path: root/sound/mips/Kconfig
2008-07-14ALSA: ALSA driver for SGI O2 audio boardThomas Bogendoerfer
This patch adds a new ALSA driver for the audio device found inside most of the SGI O2 workstation. The hardware uses a SGI custom chip, which feeds a AD codec chip. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: ALSA driver for SGI HAL2 audio deviceThomas Bogendoerfer
This patch adds a new ALSA driver for the audio device found inside many older SGI workstation (Indy, Indigo2). The hardware uses a SGI custom chip, which feeds two codec chips, an IEC chip and a synth chip. Currently only one of the codecs is supported. This driver already has the same functionality as the HAL2 OSS driver and will replace it. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-27sound: Convert to menuconfigTakashi Iwai
Convert menu in sound Kconfig files to menuconfig and if. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove snd_card_generic_dev()Takashi Iwai
Remove the obsolete snd_card_generic_dev(). CONFIG_SND_GENERIC_DRIVER is also removed from Kconfig. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Add snd_card_set_generic_dev() callTakashi Iwai
ARM,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,MIPS MIPS AU1x00 driver,PPC,PPC PowerMac driver,SPARC,SPARC AMD7930 driver SPARC cs4231 driver,SPARC DBRI driver - Added snd_card_set_generic_dev() call. - Added SND_GENERIC_DRIVER to Kconfig. - Clean up the error path in probe if necessary. Signed-off-by: Takashi Iwai <tiwai@suse.de>
