path: root/sound/isa/opti9xx
2007-05-11[ALSA] Port the rest of ALSA ISA drivers to isa_driverTakashi Iwai
Port the rest of ALSA ISA drivers to use isa_driver framework instead of platform_driver. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] sound/isa/opti9xx/opti92x-ad1848.c: check kmalloc() return valueAmit Choudhary
Check the return value of kmalloc() in function snd_card_opti9xx_pnp(), in file sound/isa/opti9xx/opti92x-ad1848.c. Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] Fix double free in error path of miro driverTakashi Iwai
Fixed the double free in error path of miro driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-12[ALSA] unregister platform device again if probe was unsuccessfulRene Herman
Unregister the platform device again if the probe was unsuccessful. This restores the behaviour of not loading the driver on probe() failure. Signed-off-by: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] Remove obsolete kfree_nocheck callTakashi Iwai
Fixed the compilation, removing obsolete kfree_nocheck() call for memory debugging. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] Add snd-miro driverMartin Langer
Added snd-miro driver for miroSOUND PCM by Martin Langer. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] opti9x - Fix compile without CONFIG_PNPTakashi Iwai
Modules: Opti9xx drivers Fix compile errors without CONFIG_PNP. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-02-01[ALSA] opti93x - Fix a compile warningTakashi Iwai
Modules: Opti9xx drivers Fix a gcc-4.1 compile warning regarding uninitialized variables. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] unregister platform devicesClemens Ladisch
Call platform_device_unregister() for all platform devices that we've registered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] opti9xx - Use platform_deviceTakashi Iwai
Modules: Opti9xx drivers Rewrite the probe/remove with platform_device. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA Opti9xxTakashi Iwai
Modules: Opti9xx drivers Remove xxx_t typedefs from the ISA Opti 9xx drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove superfluous pcm_free callbacksTakashi Iwai
Remove superflous pcm_free callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Replace with kzalloc() - isa stuffTakashi Iwai
ES18xx driver,OPL3SA2 driver,AD1816A driver,AD1848 driver,CS4231 driver ES1688 driver,GUS Library,Opti9xx drivers,EMU8000 driver SB16/AWE driver,SB drivers Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Add snd_card_set_generic_dev() call to ISA driversTakashi Iwai
ISA,CMI8330 driver,ES18xx driver,OPL3SA2 driver,Sound Galaxy driver Sound Scape driver,AD1848 driver,CS4231 driver,CS4236+ driver ES1688 driver,GUS Classic driver,GUS Extreme driver,GUS MAX driver AMD InterWave driver,Opti9xx drivers,SB16/AWE driver,SB8 driver Wavefront drivers - Added snd_card_set_generic_dev() call. - Added SND_GENERIC_DRIVER to Kconfig. - Clean up the error path in probe if necessary. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] opti93x: optimize a register accessClemens Ladisch
Opti9xx drivers When clearing some bits in a register, don't bother with the bits that won't be changed anyway. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
