Formatting a PCM name is useful for module debug too.
Add snd_prefix when making function public.
[minor coding-style fixes by tiwai]
Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com>
Mute functionality was recently added to the DSP firmware
Add names corresponding to new HPI node types.
Shorten some names so that constructed names don't overflow the
maximum name length.
Work towards moving the function into alsa common header.
In the sound/ directory there are two files (flagged by 'make
versioncheck'); sound/pci/asihpi/asihpi.c and
sound/soc/codecs/wm8991.c that include linux/version.h although they
don't need it. This patch removes the unneeded includes.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
The convention for pci_driver.name entry in kernel drivers seem to be
the module name or equivalent ones. But, so far, almost all PCI sound
drivers use more verbose name like "ABC Xyz (12)", and these are fairly
confusing when appearing as a file name.
This patch converts the all pci_driver.name entries in sound/pci/* to
use KBUILD_MODNAME for more unified appearance.
Define and use pcm_debug_name if CONFIG_SND_DEBUG
Allow older non DMA capable cards to use MMAP by
emulating the DMA using read and write functions,
and getting rid of copy & silence callbacks that
were used only by older cards.
Use the card drained status reporting for playback,
but allow it to persist for a few timer cycles before
signalling XRUN, to allow card to recover by itself.
Debug print full substream ID.
Other minor debug print updates.
Clock source is neither capture nor playback,
so change 'Capture Clock' to 'Clock'.
Add spaces to control name string for consistency,
always 'PCM 0' , never 'PCM0'
Replace local VPRINTK1 with snd_printdd.
Create local snd_printddd instead of VPRINTK2 for most verbose debug.
In most cases let snd_printk supply default level for messages.
Make playback silence callback a no-op, card automatically outputs
silence when written data runs out.
Increasing update interval and thus minimum period avoids xrun on startup
or because of timer jitter.
Cards without settable local samplerate and without SRC
still must have a valid samplerate.
This fixed rate is determined by reading the current rate for the card.
asihpi.c don't link playback and capture streams, there is too much
offset between them.
Reported samples_played from card may be inaccurate, so don't use it.
Update control names to be closer to alsa standard practice.
Also fixed some accidentally lowercased strings.
[Removed adriver.h inclusion for external module builds by tiwai]
bytes_per_sec is unsigned, so if snd_pcm_format_width() return error we
would not see it.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Remove some deprecated items.
Change compander api to one function per parameter.
Add a version string define.
Initialize prev_ctl properly before reference:
sound/pci/asihpi/asihpi.c: In function ‘snd_card_asihpi_mixer_new’:
sound/pci/asihpi/asihpi.c:2568:30: warning: ‘prev_ctl.dst_node_index’ may be used uninitialized in this function
Added the support of AudioScience ASI boards.
The driver has been tested for years on alsa-driver external tree,
now finally got merged to the kernel.
