path: root/sound/isa/opti9xx
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08sound: fix opti92x-ad1848 buildRandy Dunlap
Fix 'else' placement in ifdef block so that build succeeds: sound/isa/opti9xx/opti92x-ad1848.c:221: error: 'else' without a previous 'if' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-03ALSA: opti92x: use PnP data to select Master Control portKrzysztof Helt
The Master Control port (MC) is available as the last PnP resource (OPT005). Use this value instead fo guessing. Also, add some comments to the code. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-14Merge branch 'next/isa' into topic/miscTakashi Iwai
2009-12-12ALSA: opti93x: use dB scale for mixer controlsKrzysztof Helt
Add dB scale for mixer controls. Fix dB scale for Master Volume control. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-11ALSA: opti93x: move controls definitions to opti93x driverKrzysztof Helt
Move OPTi93x controls definitions to the opti93x driver from the common wss-lib library module. These controls are used only by the opti93x driver. Also, fix capture source names. They are the same as opl3sa2 names. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-10ALSA: opti93x: fix irq releasing if the irq cannot be allocatedKrzysztof Helt
Use the chip->irq to check if the irq should be released so the irq is not released if it has not been allocated. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: ice1724 - aureon - modify WM8770 Master & DAC volume ALSA: hda/realtek: quirk for D945GCLF2 mainboard ALSA: hda - Terradici HDA controllers does not support 64-bit mode ALSA: document: Add direct git link to grub hda-analyzer ALSA: radio/sound/miro: fix build, cleanup depends/selects ALSA: hda - Generalize EAPD inversion check in patch_analog.c ASoC: Wrong variable returned on error ALSA: snd-usb-us122l: add product IDs of US-122MKII and US-144MKII ALSA: hda - Exclude unusable ADCs for ALC88x ALSA: hda - Add missing Line-Out and PCM switches as slave ALSA: hda - iMac 9,1 sound patch. ALSA: opti93x: set MC indirect registers base from PnP data
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-08ALSA: opti93x: set MC indirect registers base from PnP dataKrzysztof Helt
The PnP data on the OPTI931 and OPTI933 contains io port range for the MC indirect registers. Use the PnP range instead of hardwired value 0xE0E. Also, request region of MC indirect registers so it is marked as used to other drivers (this was missing previously). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-02ALSA: opti9xx: remove snd_opti9xx fieldsKrzysztof Helt
Remove snd_opti9xx fields which are indirect arguments to the snd_opti9xx_configure(). Pass these values as function arguments. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-30ALSA: opti-miro: add PnP detectionKrzysztof Helt
The PCM12 and PCM20 can be set into the ISA PnP mode. The PCM12 PnP was sold as the PnP device. Add code to handle detection of these cards using ISA PnP framework. Tested on the PCM20 in PnP mode. The PCM12 PnP has the same MS Windows INF file except for a card name displayed for user. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-30ALSA: opti-miro: separate comon probing codeKrzysztof Helt
Separate common probing code in order to use it for PnP probing. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-27ALSA: opti-miro: fix OOPS if hardware is not detectedKrzysztof Helt
If a hardware is not detected there is a kernel crash due to not initialized snd_miro->aci pointer. This pointer is initialized after detection of the opti (miro) chip. This bug was introduced by patches to expose ACI mikser outside the snd-miro driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-23ALSA: opti-miro: expose ACI mixer to outside driversKrzysztof Helt
The ACI mixer is used to control the radio FM module installed on the Miro PCM20 sound card. Expose ACI mixer outside the sound card driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-23ALSA: opti-miro: make miro.h header available outside the alsa directoryKrzysztof Helt
Move the miro.h header to the include/sound directory. It can be used in the Miro PCM20 radio driver (v4l). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-21ALSA: opti-miro: remove snd_card pointer from snd_miro structureKrzysztof Helt
Remove the snd_card pointer from the snd_miro structure and do some small code improvements. Also, move Opti chipset detection before detection of the ACI mixer, so the mci_base value is set in one place only. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-18ALSA: opti-miro: Fix missing semicolonTakashi Iwai
To fix a build error sound/isa/opti9xx/miro.c:1281: error: expected ';' before '}' token Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-18ALSA: opti-miro: use variables directly in the probe functionKrzysztof Helt
Use the fm_port and mpu_port variables directly in a probe function. This completely eliminates a need to copy the fm_port value to the snd_miro structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-16Merge branch 'topic/snd_card_new-err' into topic/cs423x-mergeTakashi Iwai
2009-02-05ALSA: isa/*: Add missing KERN_* prefix to printkTakashi Iwai
2009-01-21ALSA: do not create OPL3 timers if there is no OPL3 irq wiredKrzysztof Helt
Most cards have OPL3 FM synthetiser but they do not have OPL3 interrupt wired to a sound chip or CPU. Do not create OPL3 timers for such cards as the timers are useless witthout interrupt. This patch removes OPL3 timers for following alsa drivers: snd-ad1816a, snd-opti93x, snd-opti92x, snd-sc6000, snd-cmi8330. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-14ALSA: opti9xx - Fix build breakage by snd_card_create() conversionTakashi Iwai
Add a missing variable declaration. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Return proper error code at probe in sound/isa/*Takashi Iwai
Some drivers in sound/isa/* don't handle the error code properly from snd_card_create(). This patch fixes these places. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in sound/isa/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: Kill snd_assert() in sound/isa/*Takashi Iwai
Kill snd_assert() in sound/isa/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: opti92x-ad1848 WSS_HW_DETECT fixRene Herman
snd-opti92x-ad1848 mistakingly passes WSS_HW_OPTI93X currently. This fixes it as tested with a OPTi 82C929A/AD1848 card. Signed-off-by: Rene Herman <rene.herman@gmail.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use wss detection code instead of ad1848 oneKrzysztof Helt
Use the wss detection code and kill the ad1848 library. The library is fully assimilated into the new wss library. This required reworking of the AD1848 family code so the code is changed to correctly detect chips from the AD1848 and CS4231 families. I have tested it on following cards: Gallant SC-6600 (codec: AD1848, driver: snd-sc6600) SoundScape VIVO/90 (codec: AD1845, driver: snd-sscape) SG Waverider (codec: CS4231A, driver: Rene Herman's snd-galaxy) Opti930 (codec: built-in - CS4231 compatible, driver: snd-opti93x) Opti931 (codec: built-in - CS4231 compatible, driver: snd-opti93x) Gallant SC-70P (chip/codec: CS4237B, driver: snd-cs4236) Audio Plus 3D (chip/codec: CMI8330A, driver: snd-cmi8330) Dell Latitude CP (chip/codec: cs4236, driver snd-cs4232) Sound playback and recording works on all these cards. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use wss pcm code instead of ad1848 oneKrzysztof Helt
Use the wss pcm code and kill the ad1848 pcm code. The AD1848 chip is much slower than CS4231 chips so the waiting loop was increased 100x (10x is not enough). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use wss mixer code instead of ad1848 oneKrzysztof Helt
Use the wss mixer code and kill the ad1848 mixer code. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use wss constants instead of ad1848 onesKrzysztof Helt
Use wss constants for mode. Move ad1848 hardware constants to the wss.h. Move mixer tlv macros into the ad1848_lib.c from the ad1848.h. Drop the MODE_RUNNING spurious IRQ guard on AD1848 as it doesn not seem to be needed. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: use struct snd_wss instead of snd_ad1848Krzysztof Helt
The snd_wss is superset of the snd_ad1848 so kill the latter and replace it with the snd_wss. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: rename cs4321_foo to wss_fooKrzysztof Helt
Rename functions and structures from the former cs4321_lib to names more corresponding with the new name: wss_lib. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: wss_lib: rename cs4231.h into wss.hKrzysztof Helt
Rename file include/sound/cs4231.h into include/sound/wss.h Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reviewed-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-18ALSA: opti9xx: no isapnp param for !CONFIG_PNPRene Herman
"isapnp" needs CONFIG_PNP to be useful. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-18ALSA: opti93x - Fix NULL dereferenceTakashi Iwai
Probing non-existing device causes Oops with snd-opti93x driver due to NULL access in the destructor of the error path. Signed-off-by: Takashi Iwai <tiwai@suse.de> Tested-by: Rene Herman <rene.herman@gmail.com> Acked-by: Rene Herman <rene.herman@gmail.com> Tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-06-13ALSA: opti93x: use cs4231 libKrzysztof Helt
This patch converts the Opti93x driver to use the cs4231 library instead of duplicating the code. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Tested-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-13[ALSA] opti93x: fix sound ouput for Opti930Krzysztof Helt
This patch fixes silenced output from the Opti930. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] fix opti9xx/miro section mismatchRandy Dunlap
snd_opti93x_mixer() is only called by __devinit snd_opti93x_probe(), so the former can also be __devinit. snd_miro_mixer() is only called by __devinit snd_miro_probe(), so the former can also be __devinit. sound/isa/opti9xx/opti92x-ad1848.c: WARNING: vmlinux.o(.text+0xf91cd7): Section mismatch: reference to .init.data:snd_opti93x_controls (between 'snd_opti93x_mixer' and 'snd_card_opti9xx_free') WARNING: vmlinux.o(.text+0xf91d66): Section mismatch: reference to .init.data:snd_miro_controls (between 'snd_opti93x_mixer' and 'snd_card_opti9xx_free') opti9xx/miro.c: WARNING: vmlinux.o(.text+0xf926c2): Section mismatch: reference to .init.data:snd_miro_controls (between 'snd_miro_mixer' and 'snd_legacy_find_free_ioport') WARNING: vmlinux.o(.text+0xf926e5): Section mismatch: reference to .init.data:snd_miro_eq_controls (between 'snd_miro_mixer' and 'snd_legacy_find_free_ioport') WARNING: vmlinux.o(.text+0xf926f9): Section mismatch: reference to .init.data:snd_miro_line_control (between 'snd_miro_mixer' and 'snd_legacy_find_free_ioport') WARNING: vmlinux.o(.text+0xf92716): Section mismatch: reference to .init.data:snd_miro_amp_control (between 'snd_miro_mixer' and 'snd_legacy_find_free_ioport') WARNING: vmlinux.o(.text+0xf9273e): Section mismatch: reference to .init.data:snd_miro_preamp_control (between 'snd_miro_mixer' and 'snd_legacy_find_free_ioport') WARNING: vmlinux.o(.text+0xf92764): Section mismatch: reference to .init.data:snd_miro_capture_control (between 'snd_miro_mixer' and 'snd_legacy_find_free_ioport') WARNING: vmlinux.o(.text+0xf92783): Section mismatch: reference to .init.data:snd_miro_radio_control (between 'snd_miro_mixer' and 'snd_legacy_find_free_ioport') WARNING: vmlinux.o(.text+0xf9279a): Section mismatch: reference to .init.data:snd_miro_eq_controls (between 'snd_miro_mixer' and 'snd_legacy_find_free_ioport') WARNING: vmlinux.o(.text+0xf927b9): Section mismatch: reference to .init.data:snd_miro_radio_control (between 'snd_miro_mixer' and 'snd_legacy_find_free_ioport') Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/isa: kill pnp_resource_changeRene Herman
This removes the pnp_resource_change use from the ALSA ISAPnP drivers. In 2.4 these were useful in providing an easy path to setting the resources, but in 2.6 they retain function as a layering violation only. This makes for a nice cleanup (-550 lines) of ALSA but moreover, ALSA is the only remaining user of pnp_init_resource_table(), pnp_resource_change() and pnp_manual_config_dev() (and, in fact, of 'struct pnp_resource_table') in the tree outide of drivers/pnp itself meaning it makes for more cleanup potential inside the PnP layer. Thomas Renninger acked their removal from that side, you did from the ALSA side (CC list just copied from that thread). Against current alsa-kernel HG. Many more potential cleanups in there, but this _only_ removes the pnp_resource_change code. Compile tested against current alsa-kernel HG and compile- and use-tested against 2.6.23.x (few offsets). Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly (in the rest drivers). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] This patch adds support for a wavetable chip onKrzysztof Helt
the BTC 1817DW board. The QS1000 is connected through the digital input to the Opti931 chip. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] opti9xx: adjust OPL3 FM resource valueTakashi Iwai
The OPTi ISA-PnP chips advertise their OPL4 base at 0x380 (to 0x3f0) through pnp and put their on-chip OPL3 at +8. The driver assumes the provided value is the ALBase (OPL3 address) though and checks for an OPL4 at -8, which means that simply adding 8 to the pnp provides value works to fix detection of both OPL3 and OPL4. Problem spotted on 931 and 933 by Krzysztof Helt and confirmed on 924 and 925 (together all OPTi ISA-PnP chips) by me. Signed-off-by; Rene Herman <rene.herman@gmail.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Fix unfreed pnp driver in opti9xx ISA driverTakashi Iwai
- Added the missing pnp_unregister_card_driver() in the case ISA PnP isn't found, which caused an error at kobject_add with -EEXIST Jun 11 09:07:31 rain kernel: kobject_add failed for opti9xx with -EEXIST, don't try to register things with the same name in the same directory. Jun 11 09:07:31 rain kernel: [<c01c18fa>] kobject_shadow_add+0x12a/0x1c0 Jun 11 09:07:31 rain kernel: [<c01c1a81>] kobject_register+0x21/0x50 Jun 11 09:07:31 rain kernel: [<c01f09a2>] bus_add_driver+0x72/0x1b0 Jun 11 09:07:31 rain kernel: [<c01d3dff>] pnp_register_card_driver+0x4f/0xc0 Jun 11 09:07:31 rain kernel: [<c89bc00a>] alsa_card_opti9xx_init+0xa/0x25 [snd_opti92x_ad1848] Jun 11 09:07:31 rain kernel: [<c0136947>] sys_init_module+0x157/0x1610 Jun 11 09:07:31 rain kernel: [<c01029b4>] syscall_call+0x7/0xb - Fixed the probe behavior when no PnP is set up. Now it behaves like the former version. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] isa_bus device/driver namingRene Herman
isa_bus: delete snd_ prefix from the (sysfs visible) device/driver names. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
