path: root/sound/i2c
2007-02-09[ALSA] snd-ak4114: Fix two array overflowsJean Delvare
Fix the handling of the TXCSB registers cache. There was one array overflow in reg_write() and one in snd_ak4114_reg_write(). Thanks to David Binderman for reporting the latter. The second overflow probably doesn't matter much, given that the function snd_ak4114_reg_write() appears to be never called. I wonder why it exists and why it is exported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Remove delayed work properly at free and suspendTakashi Iwai
Remove delayed work properly at free and suspend in ac97 codec and ak4114 drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add even more 'const' to everything related to TLVTakashi Iwai
Mark TLV data as 'const' Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add some more 'const', but needs changes in i2c/other/ak4*Takashi Iwai
Make data passed to ak4xxx_create 'const'. Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ak4114 - Use global workqueueTakashi Iwai
Use global workqueue for simplicity instead of own workqueue. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Enable the analog loopback of the Revolution 5.1Jochen Voss
Enable the analog loopback of the Revolution 5.1 card. This patch adds support for the PT2258 volume controller and modifies the Revolution 5.1 driver to make use of this facility. This allows to control the analog loopback of the card. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Enable capture from line-in and CD on Revolution 5.1Jochen Voss
Enable capture from line-in and CD on the Revolution 5.1 card. This patch adds support for switching between the 5 input channels of the AK5365 ADC and modifies the Revolution 5.1 driver to make use of this facility. Previously the capture channel was fixed to channel 0 (microphone on the Revolution 5.1 card). Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-23[ALSA] ak4xxx - Remove bogus IPGA controlsTakashi Iwai
Remove IPGA volume controls and merge the IPGA range to ADC volume controls. These two volumes are not really independent but connected simply in different ranges 0-0x7f and 0x80-max. It doesn't make sense to provide two controls. Since both 0x7f and 0x80 specify 0dB, a hack is needed for IPGA range to skip 0x80 (increment one) for such controls. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Clean up and add TLV support to AK4xxx i2c driverTakashi Iwai
- Clean up the code in AK4xxx-ADDA i2c code. - Fix capture gain controls for AK5365 - Changed the static table for DAC/ADC mixer labels to use structs - Implemented TLV entries for each AK codec The volumes in AK4524, AK4528 and AK5365 are corrected with a table to be suitable for dB conversion. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix volume control for the AK4358 DACJochen Voss
Fix volume control for the AK4358 DAC. The attenuation control registers of the AK4358 use only 7bit for the volume, the msb is used to enable attenuation output. Without this patch there are 256 volume levels the lower 128 of which are mute. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix compile warnings in ak4xxx-adda.cTakashi Iwai
Fixed compile warnings in ak4xxx-adda.c reagarding missing enum cases in switch. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Revolution 5.1 - complete the AK5365 supportJochen Voss
Complete the AK5365 support. This adds a boolean control to toggle the soft mute feature of the AK5365 chip. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Revolution 5.1 - add AK5365 ADC supportJochen Voss
Add support for the AK5365 ADC. Signed-off-by: Jochen Voss <voss@seehuhn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] trivial: Code clean up of i2c/cs8427.cTakashi Iwai
- Fix spaces, wrap lines in 80 columns. - Move EXPORT_SYMBOL() adjacent to each function. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-12[ALSA] sound/i2c/cs8427.c: don't export a static functionAdrian Bunk
Static functions shouldn't be exported. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-28[ALSA] ak4xxx-adda - Code clean-upTakashi Iwai
Fix spaces, fold lines to fit 80 columns in ak4xxx-adda driver codes. Split a long reset function to each codec routine just for better readability. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-28[ALSA] Stereo controls for M-Audio Revolution cardsJani Alinikula
This patch adds stereo controls to revo cards by making the ak4xxx driver mixers configurable from the card driver. Signed-off-by: Jani Alinikula <janialinikula@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] i2c - Move EXPORT_SYMBOL() to adjacent to each functionTakashi Iwai
Move EXPORT_SYMBOL() to adjacent to each exported function/variable. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] ice1712 & cs8427 - fix problem for S/PDIF input setupJaroslav Kysela
Modules: I2C cs8427,ICE1712 driver See ALSA bug#1785 for more details. Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] semaphore -> mutex (driver part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: I2C driversTakashi Iwai
Remove xxx_t typedefs from the i2c drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Clean up sa11xx-uda1341 driverTakashi Iwai
Modules: SA11xx UDA1341 driver,L3 drivers,UDA1341 Clean up sa11xx-uda1341 driver: - Fix buggy destructor - Remove the global variable - Move array definitions from uda1341.h - Make functions in uda1341.c static Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove tea6330t struct definition from public headerTakashi Iwai
Modules: I2C tea6330t Remove tea6330t struct definition from public header. It's anyway unaccessible from outside. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Fix schedule_timeout usageNishanth Aravamudan
Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Also use human-time conversion functions instead of hard-coded division to avoid rounding issues. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Add missing KERN_* suffix to printkTakashi Iwai
Add missing KERN_* suffix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - othersTakashi Iwai
Documentation,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,OPL3 OPL4,Digigram VX core,I2C cs8427,I2C lib core,I2C tea6330t,L3 drivers AK4114 receiver,AK4117 receiver,PDAudioCF driver,PPC PMAC driver SPARC AMD7930 driver,SPARC cs4231 driver,Synth,Common EMU synth USB generic driver,USB USX2Y Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-07-28[ALSA] ak4114: removed duplicate wake_up()Jaroslav Kysela
AK4114 receiver - wake_up(&runtime->sleep) is already called in snd_pcm_post_stop() Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-06-22[ALSA] Remove redundant NULL checks before kfreeJesper Juhl
Timer Midlevel,ALSA sequencer,ALSA<-OSS sequencer,Digigram VX core I2C tea6330t,GUS Library,VIA82xx driver,VIA82xx-modem driver CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,YMFPCI driver Digigram VX Pocket driver,Common EMU synth,USB generic driver,USB USX2Y Checking a pointer for NULL before calling kfree() on it is redundant, kfree() deals with NULL pointers just fine. This patch removes such checks from sound/ This patch also makes another, but closely related, change. It avoids casting pointers about to be kfree()'ed. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
