path: root/sound/oss/sb_audio.c
2015-06-12sound: oss/sb_audio: use swap() in sb_audio_close()Fabian Frederick
Use kernel.h macro definition. Thanks to Julia Lawall for Coccinelle scripting support. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-18sound: oss/sb_audio: cap value in sb201_audio_set_speed()Dan Carpenter
We set "s" before we have capped "speed" so it could be the wrong value. This could lead to a divide by zero bug. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-08-20sound: oss/sb_audio: prevent divide by zero bugDan Carpenter
Speed comes from get_user() in audio_ioctl(). We use it to set the "s" variable before clamping it to valid values so it could lead to a divide by zero bug. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
