path: root/sound/oss
2006-09-14Merge branch 'linux-2.6'Paul Mackerras
2006-09-01[PATCH] schedule obsolete OSS drivers for removal, 2nd roundAdrian Bunk
This patch schedules obsolete OSS drivers (with ALSA drivers that support the same hardware) for removal. A rationale of the patch is in http://lkml.org/lkml/2006/7/11/186 Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-31Merge branch 'merge'Paul Mackerras
2006-08-08V4L/DVB (4371b): Fix V4L1 dependencies at drivers under sound/oss and sound/pciMauro Carvalho Chehab
TVMixer and FM801 Tea5757 are still using V4L1 API. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-31[POWERPC] sound: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. powerpc-specific sound driver changes. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-03[POWERPC] Add new interrupt mapping core and change platforms to use itBenjamin Herrenschmidt
This adds the new irq remapper core and removes the old one. Because there are some fundamental conflicts with the old code, like the value of NO_IRQ which I'm now setting to 0 (as per discussions with Linus), etc..., this commit also changes the relevant platform and driver code over to use the new remapper (so as not to cause difficulties later in bisecting). This patch removes the old pre-parsing of the open firmware interrupt tree along with all the bogus assumptions it made to try to renumber interrupts according to the platform. This is all to be handled by the new code now. For the pSeries XICS interrupt controller, a single remapper host is created for the whole machine regardless of how many interrupt presentation and source controllers are found, and it's set to match any device node that isn't a 8259. That works fine on pSeries and avoids having to deal with some of the complexities of split source controllers vs. presentation controllers in the pSeries device trees. The powerpc i8259 PIC driver now always requests the legacy interrupt range. It also has the feature of being able to match any device node (including NULL) if passed no device node as an input. That will help porting over platforms with broken device-trees like Pegasos who don't have a proper interrupt tree. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30typo fixes: aquire -> acquireAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: [PATCH] i386: export memory more than 4G through /proc/iomem [PATCH] 64bit Resource: finally enable 64bit resource sizes [PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed [PATCH] 64bit resource: change pnp core to use resource_size_t [PATCH] 64bit resource: change pci core and arch code to use resource_size_t [PATCH] 64bit resource: change resource core to use resource_size_t [PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource [PATCH] 64bit resource: fix up printks for resources in misc drivers [PATCH] 64bit resource: fix up printks for resources in arch and core code [PATCH] 64bit resource: fix up printks for resources in pcmcia drivers [PATCH] 64bit resource: fix up printks for resources in video drivers [PATCH] 64bit resource: fix up printks for resources in ide drivers [PATCH] 64bit resource: fix up printks for resources in mtd drivers [PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers [PATCH] 64bit resource: fix up printks for resources in networks drivers [PATCH] 64bit resource: fix up printks for resources in sound drivers [PATCH] 64bit resource: C99 changes for struct resource declarations Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that was changed by the 64-bit resources had been deleted in the meantime ;)
2006-06-29[PATCH] re-add CONFIG_SOUND_SSCAPEAdrian Bunk
Due to a regression in the correcponding ALSA driver (ALSA #2234), the OSS driver should stay until it's fixed. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] oss/via: make bitfield unsignedRandy Dunlap
Make a 1-bit field unsigned like all of the others near it. sound/oss/via82cxxx_audio.c:311:21: error: dubious one-bit signed bitfield Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] sound: fix cs4232 section mismatchRandy Dunlap
Fix section mismatch: adds __init to probe function, frees some init memory, not critical. WARNING: sound/oss/cs4232.o - Section mismatch: reference to .init.text: from .text after 'cs4232_pnp_probe' (at offset 0x152) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] update two drivers for poison.hRandy Dunlap
Update two drivers to use poison.h. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in sound driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: typo fixes Clean up 'inline is not at beginning' warnings for usb storage Storage class should be first i386: Trivial typo fixes ixj: make ixj_set_tone_off() static spelling fixes fix paniced->panicked typos Spelling fixes for Documentation/atomic_ops.txt move acknowledgment for Mark Adler to CREDITS remove the bouncing email address of David Campbell
2006-06-26[PATCH] devfs: Remove devfs support from the sound subsystemGreg Kroah-Hartman
2006-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: trivial fixes in Makefile kbuild: adding symbols in Kconfig and defconfig to TAGS kbuild: replace abort() with exit(1) kbuild: support for %.symtypes files kbuild: fix silentoldconfig recursion kbuild: add option for stripping modules while installing them kbuild: kill some false positives from modpost kbuild: export-symbol usage report generator kbuild: fix make -rR breakage kbuild: append -dirty for updated but uncommited changes kbuild: append git revision for all untagged commits kbuild: fix module.symvers parsing in modpost kbuild: ignore make's built-in rules & variables kbuild: bugfix with initramfs kbuild: modpost build fix kbuild: check license compatibility when building modules kbuild: export-type enhancement to modpost.c kbuild: add dependency on kernel.release to the package targets kbuild: `make kernelrelease' speedup kconfig: KCONFIG_OVERWRITECONFIG ...
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] au1xxx: oss sound support for au1200Domen Puncer
au1550 ac97 driver works fine on au1200 too. Comments at the top of file state this code is GPL, so lets mark it as GPL too. Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] au1550_ac97: spin_unlock in error pathDomen Puncer
Error paths didn't spin_unlock. Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] emu10k1: mark midi_spinlock as usedAlexey Dobriyan
Why is it marked unused when in fact it's used? Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] msnd section fixAndrew Morton
WARNING: sound/oss/msnd.o - Section mismatch: reference to .init.text:msnd_register from __ksymtab between '__ksymtab_msnd_register' (at offset 0x0) and '__ksymtab_msnd_unregister' This symbol is exported. It'll oops if the driver is nonmodular and the caller is modular. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] OSS: cs46xx cleanup and tiny bugfixJesper Juhl
Here's a patch for cs46xx that - (mostly) cleans up the cs46xx driver according to CodingStyle - removes a bunch of pointless casts - fixes a small, potential use of uninitialized variable, bug - reduces the size of the compiled code by 36 bytes - reduces the size of the source file by 1831 bytes I know I should probably have split this into bits, but since I only thought of that *after* doing all the edits, splitting it up would have been a royal pain. And since these are all pretty trivial changes I thought I'd just submit the one huge patch and hope people could live with it (if not, then just tell me and I'll split it). The bug fix that's in there may be hard to spot, so I'll point it out. It's the - int val, valsave, mapped, ret; + int val, valsave, ret; + int mapped = 0; bit. Without that change we may use `mapped' uninitialized if, in cs_ioctl, the first test of "if(state)" is false and the second "if(state)" test is true. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Au1550/1200: add missing PSC #define's, make OSS driver use the ↵Sergei Shtylyov
proper ones Add missing PSC #define's required for the drivers using PSC on DBAu1550 board (also fixing Au1550 PSC3 address) and all Au1200-based boards as well. Make the OSS driver use the correct PSC definitions fo each board. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[MIPS] Correct HAL2 Kconfig descriptionKumba
The current HAL2 Kconfig description indicates it is only used on SGI Indy systems, however all members of the Indigo2 Family have this sound card as well. Plus a minor grammatical fix is included. Signed-off-by: Joshua Kinard <kumba@gentoo.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-09kconfig: remove leading whitespace in menu promptsRoman Zippel
This removes all the leading whitespace kconfig now warns about. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-05-21[PATCH] ad1848 section fixAndrew Morton
WARNING: sound/oss/ad1848.o - Section mismatch: reference to .init.data:ad1848_isapnp_list from .text between 'ad1848_init_generic' (at offset 0x46f0) and 'kmalloc' WARNING: sound/oss/ad1848.o - Section mismatch: reference to .init.data:ad1848_isapnp_list from .text between 'ad1848_init_generic' (at offset 0x46f8) and 'kmalloc' WARNING: sound/oss/ad1848.o - Section mismatch: reference to .init.data:ad1848_isapnp_list from .text between 'ad1848_init_generic' (at offset 0x4818) and 'kmalloc' Also, sound/oss/ad1848.c: In function `ad1848_init': sound/oss/ad1848.c:2029: warning: cast to pointer from integer of different size sound/oss/ad1848.c: In function `ad1848_unload': sound/oss/ad1848.c:2178: warning: cast to pointer from integer of different size sound/oss/ad1848.c: In function `adintr': sound/oss/ad1848.c:2207: warning: cast from pointer to integer of different size Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] nm256_audio section fixAndrew Morton
WARNING: sound/oss/nm256_audio.o - Section mismatch: reference to .init.text:nm256_peek_for_sig from .text between 'nm256_install' (at offset 0x3ba4) and 'nm256_probe' WARNING: sound/oss/nm256_audio.o - Section mismatch: reference to .init.text:nm256_peek_for_sig from .text between 'nm256_install' (at offset 0x3bac) and 'nm256_probe' WARNING: sound/oss/nm256_audio.o - Section mismatch: reference to .init.text: from .text between 'nm256_install' (at offset 0x3dcc) and 'nm256_probe' WARNING: sound/oss/nm256_audio.o - Section mismatch: reference to .init.text: from .text between 'nm256_install' (at offset 0x3dd0) and 'nm256_probe' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-28[PATCH] re-add the OSS SOUND_CS4232 optionAdrian Bunk
A regression in the ALSA driver compared to the OSS driver was reported as ALSA bug #1520, so let's keep the OSS driver for now. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: [PARISC] MAINTAINERS [PARISC] Make ioremap default to _nocache [PARISC] Add new entries to the syscall table [PARISC] Further work for multiple page sizes [PARISC] Fix up hil_kbd.c mismerge [PARISC] defconfig updates [PARISC] Document that we tolerate "Relaxed Ordering" [PARISC] Misc. janitorial work [PARISC] EISA regions must be mapped NO_CACHE [PARISC] OSS ad1889: Match register names with ALSA driver
2006-04-21[PARISC] OSS ad1889: Match register names with ALSA driverStuart Brady
Signed-off-by: Stuart Brady <sdb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-04-21[PATCH] powerpc: fix oops in alsa powermac driverBenjamin Herrenschmidt
This fixes an oops in 2.6.16.X when loading the snd_powermac module. The name of the requested module changed during the 2.6.16 development cycle from i2c-keylargo to i2c-powermac. Signed-off-by: Guido Guenther <agx@sigxcpu.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-20[PATCH] make the OSS SOUND_VIA82CXXX option available againAdrian Bunk
There was a report of a regression in the ALSA driver for the same hardware. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-20[PATCH] update OBSOLETE_OSS_DRIVER schedule and dependenciesAdrian Bunk
Update the schedule for the removal of drivers depending on OBSOLETE_OSS_DRIVER as follows: - adjust OBSOLETE_OSS_DRIVER dependencie - from the release of 2.6.16 till the release of 2.6.17: approx. two months for users to report problems with the ALSA drivers for the same hardware - after the release of 2.6.17 (and before 2.6.18): remove the subset of drivers marked at OBSOLETE_OSS_DRIVER without known regressions in the ALSA drivers for the same hardware Additionally, correct some OBSOLETE_OSS_DRIVER dependencies. A rationale of the changes is in http://lkml.org/lkml/2006/1/28/135 Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Last DMA_xBIT_MASK cleanupsTobias Klauser
These are the last conversions of pci_set_dma_mask(), pci_set_consistent_dma_mask() and pci_dma_supported() to use DMA_xBIT_MASK constants from linux/dma-mapping.h Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-29Merge ../linux-2.6Paul Mackerras
2006-03-28[PATCH] sound: Remove unneeded kmalloc() return value castsJesper Juhl
Get rid of unnessesary casts of kmalloc() return value in sound/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] vfree does its own NULL check, no need to be explicit in oss/msnd.cJesper Juhl
vfree() does it's own NULL checking, no need for explicit check before calling it. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] no need to check vfree arg for null in oss/sequencerJesper Juhl
There's no need to check pointers for NULL before handing them to vfree(). Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] maestro3 vfree NULL check fixupJesper Juhl
vfree() checks for NULL, no need to do it explicitly. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Zach Brown <zab@zabbo.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] vfree NULL check fixup for sb_cardJesper Juhl
There's no need to check the vfree() argument for NULL. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] powerpc: Kill _machine and hard-coded platform numbersBenjamin Herrenschmidt
This removes statically assigned platform numbers and reworks the powerpc platform probe code to use a better mechanism. With this, board support files can simply declare a new machine type with a macro, and implement a probe() function that uses the flattened device-tree to detect if they apply for a given machine. We now have a machine_is() macro that replaces the comparisons of _machine with the various PLATFORM_* constants. This commit also changes various drivers to use the new macro instead of looking at _machine. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27[PATCH] PNP: adjust pnp_register_card_driver() signature: sb_cardBjorn Helgaas
Remove the assumption that pnp_register_card_driver() returns the number of devices claimed. And fix some __init/__devinit issues. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] pnp: cs4232: adjust pnp_register_driver signatureBjorn Helgaas
Remove the assumption that pnp_register_driver() returns the number of devices claimed. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] oss/sonicvibes.c defines its own hweight32Richard Knutsson
sound/oss/sonicvibes.c:421: error: static declaration of hweight32 follows non-static declaration include/asm-generic/bitops/hweight.h:6: error: previous declaration of hweight32 was here Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] cmpci: don't use generic_hweight32()Andrew Morton
It's about to go away. Cc: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Fix compilation for sound/oss/vwsnd.cEric Sesterhenn
Fix compilation for sound/oss/vwsnd.o, by moving li_destroy() above li_create() sound/oss/vwsnd.c:275: warning: conflicting types for ‘li_destroy’ sound/oss/vwsnd.c:275: error: static declaration of ‘li_destroy’ follows non-static declaration sound/oss/vwsnd.c:264: error: previous implicit declaration of ‘li_destroy’ was here Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
