path: root/sound/oss/Kconfig
2008-05-21msnd_* is ISA-onlyAl Viro
2008-01-22Fix file references in documentation and KconfigJohann Felix Soden
Fix typo in arch/powerpc/boot/flatdevtree_env.h. There is no Documentation/networking/ixgbe.txt. README.cycladesZ is now in Documentation/. wavelan.p.h is now in drivers/net/wireless/. HFS.txt is now Documentation/filesystems/hfs.txt. OSS-files are now in sound/oss/. Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31DDB5477: remove driver bits of supportYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17remove options depending on OSS_OBSOLETEAdrian Bunk
This patch contains the scheduled removal of options depending on OSS_OBSOLETE. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Introduce CONFIG_VIRT_TO_BUSStephen Rothwell
Make some offending drivers depend on it and set CONFIG_ARCH_NO_VIRT_TO_BUS for ppc64 so that we don't build those drivers. This gets PowerPC allmodconfig and allyesconfig much closer to building. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08schedule obsolete OSS drivers for removal, 4th roundAdrian Bunk
Schedule obsolete OSS drivers for removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08the scheduled removal of OBSOLETE_OSS optionsAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Remove dead kernel config option AEDSP16_MPU401.Robert P. J. Day
Remove the dead kernel config option AEDSP16_MPU401. Signed-off-by: Robert P. J. Day <mindspring.com> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] schedule obsolete OSS drivers for removal, 3rd roundAdrian Bunk
Schedule obsolete OSS drivers (with ALSA drivers that support the same hardware) for removal. A rationale of the patch is in http://lkml.org/lkml/2006/12/18/305 Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-By: Thomas Sailer <sailer@ife.ee.ethz.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] The scheduled removal of some OSS optionsAdrian Bunk
The scheduled removal of the OSS drivers depending on OSS_OBSOLETE_DRIVER. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (39 commits) Add missing maintainer countries in CREDITS Fix bytes <-> kilobytes typo in Kconfig for ramdisk fix a typo in Documentation/pi-futex.txt BUG_ON conversion for fs/xfs/ BUG_ON() conversion in fs/nfsd/ BUG_ON conversion for fs/reiserfs BUG_ON cleanups in arch/i386 BUG_ON cleanup in drivers/net/tokenring/ BUG_ON cleanup for drivers/md/ kerneldoc-typo in led-class.c debugfs: spelling fix rcutorture: Fix incorrect description of default for nreaders parameter parport: Remove space in function calls Michal Wronski: update contact info Spelling fix: "control" instead of "cotrol" reboot parameter in Documentation/kernel-parameters.txt Fix copy&waste bug in comment in scripts/kernel-doc remove duplicate "until" from kernel/workqueue.c ite_gpio fix tabbage fix file specification in comments ... Fixed trivial path conflicts due to removed files: arch/mips/dec/boot/decstation.c, drivers/char/ite_gpio.c
2006-10-03more misc typo fixesMatt LaPlante
2006-10-03[MIPS] Remove IT8172-based platforms, ITE 8172G and Globespan IVR support.Yoichi Yuasa
As per feature-removal-schedule.txt. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-01[PATCH] schedule obsolete OSS drivers for removal, 2nd roundAdrian Bunk
This patch schedules obsolete OSS drivers (with ALSA drivers that support the same hardware) for removal. A rationale of the patch is in http://lkml.org/lkml/2006/7/11/186 Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-08V4L/DVB (4371b): Fix V4L1 dependencies at drivers under sound/oss and sound/pciMauro Carvalho Chehab
TVMixer and FM801 Tea5757 are still using V4L1 API. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-29[PATCH] re-add CONFIG_SOUND_SSCAPEAdrian Bunk
Due to a regression in the correcponding ALSA driver (ALSA #2234), the OSS driver should stay until it's fixed. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: trivial fixes in Makefile kbuild: adding symbols in Kconfig and defconfig to TAGS kbuild: replace abort() with exit(1) kbuild: support for %.symtypes files kbuild: fix silentoldconfig recursion kbuild: add option for stripping modules while installing them kbuild: kill some false positives from modpost kbuild: export-symbol usage report generator kbuild: fix make -rR breakage kbuild: append -dirty for updated but uncommited changes kbuild: append git revision for all untagged commits kbuild: fix module.symvers parsing in modpost kbuild: ignore make's built-in rules & variables kbuild: bugfix with initramfs kbuild: modpost build fix kbuild: check license compatibility when building modules kbuild: export-type enhancement to modpost.c kbuild: add dependency on kernel.release to the package targets kbuild: `make kernelrelease' speedup kconfig: KCONFIG_OVERWRITECONFIG ...
2006-06-25[PATCH] au1xxx: oss sound support for au1200Domen Puncer
au1550 ac97 driver works fine on au1200 too. Comments at the top of file state this code is GPL, so lets mark it as GPL too. Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[MIPS] Correct HAL2 Kconfig descriptionKumba
The current HAL2 Kconfig description indicates it is only used on SGI Indy systems, however all members of the Indigo2 Family have this sound card as well. Plus a minor grammatical fix is included. Signed-off-by: Joshua Kinard <kumba@gentoo.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-09kconfig: remove leading whitespace in menu promptsRoman Zippel
This removes all the leading whitespace kconfig now warns about. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-04-28[PATCH] re-add the OSS SOUND_CS4232 optionAdrian Bunk
A regression in the ALSA driver compared to the OSS driver was reported as ALSA bug #1520, so let's keep the OSS driver for now. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-20[PATCH] make the OSS SOUND_VIA82CXXX option available againAdrian Bunk
There was a report of a regression in the ALSA driver for the same hardware. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-20[PATCH] update OBSOLETE_OSS_DRIVER schedule and dependenciesAdrian Bunk
Update the schedule for the removal of drivers depending on OBSOLETE_OSS_DRIVER as follows: - adjust OBSOLETE_OSS_DRIVER dependencie - from the release of 2.6.16 till the release of 2.6.17: approx. two months for users to report problems with the ALSA drivers for the same hardware - after the release of 2.6.17 (and before 2.6.18): remove the subset of drivers marked at OBSOLETE_OSS_DRIVER without known regressions in the ALSA drivers for the same hardware Additionally, correct some OBSOLETE_OSS_DRIVER dependencies. A rationale of the changes is in http://lkml.org/lkml/2006/1/28/135 Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] schedule obsolete OSS drivers for removalAdrian Bunk
This patch schedules obsolete OSS drivers (with ALSA drivers that support the same hardware) for removal. Scheduling the via82cxxx driver for removal was ACK'ed by Jeff Garzik. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (missing dependencies on PCI in sound/*)Al Viro
a bunch of PCI-only drivers didn't have the right dependency Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (ISA_DMA_API and sound/*)Al Viro
fixed kconfig dependencies on ISA_DMA_API for parts of sound/* that rely on it. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/dtor/input.git manuallyLinus Torvalds
Some manual fixups required due to clashes with the PF_FREEZE cleanups.
2005-06-25[PATCH] change the SOUND_PRIME handlingAdrian Bunk
SOUND_PRIME (for OSS) is a tristate. This doesn't make much sense if most users are checking for SOUND_PRIME!=0. This patch changes the semantics of SOUND_PRIME to being a limit for all OSS modules, IOW: SOUND_PRIME=m does now say that all OSS drivers can only be modular. As a side effect, since SOUND_PRIME already depends on SOUND, there's no longer a reason for drivers depending on SOUND_PRIME to additionally depend on SOUND. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-01Input: make sure that joystick support in CMPCI driver can only beDmitry Torokhov
selected if either gameport is built-in or _both_ gameport and cmpci are built as modules. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-05-28Input:Adrian Bunk
This patch adds dummy gameport_register_port, gameport_unregister_port and gameport_set_phys functions to gameport.h for the case when a driver can't use gameport. This fixes the compilation of some OSS drivers with GAMEPORT=n without the need to #if inside every single driver. This patch also removes the non-working and now obsolete SOUND_GAMEPORT. This patch is also an alternative solution for ALSA drivers with similar problems (but #if's inside the drivers might have the advantage of saving some more bytes of gameport is not available). The only user-visible change is that for GAMEPORT=m the affected OSS drivers are now allowed to be built statically (but they won't have gameport support). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-04-16[PATCH] let SOUND_AD1889 depend on PCIAdrian Bunk
Compiling SOUND_AD1889 with PCI=n results in the following compile error: sound/built-in.o(.text+0x24f0c): In function `ad1889_remove': : undefined reference to `pci_release_region' This patch adds the missing dependency on PCI. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
