error: 'copy_message' defined but not used [-Werror=unused-function]
static void copy_message(u64 *frames, __be32 *buffer, unsigned int data_blocks,
sound/firewire/motu/amdtp-motu.c:271:13: error: 'copy_sph' defined but not used [-Werror=unused-function]
static void copy_sph(u32 *frames, __be32 *buffer, unsigned int data_blocks,
Marking them as __maybe_unused will do the right thing here.
Fixes: 17909c1b3058 ("ALSA: firewire-motu: add tracepoints for SPH in IEC 61883-1 fashion")
Fixes: c6b0b9e65f09 ("ALSA: firewire-motu: add tracepoints for messages for unique protocol")
