path: root/sound/oss/pss.c
2015-01-04sound: oss: Deletion of unnecessary checks before the function call "vfree"Markus Elfring
The vfree() function performs also input parameter validation. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-08-05sound/oss/pss: Remove typedefs pss_mixerdata and pss_confdataHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure types. This patch gets rid of the typedefs for pss_mixerdata and pss_confdata. The following Coccinelle semantic patch is used to make the change. @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-06sound: Remove unnecessary semicolonPeter Senna Tschudin
A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r1@ statement S; position p,p1; @@ S@p1;@p @script:python r2@ p << r1.p; p1 << r1.p1; @@ if p[0].line != p1[0].line_end: cocci.include_match(False) @@ position r1.p; @@ -;@p // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-19ALSA: module_param: make bool parameters really boolRusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-08sound: pss - don't use the deprecated function check_regionWang Shaoyan
sound/oss/pss.c: In function 'configure_nonsound_components': sound/oss/pss.c:676: warning: 'check_region' is deprecated (declared at include/linux/ioport.h:201) Signed-off-by: Wang Shaoyan <wangshaoyan.pt@taobao.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-11-11sound/oss: Remove unnecessary casts of void ptrJesper Juhl
The [vk][cmz]alloc(_node) family of functions return void pointers which it's completely unnecessary/pointless to cast to other pointer types since that happens implicitly. This patch removes such casts from sound/oss/ Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-17sound/oss/pss: Fix test of unsigned in pss_reset_dsp() and pss_download_boot()Roel Kluin
limit and jiffies are unsigned so the test did not work. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-30trivial: Fix misspelling of firmwareNick Andrew
Fix misspelling of firmware. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-02-26sound/oss: fix sparse warnings: different signednessHannes Eder
Impact: Change signature of 'set_volume_stereo' and 'set_volume_mono'. Fix this sparse warnings: sound/oss/pss.c:545:42: warning: incorrect type in argument 2 (different signedness) sound/oss/pss.c:546:42: warning: incorrect type in argument 3 (different signedness) sound/oss/pss.c:554:59: warning: incorrect type in argument 2 (different signedness) sound/oss/pss.c:560:59: warning: incorrect type in argument 2 (different signedness) sound/oss/pss.c:566:59: warning: incorrect type in argument 2 (different signedness) Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-02-06sound/oss/pss: set_io_base() always returns success, mark it voidJeff Garzik
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
