path: root/sound/pci/ac97
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29ALSA: ac97: Add Toshiba P500 to ac97 jack sense blacklistDaniel Chen
BugLink: https://launchpad.net/bugs/481058 The OR has verified that both 'Headphone Jack Sense' and 'Line Jack Sense' need to be muted for sound to be audible, so just add the machine's SSID to the ac97 jack sense blacklist. Reported-by: Richard Gagne Tested-by: Richard Gagne Cc: <stable@kernel.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-26ALSA: ac97: Add IBM ThinkPad R40e to Headphone/Line Jack Sense blacklistDaniel T Chen
BugLink: https://launchpad.net/bugs/303789 This model needs both 'Headphone Jack Sense' and 'Line Jack Sense' muted for audible audio, so just add its SSID to the blacklist and don't enumerate the controls. Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-16Merge branch 'fixes' into develJaroslav Kysela
2010-01-10ALSA: ac97: add AC97 STMicroelectronics' codecsKrzysztof Helt
Add the STMicroelectronics ST7597 codec and an unknown codec from the same manufacturer found on the Creative SB 128 card (CT4810). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-10ALSA: ac97: Add Dell Dimension 2400 to Headphone/Line Jack Sense blacklistDaniel T Chen
This model needs both 'Headphone Jack Sense' and 'Line Jack Sense' muted for audible playback, so just add it to the ad1981 jack sense blacklist. Cc: stable@kernel.org Tested-by: Pete <x41215201@gmail.com> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-08Merge branch 'topic/hda' of ↵Jaroslav Kysela
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 into devel
2010-01-08ALSA: ac97_codec: merge WM9703 and WM9705 opsKrzysztof Helt
The WM9705 and WM9703 ops are the same actually so use the same code for both. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-12-15ALSA: ac97_codec - increase timeout for analog sections to 5 secondSteve Soule
I have a Soundblaster 16PCI. For many years, alsa has had a bug where not all of the card's controls are detected (many alsa versions, many kernel versions). In particular, Master Playback Volume is usually not detected, and so I get no sound or extremely faint sound. The problem has always been inconsistent: sometimes all of the controls are detected correctly, and sometimes a partial set is detected. It works correctly about 10% of the time. Finally, I got around to tracking down the problem. When the driver fails, it prints the kernel message "AC'97 0 analog subsections not ready". This message is generated from the function snd_ac97_mixer() in ac97_codec.c. The message indicates that the card failed to come back after reset within the time limit. The time limit is 120 milliseconds. I tried increasing the time limit to 1 second, and found that this made the driver work about 70% of the time. I tried increasing it to 5 seconds, and it now seems to work 100% of the time. I expect that this change would be completely harmless for existing cards that work, and would only introduce additional delay for cards that do not work. ALSA bug#4032. Signed-off-by: Steve Soule <sts11dbxr@gmail.com> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-11-05ALSA: rename "PC Speaker" and "PC Beep" controls to "Beep"Jaroslav Kysela
To avoid confusion in control names for the standard analog PC Beep generator using a small Internal PC Speaker, rename all related "PC Speaker" and "PC Beep" controls to "Beep" only. This name is more universal and can be also used on more platforms without confusion. Introduce also "Internal Speaker" in ControlNames.txt for systems with full-featured build-in internal speaker. Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-22Merge branch 'fix/misc' into for-linusTakashi Iwai
* fix/misc: ALSA: Kill truncate warning by shortening Sigmatel-specific AC97 control name ALSA: pcsp - fix printk format warning again
2009-05-22ALSA: Kill truncate warning by shortening Sigmatel-specific AC97 control nameAndreas Mohr
ALSA sound/core/control.c:232: Control name 'Sigmatel Surround Phase Inversion Playback Switch' truncated to 'Sigmatel Surround Phase Inversion Playback ' bootup message by omitting weird Sigmatel prefix in this case; also fix up the related ca0106 mixer control removal part by using identical naming there. Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-21[ALSA] ac97_codec: increase timeout for analog subsectionsJaroslav Kysela
On some hardware platforms, the AC97 codec requires more time to wake up. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2009-03-24Merge branch 'topic/intel8x0' into for-linusTakashi Iwai
2009-03-06ALSA: ac97 - Add patch entry for Conexant CX20468-31 chipTakashi Iwai
Added the patch entry for Conexant CX20468-31 chip (4358:5430). Reference: Novell bnc#471265 https://bugzilla.novell.com/show_bug.cgi?id=471265 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: Fix missing KERN_* prefix to printk in sound/pciTakashi Iwai
2009-01-29ALSA: AC97: Fix function name type in comment s/updat/update/Thadeu Lima de Souza Cascardo
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-29ALSA: AC97: Print AC97 flags in proc file to make debug it easierThadeu Lima de Souza Cascardo
While debugging some code paths in AC97 codec patches and its suspend and resume functions, getting to know the flags has proved useful to follow those code paths. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-25Merge branch 'topic/cs5535audio' into to-pushTakashi Iwai
2008-12-10ALSA: cs5535audio: stick AD1888 bitshift values into a header fileAndres Salomon
We'd like to use the High Pass Filter and V_REFOUT bitshift values elsewhere, so stick them into a ac97_codec.h. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-01ALSA: ac97 - Add WM9715 to AC97 IDsMark Brown
The WM9715 is software compatible with the WM9711 and WM9712. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-11-07Merge branch 'topic/fix/misc' into topic/miscTakashi Iwai
2008-10-30sound: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-By: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-20ALSA: Enable SPDIF output on ALC655Takashi Iwai
Some hardwares with ALC655 codec don't indicate the proper ext id bit for SPDIF output although it supports. Force to enable the bit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-13ALSA: ASoC: update email address for Liam GirdwoodLiam Girdwood
Update the contact information for Liam Girdwood in ASoC core and drivers as my old email address is no longer valid. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-09-04ALSA: ac97_patch make functions staticHarvey Harrison
Only used in ac97_codec by including ac97_patch.c directly, effectively static Found by sparse: sound/pci/ac97/ac97_patch.c:3551:5: warning: symbol 'patch_vt1617a' was not declared. Should it be static? sound/pci/ac97/ac97_patch.c:3767:5: warning: symbol 'patch_vt1618' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-29ALSA: ac97 - vt1618 7.1 Audio SupportJohn L. Utz III
1. Implement 7.1 Output for vt1618 codec. 2. Fix typos in comments from my previous 1617a patch. Signed-off-by: John L. Utz III <john.utz@dmx.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-13ALSA: Kill snd_assert() in sound/pci/*Takashi Iwai
Kill snd_assert() in sound/pci/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-06ALSA: ac97 - Enable mono-out on ALC203 codec as defaultTakashi Iwai
Use pin 37 for mono-out as default on ALC203. Reported-by: george pee <georgepee@gmail.com> Tested-by: george pee <georgepee@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-20ALSA: re-order AC97 codec ID table.Rene Herman
Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-27ALSA: make snd_ac97_add_vmaster() staticAdrian Bunk
This patch makes the needlessly global snd_ac97_add_vmaster() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-15ALSA: add TriTech 28023 AC97 codec ID and Wolfson 9701 name.Rene Herman
2008-07-10ALSA: ac97 - fix patch_ucb1400 for proper resumeMike Rapoport
Replace 'snd_ac97_write' with snd_ac97_write_cache' in pacth_ucb1400 to allow proper codec wakeup. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: Fix AC97 power downTakashi Iwai
Some laptops don't like PR3 powerdown. Do PR3 powerdown only for the real power-saving. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-13[ALSA] ac97 - Fix power_save option value as time-outTakashi Iwai
The power_save option was set as boot although it was meant to be a timeout value like the same option of snd-hda-intel originally. Now fixed to the same style. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-13[ALSA] ac97: add support for wm9711 master left inv switchJuergen Beisert
This patch adds support for Master Left Inv Switch on wm9711. At least required to drive the mono speaker on the PXA270 platfrom Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-30[ALSA] Make ak4531 local to ens1370 driverTakashi Iwai
The ak4531 module is used only by ens1370 driver (and unlikely that any other will use it ever). Let's make it local to ens1370. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-30[ALSA] Clean up sound/pci/ac97/MakefileTakashi Iwai
2008-05-19[ALSA] ac97 - Add virtual master control to VT1616/VT1617A codec.Daniel Jacobowitz
Enable VMASTER for VT1616 / VT1617A codec. Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-30[ALSA] ac97 - Fix ASUS A9T laptop outputTakashi Iwai
ASUS A9T laptop uses line-out pin as the real front-output while other devices use it as the surround. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-05[ALSA] ac97 - Add a workaround for broken quirk for VT1617A codecTakashi Iwai
On boards with VT1617A codec, the sound disappears suddenly. This looks like a problem with HPE-bit control that is supposed to be set in patch_vt1617a(). However, on such problematic hardwares, the bit is actually reset mysteriously. The patch adds a workaround for the wrong quirk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: ac97_pcm.c fix shadowed variable warningHarvey Harrison
err is always assigned before it is used, no need to declare another inside the if statement. sound/pci/ac97/ac97_pcm.c:577:7: warning: symbol 'err' shadows an earlier one sound/pci/ac97/ac97_pcm.c:572:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] intel8x0 - Add support of 8 channel soundTakashi Iwai
Added the support of 8 channel sound for codecs that are known to work. So far, only ALC850 is marked as a 8ch-support codec. This fix is a modified version of the patch on ALSA BTS#2097 by Martin Ellis: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=2097 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] pci - check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in the rest of PCI drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ac97_patch: compilation warning fixKrzysztof Helt
This patch kills these two compilation warnings if power management is disabled: sound/pci/ac97/ac97_patch.h:86: warning: 'snd_ac97_restore_status' declared 'static' but never defined sound/pci/ac97/ac97_patch.h:87: warning: 'snd_ac97_restore_iec958' declared 'static' but never defined Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] ac97: YMF743 missing controls support (2/2)Keita Maehara
These patches enable a few YMF743 controls (Tone/3D/IEC958) that won't be detected with the current version of ALSA. The second one contains following changes: - A chip-specific SPDIF support for YMF743 (It doesn't have AC97 standard SPDIF registers seen on YMF753). - The implementation for 'IEC958 Playback Source' and 'IEC958 Mute' are identical to the ones for YMF753. But there is no 'IEC958 Output Pin' for YMF743. Signed-off-by: Keita Maehara <maehara@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] ac97: YMF743 missing controls support (1/2)Keita Maehara
These patches enable some YMF743 controls (Tone/3D/IEC958) that won't be detected with the current version of ALSA. The first one contains only cosmetic changes to share a few YMF753-specific symbols with YMF743. Signed-off-by: Keita Maehara <maehara@debian.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Add default values for power-saving as Kconfig optionsTakashi Iwai
Added CONFIG_SND_AC97_POWER_SAVE_DEFAULT and CONFIG_SND_HDA_POWER_SAVE_DEFAULT Kconfig options as the default values for power-saving mode of AC97 and HD-audio drivers, respectively. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
