path: root/sound/isa/sb/sb_mixer.c
2015-01-28ALSA: Include linux/io.h instead of asm/io.hTakashi Iwai
Nowadays it's recommended. Replace all in a shot. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-10-21ALSA: sb16: Use snd_ctl_enum_info()Takashi Iwai
... and reduce the open codes. Also add missing const to text arrays. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-05-14ALSA: sb_mixer: missing return statementDan Carpenter
The if condition here was supposed to return on error but the return statement is missing. The effect is that the ->mixername is set to "???" instead of "DT019X". Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-21ALSA: jazz16: Add support for Media Vision Jazz16 chipsetKrzysztof Helt
This is one of Sound Blaster Pro compatible chipsets which is supported by Linux OSS driver and was missing native supoort for ALSA. The Jazz16 audio codec is Crystal CS4216 which is capable of playback and recording up to 48 kHz stereo. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-14ALSA: sb_mixer: convert pointer tables to mixer control tablesKrzysztof Helt
Convert table of pointers to mixer controls into tables of the mixer controls. It saves about 20% of the snd-sb-common module size reported by lsmod. The als4000 uses part of sb16's control table. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-23ALSA: ALS4000, slight mixer improvementsAndreas Mohr
- add 8kHz / 20 kHz low-pass filter switch control - add ALS4000 Mono capture route control - add annotations to specs pages - improve ALS4000 PM saved regs selection (remove SB dummy register, add missing ones) - add some missing ALS4000 register defines - constify two variables Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: Kill snd_assert() in sound/isa/*Takashi Iwai
Kill snd_assert() in sound/isa/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-23ALSA: sb - Fix wrong assertionsTakashi Iwai
snd_assert() in save_mixer() and restore_mixer() in sb_mixer.c is just wrong. The debug code wasn't tested at all, obviously... Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-07-20[ALSA] Add support for Cyrix/NatSemi Geode CS5530 (VSA1)Takashi Iwai
Add support for Cyrix/NatSemi Geode SC5530 (VSA1). The driver is snd-cs5530. Signed-off-by Ash Willis <ashwillis@programmer.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] sound/isa/sb/sb_mixer.c double kfreeDave Jones
Modules: SB drivers snd_ctl_add() already does the free on error. Coverity bug #957 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Add PM support to SB-support codeTakashi Iwai
Modules: SB drivers,SB16/AWE driver Add PM support to SB-support code. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA SB8/SB16/SBAWETakashi Iwai
Remove xxx_t typedefs from the ISA SB8/SB16/SBAWE drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] ALS4000 updateAndreas Mohr
Modules: SB drivers,ALS4000 driver some update for the ALS4000 driver (tested with hardware in my PC): - use common control names according to ControlNames.txt - add some controls (Master Mono, 3D control) - optimize struct snd_card_als4000_t layout (performance/size) - save some bytes via unified error path - constify some read-only data - add ToDo list - move GPL license text to top - add comments Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Add missing KERN_* suffix to printkTakashi Iwai
Add missing KERN_* suffix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
