path: root/sound/isa/cs423x
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-19ALSA: cs4236: add dB scale for all volume controlsKrzysztof Helt
Use db scale for all volume controls according to Crystal's datasheets. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-18ALSA: cs4236: update control namesKrzysztof Helt
Update control names to be more closer to their meaning. Change the "Mono" name to the "Beep" as this line is usually used to forward the PC beeper signal to sound card's output. Update names for both cs423x and wss. Clean up cs4235 controls according to the cs4235 doc. Rename some of the cs4235 controls to be consistent with the cs4236's ones. Also, delete one misnamed cs4231 register define. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-05ALSA: cs4236: detect chip in one passKrzysztof Helt
The cs4236 was two step detection with call to the snd_wss_free() between two steps. The snd_wss_free() did not free a sound device created in the snd_wss_create(). This caused an OOPS during module removal as the same sound device was released twice. The same OOPS happened if the cs4236 module loading failed. Fix this by adapting the snd_cs4236_create() to correctly work with chips less capable then cs4236. The snd_cs4236_create() behaves the same as the snd_wss_create() if the chip is less capable than the cs4236. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-17ALSA: cs4236 - Merge snd-cs4236-lib module into snd-cs4236Takashi Iwai
Since cs4232 and cs4236 drivers are merged, there is no reason to keep snd-cs4236-lib module separately. Let's merge it into the main driver as well. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-16ALSA: cs4236: cs4232 and cs4236 driver merge to solve PnP BIOS detectionKrzysztof Helt
cs4232 and cs4236 driver merge to solve PnP BIOS detection. Also, the patch adds recognition if the chip is cs4236b+ or earlier part. This unifies drivers for both cs4232 and cs4236+ chips. It allows to use the PnP BIOS detection for the cs4236+ chips. Previously, only the snd-cs4232 could be detected by the PnP BIOS. The cs4232+ cards reports two separate PnP BIOS ids. The patch adds search for the second id to find out resources assigned to a control port. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-16Merge branch 'topic/snd_card_new-err' into topic/cs423x-mergeTakashi Iwai
2009-02-05ALSA: isa/*: Add missing KERN_* prefix to printkTakashi Iwai
2009-01-12ALSA: Return proper error code at probe in sound/isa/*Takashi Iwai
Some drivers in sound/isa/* don't handle the error code properly from snd_card_create(). This patch fixes these places. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/isa/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-03ALSA: remove direct access of dev->bus_id in sound/isa/*Takashi Iwai
Removed the direct accesses of dev->bus_id in sound/isa/* by replacement with dev_err() or dev_warn() functions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: Kill snd_assert() in sound/isa/*Takashi Iwai
Kill snd_assert() in sound/isa/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: snd-cs4236: add Techmakers MF-4236PW PnP card IDRene Herman
Add the Techmakers MF-4236PW (Crystal CX4236B-XQ3) PnP card ID. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: rename cs4321_foo to wss_fooKrzysztof Helt
Rename functions and structures from the former cs4321_lib to names more corresponding with the new name: wss_lib. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: rename cs4231.h into wss.hKrzysztof Helt
Rename file include/sound/cs4231.h into include/sound/wss.h Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: move cs4231_lib into wss_libKrzysztof Helt
Move the file sound/isa/cs423x/cs4231_lib.c into sound/isa/cs423x/wss_lib.c This is the first step toward merging all libraries for Windows Sound System compatible chips into a single library. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-27ALSA: cs4232: fix crash during chip PNP detectionKrzysztof Helt
The acard->wss pointer is uninitialized in this function which leads to crash during chip PNP detection. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-06-13ALSA: opti93x: add support for Opti93x codec in cs4231-libKrzysztof Helt
This patch adds support for WSS compatible Opti93x codec to the cs4231-lib. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Tested-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] cs4231: remove one busy waitKrzysztof Helt
This busy_wait is not needed after latest changes to the cs4231-lib Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/isa: kill pnp_resource_changeRene Herman
This removes the pnp_resource_change use from the ALSA ISAPnP drivers. In 2.4 these were useful in providing an easy path to setting the resources, but in 2.6 they retain function as a layering violation only. This makes for a nice cleanup (-550 lines) of ALSA but moreover, ALSA is the only remaining user of pnp_init_resource_table(), pnp_resource_change() and pnp_manual_config_dev() (and, in fact, of 'struct pnp_resource_table') in the tree outide of drivers/pnp itself meaning it makes for more cleanup potential inside the PnP layer. Thomas Renninger acked their removal from that side, you did from the ALSA side (CC list just copied from that thread). Against current alsa-kernel HG. Many more potential cleanups in there, but this _only_ removes the pnp_resource_change code. Compile tested against current alsa-kernel HG and compile- and use-tested against 2.6.23.x (few offsets). Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Fix thinko in cs4231 mce down checkTakashi Iwai
The last patches to replace with schedule_timeout() don't work as expected. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] cs4231-lib: improved waiting after mce_downKrzysztof Helt
This patch replaces long msleeps in waiting loops with schedule_timeout() calls. Signed-off-by: Krzysztof Helt <krzysztof.h1 at wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ad1848/cs4231: replace commented out debug code with snd-printd{,d}Rene Herman
While I'm at it another 'while I'm there' -- replace commented out debug code with snd-printd{,d}. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ad1838/cs4231 - fix MCE timeout upon initial loadRene Herman
When the ad1848/cs2431 is first being initialized, auto-calibration may not be set causing a timeout waiting for it in snd_ad1848/cs4231_mce_down(). This has no dire consequences other than an alarming printk, but since what we need to wait for is for the calibration to _finish_, let's just check for that instead. The early chips need a slight delay (as commented -- 5 sample periods) to be sure that _if_ calibration is going to happen, it has started when we check While the CS4231A datasheet implies it'll happen immediately on downing MCE, some testing is showing that there's a window there as well, so just do the delay everywhere. Thanks to Krysztof Helt for pinpointing this problem. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] cs4231-lib: replace common delay loop by functionKrzysztof Helt
This patch replaces a common delay loop by a function. It also uses ARRAY_SIZE macro for the rates table. Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] isa libs Makefiles cleanupKrzysztof Helt
This patch uses the Kconfig parameters SND_AD1848_LIB and SND_CS4231_LIB instead of mentioning each driver that requires the ad1848-lib or cs4231-lib separately in the Makefiles. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Fix bugs in mode change/recalibration for opl3sa2 driverPaul Vojta
The mode change / recalibration doesn't work always with opl3sa2 devices, e.g. the first time it's played back. The patch fixes the problem. Signed-off-by: Paul Vojta <vojta@math.berkeley.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-16[ALSA] Fix probe of non-PnP ISA devicesRene Herman
isa_register_driver() returns an error if no device is found and it's no fatal error for the drivers with pnp support. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] isa_bus device/driver namingRene Herman
isa_bus: delete snd_ prefix from the (sysfs visible) device/driver names. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Port the rest of ALSA ISA drivers to isa_driverTakashi Iwai
Port the rest of ALSA ISA drivers to use isa_driver framework instead of platform_driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] isa_bus: cs4231Rene Herman
cs4231: port to isa_bus infrastructure. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-12[ALSA] Fix undefined (missing) references in ISA MIRO sound driverRandy Dunlap
WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_create WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_pcm WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_timer WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko needs unknown symbol snd_cs4231_mixer WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/fs/reiser4/reiser4.ko needs unknown symbol generic_file_read Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-12[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
Unregister the platform device again if the probe was unsuccessful. This restores the behaviour of not loading the driver on probe() failure. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] continue on IS_ERR from platform device registrationRene Herman
Continue with the next one on error from device registration. This would seem the correct thing to do, even if it's not the probe() error that we're getting. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-27[PATCH] pnp: cs4236: adjust pnp_register_driver signatureBjorn Helgaas
Remove the assumption that pnp_register_driver() returns the number of devices claimed. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[ALSA] cs4236 - Fix a typoTakashi Iwai
Modules: CS4236+ driver Fixed a typo in snd_cs4236_put_master_digital(), resulting in silence right channel. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] Fix check of enable module optionTakashi Iwai
Fix the check of enable module option in probe of platform_device drivers. It shouldn't break the loop but just ignore if enable[i] is false. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] semaphore -> mutex (ISA part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-24[PATCH] snd-cs4236 typo fixRene Herman
I noticed on 2.6.16-rc4 that my MPU-401 wasn't functional, due to a simple copy & paste error in sound/isa/cs423x/cs4236.c. Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[ALSA] cs4236 - Add PnP ids for Netfinity 3000Lukasz Stemach
Modules: CS4236+ driver PnP ids for Netfinity 3000 builtin soundcard. This one works for me. This patch was submitted through kernel Bugzilla #4214. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] cs4232/cs4236 - moved CS423X_DRIVER define outside CONFIG_PNPJaroslav Kysela
Modules: CS4236+ driver Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-01-22[ALSA] Fix compilation without CONFIG_PNPTakashi Iwai
Fix compilation of some ISA drivers without CONFIG_PNP. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] unregister platform devicesClemens Ladisch
Call platform_device_unregister() for all platform devices that we've registered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
