path: root/sound/oss/pss.c
2011-08-08sound: pss - don't use the deprecated function check_regionWang Shaoyan
sound/oss/pss.c: In function 'configure_nonsound_components': sound/oss/pss.c:676: warning: 'check_region' is deprecated (declared at include/linux/ioport.h:201) Signed-off-by: Wang Shaoyan <wangshaoyan.pt@taobao.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-11sound/oss: Remove unnecessary casts of void ptrJesper Juhl
The [vk][cmz]alloc(_node) family of functions return void pointers which it's completely unnecessary/pointless to cast to other pointer types since that happens implicitly. This patch removes such casts from sound/oss/ Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-17sound/oss/pss: Fix test of unsigned in pss_reset_dsp() and pss_download_boot()Roel Kluin
limit and jiffies are unsigned so the test did not work. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-30trivial: Fix misspelling of firmwareNick Andrew
Fix misspelling of firmware. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-02-26sound/oss: fix sparse warnings: different signednessHannes Eder
Impact: Change signature of 'set_volume_stereo' and 'set_volume_mono'. Fix this sparse warnings: sound/oss/pss.c:545:42: warning: incorrect type in argument 2 (different signedness) sound/oss/pss.c:546:42: warning: incorrect type in argument 3 (different signedness) sound/oss/pss.c:554:59: warning: incorrect type in argument 2 (different signedness) sound/oss/pss.c:560:59: warning: incorrect type in argument 2 (different signedness) sound/oss/pss.c:566:59: warning: incorrect type in argument 2 (different signedness) Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-02-06sound/oss/pss: set_io_base() always returns success, mark it voidJeff Garzik
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
